foo_dsp_vlevel, dynamic compressor which amplifies the q
wore
post May 29 2004, 17:13
I'm developing VLevel foobar2000 plugin.
VLevel is a dynamic compressor which amplifies the quiet parts of music
developing by Tom Felker. VLevel's site is http://vlevel.sourceforge.net/ .
Unfortunately, current version of foo_dsp_vlevel plugin will crash foobar2000
player when you inactive this plugin. I want to fix this stupid bug,
but I cat't find what is wrong. If you know the solution, please send me patch.
You can download and debug my foo_dsp_vlevel plugin from here:
http://wore.ma.cx/foobar2k/
Have fun,
wore (info@wore.ma.cx)
elenhil
post Sep 6 2007, 22:48
Yep. If only dsp like this could recognize the silence at the beginning and at the end of tracks and do not amplify the volume there...
- wore   foo_dsp_vlevel   May 29 2004, 17:13
- - Case   It should help if you move "vl=0;" behin...   May 29 2004, 17:55
- - wore   QUOTE (Case @ May 29 2004, 08:55 AM)It should...   May 29 2004, 18:06
- - bleh   It's kind of odd... at first, the plugin crash...   May 30 2004, 03:32
- - wore   QUOTE (bleh @ May 29 2004, 06:32 PM)I think i...   May 30 2004, 05:21
- - bleh   Glad you got it fixed. Sorry I was completely wro...   May 30 2004, 17:58
- - wore   QUOTE (bleh @ May 30 2004, 08:58 AM)Glad you ...   May 30 2004, 22:30
- - spaceships   is the plugin coming anytime soon? sorry if that ...   Jun 6 2004, 07:47
- - chichiri   QUOTE (spaceships @ Jun 5 2004, 10:47 PM)is t...   Jun 6 2004, 13:59
- - spaceships   QUOTE (chichiri @ Jun 6 2004, 04:59 AM)QUOTE ...   Jun 6 2004, 18:03
- - tcfelker   You may have noticed problems with seeking before,...   Jun 7 2004, 15:32
- - ssamadhi97   release compile of foo_dsp_vlevel (as modified by ...   Jun 7 2004, 16:39
- - ssamadhi97   For giggles I just added a configuration dialog fo...   Jun 7 2004, 18:31
- - tcfelker   Hi ssamadhi97, wore, I just released the most rec...   Jun 11 2004, 03:55
- - Cyaneyes   Any progress on implementing the buffer length sli...   Jul 25 2004, 20:11
- - gribelu   i love this plugin... any updates? The only probl...   Sep 12 2004, 11:45
- - JohnMK   Bumpershoot. I use this plugin very frequently, e...   Mar 12 2006, 19:51
- - cyrano   Hi ! Now that foobaar2000 version 0.9 is out:...   Mar 22 2006, 14:10
- - G-Lite   Since I'm having fun fiddling with the foobar2...   Mar 23 2006, 14:32
- - G-Lite   I've updated this again. The plugin is now con...   Mar 24 2006, 17:47
|- - Melomane   thanks G-Lite, excellent initiative! work fine...   Mar 24 2006, 23:59
||- - odyssey   QUOTE (Melomane @ Mar 25 2006, 00:59) que...   Jul 21 2007, 17:07
|- - nawhead   QUOTE (Squeller @ Sep 6 2007, 00:07) I us...   Sep 6 2007, 06:11
|- - Squeller   QUOTE (nawhead @ Sep 6 2007, 07:11) That...   Sep 7 2007, 05:12
- - JohnMK   Thank you very much for all your work -- it's ...   Mar 31 2006, 00:18
|- - alloyD   QUOTE (JohnMK @ Mar 30 2006, 17:18) Thank...   Jan 24 2007, 16:59
|- - JohnMK   QUOTE (alloyD @ Jan 24 2007, 07:59) QUOTE...   Mar 25 2007, 07:52
