LP to CD Conversion, Hardware, Software, Guides
westgroveg
post Jul 9 2004, 08:57
I am thinking of starting to take on the task of converting my, my friends, my family's LPs, 78s, 45s to digital, CD's, I would like to do this with the best possible quality & find an easy, standard way of doing it so my mind can be at peace the process was done as best as possible & I won't have to do it again. These are questions I have,
Question 1. What hardware would be best as far as quality/price? I was thinking of getting a Darla Recording Sound Card would this be a good choice? what about Phono (I have no idea about this)?
Question 2. I want to get the best possible quality so I will clean the Vinyl records, what's the best way to do this?
Question 3. What software should I use to record the audio? Cool Edit? Sound Forge? others?
Question 4. Should clicks and crackles be filtered? if so which is (are) the best tool(s)?
Question 5. Can anyone recommend a guide to read?
Thank you
This post has been edited by westgroveg: Jul 9 2004, 08:59
Gray_Wolf
post Nov 24 2004, 01:46
Group: Banned
Hi wink.gif ; I have recorded many LP's to my PC with COOL EDIT PRO v1.2a; and cleaned the recorded tracks with the option: Transform (menu) --> Noise Reduction --> Click/Pop Eliminator ----> Hiss + Lots of clicks (preset). I am very happy with the results smile.gif smile.gif .
wink.gif One trick is clean each channel lonely (L - R) of each recorded track; not the two channels at the same time... With this technique I get better results... cool.gif
In the other hand my hardware combination is very simple:
One PI-233Mhz, 64M Ram, running Windows 95, with old soundblaster 16 bit.
One old FISHER amplifier, with RIAA preamp included...
One direct drive TECHNICS turntable, very old too...
One old, but very good cartridge: EMPIRE 2000 E/III, with
elliptical diamond stylus [0.2 X 0.7 mil];
weight and tracking force applied: Only 1.2 gm.
I recorded many LP's with good results...
I have one sample HERE: Test.zip [Right click, and "Save target as..."]
VERY IMPORTANT!! : The test sample is a old heavy metal vynil from 1981, this LP have 23 years old!!!! sweat.gif , but is a good example to show the ability of COOL EDIT PRO in this old vynil....
The electric connections are simple:
OUTPUT CABLES (including ground (GND)) of the turntable ---> PHONO PREAMP input of my FISHER amplifier...
REC LINE OUT for Tape Deck (of my FISHER amp.) ---> LINE IN of my PC (old soundblaster 16 bit...)
THAT'S ALL !!!
P.D.: sorry my bad english...
This post has been edited by Gray_Wolf: Nov 25 2004, 07:05
2Bdecided
post Nov 24 2004, 14:13
ReplayGain developer
QUOTE (Gray_Wolf @ Nov 24 2004, 12:46 AM)
A lot of people on the old Cool Edit forums reported getting great results with CEP.
I could never understand it. As much as I love CEP for other things, I've found its automatic declicking (and, to a lesser extent, its denoising) to be fairly poor. It's probably because I mainly do 78s, but even for LPs I found it to be hard work. The Sonic Foundry NR-2 direct X plug-in is faster, better and easier to use. Cheaper too, though I use it from within CEP, so it's not either/or for me.
X-waves restoration is another amazing piece of software when it comes to removing crackle (rather than just clicks) but is too expensive.
However, the "fill single click" function in CEP is great. I've also found many uses for it beyond fixing record clicks.
cliveb
post Nov 25 2004, 12:04
WaveRepair developer
QUOTE (2Bdecided @ Nov 24 2004, 02:13 PM)
I feel that the CE2000 audio cleanup plug-in (which I presume is the same code as the declicker included in CEPro/Adobe Audition) works pretty well on LPs in reasonable shape. The "Medium Amplitude Audio" preset seems the best compromise on my LPs. I've always found that the "Auto Find All Levels" facility seems to install settings that are too aggressive and lead to artifacts. Overall I'd say the CE declicker is one of the better ones around, although as you say it does run very slowly. Jeffrey Klein's ClickFix plug-in for CE/Audition also works well and is much faster.
You're right about 78s being much harder to deal with. The level of surface noise on them is much higher and far more difficult to remove without artifacts. I've only done a few 78s, and they were in appalling condition. I found that the best results were from a combination of using the Younglove procedure for crackle, plus careful manual repair of big clicks.
