13 Pages V  « < 11 12 13
foo_dsp_continuator, crossfading plugin
odyssey
post Oct 7 2011, 08:14
Post #301
Well 0.6.1 works fine here...
orangefx
post Dec 12 2011, 08:30
Post #302
WORKING HERE (after enabling in DSP)
foo 1.1.10 + win7 64bit
This post has been edited by orangefx: Dec 12 2011, 08:42
alias16384
post Feb 19 2012, 15:07
Post #303
Could anyone who has Continuator 0.61 kindly share it somehow?
mobyduck
post Feb 19 2012, 16:23
Post #304
There you go.
HTH.
Alessandro
alias16384
post Feb 24 2012, 16:50
Post #305
QUOTE (mobyduck @ Feb 19 2012, 16:23) *
There you go.
Thank you so much!!!
I thought this version can never be found, so I'm very grateful to you! smile.gif
I hope it will work in the future versions of foobar
as it does in current stable version (1.1.11). I have never heard smoother track transitions than that with Continuator!
grimpr
post Apr 12 2012, 00:45
Post #306
Can anybody reupload 0.6.1 version of Continuator?, links drop dead soon enough.
Rollin
post Apr 13 2012, 17:49
Post #307
QUOTE (grimpr @ Apr 12 2012, 03:45) *
foo_dsp_continuator 0.6.1
q-stankovic
post Apr 13 2012, 18:09
Post #308
This post has been edited by q-stankovic: Apr 13 2012, 18:09
h_o_m_e_r
post Apr 15 2012, 20:52
Post #309
Could anyone please reup the 0.6.1 Sourcecode and (english) dll?
Thanks, h_o_m_e_r
This post has been edited by h_o_m_e_r: Apr 15 2012, 20:52
db1989
post Apr 15 2012, 21:02
Post #310
QUOTE (q-stankovic @ Apr 13 2012, 18:09) *
Should I assume you mean that only a minority of people understand Russian? This ambiguously phrased sentence might be interpreted in another way that is not so agreeable.
grimpr
post Apr 23 2012, 21:30
Post #311
QUOTE (Rollin @ Apr 13 2012, 19:49) *
Thanks, but the english version of the dll would be more appreciated.
dwelx
post Sep 13 2012, 11:43
Post #312
QUOTE (grimpr @ Apr 23 2012, 23:30) *
Just in case: foo_dsp_continuator.dll 0.6.1 English.
rix81
post Feb 19 2013, 12:54
Post #313
does this plugin works with foobar 1.2.x ? I don't hear any difference when plugin enabled/disabled, what i'm doing not right?
grimpr
post Feb 20 2013, 16:24
Post #314
QUOTE (rix81 @ Feb 19 2013, 14:54) *
Yes it works. You just need to set it up right, try this settings for a start and make sure to activate Continuator in the DSP Manager.
grimpr
post Feb 20 2013, 16:27
Post #315
QUOTE (dwelx @ Sep 13 2012, 13:43) *
SgtHowie
post Mar 7 2013, 18:47
Post #316
The plugin works nicely for me with its default settings in Foobar2000 v1.2.3, but my configuration button is grayed out. Is this a known issue? Anything I can do to access the settings?
KevanGC
post Mar 22 2013, 08:09
Post #317
QUOTE (SgtHowie @ Mar 7 2013, 11:47) *
What you have to do is look above the DSP Manager section in the tree thing, Continuator doesn't use the configure button to open the settings, it puts it's own page there right above the dSP settings under playback. Hope I'm explaining this well enough.
And now a question, I'm trying to achieve certain results with this. I want it to NOT adjust the volume at all until the output level at the end of a track reaches about -10 DB. In other words, wait until that happens and start a new track, and not to care in the slightest about how much time is left in the finishing track.
But here's the problem, I pretty much am trying to get the ending track to just quickly drop off the face of the earth as the new one comes in. I've tried editing various settings and can get the new tracks to start at the correct times however can't get the fading out tracks to actually fade out. They just end without actually fading, causing two tracks to play at once for a couple seconds in some cases if the end of the song doesn't fade.
If anyone can recommend any settings I'd appreciate it! Now I have:
Buffer length is 12000.
Threshold (rms drop in dB) is 15.0
Disable track overlapping on seamless transition is not checked.
Crossfade Length is 12,000.
Empty buffer up to overlap point on track change is checked.
Adjust track length to Audio CD blocksize (588 Samples) is checked, though I doubt this matters.
Mode is overlap.
Fade-out mode is Const dB/s.
Fade-out length is 4500.
Fade-in mode is Const dB/s.
Override mode with CONTINUATOR-tag is not checked (I have no clue what this is for).
Fade-out target (dB) is -48
Fade-in target DB is -6.
Only apply when audio is up to the end is checked.
Thanks for any help / suggestions!
Simon4ik
post May 19 2014, 14:23
Post #318
VERY IMPORTANT THING: PUT THE CONTINUATOR IN THE END OF THE LIST OF ACTIVE DSPS OTHERWISE YOU CAN HEAR GLITCHES!
OUTPUT BUFFER LENGTH MUST BE 1000 MS!
NOW TRY THIS:
1) mode 1 (soft)
Mode: Overlap
Buffer lenght: 14000 ms
Threshold: 42 db
Disable track overlapping on seamsless transition is uncheked
Fade out curve - Linear
Fade out lenght - 11000 ms
Fade in curve - Linear
Fade in length - 3000 ms
Adjust track leght to Audio Cd blocksize (588 samles) is checked.
2) mode 2 (advanced)
Mode: Overlap
Buffer lenght: 8000 ms
Threshold: 24 db
Fade out curve - Const
Fade out lenght - 6000 ms
Fade target -54 db
Fade in curve - S-curve
Fade in length - 2000 ms
Steepness - 0.33
This post has been edited by Simon4ik: May 19 2014, 14:51
RSS Lo-Fi Version Time is now: 27th January 2015 - 00:14