- - Chronial   There is a way to change the volume of mp3 frames....   Mar 26 2007, 01:32
- - Squeller   meee2! But seriously I see there's current...   Sep 6 2007, 05:07
- - elenhil   Yep. If only dsp like this could recognize the sil...   Sep 6 2007, 22:48
|- - odyssey   QUOTE (elenhil @ Sep 6 2007, 23:48) Yep. ...   Sep 6 2007, 23:25
|- - nawhead   QUOTE (odyssey @ Sep 6 2007, 18:25) QUOTE...   Sep 7 2007, 07:51
- - elenhil   ...And the problem is there is often 'silence...   Sep 7 2007, 15:25
- - asral   lower the max. multiplier value a little bit. Th...   Sep 7 2007, 20:28
- - elenhil   That is not a true solution, isn't it?   Sep 7 2007, 20:32
|- - asral   QUOTE (elenhil @ Sep 7 2007, 22:32) That ...   Sep 8 2007, 21:51
|- - Squeller   QUOTE (asral @ Sep 8 2007, 22:51) Also th...   Sep 9 2007, 16:11
|- - elenhil   QUOTE (asral @ Sep 9 2007, 00:51) Also th...   Sep 10 2007, 18:27
|- - asral   [/quote] I can abide amplified "mid-silence...   Sep 10 2007, 20:36
- - blubbo   Uhm, I'd guess that this plugin is supposed to...   Sep 7 2007, 23:58
|- - elenhil   QUOTE (blubbo @ Sep 8 2007, 02:58) Simply...   Sep 8 2007, 19:38
- - Squeller   BTW you've probably seen it in another section...   Sep 8 2007, 13:21
- - asral   Unless someone designs a program that can discrimi...   Sep 9 2007, 20:56
- - Wiesl   Hello! I updated foo_dsp_vlevel to version 20...   Dec 27 2007, 08:03
|- - Wiesl   Hello! I updated foo_dsp_vlevel to version 20...   Mar 2 2008, 21:32
- - Squeller   Hey thanks, it works, but I didn't have any pr...   Dec 28 2007, 12:38
|- - Wiesl   QUOTE (Squeller @ Dec 28 2007, 13:38) Hey...   Dec 28 2007, 17:25
- - Squeller   Yes, worked, any fb2k 0.9 till latest beta and foo...   Dec 29 2007, 12:38
- - geoslake   hi thanks for this Is there a possibility to get ...   Mar 3 2008, 17:51
- - Squeller   It's about how it's compiled, static libra...   Mar 4 2008, 13:47
|- - Wiesl   QUOTE (Squeller @ Mar 4 2008, 13:47) It...   Mar 4 2008, 13:52
|- - Squeller   QUOTE (Wiesl @ Mar 4 2008, 14:52) Static ...   Mar 4 2008, 14:37
|- - Wiesl   QUOTE (Squeller @ Mar 4 2008, 14:37) QUOT...   Mar 4 2008, 15:05
- - geoslake   Ok, thanks I'll try to find another plugin the...   Mar 4 2008, 15:47
|- - Wiesl   QUOTE (geoslake @ Mar 4 2008, 15:47) Ok, ...   Mar 4 2008, 15:59
- - Squeller   fb2k is close to be portable. I'd say the only...   Mar 4 2008, 17:45
|- - Wiesl   QUOTE (Squeller @ Mar 4 2008, 17:45) fb2k...   Mar 5 2008, 06:54
- - acutum_intellectum   Can someone please tell me how to operate this plu...   Apr 18 2008, 13:34
|- - zygzak   I have a crash: playback_process entry=>dsp/run...   May 20 2008, 00:23
- - Squeller   Acutum, all description and technical detail is he...   Apr 18 2008, 17:42
- - Tapsa   Wiesls links are not working ;<   May 20 2008, 13:56
|- - JohnMK   QUOTE (Tapsa @ May 20 2008, 04:56) Wiesls...   Aug 9 2008, 03:20
- - Canar   The version from 2006 is compiled with an old vers...   Sep 10 2008, 16:06
- - Canar   I've recompiled G-Lite's source code for f...   Sep 13 2008, 03:12
- - 2E7AH   no problems with 06 version, but here: CODEIllega...   Sep 13 2008, 03:30
