foo_dsp_continuator, crossfading plugin
Cpt. Footure
post Feb 13 2004, 23:42
try my (advanced) crossfading plugin 'Continuator' with following features:
- threshold-controlled start of new track
- force current track to fade-out with desired rate
- disable crossfading for seamless track transitions (may not work with mp3, ogg and wav should be fine)
- force tracklength to be multiple of Audio CD blocksize (588 samples), useful for creation of gapless mix cds
enjoy!
Cpt. Footure
post Mar 29 2004, 20:32
@ CyberSnooP and Smiff
It doens't always detect seamless transitions with my MP3s
after reading the post above, i don't think continuator ever detects gapless mp3s for me, it always crossfades, any ideas why? yes i have "disable overlapping..." selected.
Detecting seamless transitions with mp3's is somewhat tricky, because the encoding and decoding process adds new signal samples (a gap) that destroy the seamless transition. You (i.e. me) have to guess where the original ending and starting points have been and then guess again if that was a seamless transition.
Anyway, i know there is room for improvement with my seamless transition detecting, but i don't have much time now, sorry.
@CyberSnooP
there will be a skip near the end of the that track
try a longer output buffer length (preferences->playback->output)
@ Lyx
Maybe a simple way for continuator to fix this could be to even if seamless transition is detected, a small amount of frames gets overlapped?
Yes, that could fix it, but again, no time yet.
- Cpt. Footure   foo_dsp_continuator   Feb 13 2004, 23:42
- - kelesh   it caused a crash within the first 5 songs i tried...   Feb 14 2004, 03:02
- - ditto_n   Crashed while testing.. between two songs that fa...   Feb 14 2004, 03:34
- - Cpt. Footure   Hi, new version (0.1.2) uploaded. bye   Feb 15 2004, 21:17
- - kelesh   this is awesome. Thank you Cpt. Footure!   Feb 15 2004, 23:01
- - Lyx   version 0.1.2 crash happened when skipping forwar...   Feb 16 2004, 01:05
- - kelesh   is gap killer necessary if you are using continuat...   Feb 16 2004, 02:10
- - Cpt. Footure   QUOTE is gap killer necessary if you are using con...   Feb 16 2004, 08:39
- - Lyx   the above crashlog isn't caused by gap killer....   Feb 16 2004, 15:05
- - tom_vienna_at   Finally a crossfader that seems to work properly -...   Feb 16 2004, 15:29
- - Cpt. Footure   Hi, version 0.1.3 is available. This should fix th...   Feb 16 2004, 20:57
- - Rogacz   Trully awesome.   Feb 16 2004, 21:13
- - canyoneroboy   Great job! Just what I needed.   Feb 17 2004, 04:54
- - spase   Can you add gapless detection for FLAC files? Or ...   Feb 17 2004, 07:02
- - Cpt. Footure   There should be no difference regarding gapless-de...   Feb 17 2004, 20:54
- - Lyx   the plugin still has some problems on my system wi...   Feb 23 2004, 21:49
- - rectangle   QUOTE (Lyx @ Feb 23 2004, 12:49 PM)the plugin...   Feb 23 2004, 22:04
- - kelesh   occasionally, while crossfading, i have 1/2 second...   Feb 23 2004, 22:16
- - rectangle   QUOTE (kelesh @ Feb 23 2004, 01:16 PM)occasio...   Feb 23 2004, 22:21
- - kelesh   QUOTE (rectangle @ Feb 23 2004, 04:21 PM)QUOT...   Feb 23 2004, 23:58
- - tom_vienna_at   QUOTE (kelesh @ Feb 23 2004, 10:16 PM)occasio...   Feb 24 2004, 09:33
- - Lyx   QUOTE Plus, occasionally, song A has a moment of s...   Feb 24 2004, 12:30
