List of recommended MPC settings
user
post Jun 2 2002, 16:41
These settings require Musepack MPC 1.1 or later.
mppenc 1.16 is the recommended encoder version,
mppdec 1.95e is the recommended decoder version.
Download them at Musepack.net.
Recommended encoder settings
--quality 5
(Previously "--standard", ~170 kbit/s, typical 142 ... 184)
--quality 6
(Previously "--xtreme", ~200 kbit/s, typical 168 ... 212)
--quality 7
(Previously "--insane", ~220 kbit/s)
Note that --quality 5 is transparent for most test samples.
Higher settings can provide a quality headroom, however, you should start off with 5.
Custom settings:
--quality x.xx
Example: --quality 5.55 . The range goes from 0.00 (worst) to 10.00 (best).
The switch --xlevel doesn't need to be specified anymore,
it's a default setting since mppenc 1.15s.
Don't use any further switches to "tweak" the quality.
Some of them no longer work or have undesired effects on quality.
Meanings of older tweaking switches may have completely changed.
Just use the --quality switch for fine-tuning, that's the best way.
Recommended EAC / MPC Batch Encoder settings
EAC: Exact Audio Copy
Compression Options -> External Compression -> Use external program for compression
Parameter passing scheme: "User Defined Encoder"
Use file extension: .mpc
Program, including path: C:\MPC\mppenc.exe
Additional command line options (example):
--quality 6 --artist "%a" --title "%t" --album "%g" --year "%y" --track "%n" --genre "%m" %s
Copy the whole line into that option field in EAC.
For comments, add this switch before %s: --comment "blabla"
Example: (...) --genre "%m" --comment "EAC secure" %s
The MPCs will automatically get APEv2 tags, so "Add ID3 tag" must be turned off.
ID3v1 tags could be used, but they are length-limited.
ID3v2 tags are not compatible with MPC!
It's also recommended to use "Secure mode" in "Extraction method",
because if you have a rip with a lot of clicks in it, what good is the MPC quality?
(Only for mppenc 1.14 and older encoder versions: Add "--xlevel" after "--quality 6".)
Simple guide with screenshots
Encoding switch for the MPC Batch Encoder frontend:
(an easier way would be to use foobar2000 instead)
--quality x.xx
Example: --quality 6
The frontend can also take care of proper tagging.
In case this was done by EAC, you can then apply ReplayGain:
Replaygain commandline with the MPC Batch Encoder + Replaygain.exe: --auto
(What is ReplayGain good for? / ReplayGain FAQ)
Decoding switches / MPC to WAV (i.e. with the MPC Batch Encoder frontend + mppdec.exe):
For albums: --gain 1 --prev
(or --gain 3 --prev)
For compilations: --gain 0 --prev
(or --gain 2 --prev)
Or use foobar2000.
It's a good idea to apply ReplayGain first (see above and further below). Explanations of the switches:
--prev: Activate clipping prevention.
(Clipping occurs when the amplitude of a sound is above the maximum allowed level,
i.e. when it is too loud to be recorded/reproduced. Clipping causes sound to distort.)
--gain 0:
No usage of replaygain. Together with --prev: Title-based clipping prevention.
The loudness of each song is reduced individually to the point where no song is clipping.
--gain 1:
No usage of replaygain. Together with --prev: Album-based clipping prevention.
Each song of an album is attenuated by the same amount and no song has clipping.
--gain 2:
Title-based replaygain, rest like 0.
--gain 3:
Album-based replaygain, rest like 1.
Recommended Winamp 2.x plug-in settings
You should use foobar2000 for maximum flexibility, also concerning Replaygain.
However, here's how to make it work in Winamp:
in_mpc 0.99g is the recommended Winamp plug-in: Download here
Settings:
(In Winamp, press "CTRL-P" (Preferences), go to "Plug-ins" -> "Input",
select the MPC plug-in and press "Configure"):
Equalizing by [x] Musepack
Winamp's own equalizer attenuates high frequencies.
Dynamic range: 6 dB
Range of the equalizer: -6 to +6 dB
Headroom "K-14"
Headroom is needed to avoid clipping and oversaturated sound. K-14 is the best choice for home listening
(see Level Practices Part I and Level Practices Part II, K-System explained).
ReplayGain'ed MPCs at K-14 will have the same perceived loudness as other formats with applied ReplayGain
- such as Ogg Vorbis or MP3 - with the recommended reference volume of 89 dB.
