WavPack 4.0 Beta Release 2, including sources
bryant
post May 7 2004, 06:01
WavPack Developer
Group: Developer (Donating)
The second beta release of WavPack 4.0 includes the following:
  • stable format (beta1 files okay too; beta1 decoder obsolete)
  • decodes and plays legacy WavPack files (vers 1.0 to 3.97)
  • sources available with new decoding library
download win32 executables plus winamp2/5 & foobar2000 plugins
download sources
This post has been edited by bryant: May 14 2004, 08:06
robUx4
post May 8 2004, 09:12
Matroska Developer
QUOTE (xmixahlx @ May 8 2004, 07:16 AM)
a few notes on the *nix port (usage debian sid)
* segfaults when overwriting
* doesn't exit gracefully
* still has win32 header
* i'd like to see a library + frontend duo (i.e. frontend does encode/decode)
--> library allows for ease of plugins/etc.
GREAT WORK ROBUX4! Thanx for your efforts! *cough*monkeysaudio*cough* smile.gif
later
You know what ? I'm already running my main compiter with Debian and I'm going to investigate on this.
What is this "win32 header thing" ?
About the library, I'll work on it under Windows first to make room for a DirectShow filter (for decoding from Matroska). The linux version will come afterward.
What about MonkeyAudio ? The linux support doesn't exist ? I can have a look too. And at OptimFrog too. That would make the best 4 lossless codec available which is great. Also note that TTA is now hosted on CoreCodec (maybe WavPack could be hosted there too for the CVS) and so I can probably port that too...
http://www.matroska.org/ : the best vapourware / http://robux4.blogspot.com/
- bryant   WavPack 4.0 Beta Release 2   May 7 2004, 06:01
- - xmixahlx   excellent! so porting to, say, libwavpack lib...   May 7 2004, 07:05
- - aabxx   I tried the new asymmetrical encoding... very slow...   May 7 2004, 07:19
- - NRAninja   Hello bryant, I like Wavpack 4 very much. I notic...   May 7 2004, 07:23
- - Tec9SD   QUOTE (NRAninja @ May 7 2004, 01:23 AM)I was ...   May 7 2004, 07:37
- - robUx4   We're planning to have WavPack handling native...   May 7 2004, 08:07
- - NumLOCK   QUOTE (aabxx @ May 7 2004, 07:19 AM)A typical...   May 7 2004, 09:29
- - tcmjr   Hey Bryant , nice to see you again Had an Hdd cra...   May 7 2004, 14:24
- - mrbruno   hi ! wavpack seems to be a very interesting ...   May 7 2004, 17:12
- - Tomb   You can tag with ID3v1, ID3v2 or APE2. I tag with ...   May 7 2004, 17:19
- - mrbruno   well, I'd like to tag wavpack files with ID3 t...   May 7 2004, 17:27
- - rjamorim   QUOTE (Tec9SD @ May 7 2004, 03:37 AM)QUOTE (N...   May 7 2004, 18:12
- - robUx4   I'm currently porting the sources to Linux (ke...   May 7 2004, 18:19
- - emtee   What about seeking? I remember version 3.97 had so...   May 7 2004, 18:21
- - Speek   QUOTE What about seeking? I remember version 3.97 ...   May 7 2004, 19:07
- - tcmjr   QUOTE (emtee @ May 7 2004, 09:21 AM)What abou...   May 7 2004, 19:17
- - Tec9SD   QUOTE (mrbruno @ May 7 2004, 11:27 AM)well, I...   May 7 2004, 19:27
- - robUx4   The modified sources that work both under Win32 an...   May 7 2004, 21:35
- - rjamorim   Wonderful. Thank-you very much @xmixahlx: Where ...   May 7 2004, 22:25
- - naturfreak   Bug in Wavpack4 beta2 (win32 executable)? Hello, ...   May 7 2004, 22:44
- - tcmjr   no problem using windows xp sp1 all patches   May 7 2004, 23:28
- - kuniklo   QUOTE (robUx4 @ May 7 2004, 08:35 PM)The modi...   May 7 2004, 23:38
- - den   Now that Wavpack 4 is relatively stable, and the f...   May 8 2004, 00:21
- - xmixahlx   QUOTE (rjamorim @ May 7 2004, 01:25 PM)@xmixa...   May 8 2004, 07:16
- - Pamel   QUOTE (tcmjr @ May 7 2004, 01:17 PM)First of ...   May 8 2004, 07:29
- - robUx4   QUOTE (xmixahlx @ May 8 2004, 07:16 AM)a few ...   May 8 2004, 09:12
- - FireStarter   Maybe i am blind and it have already been posted, ...   May 8 2004, 12:39
