foo_dsp_vlevel, dynamic compressor which amplifies the q
wore
post May 29 2004, 17:13
I'm developing VLevel foobar2000 plugin.
VLevel is a dynamic compressor which amplifies the quiet parts of music
developing by Tom Felker. VLevel's site is http://vlevel.sourceforge.net/ .
Unfortunately, current version of foo_dsp_vlevel plugin will crash foobar2000
player when you inactive this plugin. I want to fix this stupid bug,
but I cat't find what is wrong. If you know the solution, please send me patch.
You can download and debug my foo_dsp_vlevel plugin from here:
http://wore.ma.cx/foobar2k/
Have fun,
wore (info@wore.ma.cx)
Canar
post Dec 23 2009, 14:03
For the record, for any component developers reading this, this is why you statically link all relevant libraries into your code. It prevents your users from suffering from this nonsense. When I get my build environment set up again I'll statically-link one for you all.
2. Assume good faith.
- wore   foo_dsp_vlevel   May 29 2004, 17:13
- - Case   It should help if you move "vl=0;" behin...   May 29 2004, 17:55
- - wore   QUOTE (Case @ May 29 2004, 08:55 AM)It should...   May 29 2004, 18:06
- - bleh   It's kind of odd... at first, the plugin crash...   May 30 2004, 03:32
- - wore   QUOTE (bleh @ May 29 2004, 06:32 PM)I think i...   May 30 2004, 05:21
- - bleh   Glad you got it fixed. Sorry I was completely wro...   May 30 2004, 17:58
- - wore   QUOTE (bleh @ May 30 2004, 08:58 AM)Glad you ...   May 30 2004, 22:30
- - spaceships   is the plugin coming anytime soon? sorry if that ...   Jun 6 2004, 07:47
- - chichiri   QUOTE (spaceships @ Jun 5 2004, 10:47 PM)is t...   Jun 6 2004, 13:59
- - spaceships   QUOTE (chichiri @ Jun 6 2004, 04:59 AM)QUOTE ...   Jun 6 2004, 18:03
- - tcfelker   You may have noticed problems with seeking before,...   Jun 7 2004, 15:32
- - ssamadhi97   release compile of foo_dsp_vlevel (as modified by ...   Jun 7 2004, 16:39
- - ssamadhi97   For giggles I just added a configuration dialog fo...   Jun 7 2004, 18:31
- - tcfelker   Hi ssamadhi97, wore, I just released the most rec...   Jun 11 2004, 03:55
- - Cyaneyes   Any progress on implementing the buffer length sli...   Jul 25 2004, 20:11
- - gribelu   i love this plugin... any updates? The only probl...   Sep 12 2004, 11:45
- - JohnMK   Bumpershoot. I use this plugin very frequently, e...   Mar 12 2006, 19:51
- - cyrano   Hi ! Now that foobaar2000 version 0.9 is out:...   Mar 22 2006, 14:10
- - G-Lite   Since I'm having fun fiddling with the foobar2...   Mar 23 2006, 14:32
- - G-Lite   I've updated this again. The plugin is now con...   Mar 24 2006, 17:47
|- - Melomane   thanks G-Lite, excellent initiative! work fine...   Mar 24 2006, 23:59
||- - odyssey   QUOTE (Melomane @ Mar 25 2006, 00:59) que...   Jul 21 2007, 17:07
|- - nawhead   QUOTE (Squeller @ Sep 6 2007, 00:07) I us...   Sep 6 2007, 06:11
|- - Squeller   QUOTE (nawhead @ Sep 6 2007, 07:11) That...   Sep 7 2007, 05:12
- - JohnMK   Thank you very much for all your work -- it's ...   Mar 31 2006, 00:18
|- - alloyD   QUOTE (JohnMK @ Mar 30 2006, 17:18) Thank...   Jan 24 2007, 16:59