[x] Dither output
What is dither?
[ReplayGain title based | ClipProtect Off] or [ReplayGain album based | ClipProtect Off]
Use title-based ReplayGain for a "radio-like" listening environment (all songs will have a comparable loudness). Use album-based ReplayGain for an "album-by-album" listening environment (different albums will have a comparable loudness, but volume differences between single songs of an album are preserved).
Replaygain
You have to apply ReplayGain to your MPC files for this to work. The Winamp plug-in will read out the ReplayGain information and use it for title-based or album-based playback. Applying ReplayGain is easy:
First you have to download the MPC decoder and the Replaygain tool from Musepack.net.
Then, the MPC Batch Encoder. It's easier with foobar2000, by the way.
Extract everything to one folder, start the frontend and go to the "ReplayGain" tab.
In the "Switches" field, enter --auto . Then add the folder with the MPC files.
Important: For correct album gain calculation, only apply ReplayGain to
one album at a time (put each album into a seperate folder).
Getting a "can't decode file" error with Replaygain? Make sure mppdec.exe is in the same directory as replaygain.exe.
How To...
1) ...recursively go through a directory structure and apply ReplayGain to all MPC files,
considering each directory as an individual album ?
Use foobar2000, or:
Download Sweep and the Replaygain tool. Extract them to your path (e.g. C:\Windows).
In a command-line window (so-called DOS-box), type: sweep replaygain --smart --auto *.mpc
Already replaygained albums will be skipped, due to the --smart option. Sweep starts to scan in the current directory of the DOS-box, going through all subdirectories. To process only a specific path, use the well-known DOS commands to go to that directory (for instance cd "c:\mpc\my downloads\") and then use the command sweep replaygain --smart --auto *.mpc to process all subdirectories from there.
2) ...create replaygain.txt files for a lot albums in one step,
Create a file called "replaygain.bat" with the following contents:
replaygain --listallreport *.mpc > "replaygain --auto album.txt"
Copy this file into your Windows directory.
This *.bat file needs to be created only once in your life...
So don't worry...
Now the procedure:
- Open a DOS-Box, go to the main folder/directory where the albums are located.
- type: sweep replaygain.bat and press Return
A file ' replaygain --auto album.txt ' will be created in each album-folder. That's it!
Useful links
[ Latest MPC compiles ]
Musepack.net: Official page, downloads & source code
[ Exact Audio Copy ]
The best CD grabbing software, period.
Official site
[ Ripping guides for EAC & MPC ]
Simple EAC guide for MPC
General Tutorials for EAC
users' Tutorials for EAC, MPC & Lossless
The Essential Audio & EAC guide
EAC forum
EAC Offsetbase
AccurateRip Drive Offsets
[ MPC Frontends ]
foobar2000 - Player, frontend, it's the best.
MuseDrop, drag&drop encoding/decoding
Speek's Frontend, batch encoding, decoding & ReplayGain
Monkey's Audio is a good frontend for MPC, too.
[ Renaming / Tagging / Music Database]
Tag, a very powerful tagger
Tag Frontend
CDIndexer : for CD-Audio & data-CDs
MAC: MPEG Audio Collection 2.92
MAC 2.93
How To...
..convert ID3v2 tags to APEv2 tags:
Use Tag & Tag Frontend with the switches --force ape2 --removeid3v2 in "other options"
(remove all other checkmarks).
Directly from a command-line window: Tag *.mpc --force ape2 --removeid3v2
Or use foobar2000.
..transcode MPC to MP3 while keeping tags?
Not recommended for quality reasons, quality will degrade! It can be done with foobar2000 though.
[ ReplayGain, lossless normalizing ]
ReplayGain information page
[ Useful tools ]
MPC filter for CoolEdit / Adobe Audition
Mr QuestionMan
EncSpot
Tool for ABXing, Blind listening tests
ABC/HR, blind listening tests
Training of musically listening good-ear.com
QuickSFV - SFV and MD5 checksums for files
Credits
A big thanks to all MPC developers for making one kickass MPC codec, the best lossy codec in the world.
Idea, original post and list of original settings collected by user, Layout & additional work by CiTay, SNYder and Dibrom.
