List of recommended LAME settings, Discussion
user
post Oct 28 2001, 19:37
The actual list can be found here:
This thread is for discussion about the list.
www.High-Quality.ch.vu -- High Quality Audio Archiving Tutorials
HansHeijden
post Nov 5 2001, 12:37
Dibrom,
Great you implemented this preset system! Of course there are things i'm not happy about biggrin.gif so here it goes. Feel free to ignore, anyway I noted that additional switches behind the preset can be added!
The choise of lowpass: too high at low bitrates, too low at high bitrates.
There's a good reason to stay below 16 kHz at 128 k, because at this bitrate nspsytune's default -X1 doesn't encode > 16 kHz well, if at all. It tends to be smeared as well, though I don't recall on what samples. Encoding above 16 kHz is too ambitious period!
I suggest 80k/12.3kHz, 96k/15.3kHz, 112k/16kHz and 128k/16kHz.
For higher bitrates, lame's defaults are just fine:
160k/18.0kHz, 192k/19.5kHz, 224k/20kHz, 256k/21kHz, 320k/22kHz.
At 320k I noticed the use of both -X3 and -Z. Can you explain why the -Z as well? Unlike the combination with -X1, it does not make much difference to me.
I heard that you probably lowered the --ns-bass -8 value in the 128k preset. Clips like 41_30sec, spahm, youcantdothat etc rumble more than they already did. The -8 shall not be touched! :mad:
It would be nice to know where you transition to nssafejoint, -X3 etc.
Hans
- user   List of recommended LAME settings   Oct 28 2001, 19:37
- - user   Hi user i personaly would like a 128 kbit setting...   Oct 28 2001, 19:39
- - user   Added 128 CBR settings. It would be useful, if som...   Oct 28 2001, 19:40
- - user   man! what a great idea! this would help out soooo...   Oct 28 2001, 19:41
- - user   Hi, thanks. Added current date at top. If somebod...   Oct 28 2001, 19:42
- - Riggs   Ugh so many users.   Oct 28 2001, 19:57
- - user   Hi, not really ! As you see, i have written who ha...   Oct 28 2001, 20:06
- - CiTay   Ummm user, i don't think this reposting is the way...   Oct 28 2001, 22:38
- - cd-rw.org   Yes, this is a good idea. I have been planning on ...   Oct 28 2001, 22:41
- - user   Hi, done. Please somebody should read over the set...   Oct 30 2001, 14:59
- - CiTay   Hi user, good work. I corrected a few things, i h...   Oct 30 2001, 20:37
- - GeSomeone   QUOTE Originally posted by user 160 kbits CBR -b ...   Oct 30 2001, 21:45
- - CiTay   user, you may replace your post with this if you l...   Oct 31 2001, 03:23
- - CiTay   Edited original post. It's a heavily edited versi...   Nov 1 2001, 05:19
- - mp3fan   Hmm, I'd like someone to try "--nsmsfix 1.2" with...   Nov 1 2001, 07:30
- - CiTay   Made some changes to the alternative 128 CBR / ABR...   Nov 1 2001, 16:10
- - CiTay   Added new 320 CBR setting, suggested by Dibrom: -...   Nov 1 2001, 17:12
- - CiTay   Made some more layout changes. Also: removed --dm...   Nov 2 2001, 23:47
- - CiTay   From the r3mix.net board: QUOTE > Should the v...   Nov 3 2001, 14:31
- - user   to How to avoid clipping with mp3gain ? How to bur...   Nov 3 2001, 15:17
- - Somebody   great list suggestion to add MP3Utility to (Analy...   Nov 3 2001, 17:30
- - user   following: mp3utility razorlame renatager   Nov 3 2001, 20:48
- - CiTay   Some changes to the 128 kbit ABR lines, suggested ...   Nov 5 2001, 04:38
