MAC(.APE) Linux Port 3.99 update 4 released
SuperMMX
post May 22 2004, 11:34
hi, all, I have ported the Monkey's Audio Codec to linux(and fixed some problems),
the latest is 3.99 update 4. And I also make a native plugin for XMMS. They all work well in my Debian SID box.
here is the change log:
MAC: short for Monkey's Audio Codec, a loseless audio codec (almost with the .ape extension).
Version 3.99 update 4 (2004/05/12)
    * added support for the original 3.99 update 4
    * added -Wno-long-long directive in config.in
    * changed the location of parameter BUILD_CROSSPLATFORM, added into configure.in
    * removed -D__GNUC_IA32__ directive
Version 3.99  (2004/05/02)
    * added support for original 3.99
    * fixed console compressing finishing error.
Version 3.98a (2004/02/20)
    * added BACK_COMPATIBILITY
    * added a shell script "strip_fPIC.sh", for compiling and linking the
        ASM sources. Thanks the FLAC guys.
    * fixed some conversions between and multi bytes and wide char.
    * fixed that APL files are not right played.
    * updated the Analyze sample to work correctly.
    * changed some codes to avoid warning, but some of those still couldn't be avoided.
    * changed the link style of Console and Sample to static
    * changed some autoconf automake codes.
Version 3.96 (2003/07/27)
    * built 1st. including the frontend, the shared lib and some examples.
libxmms-mac: Monkey's Audio Codec plugin for XMMS!
Version 0.2.0 (2004/02/19)
    * added support for MAC 3.98a.
    * added file information display including metadata(tags).
    * added APL support.
    * fixed some XMMS header file compile error (XMMS_NEW_TITLE_INPUT).
Version 0.1.0 (2003/07/27)
    * Built and worked.
No News is Good News.
The homepage is http://supermmx.org/linux/mac, which is in Chinese. But due to the network problem, the site can only be connected from China, so if u are not in China, u need a proxy to visit it. Or i can just upload them in the Upload forum(Is it ok with this?)
Any suggestions and feedbacks is appreciated, thanks.
Speek
post Oct 19 2007, 11:20
It seems the mac-port website has been removed again. I think it would be a pity if the Monkey's Audio non-win32 port wouldn't be available, so I will host it for a while.
Monkey's Audio non-win32 port:
mac-3.99-u4-b5.tar.gz
This post has been edited by Speek: Oct 19 2007, 18:10
Lear
post Oct 19 2007, 13:57
VorbisGain developer
Another option is write a decoder based on libdemac, a GPL-licensed APE decoder library (only supports 3.97 and later though), which is a part of Rockbox.
ak
post Oct 19 2007, 18:17
Musepack Developer
QUOTE (Lear @ Oct 19 2007, 15:57) *
By the way, ffmpeg guys did just that recently, ie added monkeys demuxer/decoder based on libdemac. Meaning it's now possible to play apes with recent enough mplayer and stuff.
- SuperMMX   MAC(.APE) Linux Port 3.99 update 4 released   May 22 2004, 11:34
- - Jan S.   Uploading would be fine.   May 22 2004, 11:37
- - SuperMMX   what kind of files are supported ? I tried with th...   May 22 2004, 11:53
- - loophole   Is the source available? I would like to see if I ...   May 22 2004, 12:46
- - xmixahlx   hey, thanx! (downloaded your source through c...   May 22 2004, 20:14
- - SuperMMX   QUOTE (xmixahlx @ May 22 2004, 11:14 AM)the x...   May 23 2004, 04:11
- - SuperMMX   http://www.monkeysaudio.com/cgi-bin/YaBB/Y...;num=...   Jan 17 2005, 06:47
- - jcoalson   don't know if you saw my reply on that thread,...   Jan 18 2005, 06:41
- - xmixahlx   i'm not sure, but the authors concept of ...   Jan 18 2005, 07:44
- - jcoalson   if that's the case then at his whim the author...   Jan 18 2005, 09:17
- - SuperMMX   @jcoalson: yes, i saw your post in Monkey's A...   Jan 18 2005, 13:56
- - jcoalson   I know your intentions are good but according to M...   Jan 18 2005, 20:09
- - rjamorim   I think people are making a huge deal about this. ...   Jan 18 2005, 21:17
- - jcoalson   that's just speculation. he's heard many ...   Jan 18 2005, 21:32
- - SuperMMX   mac-port new release: ChangeLog: CODEMAC: sh...   Apr 6 2005, 04:06
|- - jcoalson   QUOTE (SuperMMX @ Apr 5 2005, 10:06 PM)BTW: I...   Apr 6 2005, 04:44
|- - SuperMMX   QUOTE (jcoalson @ Apr 5 2005, 07:44 PM)then a...   Apr 6 2005, 05:04
- - xmixahlx   excellent! will be updated at RW/Debian tonig...   Apr 6 2005, 04:30
- - xmixahlx   supermmx - is there a reason the mac binary is bui...   Apr 6 2005, 05:34
