mppenc 1.04, mppdec 1.04, WinAMP plugins 0.94, XMMS plugin 0
Case
post May 27 2002, 23:05
Group: Developer (Donating)
* Files with PNS are marked as SV 7.1 to prevent confusion with old decoders
* URL for download displayed on unknown StreamVersions
* Bug fixes in XMMS
* mppenc now needs less bitrate while at least maintaining the quality
* smart help screens for mppenc
* Changed overwrite behavior of mppenc
http://www.uni-jena.de/~pfk/MPP/
* Update: Improved 1.06 available *
CiTay
post Jun 1 2002, 02:30
Administrator
Group: Admin
ABX test, equipment: Hercules GTXP, AKG K-290 headphones, PCABX 1.7.5 (BTW it looks awful with Windows XP's "Luna" GUI, somebody should fix that).
I used the "--radio" profile for all tests, to get usable results (--standard is already too good sometimes).
Sample: "SmashingSample89.wav"
mppenc 1.0, 139.8 kbps: 15/16. Cymbal in the right channel is overemphasized.
mppenc 1.04, 138.4 kbps: 14/16. Same effect, slightly less distinct. I would even say that this sounds a bit better than 1.0.
Sample: "dogwhistle.wav"
mppenc 1.0, 129.7 kbps: 16/16. The whistle tone appears to be lower. Nervous chirping of the noise.
mppenc 1.04, 123.4 kbps: 16/16. Same effect. Again it sounds a little more pleasant to my ears.
I can't test longer in a row. Odd results, the opposite of what i expected. Of course these are only two samples, and the bitrate difference isn't immense. But so far i couldn't ask for more than maintaining the quality level of 1.0, and this seems to have worked.
- Case   mppenc 1.04, mppdec 1.04, WinAMP plugins 0.94, XMMS plugin 0   May 27 2002, 23:05
- - Case   Compiled Windows binaries for 16...32 bit decoders...   May 27 2002, 23:23
- - CiTay   There seems to be a weird little bug in the latest...   May 28 2002, 00:07
- - Case   QUOTE Originally posted by CiTay In the "Info" ta...   May 28 2002, 00:13
- - gdougherty   Is it possible to directly convert older files int...   May 28 2002, 00:57
- - CiTay   QUOTE Originally posted by Case Thanks for repor...   May 28 2002, 01:33
- - Ruse   Chemical Brothers "Dig Your Own Hole" - Electronic...   May 28 2002, 01:50
- - macdaddy   My mileage is a little less impressive, but I use ...   May 28 2002, 03:04
- - experttech   QUOTE Originally posted by Ruse mppenc 1.02 --xt...   May 28 2002, 04:20
- - rjamorim   http://www.hydrogenaudio.org/forums/showth...15496...   May 28 2002, 04:41
- - macdaddy   QUOTE Originally posted by rjamorim http://www.hy...   May 28 2002, 05:03
- - rjamorim   QUOTE Originally posted by macdaddy Is that why ...   May 28 2002, 05:14
- - Ruse   QUOTE Originally posted by rjamorim http://www.hy...   May 28 2002, 05:30
- - rjamorim   QUOTE Originally posted by Ruse Trouble is in th...   May 28 2002, 05:33
- - Dibrom   QUOTE Originally posted by Ruse Chemical Brothers...   May 28 2002, 10:04
- - Q!   > Anyone checked out the bitrate differences fo...   May 28 2002, 13:52
- - CiTay   QUOTE Originally posted by Q! (just one track, h...   May 28 2002, 14:01
- - Q!   Thanks! A-ha 'Lifelines ' (--standard) 1.02 - 76....   May 28 2002, 17:15
- - Frank Klemm   QUOTE Originally posted by CiTay Download EncSp...   May 28 2002, 17:23
- - CiTay   Yes, seems like this would also work. But what's t...   May 28 2002, 17:46
- - Gecko   Is mppenc 1.04 based on one of the four versions o...   May 28 2002, 18:20
- - Frank Klemm   QUOTE Originally posted by CiTay Yes, seems like ...   May 28 2002, 22:26
- - NickSD   No one ever answered the question asked before... ...   May 29 2002, 00:48
- - JohnV   The primary question raised again by NickSD was st...   May 29 2002, 02:07
- - experttech   I think this is deviating too much from the main t...   May 29 2002, 08:52