- - Cpt. Footure   QUOTE Song A would end, and right in the first sec...   Feb 24 2004, 14:51
- - tom_vienna_at   QUOTE (Cpt. Footure @ Feb 24 2004, 02:51 PM)Q...   Feb 24 2004, 18:46
- - Cpt. Footure   Finding (really) stupid bug... Banging head agains...   Feb 24 2004, 20:18
- - kelesh   what bug did this fix? did it fix the cracking/po...   Feb 25 2004, 02:04
- - rectangle   QUOTE (Cpt. Footure @ Feb 24 2004, 11:18 AM)F...   Feb 25 2004, 06:26
- - rectangle   O-Oh! I've just got this failure.txt ...   Feb 25 2004, 08:03
- - kamien001   Cool plugin ...   Feb 25 2004, 11:35
- - Cpt. Footure   QUOTE (kamien001 Posted on Feb 25 2004 @ 11:...   Feb 25 2004, 23:55
- - Melomane   Cpt. Footure, thank you for your Continuator! ...   Mar 1 2004, 01:29
- - Cpt. Footure   QUOTE Question, what is the function of "empt...   Mar 1 2004, 20:55
- - Lyx   hmm, i still get a short (0,3 - 0,7 sec.) "pl...   Mar 1 2004, 22:21
- - Cpt. Footure   i will try to lower the cpu consumption on track c...   Mar 2 2004, 20:20
- - Lyx   you are probably right about cpu consumption, sinc...   Mar 2 2004, 20:41
- - Cpt. Footure   new version (0.1.7) uploaded with reduced cpu cons...   Mar 2 2004, 21:36
- - Lyx   QUOTE Illegal operation: Code: C0000005h, flags: 0...   Mar 4 2004, 21:02
- - Cpt. Footure   QUOTE (Lyx on Mar 4 2004 @ 09:02 PM)crash ha...   Mar 5 2004, 21:52
- - Lyx   works great now - thank you Feature request: Wou...   Mar 10 2004, 23:47
- - Cpt. Footure   QUOTE (Lyx @ Mar 10 2004, 11:47 PM)Feature re...   Mar 11 2004, 21:35
- - Melomane   WONDERFUL!   Mar 11 2004, 22:24
- - Canar   Okay... I've been trying to write a crossfaded...   Mar 17 2004, 04:29
- - tom_vienna_at   QUOTE (Canar @ Mar 17 2004, 04:29 AM)Okay... ...   Mar 18 2004, 09:25
- - Enig123   Footure, I have tested your great plugin and tried...   Mar 19 2004, 05:11
- - Cpt. Footure   QUOTE (tom_vienna_at @ Mar 18 2004, 09:25 AM)...   Mar 19 2004, 10:00
- - Cpt. Footure   QUOTE (tom_vienna_at @ Mar 18 2004, 09:25 AM)...   Mar 19 2004, 10:06
- - tom_vienna_at   QUOTE (Cpt. Footure @ Mar 19 2004, 11:06 AM)Q...   Mar 19 2004, 11:59
- - Melomane   QUOTE (Canar @ Mar 17 2004, 04:29 AM)Okay... ...   Mar 19 2004, 19:20
- - Lyx   i just ripped a seamless ambient album and encoded...   Mar 20 2004, 06:16
- - Cpt. Footure   QUOTE (Cpt. Footure @ Mar 19 2004, 10:00 AM)Q...   Mar 21 2004, 20:52
- - CyberSnooP   Would it be possible to define some menu-actions f...   Mar 23 2004, 09:41
- - Smiff   um I think i have a bug to report: if there is no...   Mar 28 2004, 03:18
- - Cpt. Footure   @ CyberSnooP and Smiff QUOTE It doens't always...   Mar 29 2004, 20:32
|- - kode54   QUOTE (Cpt. Footure @ Mar 29 2004, 11:32 AM)D...   Jul 27 2004, 09:43
- - Sylt-Tomten   Is it possible to make it crossfade when changing ...   Jul 26 2004, 21:16
- - Lyx   not with foo-continuator - but with cpt footure...   Jul 26 2004, 21:31
|- - Cpt. Footure   QUOTE (Lyx @ Jul 26 2004, 10:31 PM)but with c...   Jul 27 2004, 08:06
- - Sylt-Tomten   Okey, thanks for the quick answer   Jul 26 2004, 21:42
- - Cpt. Footure   yup   Jul 27 2004, 19:37
- - ears   Cpt., Great work--I've been looking for somet...   Aug 13 2004, 03:13
- - Cpt. Footure   Hi, sorry for the delay, i'm quite busy these ...   Aug 16 2004, 14:57
- - Cpt. Footure   Hi, fixed the last-track-skipping-near-end-bug: do...   Aug 17 2004, 19:51
