8 Pages V  « < 3 4 5 6 7 > »
foo_rmx beta, RM-X plugin for (remote) control freaks
darkain
post Feb 8 2006, 00:14
Post #101
QUOTE (optimuz @ Feb 7 2006, 01:38 PM)
But, I do have a request to make, the Play button, can you do it to a Play/Pause, so when you press play when a track is playing it will pause, so you dont need one play button and one pause button. I hope you understand what I mean. smile.gif
Check the list of selectable functions, there should be "Play", "Play/Pause", and "Pause" in the list. Just assign your remote button to "Play/Pause" and it should work.
-=- Darkain Dragoon -=-
optimuz
post Feb 8 2006, 01:00
Post #102
QUOTE (darkain @ Feb 8 2006, 12:14 AM)
For me, there is none, I've downloaded the latest RC3 from your webpage... I've only choosed to install Intelliremote, unmarked all other options, is it because of that? huh.gif
darkain
post Feb 8 2006, 02:26
Post #103
QUOTE (optimuz @ Feb 7 2006, 04:00 PM)
hmm, check again, it should be there. also, verify that you are running the currect version of RM-X while it is running. (it will say at the bottom of the configuration window)
darkain
post Feb 8 2006, 03:36
Post #104
QUOTE (darkain @ Feb 6 2006, 01:48 PM)
QUOTE (david_dl @ Feb 4 2006, 04:53 PM)
well, i fixed up a different bug in some code the console depends on, and ever since then, i havnt been able to reproduce the console task bar bug. lets hope its gone for good!!
still need to add the param stuff to volume tho, but this is gonna take a day or three, as i dont want to half-ass it. i want it to be standardized across all versions of RM-X. so, while you might be used to -db for volume, it will still be represented as 0-100% in RM-X.
ok, while messing around w/ some other stuff tonight, the console bug came back. oh noes! well, this time, it was consistant when it would or wouldnt appear. so, i spent a good hour or so trying to track down "why" it was occuring. the thing only happens with foobar, and nothing else. i almost gve up, then decided to browse around the MSDN a bit, and i gave something a try, and it seems to have worked now.
optimuz
post Feb 8 2006, 04:16
Post #105
But as I said, I've downloaded the latest installer from your website and installed it. So it is kinda strange that it says 1.0!
*edit*
Stupid me saw that I had downloaded 1.0 from your site and not 1.2 RC3 ohmy.gif
But now I have downloaded it and everything works just fine now, thank you again for an AWESOME plugin! smile.gif
This post has been edited by optimuz: Feb 8 2006, 04:22
darkain
post Feb 18 2006, 11:10
Post #106
RM-X Wiki now has the final build of RM-X v1.2. Much newnes and loving to be had!
optimuz
post Feb 20 2006, 03:21
Post #107
I've switched to 0.9 now, hope you will make rm-x work with 0.9 soon? smile.gif
This post has been edited by optimuz: Feb 24 2006, 01:41
darkain
post Mar 1 2006, 22:33
Post #108
QUOTE (optimuz @ Feb 19 2006, 06:21 PM)
optimuz
post Mar 2 2006, 00:55
Post #109
Yeah I know that you don't have access to the SDK sad.gif But I mean, as soon as you get it I hope you can fix a version for 0.9 too! smile.gif
leafo
post Mar 20 2006, 04:57
Post #110
SDK is out!
http://www.foobar2000.org/SDK.zip
Please port this over to 0.9 as soon as you can, this is probably one of my most favorite plugins!
I love using my gamepad as a remote, and even my nintendo ds.
4nt1
post Mar 20 2006, 05:30
Post #111
QUOTE (leafo @ Mar 20 2006, 01:57 PM)
SDK is out!
I second that...
darkain
post Mar 20 2006, 07:19
Post #112
yes, i know the SDK is out. the SDK also REQUIRES Visual Studio 2005... which means either no port, or i am forced to migrate my entire codebase over to Visual Studio 2005. so basically, in other words, dont expect anything from me anytime soon.
Duble0Syx
post Mar 26 2006, 02:33
Post #113
QUOTE (darkain @ Mar 19 2006, 10:19 PM)
Thats a real shame. Although after using foobar v0.9 I don't see much that makes continuing to use v0.8.3 painful in any way. 0.9 does seem a bit faster and has a few nice feature. Hope that sooner or later this gets ported. I won't switch until RMX, albumart & the trackinfo panel are working.
Seldaek
post Mar 26 2006, 05:16
Post #114
You can manage to control foobar without this plugin by using a combination of Girder & shortcuts in foobar (they don't have to be global if you target foobar's window in Girder).
Duble0Syx
post Mar 26 2006, 08:05
Post #115
QUOTE (Seldaek @ Mar 25 2006, 08:16 PM)
The advantage of RMX was that foobar could be minimized and the screensaver could be active. Changing tracks wouldn't effect any of this. If that option would work the same way then it would be feasible. smile.gif
This post has been edited by Duble0Syx: Mar 26 2006, 08:06
Seldaek
post Mar 26 2006, 13:31
Post #116
Well I just tried that with Girder. You have two options:
- Set the key to global in foobar and then it works even in the tray, it will then wake up the computer but you can restore the screensaver at the same time, not perfect.