|- - SuperMMX   QUOTE (xmixahlx @ Apr 5 2005, 08:34 PM)superm...   Apr 6 2005, 09:18
- - xmixahlx   well, anyways... i've updated RW/Debian to in...   Apr 6 2005, 10:30
- - SuperMMX   MAC plugin for Beep Media Player, anyone want it? ...   Apr 13 2005, 02:01
- - xmixahlx   thanx again   Apr 13 2005, 02:59
- - Mr_Rabid_Teddybear   I know some people think Monkey's Audio are op...   Apr 13 2005, 03:41
- - rjamorim   Well, people tried convincing him several times to...   Apr 13 2005, 03:59
- - xmixahlx   well, the *nix community has support without his h...   Apr 13 2005, 18:10
- - SuperMMX   new release, mac 3.99 update 4 build 3, this is a ...   Apr 15 2005, 02:33
- - xmixahlx   hi supermmx, i needed to patch ./configure.in wit...   Apr 15 2005, 08:51
- - SuperMMX   1) Thank you, will be fixed next release. I am sor...   Apr 15 2005, 10:08
- - xmixahlx   1) no problem. i bumped EXTRA_VERSION up to 1 (so...   Apr 15 2005, 12:03
- - SuperMMX   hmmmmmm, No problem here.. could you test it wit...   Apr 15 2005, 13:14
- - SuperMMX   updated version of bmp-mac and xmms-mac CODExmms-...   Apr 29 2005, 04:25
- - xmixahlx   thanx for this update, SuperMMX i apologize, i th...   Apr 29 2005, 19:03
- - SuperMMX   so the problem still there ?? it is really weird.....   Apr 30 2005, 03:39
- - gian   Dear SuperMMX, just downloaded your lib+xmms plug...   Apr 30 2005, 17:42
- - SuperMMX   There are some comments in the Monkey's Audio ...   May 2 2005, 03:44
- - Legoguy   Hello, thanks for your efforts on this! Howeve...   May 6 2005, 20:15
- - SuperMMX   what about removing the --prefix option? I have n...   May 8 2005, 02:24
- - KLJ   First off, I'd like to thank you for your work...   Jun 4 2005, 04:32
- - SuperMMX   if you are in UTF-8 locale, it is the problem, ple...   Jun 5 2005, 13:36
- - KLJ   Ah, didn't even think of checking there. I do...   Jun 5 2005, 23:07
- - ndn   trying to install xmms-mac but get this: checking...   Jul 5 2005, 02:30
|- - smthmlk   QUOTE (ndn @ Jul 4 2005, 07:30 PM)trying to i...   Jul 5 2005, 03:26
- - ndn   do you know where could i find "MAC"?   Jul 7 2005, 01:09
|- - Mr_Rabid_Teddybear   QUOTE (ndn @ Jul 6 2005, 04:09 PM)do you know...   Jul 7 2005, 01:29
- - SuperMMX   currently the main site http://supermmx.org is una...   Jul 7 2005, 09:15
- - SuperMMX   mac-port update 4 build 4 released: CODEVersion 3...   Sep 1 2005, 15:33
- - xmixahlx   QUOTE (SuperMMX @ Sep 1 2005, 07:33 AM)* adde...   Sep 1 2005, 19:09
- - SuperMMX   There is a backward compatibility macro definition...   Sep 2 2005, 02:23
- - xmixahlx   ok, just clairifying what you were referring to ...   Sep 2 2005, 02:32
- - Triza   Short question. Do you guys know any command line ...   Sep 2 2005, 13:06
- - SuperMMX   Long time no see, guys. mac-port 3.99 update 4 bu...   Jun 1 2006, 14:28
- - xmixahlx   thanks supermmx!   Jun 1 2006, 20:27
|- - geekoe   yeah, thanks for that! finally I can use it on...   Jun 1 2006, 22:23
- - yngwin   The project seems to no longer exist on sourceforg...   Jun 8 2007, 16:44
- - xmixahlx   i think it wasn't saved during the huge overha...   Jun 8 2007, 18:31
- - ak   It might be due to mac's license nonsense too....   Jun 9 2007, 18:27
|- - Mr_Rabid_Teddybear   QUOTE (ak @ Jun 9 2007, 09:27) It might b...   Jun 9 2007, 23:30
- - xmixahlx   at rarewares/debian i repackaged/updated 3.99b4u5 ...   Jul 6 2007, 00:20
- - Stauntonel   Thanks for this one! I have been searching for...   Sep 19 2007, 23:04
- - wegmethaat   Hi all, just a quick note to let you know the mac-...   Sep 25 2007, 12:12
- - xmixahlx   the shntool patch would be nice   Sep 25 2007, 17:53
- - jcoalson   what's the point of reuploading? it was pulle...   Sep 25 2007, 22:35
- - Speek   It seems the mac-port website has been removed aga...   Oct 19 2007, 11:20
|- - Lear   Another option is write a decoder based on libdema...   Oct 19 2007, 13:57
|- - ak   QUOTE (Lear @ Oct 19 2007, 15:57) Another...   Oct 19 2007, 18:17
- - xmixahlx   it's more confusing to have a 3.99-u4-b6 tarba...   Oct 19 2007, 17:16
|- - Speek   Maybe you're right. I was a bit worried about ...   Oct 19 2007, 18:17
- - monkey   It's great to see this! Thanks for your h...   Feb 6 2008, 15:56
- - Xenno   Excellent! Thanks to all. A nice HowTo on pro...   Oct 30 2008, 05:28
RSS Lo-Fi Version Time is now: 29th July 2015 - 23:44
