New portable Musepack decoder library, including fixed-point mode
Peter
post May 19 2004, 16:40
foobar2000 developer
Group: Admin
UPDATE: source posted here is outdated now, newer version is hosted on musepack.net.
Full C++ source in post attachement.
License: LGPL.
Features:
- Switchable fixed-point and floating-point modes - enable/disable "#define MPC_FIXED_POINT" in mpc_math.h
- Endian-safe, verified running correctly on big-endian machines
- Multiinstance and multithread safe
- File access callbacks
- No assembly code used, for full portability
Verified correctly compiling/running under:
- win32 / x86 / MSVC6 + SP5 + processor pack - very fast floating-point mode (goes above 200x on ~2GHz machines), fixed-point mode is significantly slower (~60x)
- win32 / x86 / MSVC7.1 - slightly faster than MSVC6, fixed-point mode still relatively slow
- win32 / x86 / DMCPP - fixed-point mode faster than MSVC, floating-point mode slower than expected with strange slowdowns when compiled with speed optimizations enabled
- wince / ARM (32bit) / eVC4 + SP3 - fixed-point decoding speed on 400MHz XScale CPU is about 10x realtime
- Darwin 7.3.0, MacOS X 10.3.3 / PowerPC970/G5 / GCC 3.3 - about 80x-100x decoding speed in both modes on 2GHz G5, thanks to TrNSZ for testing/feedback
I'm planning to put this in official MPC CVS, unfortunately I can't do that right now because corecodec server has been down for serveral days.
Attached File(s)
harad
post Aug 23 2004, 18:06
Using VC++ 3.0 [LOG]:
--------------------Configuration: mpcdec - Win32 (WCE x86) Release--------------------
Compiling...
bitstream.cpp
huffsv46.cpp
huffsv7.cpp
idtag.cpp
mpc_dec.cpp
requant.cpp
StdAfx.cpp
streaminfo.cpp
synth_filter.cpp
Creating library...
mpcdec.lib - 0 error(s), 0 warning(s)
You need to add:
#ifdef _WIN32_WCE
   # include <windows.h>
   #define assert ASSERT
#else
   # include <assert.h>
#endif
to mpc_dec.h, because PocketPC SDK 2002 doesn't have assert header.
- Peter   New portable Musepack decoder library   May 19 2004, 16:40
- - jarsonic   sweet, Peter! Should make it easier for (pote...   May 19 2004, 17:08
- - caligae   Not very portable at the moment though. No Makefi...   May 19 2004, 18:11
- - Peter   Package updated with stdafx.cpp/.h names changed t...   May 19 2004, 18:24
- - Gecko   Ah! Thx, Peter! Someone should show this ...   May 19 2004, 18:29
- - dev0   Already happened apparently: http://ipodlinux.sou...   May 19 2004, 18:33
- - xmixahlx   QUOTE (caligae @ May 19 2004, 09:11 AM)Not ve...   May 19 2004, 19:44
- - ak   Well, dsw2mak can be utilized for converting .dsw/...   May 19 2004, 20:53
- - soellman   i can verify that it works on mac osx 10.3.3.. now...   May 19 2004, 22:45
- - Tec9SD   Wow, Peter! I'm thoroughly impressed! ...   May 19 2004, 23:07
- - atici   That's great news indeed. We've had enough...   May 19 2004, 23:45
- - rjamorim   Is the integer part based on c.b.2000's intege...   May 20 2004, 00:11
- - Peter   Fixed-point mode has been added from scratch and i...   May 20 2004, 00:23
- - TrNSZ   [deleted]   May 20 2004, 00:39
- - BetaBoy   zZzZzZz.... On CoreCodec.org.... we were in the mi...   May 20 2004, 01:39
- - caligae   QUOTE (TrNSZ @ May 20 2004, 01:39 AM)To whome...   May 20 2004, 08:56
- - Althalus   Thank you zZzZzZz.   May 20 2004, 09:31
- - Slo Mo Snail   QUOTE (TrNSZ @ May 20 2004, 01:39 AM)The code...   May 20 2004, 09:58
- - caligae   Doesn't work on Alpha. CODEProgram received s...   May 20 2004, 10:30
- - picard   thank zZzZzZz! i added this library to BetaPl...   Jun 30 2004, 10:08
- - Atlantis   QUOTE (picard @ Jun 30 2004, 11:08 AM)thank z...   Jun 30 2004, 10:16
- - harad   Using VC++ 3.0 [LOG]: --------------------Configu...   Aug 23 2004, 18:06
- - Axon   Excellent work! But I have a licensing nitpick...   Aug 23 2004, 18:23
- - Peter   I personally don't care whatever you do with t...   Aug 23 2004, 18:48
- - harad   i think that someone should merge the mpc decoder ...   Aug 24 2004, 16:41
- - Sebastian Andersson   Hello! Is there any way to get the bits per s...   Aug 28 2004, 21:46
|- - Sebastian Andersson   QUOTE (Sebastian Andersson @ Aug 28 2004, 10:...   Aug 29 2004, 13:06
|- - Sebastian Andersson   OK   Aug 29 2004, 13:11
- - dev0   Why would you want to know the BPS of the source f...   Aug 28 2004, 22:06
- - dev0   QUOTE (Garf)Why would the decoder care at all what...   Aug 29 2004, 13:09
- - Sebastian Mares   So, is it possible or not?   Sep 17 2004, 21:45
- - Tang   Great news, thanks Mr Peter! I wonder there i...   Oct 20 2004, 20:58
- - Tang   EDIT: i've just understood how the Rockbox WiK...   Nov 3 2004, 01:42
- - kuniklo   I've just finished a first rough port of this ...   Dec 12 2004, 17:34
|- - Tang   QUOTE (kuniklo @ Dec 12 2004, 08:34 AM)I...   Dec 14 2004, 18:55
- - picard   I updated the old library in BetaPlayer's MPC ...   Dec 14 2004, 18:37
|- - kuniklo   QUOTE (picard @ Dec 14 2004, 05:37 PM)I updat...   Dec 14 2004, 18:40
|- - Lefungus   QUOTE (picard @ Dec 14 2004, 07:37 PM)I updat...   Dec 14 2004, 18:45
- - picard   Yes, I'am using the C++ version and the SeekTa...   Dec 14 2004, 18:49
|- - Lefungus   Some files have huge frame dependencies. There...   Dec 14 2004, 18:56
- - Tang   The codec section of the Rockbox iRiverport wiki i...   Feb 12 2005, 17:54
- - xmixahlx   someone on teh MDT should submit info for the ...   Feb 14 2005, 20:47
|- - Tang   QUOTE (xmixahlx @ Feb 14 2005, 11:47 AM)someo...   Feb 14 2005, 20:50
|- - Florian   QUOTE (Tang @ Feb 14 2005, 08:50 PM)QUOTE (xm...   Feb 14 2005, 20:52
- - Tang   Thanks Ganymed...   Feb 15 2005, 18:43
RSS Lo-Fi Version Time is now: 29th August 2015 - 13:58