This post has been edited by CiTay: Nov 13 2006, 16:25
xmixahlx
post Aug 1 2003, 09:16
TO ADD:
LINUX RESOURCES:
players: XMMS, BMP, LAMIP
xmms-musepack plugin
lamip-inputmpc plugin
bmp-musepack plugin
Debian Packages:
http://rarewares.hydrogenaudio.org/
http://www.hydrogenaudio.org/forums/index....showtopic=10340
GRIP FOR *NIX (v3.x.x)
(will be put into an actual guide, soon...)
(for scsi emulation of ide)
CONFIG>CD
cdrom device: <scsi device> (i.e. /dev/scd0)
CONFIG>RIPPER
Ripper: grip (cdparanoia)
(disable) Disable paranoia
(disable) Disable extra paranoia
Disable scratch:
(disable) detection
(disable) repair
Rip file format: ~/%A - %d - %t - %n.wav (e.g. "led zeppelin - coda - 03 - i can't quit you baby.wav")
CONFIG>ENCODE>ENCODER
Encoder: other
Encoder executable: mppenc (or mppenc-static, ~/bin/mppenc-static, /home/user/bin/mppenc-static - make sure executable is in $PATH or an absolute path is given)
Encoder commandline: --quality 5 --xlevel --artist "%*A" --title "%*n" --album "%*d" --year "%*y" --track "%*t" --genre "%*G" %w
Encode file format: ~/%A - %d - %t - %n.mpc (e.g. "led zeppelin - coda - 03 - i can't quit you baby.mpc")
** CURRENTLY, XMMS MPC PLUGIN DISPLAYS TITLE, ARTIST, ALBUM CORRECTLY
** full list of switches here: http://www.nostatic.org/grip/doc/gripswitches.html
CONFIG>ID3
(disable) Add ID3 tags to encoded files (preference, id3v1 is possible)
(disable) Add ID3v2 tags to encoded files (Musepack does NOT use id3v2 tags!!)
[edit: removed image URLs as they don't exist any more smile.gif ]
later
This post has been edited by xmixahlx: Oct 4 2004, 04:08
RareWares/Debian :: http://www.rarewares.org/debian.html
- user   List of recommended MPC settings   Jun 2 2002, 16:41
- - CiTay   Added a small tutorial on how to apply ReplayGain.   Aug 7 2002, 18:30
- - guruboolez   I experiment a similar thing with my castanet ABX ...   Aug 9 2002, 15:33
- - ff123   QUOTE Originally posted by guruboolez I experimen...   Aug 9 2002, 15:53
- - user   I have added links to Easy MD5 Creator, MPCxchange...   Aug 23 2002, 14:33
- - user   MPCscan - Check a directory for corrupted mpc/mp+ ...   Sep 15 2002, 12:00
- - user   Case, can u explain how to use mpcscan ? quick an...   Sep 15 2002, 20:39
- - Somebody   There is no need to copy mpcscan to a specific dir...   Sep 15 2002, 23:25
- - user   * * url updated. Thanks to smok3, who told me abo...   Sep 17 2002, 22:45
- - user   Musepack in English and German / Deutsch added   Sep 22 2002, 19:01
- - JEN   So how do you get a 5.1 wav to 5.1 mpc? whats the...   Sep 24 2002, 22:24
- - user   at the moment I don't think that mpc is capabl...   Sep 24 2002, 22:30
- - ProtectYaNeck36   are there any advantages to using the --quality x....   Sep 24 2002, 23:40
- - user   The advantage of --quality x.yz is, that you can u...   Sep 26 2002, 19:17
- - user   High Quality + Previously "--xtreme". Pr...   Sep 26 2002, 21:28
- - user   added How To : Recursively traverse a directory s...   Sep 27 2002, 16:52
- - CiTay   Sorry user, the method was not really correct, bec...   Sep 27 2002, 17:18
- - GeSomeone   QUOTE (user @ Sep 26 2002 - 08:17 PM)with wor...   Sep 27 2002, 17:46
- - user   yea, better, I found that first way here in an act...   Sep 27 2002, 21:40
- - user   added an explanation for navigating command-line-w...   Sep 28 2002, 09:25