|- - JohnMK   QUOTE (alloyD @ Jan 24 2007, 07:59) QUOTE...   Mar 25 2007, 07:52
- - Chronial   There is a way to change the volume of mp3 frames....   Mar 26 2007, 01:32
- - Squeller   meee2! But seriously I see there's current...   Sep 6 2007, 05:07
- - elenhil   Yep. If only dsp like this could recognize the sil...   Sep 6 2007, 22:48
|- - odyssey   QUOTE (elenhil @ Sep 6 2007, 23:48) Yep. ...   Sep 6 2007, 23:25
|- - nawhead   QUOTE (odyssey @ Sep 6 2007, 18:25) QUOTE...   Sep 7 2007, 07:51
- - elenhil   ...And the problem is there is often 'silence...   Sep 7 2007, 15:25
- - asral   lower the max. multiplier value a little bit. Th...   Sep 7 2007, 20:28
- - elenhil   That is not a true solution, isn't it?   Sep 7 2007, 20:32
|- - asral   QUOTE (elenhil @ Sep 7 2007, 22:32) That ...   Sep 8 2007, 21:51
|- - Squeller   QUOTE (asral @ Sep 8 2007, 22:51) Also th...   Sep 9 2007, 16:11
|- - elenhil   QUOTE (asral @ Sep 9 2007, 00:51) Also th...   Sep 10 2007, 18:27
|- - asral   [/quote] I can abide amplified "mid-silence...   Sep 10 2007, 20:36
- - blubbo   Uhm, I'd guess that this plugin is supposed to...   Sep 7 2007, 23:58
|- - elenhil   QUOTE (blubbo @ Sep 8 2007, 02:58) Simply...   Sep 8 2007, 19:38
- - Squeller   BTW you've probably seen it in another section...   Sep 8 2007, 13:21
- - asral   Unless someone designs a program that can discrimi...   Sep 9 2007, 20:56
- - Wiesl   Hello! I updated foo_dsp_vlevel to version 20...   Dec 27 2007, 08:03
|- - Wiesl   Hello! I updated foo_dsp_vlevel to version 20...   Mar 2 2008, 21:32
- - Squeller   Hey thanks, it works, but I didn't have any pr...   Dec 28 2007, 12:38
|- - Wiesl   QUOTE (Squeller @ Dec 28 2007, 13:38) Hey...   Dec 28 2007, 17:25
- - Squeller   Yes, worked, any fb2k 0.9 till latest beta and foo...   Dec 29 2007, 12:38
- - geoslake   hi thanks for this Is there a possibility to get ...   Mar 3 2008, 17:51
- - Squeller   It's about how it's compiled, static libra...   Mar 4 2008, 13:47
|- - Wiesl   QUOTE (Squeller @ Mar 4 2008, 13:47) It...   Mar 4 2008, 13:52
|- - Squeller   QUOTE (Wiesl @ Mar 4 2008, 14:52) Static ...   Mar 4 2008, 14:37
|- - Wiesl   QUOTE (Squeller @ Mar 4 2008, 14:37) QUOT...   Mar 4 2008, 15:05
- - geoslake   Ok, thanks I'll try to find another plugin the...   Mar 4 2008, 15:47
|- - Wiesl   QUOTE (geoslake @ Mar 4 2008, 15:47) Ok, ...   Mar 4 2008, 15:59
- - Squeller   fb2k is close to be portable. I'd say the only...   Mar 4 2008, 17:45
|- - Wiesl   QUOTE (Squeller @ Mar 4 2008, 17:45) fb2k...   Mar 5 2008, 06:54
- - acutum_intellectum   Can someone please tell me how to operate this plu...   Apr 18 2008, 13:34
|- - zygzak   I have a crash: playback_process entry=>dsp/run...   May 20 2008, 00:23
- - Squeller   Acutum, all description and technical detail is he...   Apr 18 2008, 17:42
- - Tapsa   Wiesls links are not working ;<   May 20 2008, 13:56
|- - JohnMK   QUOTE (Tapsa @ May 20 2008, 04:56) Wiesls...   Aug 9 2008, 03:20
- - Canar   The version from 2006 is compiled with an old vers...   Sep 10 2008, 16:06
- - Canar   I've recompiled G-Lite's source code for f...   Sep 13 2008, 03:12
