> Upload forum rules
Changes Made to TAG.EXE, Tags from text file & OptimFrog support
Synthetic Soul
post Aug 22 2004, 21:00
2006-02-08 11:53 :
2.0.45 released. As well as --tocue, --tocuen and --tocuea, I have now added the --paranoid switch which will cause warnings and non-critical errors to return a non-zero return code, so that this can be picked up in a script. Thanks to R Hannes Beinert for the suggestion and patch.
2005-12-08 13:24 :
2.0.45b9: Added code to fix memory leak. Report and code kindly provided by Steve Vibert.
2005-12-08 13:24 :
2.0.45b8: Added --tocue, --tocuen and --tocuea. libVorbis 1.1.2 & libOgg 1.1.3.
2005-04-21 22:00 BST:
If you downloaded Tag 2.0.43 before 19:30 BST you may want to download it again.
See this post for more info.
2005-04-21:
QUOTE (Compact Dick @ Feb 9 2005, 02:40 AM)
a small bug report for 2.0.42. View APE 3.98 and higher files' tags and the details field is incorrect, for example: "Details: 24 Hz, playtime 42274:53:30". The 24 Hz part is always constant.
Version 2.0.43 has been uploaded.
v3.98+ APE files are now detailed correctly. Also, the 10KB limit when using the -f switch has been removed.
Update: wapet has also been updated now, so that the 10KB limit no longer applies. wapet 0.5 available here.
2005-02-07:
I thought I may as well record on forum that I have updated Case's Tag with libFLAC 1.1.2. You can get it here.
It now uses libFLAC 1.1.2, libOgg 1.1.2 and libVorbis 1.1.0 - all the most recent releases.
I see from the FLAC changelog that there have been some changes relevant to VORBIS tagging, so I thought I may as well.
Original Post:
This topic explains the history of this amendment
EAC+MAC+TAG+PAR2
There is a little information, and all the downloads here:
http://synthetic-soul.co.uk/tag/
I hope someone else finds this useful as well.
wapet is also now available, with the additional -f switch.
This post has been edited by Synthetic Soul: Feb 8 2006, 12:59
I'm on a horse.
Synthetic Soul
post Aug 5 2008, 16:46
QUOTE (Paul Burger @ Aug 5 2008, 13:14) *
I tried to get this done with Tag but it does not seem to support directory references.
If this cannot be done in Tag, can you possibly recommend something else?
No, it doesn't look like it does.
I guess that you could just use ECHO commands in your config to append to a playlist, e.g.:
ECHO $cdartist$ - $album$ [$date$]\$track$ - $title$.mp3>>@OutRoot@\Music\MP3\Playlists\$cdartist$ - $album$.m3u
You may have to escape some characters though, otherwise ampersands (for example) will cause problems. Certainly a possibility though.
QUOTE (noorotic @ Aug 5 2008, 16:10) *
Synthetic Soul, I had not checked this thread in a long time. If it is needed, I have the C code for importing and exporting binary (images) into APEv2 tags. I am not sure I know the Tag code well enough to insert into it however. Also, it would create a feature for APE not supplied by Tag for other tag types.
I would like to see support for embedding images in Tag; however, as you say, it would be wrong to add it for APEv2 only. Also, I'm not sure that I would have the where-with-all (or inclination) to insert the code. Thanks for the thought though. I must admit that I have lost an interest in doing anything else with Tag.
I'm on a horse.
- Synthetic Soul   Changes Made to TAG.EXE   Aug 22 2004, 21:00
- - phwip   Thanks for this. Tag is for me an incredibly usef...   Aug 23 2004, 09:57
- - Synthetic Soul   Thanks for the feedback phwip. I will investigate...   Aug 23 2004, 12:05
- - phwip   I've tested this a little further with APEv2, ...   Aug 23 2004, 13:20
- - Synthetic Soul   I'm pretty sure I've resolved this now. T...   Aug 23 2004, 14:53
- - phwip   Excellent. Overcomes the problem for all the tag ...   Aug 23 2004, 16:35
- - Synthetic Soul   Good news. I'm hoping to get chance to test o...   Aug 23 2004, 17:06
- - Synthetic Soul   I thought I may as well record on forum that I hav...   Feb 7 2005, 14:35
|- - Compact Dick   Hi Synthetic Soul, a small bug report for 2.0.42....   Feb 9 2005, 02:40
