First on board solid-state audio, now on board Vacuum Tube a
Filburt
post Jun 4 2002, 06:20
http://www.aopen.com/products/mb/ax4b-533Tube.htm
That's just...indescribably odd.
Dibrom
post Jun 4 2002, 07:25
Founder
Group: Admin
Heh... that is really trippy. Who'd have thought we would see something like this....
jgalt
post Jun 4 2002, 11:10
Is this some form of retrogression?
JonPike
post Jun 4 2002, 11:25
Yeah.. I had to pick the jaw off the floor and jam it back in place.
Better pics here: http://www.hardocp.com/image.html?image=MT...V8xMl9sLmpwZw==
(if the link's broken go to hardocp's Computex report, AOpen section)
And the announcement in the news section of the AOpen site goes into a lot of tech detail of what it's all about..
If it dosen't hum and buzz, and all, being inside a box with switching power supplies and digital circiutry.. it should provide a very nice sound..
Kinda cool that a big Corporation decides to put together a product that they have no chance of making any money on.. just because they love great sound.
Who the hell does that nowadays??
KikeG
post Jun 4 2002, 11:54
WinABX developer
I guess that some valve-maniatics will buy it.
What's next? A vinyl reading unit?
ssamadhi97
post Jun 4 2002, 12:48
Group: Developer (Donating)
pretty weird that they combine it with the (fairly crappy, iirc) AC97..
A riddle is a short sword attached to the next 2000 years.
indybrett
post Jun 4 2002, 14:12
Group: Members (Donating)
I wonder how much space you would need if they replaced the P4 with vacuum tubes...
flac>fb2k>kernel streaming>audiophile 2496>magni>dt990 pro
fewtch
post Jun 4 2002, 14:39
LOL!
How much cooling needed too. A heatsink the size of Texas? biggrin.gif Tornado force winds as the cooling fan.
Bring back dynamic range... www.loudnessrace.net
Ruse
post Jun 4 2002, 14:55
Imagine a Soundblaster Live Valve Card.
Ruse
____________________________
Don't let the uncertainty turn you around,
Go out and make a joyful sound.
redcane
post Jun 4 2002, 14:58
AC97 is a hardware interface to access the codec (an API if you will). So depending on which implementation of it you have, the sound quality changes. Anywhere from the $15 bargain bin sound cards up to some audiophile gold plated terminals whizz bang models implement AC97 compatibility (the live and audigy do I think too). It is nicely compatible, and as long as they've used solid audio components it sounds good too. (I've heard some shitty AC97 cards, but I don't mind my Live with it's AC97 mixer).
indybrett
post Jun 4 2002, 16:04
gdougherty
post Jun 4 2002, 16:41
Not to bust anybody's bubble, but throwing a tube on there doesn't necessarily do anything positive for the sound. I'm a recording hobbyist and all kinds of gear throws in a tube and calls itself "tube" whatever, but if a high-quality tube isn't used, the result can be worse than solid state electronics.
Given the electromagnetic noise present in a PC I'd suspect that this tube, combined with the "crappy" AC'97 codec, continues the crappiness trend and is merely for dick measuring contests and as a marketing tool to sucker in those gullible enough to think it'll make things sound better. If I want tube warmth to color my sound, I'll go out and buy a high quality tube amp and keep the tubes where they belong, out of a modern PC.
G
indybrett
post Jun 4 2002, 16:50
Now, if only they would throw in a green marker for making CD's sound better wink.gif
ssamadhi97
post Jun 4 2002, 16:57
hmmm! maybe painting the tube green with the marker would magically shield it from the electromagnetic noise! biggrin.gif
Filburt
post Jun 4 2002, 18:02
Post #15
Well, there's a store near me with about 100000 tubes sitting around (literally) so I'm sure I could find a replacement of some sort if this tube sucks biggrin.gif.
fewtch
post Jun 4 2002, 20:35
Post #16
It just seems so bizarre to put a tube on a motherboard. Is it made of regular glass... how are they gonna make sure it doesn't break in transit? Does the company provided replacements if/when the tube burns out? biggrin.gif
It's just weird... :too_hot:
JonPike
post Jun 5 2002, 07:19
Post #17
Heh.. well, like I expected.. good, bad, it's sure got peoples attention.
They seem to think it sounds good enough that it was worth finishing in the lab, and producing it as a product. Either that, or the audiophile big boss REALLY wanted to do it, and they've had a good year as a company..
I read something that you might be able to run audio thru the tube without using the soundcard..
And, I imagine there is a foam block with a tube sized hole inside that motherboard package... would make sense.. though tube sockets tend to hold pretty tightly. A little, light tube like that .. you'ld have to REALLY bash the thing to do some damage.
Pio2001
post Jun 5 2002, 11:28
Post #18
Moderator
I can't imagine the temperature in this box ! The tube must produce as much heat as an AMD CPU !
godzilla525
post Jun 6 2002, 13:32
Post #19
If anything, they'll probably just ship the tube in the usual little cardboard box in a separate partition in the mobo box, and make the end user plug it in. Or it will be exposed for view by means of a bubble-pack window in the box. Scary.
The only way that sticking tubes in a PC will do any good is if they eliminate the solid-state output buffer in the DAC--and I don't know of any that don't have that built in.
Furthermore, I don't like having 150 VDC running loose on the motherboard right beside sensitive 3.3v CMOS logic. It's too easy to get shocked or for something else to get shocked. I'd rather just use an optical connection and connect to external equipment instead.
godzilla525
JonPike
post Jun 7 2002, 04:07
Post #20
Heat?? Oh no.. that tube probably won't dissipate more than a couple o' three watts, as opposed to the 40-50W that a high end processor does.. Not a biggie..
As for the voltage.. it's probably more like 200-250VDC!! wink.gif As long as it stays where it's supposed to be, no problemo. And, why would you be fondling your motherboard after you've got it all set up, anyway.. But, probably not a good board choice for a watercooled rig... biggrin.gif
As for tube life.. it should last for more years than you'ld want to use the board for..
smg
post Jun 18 2002, 05:26
Post #21
I Agree To me nothing sounds better than the warm sound of analog (not the pops and cracks)
RSS Lo-Fi Version Time is now: 30th August 2015 - 19:03