- - 2E7AH   no problems with 06 version, but here: CODEIllega...   Sep 13 2008, 03:30
- - Canar   Reproduced... Now to figure out why... But first, ...   Sep 13 2008, 07:03
- - Melomane   link to vlevel 20080302.0 working here on vista h...   Sep 13 2008, 15:37
|- - FunkyBrewster   QUOTE (Melomane @ Sep 13 2008, 09:37) lin...   Aug 1 2009, 06:12
- - 2E7AH   i was searching for the last 2 versions, so thank ...   Sep 13 2008, 16:56
- - Canar   I have a build that is fixed, but really, use Wies...   Sep 13 2008, 22:35
|- - Wiesl   QUOTE (Canar @ Sep 13 2008, 22:35) I have...   Sep 14 2008, 10:40
- - Canar   Thank you Wiesl.   Sep 14 2008, 15:48
- - geoslake   i have latest compiled version you proposed (march...   Sep 24 2008, 06:16
- - elenhil   Would it be possible to extend the buffer length s...   Oct 1 2008, 09:58
- - richms   Is there a working version of this? Ones I have t...   Sep 30 2009, 01:06
- - igndenok   maybe you need MSV C++ SP1 Redistributable !? ...   Nov 13 2009, 11:56
- - alter4   It doesn't work with foobar2000 1.0 beta4 (OS ...   Dec 17 2009, 14:37
- - lvqcl   alter4, you can find the solution on the previous ...   Dec 17 2009, 16:53
- - geoslake   QUOTE (lvqcl @ Dec 17 2009, 09:53) alter4...   Dec 22 2009, 15:33
- - Canar   Works fine here on WinXP. You're probably just...   Dec 22 2009, 15:44
- - geoslake   Thanks for answering. QUOTE (Canar @ Dec 22 ...   Dec 23 2009, 08:19
- - Yirkha   Are you sure you have C:\Windows\WinSxS...   Dec 23 2009, 13:40
- - Canar   For the record, for any component developers readi...   Dec 23 2009, 14:03
- - geoslake   Don't have the exact folder name you mention, ...   Dec 23 2009, 18:41
|- - Yirkha   Well you can also put the relevant DLLs to the foo...   Dec 24 2009, 00:42
- - geoslake   Tried that as well, no luck. About that manifest, ...   Dec 24 2009, 08:10
- - Yirkha   Yeah. You can install e.g. Google Earth and see ho...   Dec 24 2009, 12:59
- - Zao   The proper way to privately deploy the runtime is ...   Dec 24 2009, 22:25
- - musicmusic   Try installing the VC2005 SP1 run-time libraries: ...   Dec 24 2009, 23:42
- - geoslake   I reinstalled windows yesterday (as my usual month...   Dec 28 2009, 13:42
- - Zao   You should not cancel an installation of a VC++ CR...   Dec 28 2009, 15:43
|- - geoslake   I know but my windows cd always include latest ver...   Dec 28 2009, 17:01
- - lvqcl   QUOTE I know but my windows cd always include late...   Dec 28 2009, 18:14
- - geoslake   Wlee, I thougt it worked, but actually, after havi...   Dec 30 2009, 09:35
- - mudlord   Static compile since people complained enough. I...   Jan 1 2010, 23:08
|- - geoslake   Thanks Mudlord (The Mudlord, from the emu scene ?)...   Jan 1 2010, 23:38
- - mudlord   Weird...All I did was a plain compile. I remember ...   Jan 1 2010, 23:45
- - Canar   http://www.wiesinger.com/opensource/foobar...-2008...   Jan 2 2010, 04:34
- - mudlord   Thanks Canar, those sources fixed the problem.   Jan 2 2010, 05:19
- - Canar   Thank you for your efforts, mudlord.   Jan 2 2010, 05:52
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 6th May 2015 - 11:20