When I evaluated it, the Sonic Foundry NR2 plug-in did some things better than the CE audio cleanup facilities, and some things worse. I got very excited on my first test, because it successfully removed some nasty clicks that had defeated every other declicker I'd tried, but after further testing I came to the conclusion that overall, CE's declicker and NR2 are about on a par, but with different strengths and weaknesses. As you say, the SF plug-in is much faster (about 10x, I'd say). But it's certainly far more expensive than the old CE plug-in. Granted, now that CE2000 is unavailable, NR2 is cheaper than Audition, but it can hardly be described as "affordable".
FWIW, I reckon the best affordable standalone auto declicker around at the moment is Wave Corrector (no relation to my own program Wave Repair, BTW).
auldyin
post Nov 25 2004, 17:01
I also have been using Wave Corrector and have to say that I'm very happy with results from vinyl and tape
I'm now going to upgrade my sound card, redo some stuff, sit back and listen and then get the precious vinyl stored away for posterity.
auldyin
This post has been edited by auldyin: Nov 25 2004, 17:05
- westgroveg   LP to CD Conversion   Jul 9 2004, 08:57
- - Jan S.   This guide is vrey good: http://www.delback.co.uk/...   Jul 9 2004, 11:21
- - magic75   If price is an issue... Q3: I like Waverepair, for...   Jul 9 2004, 11:39
- - Pio2001   QUOTE (westgroveg @ Jul 9 2004, 08:57 AM)Ques...   Jul 9 2004, 12:31
|- - DonP   QUOTE (Pio2001 @ Jul 9 2004, 06:31 AM)If you ...   Nov 23 2004, 20:24
|- - 2Bdecided   QUOTE (DonP @ Nov 23 2004, 07:24 PM)I have a ...   Nov 24 2004, 12:36
- - toomuch   "Question 4. Should clicks and crackles be fi...   Jul 9 2004, 15:37
- - dev0   Personally I always leave the recording untouched ...   Jul 9 2004, 15:46
- - DerEber   me too .... untouched!! in some rear cases...   Jul 9 2004, 16:50
- - JeanLuc   What really rocks are the Waves DX Plug-Ins X-Hum,...   Jul 9 2004, 17:27
- - gordo   I've embarked on the same thing and for what i...   Jul 9 2004, 17:59
|- - magic75   QUOTE (gordo @ Jul 9 2004, 08:59 AM)Prior to ...   Nov 23 2004, 13:07
|- - gordo   There may be an issue for a non-integer ratio samp...   Nov 23 2004, 19:59
- - ChangFest   I get decent results using my cheap Technics SL-B...   Nov 23 2004, 17:38
|- - rhadinocentrus   Hello Changfest, ? I pickup subsonics on your sam...   Nov 23 2004, 22:54
- - Gray_Wolf   Hi ; I have recorded many LP's to my PC with...   Nov 24 2004, 01:46
|- - 2Bdecided   QUOTE (Gray_Wolf @ Nov 24 2004, 12:46 AM)Hi...   Nov 24 2004, 14:13
|- - cliveb   QUOTE (2Bdecided @ Nov 24 2004, 02:13 PM)A lo...   Nov 25 2004, 12:04
|- - auldyin   I also have been using Wave Corrector and have to ...   Nov 25 2004, 17:01
- - Vietwoojagig   QUOTE (westgroveg @ Jul 9 2004, 08:57 AM)Ques...   Nov 24 2004, 14:40
- - ChangFest   QUOTE A lot of people on the old Cool Edit forums ...   Nov 24 2004, 18:30
- - dvautier   The most important consideration in LP to CD conve...   Mar 1 2005, 01:28
- - Joncat   Why would you recommend direct drive as opposed to...   Mar 19 2005, 17:01
- - Acid Orange Juice   QUOTE (Joncat @ Mar 19 2005, 10:01 AM)Why wou...   Mar 20 2005, 06:19
|- - Joncat   I still don't buy it. I do agree those tables ...   Mar 20 2005, 17:55
|- - optimali   I have an Akai DD c. late 80's with I think a ...   Jun 5 2005, 05:57
- - dvautier   This has been a real fun thread. I love the discu...   Mar 30 2005, 20:06
|- - _Prelude_   QUOTE (dvautier @ Mar 30 2005, 01:06 PM)This ...   Jun 11 2005, 20:39
- - snookerdoodle   I was looking for a stylus for my dad this weekend...   Jun 13 2005, 14:47
- - 2Bdecided   Isn't it amazing how much new equipment is ava...   Jun 14 2005, 11:14
- - optimali   For ppl who want to align their cartridges, here...   Jun 14 2005, 17:12
RSS Lo-Fi Version Time is now: 4th August 2015 - 17:43