- - CiTay   Overhauled the text a little.   Sep 28 2002, 14:00
- - CiTay   Improved layout a bit and made the "decoding ...   Oct 17 2002, 04:16
- - CiTay   New recommended encoder version: MPC 1.12 Also mo...   Oct 17 2002, 14:56
- - user   added link to *** ** edit: no links to ripping g...   Oct 24 2002, 13:23
- - WaldoMonster   Because MPC plays perfectly gapless, I use separat...   Oct 24 2002, 13:58
- - CiTay   QUOTE Will --xlevel destroy the music level by Liv...   Oct 24 2002, 14:36
- - WaldoMonster   Hello Citay, Thanks for the clear answers. Now I ...   Oct 24 2002, 14:42
- - Andavari   QUOTE (user @ Sep 28 2002 - 02:25 AM)How To.....   Oct 25 2002, 23:18
- - guruboolez   http://www.saunalahti.fi/~cse/files/Sweep.zip   Oct 25 2002, 23:42
- - Case   QUOTE (Andavari @ Oct 26 2002 - 01:18 AM)QUOT...   Oct 25 2002, 23:43
- - CiTay   Andavari, did you have an old version of the list?...   Oct 25 2002, 23:51
- - CiTay   New recommended encoder version: mppenc 1.14 Test...   Oct 27 2002, 15:05
- - CiTay   New: - How to add comments to tags - Quick ...   Nov 2 2002, 21:33
- - Andavari   QUOTE (CiTay @ Oct 25 2002 - 04:51 PM)Andavar...   Nov 3 2002, 00:01
- - ProtectYaNeck36   would someone be able to point me to some papers w...   Nov 20 2002, 17:36
- - liekloo   heh. That's a cute guide   Nov 20 2002, 19:17
- - cmokruhl   How about some links for the latest Linux builds? ...   Nov 21 2002, 02:13
- - SK1   Case's MPC site of course...   Nov 21 2002, 02:29
- - Q!   QUOTE (user @ Jun 2 2002 - 05:41 PM)(What is ...   Nov 23 2002, 22:45
- - CiTay   QUOTE (Q! @ Nov 23 2002 - 10:45 PM)These ...   Nov 23 2002, 23:50
- - Dibrom   I could mirror the pages here on the HA server if ...   Nov 24 2002, 00:11
- - liekloo   QUOTE (liekloo @ 20Nov 10:17am)heh. That...   Dec 4 2002, 11:03
- - CiTay   QUOTE (liekloo @ Dec 4 2002 - 11:03 AM)I just...   Dec 4 2002, 14:35
- - boiling_ice2k4   uh oh, I keep getting an error "Can't pat...   Dec 8 2002, 21:17
- - Mr. Superbad   QUOTE (boiling_ice2k4 @ Dec 8 2002 - 12:17 PM...   Dec 11 2002, 21:26
- - CiTay   The links to the ReplayGain homepage are back... b...   Dec 23 2002, 20:54
- - liekloo   QUOTE (boiling_ice2k4 @ Dec 8 2002 - 09:17 PM...   Jan 10 2003, 14:23
- - CiTay   New Winamp 2.x plugin 0.98b at Case's page: Do...   Jan 19 2003, 18:24
- - MusicLover   Tagger-the Tagger that uses Tag 05.01.2003 Beta ...   Jan 22 2003, 06:03
- - David Racho   Which is recommended? with -xlevel or without? I p...   Jan 23 2003, 09:32
- - user   *** NOTICE *** --quality and --xlevel are safe to...   Jan 23 2003, 09:53
- - chrisgeleven   I noticed on Case's Musepack Page that there i...   Feb 8 2003, 01:31
- - David Nordin   You can't stay updated all the time 1.15j is ...   Feb 8 2003, 01:48
- - CiTay   QUOTE (chrisgeleven @ Feb 8 2003 - 01:31 AM)I...   Feb 8 2003, 01:52
- - user   2003-04-10 Added: CDIndexer : for CD-Audio & data...   Apr 10 2003, 15:18
- - alfa156   newbie question should i use both -extreme AND --...   Apr 16 2003, 07:36
- - mikeson   @alfa156: All you've asked for is in the begi...   Apr 16 2003, 09:48
- - user   newbie question should i use both -extreme AND --...   Apr 16 2003, 10:16
- - 2Bdecided   QUOTE (user @ Apr 4 2003 - 03:20 PM)QUOTE...   Apr 16 2003, 10:42
- - alfa156   thank you for your quick answer! Of course i ...   Apr 16 2003, 10:45
