foo_dsp_continuator, crossfading plugin
Cpt. Footure
post Feb 13 2004, 23:42
try my (advanced) crossfading plugin 'Continuator' with following features:
- threshold-controlled start of new track
- force current track to fade-out with desired rate
- disable crossfading for seamless track transitions (may not work with mp3, ogg and wav should be fine)
- force tracklength to be multiple of Audio CD blocksize (588 samples), useful for creation of gapless mix cds
enjoy!
Cpt. Footure
post Feb 16 2004, 20:57
version 0.1.3 is available. This should fix the skip-to-end crashes.
bye
- Cpt. Footure   foo_dsp_continuator   Feb 13 2004, 23:42
- - kelesh   it caused a crash within the first 5 songs i tried...   Feb 14 2004, 03:02
- - ditto_n   Crashed while testing.. between two songs that fa...   Feb 14 2004, 03:34
- - Cpt. Footure   Hi, new version (0.1.2) uploaded. bye   Feb 15 2004, 21:17
- - kelesh   this is awesome. Thank you Cpt. Footure!   Feb 15 2004, 23:01
- - Lyx   version 0.1.2 crash happened when skipping forwar...   Feb 16 2004, 01:05
- - kelesh   is gap killer necessary if you are using continuat...   Feb 16 2004, 02:10
- - Cpt. Footure   QUOTE is gap killer necessary if you are using con...   Feb 16 2004, 08:39
- - Lyx   the above crashlog isn't caused by gap killer....   Feb 16 2004, 15:05
- - tom_vienna_at   Finally a crossfader that seems to work properly -...   Feb 16 2004, 15:29
- - Cpt. Footure   Hi, version 0.1.3 is available. This should fix th...   Feb 16 2004, 20:57
- - Rogacz   Trully awesome.   Feb 16 2004, 21:13
- - canyoneroboy   Great job! Just what I needed.   Feb 17 2004, 04:54
- - spase   Can you add gapless detection for FLAC files? Or ...   Feb 17 2004, 07:02
- - Cpt. Footure   There should be no difference regarding gapless-de...   Feb 17 2004, 20:54
- - Lyx   the plugin still has some problems on my system wi...   Feb 23 2004, 21:49
- - rectangle   QUOTE (Lyx @ Feb 23 2004, 12:49 PM)the plugin...   Feb 23 2004, 22:04
- - kelesh   occasionally, while crossfading, i have 1/2 second...   Feb 23 2004, 22:16
- - rectangle   QUOTE (kelesh @ Feb 23 2004, 01:16 PM)occasio...   Feb 23 2004, 22:21
- - kelesh   QUOTE (rectangle @ Feb 23 2004, 04:21 PM)QUOT...   Feb 23 2004, 23:58
- - tom_vienna_at   QUOTE (kelesh @ Feb 23 2004, 10:16 PM)occasio...   Feb 24 2004, 09:33
- - Lyx   QUOTE Plus, occasionally, song A has a moment of s...   Feb 24 2004, 12:30
- - Cpt. Footure   QUOTE Song A would end, and right in the first sec...   Feb 24 2004, 14:51
- - tom_vienna_at   QUOTE (Cpt. Footure @ Feb 24 2004, 02:51 PM)Q...   Feb 24 2004, 18:46
- - Cpt. Footure   Finding (really) stupid bug... Banging head agains...   Feb 24 2004, 20:18
- - kelesh   what bug did this fix? did it fix the cracking/po...   Feb 25 2004, 02:04
- - rectangle   QUOTE (Cpt. Footure @ Feb 24 2004, 11:18 AM)F...   Feb 25 2004, 06:26
- - rectangle   O-Oh! I've just got this failure.txt ...   Feb 25 2004, 08:03
- - kamien001   Cool plugin ...   Feb 25 2004, 11:35
- - Cpt. Footure   QUOTE (kamien001 Posted on Feb 25 2004 @ 11:...   Feb 25 2004, 23:55