- - mp3fan   Question, Why not advise people to use normalizat...   Nov 5 2001, 06:25
- - Dibrom   No. This has been explained before, but basically...   Nov 5 2001, 06:36
- - Dibrom   I've updated the list of settings to reflect the c...   Nov 5 2001, 08:06
- - HansHeijden   Dibrom, Great you implemented this preset system!...   Nov 5 2001, 12:37
- - Dibrom   QUOTE Originally posted by HansHeijden There's a ...   Nov 5 2001, 16:13
- - Dibrom   Hans: OK, I updated the lowpasses a bit: 80kbp...   Nov 5 2001, 16:31
- - HansHeijden   Yes, I used Dmitry's compile, so that explains the...   Nov 5 2001, 17:50
- - Dibrom   QUOTE Originally posted by HansHeijden Indeed --n...   Nov 5 2001, 18:04
- - user   Updated November 6, 2001 Especially the dm settin...   Nov 6 2001, 23:45
- - mitiok   QUOTE Originally posted by Dibrom   80kbps ...   Nov 7 2001, 02:07
- - user   Added   Nov 9 2001, 22:28
- - user   Hi, I edited the resulting file sizes of VBR pres...   Nov 9 2001, 22:36
- - Dibrom   I'd like to point out that on the r3mix.net versio...   Nov 9 2001, 22:40
- - cd-rw.org   Dibrom, Yes, the problem is that we can't really ...   Nov 9 2001, 23:00
- - Dibrom   I don't think it is a good idea to try and give ra...   Nov 9 2001, 23:11
- - Dibrom   What I think I'll do since I'm about ready to star...   Nov 9 2001, 23:20
- - tangent   The best way to represent a range would be to prov...   Nov 10 2001, 08:28
- - cd-rw.org   Dibber: That's an idea but it will give only your ...   Nov 10 2001, 08:33
- - jord   Hi, Let me start by saying that the new Lame sett...   Nov 15 2001, 02:17
- - Dibrom   QUOTE Originally posted by jord Secondly, user, D...   Nov 15 2001, 02:40
- - jord   Great! ...and you'll add your compile to the main...   Nov 15 2001, 03:10
- - Kblood   --dm-preset <bitrate> Simple question: In t...   Nov 15 2001, 11:49
- - auldyin   Hi, I just did. See auldyin posts auldyin   Nov 15 2001, 13:19
- - mp3fan   Well, here is my offering. I'd like the developer...   Nov 23 2001, 19:26
- - SNYder   why is every settin on this list still in the --dm...   Nov 30 2001, 00:47
- - Somebody   QUOTE Originally posted by SNYder why is every se...   Nov 30 2001, 02:53
- - SNYder   QUOTE Originally posted by Somebody As far as I ...   Nov 30 2001, 04:32
- - JohnV   QUOTE Originally posted by SNYder So then how come...   Nov 30 2001, 04:53
- - Dibrom   Updated the recommended settings to reflect the la...   Dec 15 2001, 23:35
- - layer3maniac   QUOTE I also removed some unoptimized settings, in...   Dec 15 2001, 23:54
- - Dibrom   QUOTE Originally posted by layer3maniac Roel's b...   Dec 16 2001, 00:01
- - SNYder   I think under the 96kbps CBR preset there should b...   Dec 16 2001, 00:16
- - Dibrom   QUOTE Originally posted by SNYder I think a link ...   Dec 16 2001, 00:19
- - SNYder   fyi: u have --alt-preset insane under vbr.   Dec 16 2001, 00:24
- - Dibrom   QUOTE Originally posted by SNYder fyi:  u ha...   Dec 16 2001, 00:34
- - Northpack   Mmh, I don't think that LAME performs bad on ~96kb...   Dec 16 2001, 00:41
- - Dibrom   Out of curiosity, you should give --alt-preset 95 ...   Dec 16 2001, 00:47
- - SNYder   QUOTE Originally posted by Dibrom [b] I did that...   Dec 16 2001, 01:29