- - Cutter   Hello! This program is really useful for crea...   Feb 8 2005, 21:01
- - Synthetic Soul   QUOTE (Cutter @ Feb 8 2005, 08:01 PM)This pro...   Feb 9 2005, 13:13
- - Skates   Any chance of adding support for the removal of sp...   Mar 8 2005, 03:13
- - Synthetic Soul   To remove an individual tag in Tag just use: TAG....   Mar 8 2005, 09:57
- - Synthetic Soul   QUOTE (Compact Dick @ Feb 9 2005, 02:40 AM)a ...   Apr 21 2005, 12:05
- - Synthetic Soul   QUOTE (Synthetic Soul @ Feb 9 2005, 01:13 PM)...   Apr 21 2005, 12:14
- - Buddy Casino   When trying to download 2.0.43 I get a 404...   Apr 21 2005, 12:50
- - Synthetic Soul   Sorry - should be there now.   Apr 21 2005, 13:04
- - Synthetic Soul   wapet has also been updated now, so that the 10KB ...   Apr 21 2005, 17:00
- - Synthetic Soul   If you downloaded Tag 2.0.43 before 19:30 BST you ...   Apr 21 2005, 22:08
|- - Supernaut   QUOTE (Synthetic Soul @ Apr 21 2005, 10:08 PM...   Apr 21 2005, 23:24
- - xmixahlx   was gcc used to compile TAG before?   Apr 22 2005, 02:08
- - Compact Dick   tag 2.0.43 reports the correct bitrate for APE fil...   Apr 22 2005, 02:43
- - Synthetic Soul   QUOTE (Supernaut @ Apr 21 2005, 11:24 PM)Righ...   Apr 22 2005, 08:56
- - Bryanhoop   Rename From Tag Then Tag From Filename CODE@ECHO O...   Jul 6 2005, 00:22
- - Synthetic Soul   Following a request from [proxima] I have made som...   Dec 8 2005, 14:26
|- - [proxima]   QUOTE (Synthetic Soul @ Dec 8 2005, 02:26 PM)...   Dec 8 2005, 14:49
- - [proxima]   @Synthetic Soul: the new switches you added return...   Dec 10 2005, 02:12
- - Synthetic Soul   I can't really return a non-zero value, as it ...   Dec 10 2005, 20:51
- - JJZolx   I'm sure TAG.EXE has a long and storied past, ...   Jan 13 2006, 21:49
- - Synthetic Soul   Much of the story I can't explain. I am a rel...   Jan 13 2006, 23:18
- - lossman   Is there any way to pipe the output to a text file...   Jan 20 2006, 10:18
- - Synthetic Soul   TAG.EXE --stdout *.* > report.txt You will nee...   Jan 20 2006, 10:28
- - hawkeye_p   use the --nfo switch! Edit: Ooops Synthetic_S...   Jan 20 2006, 10:35
- - lossman   Thanks guys, cant believe i missed that one! ...   Jan 20 2006, 11:02
- - audiophiler   ...i hope for an id3v2 writing support.... ... if ...   Mar 26 2006, 07:40
- - cyborg   Tag.exe doesn't seem to be able to read ID3v2 ...   Mar 26 2006, 11:30
- - Synthetic Soul   Sorry, no. I just don't have the knowledge of...   Mar 26 2006, 12:03
- - odyssey   Damn, I really hoped tag.exe could write ID3v2...   Apr 12 2006, 12:27
|- - rjamorim   QUOTE (odyssey @ Apr 12 2006, 08:27) Damn...   Mar 1 2007, 03:57
|- - Andavari   QUOTE (rjamorim @ Feb 28 2007, 21:57) QUO...   Mar 12 2007, 12:01
- - vasya_pupkin   I have a small feature request. Since foobar2000 s...   Oct 31 2006, 04:08
- - dv1989   Try loading all of the MP3s whose tags you want to...   Oct 31 2006, 10:45
|- - vasya_pupkin   QUOTE (dv1989 @ Oct 31 2006, 12:45) Try l...   Oct 31 2006, 11:58
|- - odyssey   QUOTE (dv1989 @ Oct 31 2006, 10:45) Try l...   Oct 31 2006, 16:45
|- - urak   QUOTE (odyssey @ Oct 31 2006, 15:45) HMM ...   Oct 31 2006, 17:03
- - Daijoubu   I've got those ID3v2 tag that iTune produce wi...   Mar 12 2007, 09:00
- - fairway   Hello Is there a reason that tag.exe does not cre...   Apr 24 2007, 18:41
- - Synthetic Soul   I'm not familiar with M3U playlists, or Tag...   May 2 2007, 07:42
|- - fairway   QUOTE (Synthetic Soul @ May 2 2007, 07:42...   May 2 2007, 07:48
- - Synthetic Soul   Just tried. I got the header (below), but not any...   May 2 2007, 08:22
- - Synthetic Soul   Thinking about it, I think this will be because Ta...   May 2 2007, 09:20
- - Synthetic Soul   OK, you can give Tag 2.0.52 a go. This version sh...   May 2 2007, 20:09
- - WaldoMonster   I use tag.exe to write the correct tags based on f...   May 5 2007, 22:59
- - Synthetic Soul   I can confirm that this is the case, but can't...   May 6 2007, 13:24
- - Synthetic Soul   Doh. Just seen the real culprit just before that ...   May 6 2007, 18:38