- - Dibrom   Cleaned up the thread and moved the OT stuff here.   May 29 2002, 22:41
- - m0rbidini   Having read two pages of this topic I've seen noth...   May 30 2002, 14:09
- - Dezibel   for me mppenc version 1.02 sounds a little bit bet...   May 30 2002, 14:22
- - cmagic   I made a few test with mppenc 1.04 and one of them...   May 30 2002, 14:31
- - Hanky   This bitrate drops in the 20% range make me kind o...   May 30 2002, 14:44
- - -=Ducky=-   QUOTE Originally posted by Case     *...   May 30 2002, 15:33
- - AgentMil   I do seem to recall that one of the features of St...   May 30 2002, 17:38
- - Frank Klemm   QUOTE Originally posted by AgentMil I do seem to ...   May 30 2002, 20:34
- - Jan S.   most ppl here will care less about low bitrates an...   May 30 2002, 21:00
- - mithrandir   Unfortunately, I am relying completely on subjecti...   May 31 2002, 05:43
- - Dibrom   QUOTE Originally posted by mithrandir Unfortunate...   May 31 2002, 05:51
- - PoisonDan   QUOTE Originally posted by Dibrom For what it's ...   May 31 2002, 08:11
- - Jan S.   QUOTE It almost seems as if he is hiding something...   May 31 2002, 09:12
- - guruboolez   I tried to compare 1.02 and 1.04 (on recently enco...   May 31 2002, 09:25
- - AgentMil   Thanks Frank for clearing what I thought was the r...   May 31 2002, 09:41
- - ssamadhi97   QUOTE Originally posted by Jan S. I say I would ...   May 31 2002, 12:38
- - mithrandir   QUOTE Originally posted by Dibrom Hrmm.. do you ...   May 31 2002, 16:19
- - -=Ducky=-   What I'm wondering is, if there wasn't any reducti...   May 31 2002, 16:42
- - CiTay   After (quite theoretical, i admit) inverse-mix-pas...   May 31 2002, 17:32
- - Dibrom   QUOTE Originally posted by -=Ducky=- What I'm won...   May 31 2002, 17:37
- - CiTay   QUOTE Originally posted by Dibrom I wouldn't rea...   May 31 2002, 17:47
- - Frank Klemm   QUOTE Originally posted by cmagic I made a few te...   May 31 2002, 21:26
- - cmagic   QUOTE Originally posted by Frank Klemm Reducing...   May 31 2002, 22:17
- - CiTay   ABX test, equipment: Hercules GTXP, AKG K-290 head...   Jun 1 2002, 02:30
- - Garf   GCC 3.1 cannot compile the XMMS plugin correctly a...   Jun 1 2002, 10:27
- - Frank Klemm   QUOTE Originally posted by Garf GCC 3.1 cannot co...   Jun 1 2002, 14:20
- - Frank Klemm   QUOTE Originally posted by CiTay ABX test, equipm...   Jun 1 2002, 14:25
- - Garf   QUOTE Originally posted by Frank Klemm Test mpp...   Jun 1 2002, 15:06
- - Frank Klemm   QUOTE Originally posted by Garf mppdec works. I...   Jun 1 2002, 17:41
- - jeffster   The XMMS plugin 0.94 seems to be an empty archive,...   Jun 2 2002, 02:45
- - rjamorim   QUOTE Originally posted by jeffster The XMMS plug...   Jun 2 2002, 03:02
- - jeffster   QUOTE Originally posted by rjamorim Works fine ...   Jun 2 2002, 05:18
- - Frank Klemm   QUOTE Originally posted by jeffster Hi Roberto,...   Jun 2 2002, 11:34
- - Dibrom   QUOTE Originally posted by jeffster if you can po...   Jun 2 2002, 11:39
- - jeffster   QUOTE Originally posted by Dibrom Just download...   Jun 2 2002, 15:22
- - Garf   QUOTE Originally posted by Frank Klemm I have p...   Jun 2 2002, 21:11
- - Garf   The file I changed was mpp.h, not config.h. There ...   Jun 3 2002, 21:03
- - Madrigal   This is getting crazy. Aside from its phenomenal ...   Jun 13 2002, 15:07
- - CiTay   QUOTE Originally posted by Madrigal I have settl...   Jun 13 2002, 15:21
- - Madrigal   QUOTE Originally posted by CiTay I suggest you g...   Jun 13 2002, 21:54
- - AgentMil   IMHO MusePack Encoder v1.04, provides the same qua...   Jun 14 2002, 04:06
RSS Lo-Fi Version Time is now: 2nd August 2015 - 20:14