- - Dibrom   Good idea, I went ahead and just did that. I also...   Dec 16 2001, 01:36
- - Amadeus93   One thing about the format: the first three catego...   Dec 16 2001, 02:04
- - Dibrom   Fixed.   Dec 16 2001, 02:11
- - Dibrom   Modified the layout some more and added more to th...   Dec 16 2001, 04:01
- - jraneses   Dibrom, can you comment on the differences between...   Dec 16 2001, 07:40
- - Dibrom   QUOTE Originally posted by jraneses Dibrom, can y...   Dec 16 2001, 09:31
- - Northpack   QUOTE Originally posted by Dibrom Areas where the...   Dec 16 2001, 13:09
- - john33   Dibrom, I notice the rlo presets file for RazorLam...   Dec 16 2001, 14:39
- - user   Hi, the presets are designed for the aim that eve...   Dec 16 2001, 15:48
- - user   Hi, with alt prset extreme the compiles reslut to...   Dec 16 2001, 15:59
- - Dibrom   QUOTE Originally posted by Northpack You are fa...   Dec 16 2001, 18:34
- - Dibrom   QUOTE Originally posted by john33 Dibrom, I notic...   Dec 16 2001, 18:34
- - jraneses   QUOTE Originally posted by Dibrom Hrmm.. that's...   Dec 16 2001, 19:04
- - Dibrom   QUOTE Originally posted by jraneses It's hip hop ...   Dec 16 2001, 19:42
- - SNYder   Could someone add, in the links section under (Ren...   Dec 16 2001, 19:50
- - user   Hi, done. Added only the link to the list, not...   Dec 16 2001, 20:09
- - user   Hi, the increasement from 248 to 267 is not much....   Dec 16 2001, 20:19
- - Dibrom   user, Well perhaps I won't change too much. I'm ...   Dec 16 2001, 20:26
- - jraneses   Thanks for checking into this again...because I re...   Dec 16 2001, 21:10
- - JohnV   Edited the link list a bit. The link to "Dibrom's ...   Dec 16 2001, 22:42
- - SNYder   QUOTE Originally posted by user Hi, done.  ...   Dec 16 2001, 23:03
- - CiTay   Improved spelling & layout.   Dec 16 2001, 23:42
- - jraneses   Where is this list you're speaking of? I haven't ...   Dec 17 2001, 02:44
- - Amadeus93   One more formatting bit: Under "VBR (variable bit...   Dec 17 2001, 03:55
- - Dibrom   I prefer "even higher quality" personally. The + ...   Dec 17 2001, 05:32
- - Dibrom   Updated the bitrate information for "extreme".   Dec 18 2001, 17:46
- - SNYder   can someone please just add the 2 ID3Taggers i sug...   Dec 19 2001, 05:33
- - Dibrom   done   Dec 19 2001, 05:56
- - SNYder   thanks buddy [edit]p.s. at the top of the list ...   Dec 19 2001, 06:15
- - JohnV   QUOTE Originally posted by SNYder p.s. at the to...   Dec 19 2001, 14:01
- - c15zyx   2 short questions: 1. Why is -q 2 (-h) used inste...   Dec 23 2001, 22:57
- - Dibrom   QUOTE Originally posted by c15zyx 2 short questio...   Dec 23 2001, 23:29
- - user   Added link to HOW TO Reencode mp3 to mp3 keeping i...   Dec 26 2001, 18:21
- - user   added lowpass 16 to ABR 134/128 setting. It was mi...   Dec 30 2001, 18:19
- - ff123   QUOTE added lowpass 16 to ABR 134/128 setting. It ...   Dec 30 2001, 21:11
- - sphoid   QUOTE Originally posted by ff123 Probably 134 sho...   Dec 30 2001, 22:20
- - Snelg   QUOTE Originally posted by user Snelg wants to ad...   Dec 31 2001, 00:06
- - user   "or (ff123's and Hans' suggestion -- http://www.ff...   Dec 31 2001, 10:25
- - ff123   QUOTE "or (ff123's and Hans' suggestion -- http://...   Dec 31 2001, 16:43
6 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 29th May 2015 - 07:19