- - tcmjr   No foobar plugin for wavpack 4 yet.   May 8 2004, 13:18
- - robUx4   I fixed all the known bugs in Linux. You can find ...   May 8 2004, 15:00
- - xmixahlx   optimfrog is closed source, florin just hasn't...   May 8 2004, 15:01
- - robUx4   What's the license of Monkey's Audio ? I w...   May 8 2004, 15:05
- - Peter   I see WavPack author has yet to discover the idea ...   May 8 2004, 15:38
- - robUx4   With David's permission I'll work on a lib...   May 8 2004, 15:57
- - glauco   TEST MACHINE Intel Pentium 4 2,4 GHz. 512 MB DDR ...   May 8 2004, 20:05
- - den   OK, as promised some Wavpack lossy listening test ...   May 10 2004, 03:20
- - The_Cisco_Kid   Played with it briefly, saw it was no joy in FB2k ...   May 10 2004, 03:50
- - bryant   First of all, thanks to everyone who has tried out...   May 10 2004, 05:44
- - Cerebus   I, too, would like a way to perform the replaygain...   May 10 2004, 21:12
- - NRAninja   The single file image and separate tracks issue is...   May 10 2004, 21:20
- - ghido   Hello, Here it is a little summary of WavPack 4.0...   May 11 2004, 00:41
- - den   QUOTE Hello, Here it is a little summary of WavPa...   May 11 2004, 02:14
- - Pamel   QUOTE (NRAninja @ May 10 2004, 03:20 PM)The s...   May 11 2004, 04:05
- - den   Ok, you asked for it... kraftwerk1: 264 Kb WV hb2...   May 12 2004, 11:52
- - den   Just to make sure that all is clear: QUOTE waitin...   May 12 2004, 13:59
- - bryant   My first attempt at an updated Foobar2000 plugin h...   May 14 2004, 08:00
- - den   Thanks David. If there was anything holding Wavpac...   May 14 2004, 08:47
- - john33   New 4.0b2 foobar2k plugin binary now at Rarewares.   May 14 2004, 09:05
- - FireStarter   Other then using foobar for transcode wavepack, is...   May 14 2004, 10:12
- - Speek   Thanks for the foobar component. It works fine (so...   May 14 2004, 11:25
- - robUx4   Maybe that should be an option, with a third possi...   May 14 2004, 13:13
- - robUx4   The latest sources are now uploaded on the CVS of ...   May 14 2004, 14:09
- - glauco   WOW!!! Linux version, foobar plugin, ...   May 14 2004, 15:27
- - bryant   QUOTE (naturfreak @ May 7 2004, 01:44 PM)Afte...   May 15 2004, 20:12
- - Pamel   QUOTE (bryant @ May 15 2004, 02:12 PM)Yes, on...   May 17 2004, 22:49
- - HansHeijden   For those interested, just updated the compression...   May 19 2004, 19:33
- - SometimesWarrior   QUOTE (HansHeijden @ May 19 2004, 11:33 AM)Fo...   May 20 2004, 07:47
- - den   @FireStarter Sorry I didn't answer you before...   May 20 2004, 10:07
- - robUx4   For those interrested, I've tuned the Wavpack ...   Jun 1 2004, 21:38
- - rjamorim   Elite! Thanks   Jun 1 2004, 21:54
- - MyAdviceIha   It has been a while since any updates have been to...   Jun 18 2004, 16:26
- - robUx4   I guess it's quite stable. Unfortunately CoreC...   Jun 18 2004, 16:54
- - bryant   QUOTE (MyAdviceIha @ Jun 18 2004, 07:26 AM)It...   Jun 19 2004, 18:26
- - Tec9SD   Nice to hear, thank you all for your time and effo...   Jun 20 2004, 09:08
- - bryant   QUOTE (Tec9SD @ Jun 20 2004, 12:08 AM)Has MD5...   Jun 21 2004, 05:28
- - dzy   is the md5 going to be the md5 of decoded raw data...   Jun 21 2004, 07:59
- - bryant   QUOTE (dzy @ Jun 20 2004, 10:59 PM)is the md5...   Jun 21 2004, 18:40
- - guruboolez   Does it mean that files need to be decoded in orde...   Jun 21 2004, 18:45
- - bryant   QUOTE (guruboolez @ Jun 21 2004, 09:45 AM)Doe...   Jun 21 2004, 19:13
- - guruboolez   QUOTE (bryant @ Jun 21 2004, 07:13 PM)Aren...   Jun 21 2004, 19:34
- - bryant   QUOTE (guruboolez @ Jun 21 2004, 10:34 AM)Cha...   Jun 21 2004, 19:49
- - robUx4   IMO it's good to compute it on the encoded dat...   Jun 21 2004, 21:49
RSS Lo-Fi Version Time is now: 3rd June 2015 - 19:39