- - Melomane   Cpt. Footure, thank you for your Continuator! ...   Mar 1 2004, 01:29
- - Cpt. Footure   QUOTE Question, what is the function of "empt...   Mar 1 2004, 20:55
- - Lyx   hmm, i still get a short (0,3 - 0,7 sec.) "pl...   Mar 1 2004, 22:21
- - Cpt. Footure   i will try to lower the cpu consumption on track c...   Mar 2 2004, 20:20
- - Lyx   you are probably right about cpu consumption, sinc...   Mar 2 2004, 20:41
- - Cpt. Footure   new version (0.1.7) uploaded with reduced cpu cons...   Mar 2 2004, 21:36
- - Lyx   QUOTE Illegal operation: Code: C0000005h, flags: 0...   Mar 4 2004, 21:02
- - Cpt. Footure   QUOTE (Lyx on Mar 4 2004 @ 09:02 PM)crash ha...   Mar 5 2004, 21:52
- - Lyx   works great now - thank you Feature request: Wou...   Mar 10 2004, 23:47
- - Cpt. Footure   QUOTE (Lyx @ Mar 10 2004, 11:47 PM)Feature re...   Mar 11 2004, 21:35
- - Melomane   WONDERFUL!   Mar 11 2004, 22:24
- - Canar   Okay... I've been trying to write a crossfaded...   Mar 17 2004, 04:29
- - tom_vienna_at   QUOTE (Canar @ Mar 17 2004, 04:29 AM)Okay... ...   Mar 18 2004, 09:25
- - Enig123   Footure, I have tested your great plugin and tried...   Mar 19 2004, 05:11
- - Cpt. Footure   QUOTE (tom_vienna_at @ Mar 18 2004, 09:25 AM)...   Mar 19 2004, 10:00
- - Cpt. Footure   QUOTE (tom_vienna_at @ Mar 18 2004, 09:25 AM)...   Mar 19 2004, 10:06
- - tom_vienna_at   QUOTE (Cpt. Footure @ Mar 19 2004, 11:06 AM)Q...   Mar 19 2004, 11:59
- - Melomane   QUOTE (Canar @ Mar 17 2004, 04:29 AM)Okay... ...   Mar 19 2004, 19:20
- - Lyx   i just ripped a seamless ambient album and encoded...   Mar 20 2004, 06:16
- - Cpt. Footure   QUOTE (Cpt. Footure @ Mar 19 2004, 10:00 AM)Q...   Mar 21 2004, 20:52
- - CyberSnooP   Would it be possible to define some menu-actions f...   Mar 23 2004, 09:41
- - Smiff   um I think i have a bug to report: if there is no...   Mar 28 2004, 03:18
- - Cpt. Footure   @ CyberSnooP and Smiff QUOTE It doens't always...   Mar 29 2004, 20:32
|- - kode54   QUOTE (Cpt. Footure @ Mar 29 2004, 11:32 AM)D...   Jul 27 2004, 09:43
- - Sylt-Tomten   Is it possible to make it crossfade when changing ...   Jul 26 2004, 21:16
- - Lyx   not with foo-continuator - but with cpt footure...   Jul 26 2004, 21:31
|- - Cpt. Footure   QUOTE (Lyx @ Jul 26 2004, 10:31 PM)but with c...   Jul 27 2004, 08:06
- - Sylt-Tomten   Okey, thanks for the quick answer   Jul 26 2004, 21:42
- - Cpt. Footure   yup   Jul 27 2004, 19:37
- - ears   Cpt., Great work--I've been looking for somet...   Aug 13 2004, 03:13
- - Cpt. Footure   Hi, sorry for the delay, i'm quite busy these ...   Aug 16 2004, 14:57
- - Cpt. Footure   Hi, fixed the last-track-skipping-near-end-bug: do...   Aug 17 2004, 19:51
- - ludox   Thanks for the update. The new plugin is on the ...   Aug 20 2004, 20:11
- - Squeller   It crashes very often between 2 tracks: the first ...   Aug 22 2004, 14:10
|- - Cpt. Footure   QUOTE (CyberSnooP @ Mar 23 2004, 10:41 AM)Wou...   Aug 31 2004, 21:05
- - CarlosTheTackle   Wow. This is a great plug-in. It was the thing tha...   Nov 16 2004, 23:04