- - Canar   Reproduced... Now to figure out why... But first, ...   Sep 13 2008, 07:03
- - Melomane   link to vlevel 20080302.0 working here on vista h...   Sep 13 2008, 15:37
|- - FunkyBrewster   QUOTE (Melomane @ Sep 13 2008, 09:37) lin...   Aug 1 2009, 06:12
- - 2E7AH   i was searching for the last 2 versions, so thank ...   Sep 13 2008, 16:56
- - Canar   I have a build that is fixed, but really, use Wies...   Sep 13 2008, 22:35
|- - Wiesl   QUOTE (Canar @ Sep 13 2008, 22:35) I have...   Sep 14 2008, 10:40
- - Canar   Thank you Wiesl.   Sep 14 2008, 15:48
- - geoslake   i have latest compiled version you proposed (march...   Sep 24 2008, 06:16
- - elenhil   Would it be possible to extend the buffer length s...   Oct 1 2008, 09:58
- - richms   Is there a working version of this? Ones I have t...   Sep 30 2009, 01:06
- - igndenok   maybe you need MSV C++ SP1 Redistributable !? ...   Nov 13 2009, 11:56
- - alter4   It doesn't work with foobar2000 1.0 beta4 (OS ...   Dec 17 2009, 14:37
- - lvqcl   alter4, you can find the solution on the previous ...   Dec 17 2009, 16:53
- - geoslake   QUOTE (lvqcl @ Dec 17 2009, 09:53) alter4...   Dec 22 2009, 15:33
- - Canar   Works fine here on WinXP. You're probably just...   Dec 22 2009, 15:44
- - geoslake   Thanks for answering. QUOTE (Canar @ Dec 22 ...   Dec 23 2009, 08:19
- - Yirkha   Are you sure you have C:\Windows\WinSxS...   Dec 23 2009, 13:40
- - Canar   For the record, for any component developers readi...   Dec 23 2009, 14:03
- - geoslake   Don't have the exact folder name you mention, ...   Dec 23 2009, 18:41
|- - Yirkha   Well you can also put the relevant DLLs to the foo...   Dec 24 2009, 00:42
- - geoslake   Tried that as well, no luck. About that manifest, ...   Dec 24 2009, 08:10
- - Yirkha   Yeah. You can install e.g. Google Earth and see ho...   Dec 24 2009, 12:59
- - Zao   The proper way to privately deploy the runtime is ...   Dec 24 2009, 22:25
- - musicmusic   Try installing the VC2005 SP1 run-time libraries: ...   Dec 24 2009, 23:42
- - geoslake   I reinstalled windows yesterday (as my usual month...   Dec 28 2009, 13:42
- - Zao   You should not cancel an installation of a VC++ CR...   Dec 28 2009, 15:43
|- - geoslake   I know but my windows cd always include latest ver...   Dec 28 2009, 17:01
- - lvqcl   QUOTE I know but my windows cd always include late...   Dec 28 2009, 18:14
- - geoslake   Wlee, I thougt it worked, but actually, after havi...   Dec 30 2009, 09:35
- - mudlord   Static compile since people complained enough. I...   Jan 1 2010, 23:08
|- - geoslake   Thanks Mudlord (The Mudlord, from the emu scene ?)...   Jan 1 2010, 23:38
- - mudlord   Weird...All I did was a plain compile. I remember ...   Jan 1 2010, 23:45
- - Canar   http://www.wiesinger.com/opensource/foobar...-2008...   Jan 2 2010, 04:34
- - mudlord   Thanks Canar, those sources fixed the problem.   Jan 2 2010, 05:19
- - Canar   Thank you for your efforts, mudlord.   Jan 2 2010, 05:52
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 2nd March 2015 - 13:11