- Send a command to foobar window with WParam & LParam set (you can capture them through Girder), then it doesn't wake up the computer but doesn't work if foobar is in the tray, so it's not perfect either. Although I may not be aware of all the possibilities of Girder which is quite complex so that may still be possible.
darkain
post Mar 31 2006, 00:29
Post #117
it seems to be a very common arguement for people to just use another app for their "remotes", and therefor "rm-x isnt needed". but if we kept up w/ this mentatlity, we would all still be using MIDI files played on our sound-blaster 16's, right? RM-X does a hell of a lot more then just give a few remotes access to a media player. it is an entirely dynamic programming API + scripting envoirnment with features only limited by ones imagination.
ok, enough about that rant, back to whats important. "RM-X Media Edition" is a very special and specific build of the RM-X Core. Media Edition relies on a single code base with multiple entry points to support multiple media players with a single binary (this is why there is only 1 installer for all of Media Edition for all players).
with foobar2000 now requiring components to be built in Visual Studio 8 and forcing them to be Unicode (instead of ANSI), this leaves me with only three possible options.
1) rebuild all of RM-X Core from the ground up in VS8 w/ unicode support and hope and pray that I can get this to work with the four other active media players (as well as the three or more other media players i'm adding support for on the side)
2) fork the RM-X Media Edition tree between foobar2000 vs all other media players.
3) abandon foobar2000 support completely.
problems:
1) The RM-X Core is used in more then just RM-X Media Edition. I have several projects that use it now. Forcing VS8 + Unicode would mean abandoning Windows 9x/ME support completely, and possibly hurting Windows NT4 support. While this may not bother the majority of users out there, one of the build of RM-X is designed to run on legacy hardware/software to have a very cheaply built home-automation system.
2) For a fork, the entire RM-X Core and vBase SDK would need to be forked, not just the media player interaction. This would mean I would have to actively manage twice as much code for every single update. Plus going this route, there would no longer be that guarantee that all of the RM-X plugins would work in both the normal build of RM-X as well as in the foobar2000 specific build.
3) not supporting foobar2000 would be the easist course of action for me, however, i dont want to lose support for this player after all of the work i have already put into it.
I think the biggest issue right now is that RM-X has grown too large and is out of hand now. There are currently (i think) 8 media player plugins/components in R&D, and about 30 RM-X plugins in the active development tree. This doesnt count the work being done on RM-X Stand-Alone, the IPC, and networking tools in development.
Both time and money are extremely limited for me right now, so its been a struggle for prioritizing what does or doesnt get worked on. If I do get around to getting an updated version of RM-X for foobar2000, I have no idea when I would even begin such a project. sad.gif
optimuz
post Apr 4 2006, 00:33
Post #118
This means I'm going back to 0.8.3 because this plugin is the most important out there! smile.gif
david_dl
post Apr 4 2006, 07:57
Post #119
VS8 can build ANSI apps fine. The only difference is it uses unicode *by default*, ie. you actually have to select ANSI if you want it. If it is too hard to use VS8, would it not be possible to build a 'proxy plugin' for foobar, using VS8, which loads the rmx functionality from another module? IMHO this would be a good way to go especially when multiple media players are involved, they could all share the same RMX core modules, new versions of the media player plugins would not be needed unless you wanted to add new features dependant on that particular media player's api.
Duble0Syx
post Apr 4 2006, 18:25
Post #120
QUOTE (david_dl @ Apr 3 2006, 10:57 PM)
I'm no programmer, but that sounds pretty good. I can't switch to 0.9 without my remote functioning properly. If it won't work, couldn't someone write a similar component just for foobar? I'd imagine the hardest part would be adding support for different remotes.
Seldaek
post Apr 5 2006, 03:52
Post #121
QUOTE (darkain @ Mar 31 2006, 01:29 AM)
Girder is kinda that too, but don't get me wrong, I'm not trying to say "don't use RM-X", I was just pointing that other solutions exist while they way for a .9 port of RM-X so no-one kills himself because of a missing plugin smile.gif
darkain
post Sep 20 2006, 21:54
Post #122
OKAY!! Time for some beta testing RM-X on Foobar 0.9.
For now, there is no installer for the beta, so you have to do a few steps to get it to work.
Step 1:
Download and install the old RM-X for foobar 0.8 from this URL: http://www.darkain.com/Download/index.php?download_id=15
Step 2:
Replace foobar2000\components\foo_RMX.dll with the one contained at the following URL: http://www.darkain.com/Download/foo_RMX.dll
Step 3:
marc2003
post Sep 20 2006, 22:57
Post #123
are there any pre-requisites for this to work? do i need to install any creative software for my rm1000? (shudders) tongue.gif
This post has been edited by marc2003: Sep 20 2006, 22:58
darkain
post Sep 20 2006, 23:10
Post #124
QUOTE (marc2003 @ Sep 20 2006, 13:57) *
RM-X does all device detection on start-up, so it doesn't matter what order things are installed in.
as for the RM-1000 specifically, if its an external reciever (such as the Extigy), you will need creative's software installed and use the Remote Center plugin. (make sure this plugin gets installed when installing RM-X). If its an internal reciever (such as SB-Live Platinum), then you can use the IntelliRemote plugin.
marc2003
post Sep 20 2006, 23:14
Post #125
QUOTE (darkain @ Sep 20 2006, 23:10) *
ah ok. i have an external box for my platinum ex. guess i need the creative software....... crying.gif laugh.gif
RSS Lo-Fi Version Time is now: 27th April 2015 - 20:22