- - Cpt. Footure   Hi, good to hear that i could help to save another...   Nov 22 2004, 20:11
- - PlazzTT   Great plugin! I'd like to see more updates...   Dec 18 2004, 19:30
|- - kelesh   QUOTE (PlazzTT @ Dec 18 2004, 01:30 PM)Great ...   Jan 26 2005, 21:52
|- - aharden   QUOTE (kelesh @ Jan 26 2005, 03:52 PM)QUOTE (...   Feb 5 2005, 14:07
- - Zeugma   First of all, great job, Cpt. Footure ! Your p...   Feb 11 2005, 15:19
|- - aharden   QUOTE (Zeugma @ Feb 11 2005, 09:19 AM)aharden...   Feb 13 2005, 13:50
- - CarlosTheTackle   Small request: The current command to enable this ...   Feb 13 2005, 13:53
- - Lyx   Actually, having a toggle is easier for hotkeys, b...   Feb 13 2005, 16:23
|- - CarlosTheTackle   QUOTE (Lyx @ Feb 14 2005, 04:23 AM)Actually, ...   Feb 13 2005, 21:38
- - Cpt. Footure   Hi guys, version 0.2.4 is uploaded: - added enable...   May 2 2005, 17:18
|- - aharden   QUOTE (Cpt. Footure @ May 2 2005, 11:18 AM)Hi...   May 2 2005, 20:23
|- - CarlosTheTackle   QUOTE (Cpt. Footure @ May 3 2005, 05:18 AM)Hi...   May 5 2005, 03:37
- - Lyx   thanks for the update. Here's an idea which i...   May 2 2005, 18:45
- - Zeugma   Heh, thanks for thinking about us again Cpt. Footu...   May 2 2005, 19:46
|- - Cpt. Footure   QUOTE (Zeugma @ May 2 2005, 08:46 PM)Heh, tha...   May 4 2005, 08:04
|- - Squeller   QUOTE (Cpt. Footure @ May 3 2005, 11:04 PM)@s...   May 4 2005, 08:37
||- - Cpt. Footure   QUOTE (Squeller @ May 4 2005, 09:37 AM)I know...   May 4 2005, 08:46
||- - Cpt. Footure   QUOTE (Squeller @ May 4 2005, 09:37 AM)Thanks...   May 11 2005, 09:50
|- - Mr_Rabid_Teddybear   QUOTE (Cpt. Footure @ May 3 2005, 11:04 PM)bu...   May 4 2005, 15:41
||- - The Link   QUOTE (Mr_Rabid_Teddybear @ May 4 2005, 03:41...   May 4 2005, 15:46
|- - Zeugma   QUOTE (Cpt. Footure @ May 4 2005, 01:04 AM)QU...   May 4 2005, 17:26
|- - Cpt. Footure   QUOTE (Zeugma @ May 4 2005, 06:26 PM)Hehe ^^...   May 5 2005, 08:02
- - Squeller   I cannot start fb2k with this. I'm on w2ksp4. ...   May 3 2005, 15:14
- - Lyx   Refined version of the continuator-tag proposal: ...   May 4 2005, 15:14
|- - Squeller   QUOTE (Lyx @ May 4 2005, 06:14 AM)CODECONTINU...   May 5 2005, 07:51
||- - Lyx   QUOTE (Squeller @ May 5 2005, 08:51 AM)We...   May 5 2005, 15:45
||- - Squeller   QUOTE (Lyx @ May 5 2005, 06:45 AM)Not necessa...   May 5 2005, 16:54
|- - Cpt. Footure   QUOTE (Lyx @ May 4 2005, 04:14 PM)Refined ver...   May 5 2005, 08:06
- - Lance Uppercut   I don't know what's up with my settings bu...   May 5 2005, 02:53
|- - Cpt. Footure   QUOTE (Lance Uppercut @ May 5 2005, 03:53 AM)...   May 5 2005, 07:57
|- - Lance Uppercut   QUOTE btw: At the moment Continuator does no fade-...   May 5 2005, 10:28
- - kjoonlee   I wonder if I'm the only one who's not att...   May 11 2005, 10:48
|- - Lyx   QUOTE (kjoonlee @ May 11 2005, 11:48 AM)I won...   May 11 2005, 12:02
- - kjoonlee   /me shrugs. You have the masstagger, so if you en...   May 11 2005, 12:34
4 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 29th May 2015 - 22:40