- - ludox   Thanks for the update. The new plugin is on the ...   Aug 20 2004, 20:11
- - Squeller   It crashes very often between 2 tracks: the first ...   Aug 22 2004, 14:10
|- - Cpt. Footure   QUOTE (CyberSnooP @ Mar 23 2004, 10:41 AM)Wou...   Aug 31 2004, 21:05
- - CarlosTheTackle   Wow. This is a great plug-in. It was the thing tha...   Nov 16 2004, 23:04
- - Cpt. Footure   Hi, good to hear that i could help to save another...   Nov 22 2004, 20:11
- - PlazzTT   Great plugin! I'd like to see more updates...   Dec 18 2004, 19:30
|- - kelesh   QUOTE (PlazzTT @ Dec 18 2004, 01:30 PM)Great ...   Jan 26 2005, 21:52
|- - aharden   QUOTE (kelesh @ Jan 26 2005, 03:52 PM)QUOTE (...   Feb 5 2005, 14:07
- - Zeugma   First of all, great job, Cpt. Footure ! Your p...   Feb 11 2005, 15:19
|- - aharden   QUOTE (Zeugma @ Feb 11 2005, 09:19 AM)aharden...   Feb 13 2005, 13:50
- - CarlosTheTackle   Small request: The current command to enable this ...   Feb 13 2005, 13:53
- - Lyx   Actually, having a toggle is easier for hotkeys, b...   Feb 13 2005, 16:23
|- - CarlosTheTackle   QUOTE (Lyx @ Feb 14 2005, 04:23 AM)Actually, ...   Feb 13 2005, 21:38
- - Cpt. Footure   Hi guys, version 0.2.4 is uploaded: - added enable...   May 2 2005, 17:18
|- - aharden   QUOTE (Cpt. Footure @ May 2 2005, 11:18 AM)Hi...   May 2 2005, 20:23
|- - CarlosTheTackle   QUOTE (Cpt. Footure @ May 3 2005, 05:18 AM)Hi...   May 5 2005, 03:37
- - Lyx   thanks for the update. Here's an idea which i...   May 2 2005, 18:45
- - Zeugma   Heh, thanks for thinking about us again Cpt. Footu...   May 2 2005, 19:46
|- - Cpt. Footure   QUOTE (Zeugma @ May 2 2005, 08:46 PM)Heh, tha...   May 4 2005, 08:04
|- - Squeller   QUOTE (Cpt. Footure @ May 3 2005, 11:04 PM)@s...   May 4 2005, 08:37
||- - Cpt. Footure   QUOTE (Squeller @ May 4 2005, 09:37 AM)I know...   May 4 2005, 08:46
||- - Cpt. Footure   QUOTE (Squeller @ May 4 2005, 09:37 AM)Thanks...   May 11 2005, 09:50
|- - Mr_Rabid_Teddybear   QUOTE (Cpt. Footure @ May 3 2005, 11:04 PM)bu...   May 4 2005, 15:41
||- - The Link   QUOTE (Mr_Rabid_Teddybear @ May 4 2005, 03:41...   May 4 2005, 15:46
|- - Zeugma   QUOTE (Cpt. Footure @ May 4 2005, 01:04 AM)QU...   May 4 2005, 17:26
|- - Cpt. Footure   QUOTE (Zeugma @ May 4 2005, 06:26 PM)Hehe ^^...   May 5 2005, 08:02
- - Squeller   I cannot start fb2k with this. I'm on w2ksp4. ...   May 3 2005, 15:14
- - Lyx   Refined version of the continuator-tag proposal: ...   May 4 2005, 15:14
|- - Squeller   QUOTE (Lyx @ May 4 2005, 06:14 AM)CODECONTINU...   May 5 2005, 07:51
||- - Lyx   QUOTE (Squeller @ May 5 2005, 08:51 AM)We...   May 5 2005, 15:45
||- - Squeller   QUOTE (Lyx @ May 5 2005, 06:45 AM)Not necessa...   May 5 2005, 16:54
|- - Cpt. Footure   QUOTE (Lyx @ May 4 2005, 04:14 PM)Refined ver...   May 5 2005, 08:06
- - Lance Uppercut   I don't know what's up with my settings bu...   May 5 2005, 02:53
|- - Cpt. Footure   QUOTE (Lance Uppercut @ May 5 2005, 03:53 AM)...   May 5 2005, 07:57
|- - Lance Uppercut   QUOTE btw: At the moment Continuator does no fade-...   May 5 2005, 10:28
- - kjoonlee   I wonder if I'm the only one who's not att...   May 11 2005, 10:48
|- - Lyx   QUOTE (kjoonlee @ May 11 2005, 11:48 AM)I won...   May 11 2005, 12:02
- - kjoonlee   /me shrugs. You have the masstagger, so if you en...   May 11 2005, 12:34
4 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 1st February 2015 - 14:04