- - alfa156   hold on tight...here comes another newbie question...   Apr 24 2003, 14:48
- - Jan S.   QUOTE (alfa156 @ Apr 24 2003 - 03:48 PM)hold ...   Apr 24 2003, 15:11
- - alfa156   QUOTE (Jan S. @ Apr 24 2003 - 06:11 AM)QUOTE ...   Apr 25 2003, 09:51
- - ErikS   ReplayGain always adds Track gain. You choose whet...   Apr 25 2003, 11:19
- - alfa156   QUOTE (ErikS @ Apr 25 2003 - 02:19 AM)ReplayG...   Apr 25 2003, 14:43
- - Jan S.   QUOTE (alfa156 @ Apr 25 2003 - 03:43 PM)QUOTE...   Apr 25 2003, 16:09
- - alfa156   Thank you!   Apr 25 2003, 23:12
- - alfa156   when i replaygain my mpc files with the batch enco...   May 1 2003, 12:50
- - CiTay   QUOTE (alfa156 @ May 1 2003 - 01:50 PM)when i...   May 1 2003, 13:37
- - Moguta   Why is it recommended that ClipProtect be off in t...   May 25 2003, 00:21
- - CiTay   Redesign of the recommended settings: I tried to m...   Jun 10 2003, 14:00
- - CiTay   ... also fixed all broken links.   Jun 10 2003, 14:13
- - Garf   Maybe the mp3 settings thread should be modified s...   Jun 10 2003, 14:15
- - CiTay   QUOTE (Garf @ Jun 10 2003 - 03:15 PM)Maybe th...   Jun 10 2003, 14:18
- - GeSomeone   QUOTE (CiTay @ Jun 10 2003 - 03:00 PM)Provide...   Jun 10 2003, 14:33
- - Moguta   I have noticed with several of my albums, that Foo...   Jun 10 2003, 23:06
- - CiTay   QUOTE (Moguta @ Jun 11 2003 - 12:06 AM)Are yo...   Jun 10 2003, 23:16
- - DickD   QUOTE (Moguta @ Jun 10 2003 - 11:06 PM)I have...   Jun 11 2003, 14:17
- - Frozen Fire   ... also fixed all broken links. EncSpot link see...   Jun 11 2003, 14:31
- - CiTay   QUOTE (Frozen Fire @ Jun 11 2003 - 03:31 PM)E...   Jun 11 2003, 15:34
- - Moguta   Make sure it is obvious that the --xlevel command ...   Jun 29 2003, 04:52
- - rejj   QUOTE (user @ Jun 3 2002 - 01:41 AM)Additiona...   Jun 29 2003, 07:11
- - Pio2001   That's right, getting MPC, I went here to setu...   Jun 29 2003, 11:54
- - CiTay   QUOTE (rejj @ Jun 29 2003 - 08:11 AM)Why do y...   Jun 29 2003, 12:01
- - AstralStorm   Higher quality seems to transcode better. Maybe th...   Jun 29 2003, 12:29
- - zegilles   QUOTE (AstralStorm @ Jun 29 2003 - 03:29 AM)H...   Jun 30 2003, 10:13
- - user   ok, if some people write here their personal setti...   Jun 30 2003, 10:27
- - David Nordin   I prefer "mppenc --xlevel" myself, I fin...   Jun 30 2003, 10:39
- - kl33per   QUOTE Many people will cut&paste this line rig...   Jul 2 2003, 14:51
- - R.A.F.   QUOTE (user @ Jun 30 2003 - 11:27 AM)MPC --qu...   Jul 2 2003, 20:28
- - user   I have added to the How to about replaygain, the p...   Jul 7 2003, 10:34
- - CiTay   Added --xlevel to all recommendations, simplified ...   Jul 8 2003, 17:46
- - Pio2001   I Splitted the tag question to http://www.hydrogen...   Jul 24 2003, 11:34
- - Pio2001   Decode question splitted : http://www.hydrogenaudi...   Jul 26 2003, 01:16
- - xmixahlx   TO ADD: LINUX RESOURCES: players: XMMS, BMP, LAM...   Aug 1 2003, 09:16
- - Opeth   how do i on the fly encode with cdex? thx   Aug 5 2003, 12:48
- - CiTay   QUOTE (Opeth @ Aug 5 2003, 01:48 PM)how do i ...   Aug 5 2003, 13:51
- - Q!   QUOTE (CiTay @ Aug 5 2003, 03:51 PM)CD Drive ...   Aug 5 2003, 15:34
- - CiTay   QUOTE (Q! @ Aug 5 2003, 04:34 PM)that onl...   Aug 5 2003, 15:41
- - torok   The link to the Winamp plugin is dead.   Sep 8 2003, 06:20
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 27th May 2015 - 21:13