- - WaldoMonster   Thanks for the clear explanation. I understand th...   May 6 2007, 22:06
- - Synthetic Soul   Well, users should really be able to swap any char...   May 7 2007, 06:48
- - WaldoMonster   If I understood correctly than the ; will still be...   May 7 2007, 08:13
- - Synthetic Soul   You understand correctly. You can try 2.0.53b1. F...   May 7 2007, 09:34
- - WaldoMonster   Simply fixes are mostly the best Everything see...   May 7 2007, 10:20
- - WaldoMonster   I have done some test the last days with tag 2.0.5...   May 11 2007, 15:33
- - Synthetic Soul   It looks to me as though there is a way to get the...   May 11 2007, 17:08
- - WaldoMonster   I don't want to be a pain in the arse But s...   May 11 2007, 19:10
- - vasya_pupkin   I have a feature request. Tag currently doesn...   May 11 2007, 19:36
- - Synthetic Soul   QUOTE (WaldoMonster @ May 11 2007, 19:10)...   May 11 2007, 21:48
|- - vasya_pupkin   QUOTE (Synthetic Soul @ May 11 2007, 23:4...   May 12 2007, 00:59
|- - Synthetic Soul   QUOTE (vasya_pupkin @ May 12 2007, 00:59)...   May 12 2007, 08:23
|- - vasya_pupkin   QUOTE (Synthetic Soul @ May 12 2007, 10:2...   May 12 2007, 13:08
||- - Synthetic Soul   QUOTE (vasya_pupkin @ May 12 2007, 13:08)...   May 12 2007, 13:19
|- - vasya_pupkin   QUOTE (Synthetic Soul @ May 12 2007, 10:2...   May 12 2007, 15:03
- - Synthetic Soul   That appears to work. Shouldn't it still pad ...   May 12 2007, 16:01
- - vasya_pupkin   Thank you very much! It works!   May 12 2007, 17:57
- - odyssey   Ummm, is it possible to avoid printing the copyrig...   Oct 31 2007, 18:13
- - Synthetic Soul   I don't think that you can, but I don't th...   Oct 31 2007, 21:03
|- - odyssey   QUOTE (Synthetic Soul @ Oct 31 2007, 21:0...   Nov 26 2007, 16:04
- - A1S   Thanks for the tool. Will not prompt, how I can wr...   Nov 26 2007, 14:23
- - Synthetic Soul   QUOTE (odyssey @ Oct 31 2007, 17:13) Ummm...   Nov 26 2007, 17:38
|- - A1S   QUOTE (Synthetic Soul @ Nov 26 2007, 19:3...   Nov 26 2007, 18:52
- - Synthetic Soul   There is every possibility, but very little probab...   Nov 26 2007, 19:27
- - A1S   But can all the same it will be possible? We by m...   Nov 27 2007, 00:28
- - Synthetic Soul   It is obviously possible for an accomplished C(++)...   Nov 27 2007, 10:27
- - ntan01   I am having a technical problem with tag.exe. My ...   Dec 3 2007, 21:43
- - Synthetic Soul   --allow will check for an exact match, and that...   Dec 5 2007, 20:57
- - ntan01   Thanks. When I drag and drop, it works fine, but I...   Dec 6 2007, 17:02
- - Synthetic Soul   It may be to do with the path to Tag. Try changin...   Dec 6 2007, 17:13
- - odyssey   Is it impossible to remove all tags from a file, w...   May 25 2008, 23:14
- - Paul Burger   Hi Synthetic Soul, First of all, thanks for keepi...   Aug 5 2008, 13:14
- - noorotic   Synthetic Soul, I had not checked this thread in a...   Aug 5 2008, 16:10
- - Synthetic Soul   QUOTE (Paul Burger @ Aug 5 2008, 13:14) I...   Aug 5 2008, 16:46
- - Synthetic Soul   Off-topic posts regarding REACT moved to a new thr...   Aug 7 2008, 13:11
- - Lurkas   TAG doesn't write ID3v2.3 tags. The source is ...   Aug 7 2008, 13:47
|- - greynol   QUOTE (Lurkas @ Aug 7 2008, 05:47) TAG do...   Aug 7 2008, 15:49
- - Synthetic Soul   Would metamp3 (search this board) be of any use?   Aug 7 2008, 13:49
- - Lurkas   Thanks for the notification but I had a look at it...   Aug 7 2008, 14:26
- - Lurkas   That sounds interesting. Can someone please explai...   Aug 7 2008, 16:16
- - greynol   CODEtag %1 2> "%~1.tag" FOR /F ...   Aug 7 2008, 16:25
- - Lurkas   Thank you for your reply greynol. I assume that...   Aug 7 2008, 17:59
- - greynol   It's a subroutine to be used in a batch script...   Aug 7 2008, 18:19
- - Lurkas   Can I get this to work with wildcards, and what sy...   Aug 11 2008, 20:30
- - greynol   >Can I get this to work with wildcards, and wha...   Aug 11 2008, 20:45
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 24th May 2015 - 08:36
