10 Pages V  < 1 2 3 4 > »
Otachan's in_!mpg123, Alternative Winamp mp3 playback plugin
witt
post Mar 21 2004, 22:18
Post #26
mp3infp ver.2.44 released. (bugfix)
This post has been edited by witt: Mar 21 2004, 22:19
foobar2000 Wiki for Japanese Users
http://foobar.s53.xrea.com/fbwiki/
NatGun
post Mar 22 2004, 05:04
Post #27
the gapless playback doesnt seem to work for me, is there an option i need to select to enable it?
amano
post Mar 22 2004, 05:58
Post #28
*sigh*
maybe search the forums?
or activate sufficient "buffer ahead on track change" in out_ds?
kjoonlee
post Mar 22 2004, 06:12
Post #29
And there's one more thing: do the files have the correct encoder delay and correct encoder padding info written in their LAME tags?
Only then will the files be decoded gaplessly. Files encoded with recent versions of LAME, for example, will do nicely.
http://blacksun.ivyro.net/vorbis/vorbisfaq.htm
NatGun
post Mar 22 2004, 16:32
Post #30
i encode with 3.90.3 and the gapless decoding works fine in foobar. i dont get it.
kjoonlee
post Mar 22 2004, 16:49
Post #31
Then are you sure you're using "buffer ahead on track change"? How long is your buffer?
This post has been edited by kjoonlee: Mar 22 2004, 16:50
amano
post Mar 22 2004, 17:08
Post #32
And are you sure, that in_mpg123 is in use???
You have to remove/rename in_mp3 or remove the MP3 extension from in_MP3!
If both in_mpg123 and in_mp3 are in the plugins folder, Winamp will always use in_mp3!
You can test it out when choosing "File Info" in the PL.
EDIT: BTW, thanks to kjoonlee for updating the mpg123 information post again.
This post has been edited by amano: Mar 22 2004, 17:25
amano
post Mar 23 2004, 15:46
Post #33
otachan ot66 is out!!!
a bug with IDv2.4 seems to have been fixed.
bidz
post Mar 26 2004, 05:10
Post #34
There seems to be a bug with either Winamp 5.03 or the latest in_mpg123.dll plugin. Every time i right-click and select "view file info" from within Winamp 5.03, i get a message "Winamp has encountered a problem and needs to close."
This happens with and without mp3infp 2.44 (latest) installed.
Anyone else experiencing this?
myspace.com/borgei - last.fm/user/borgei
kjoonlee
post Mar 28 2004, 03:54
Post #35
I'm having no trouble with ot66 and Winamp 5.03. WinXP+SP1.
edit: P4, 1.4GHz.
This post has been edited by kjoonlee: Mar 28 2004, 05:01
Hyperion
post Mar 28 2004, 04:17
Post #36
QUOTE (bidz @ Mar 25 2004, 08:10 PM)
0000: 41 70 70 6c 69 63 61 74   Applicat
0008: 69 6f 6e 20 46 61 69 6c   ion Fail
0010: 75 72 65 20 20 77 69 6e   ure  win
0018: 61 6d 70 2e 65 78 65 20   amp.exe
0020: 35 2e 30 2e 30 2e 33 20   5.0.0.3
0028: 69 6e 20 6e 74 64 6c 6c   in ntdll
0030: 2e 64 6c 6c 20 35 2e 31   .dll 5.1
0038: 2e 32 36 30 30 2e 31 32   .2600.12
0040: 31 37 20 61 74 20 6f 66   17 at of
0048: 66 73 65 74 20 30 30 30   fset 000
0050: 31 39 65 63 64 0d 0a      19ecd..
This post has been edited by Hyperion: Mar 28 2004, 04:30
It's My Life,
It's Now Or Never,
I Ain't Gonna Live Forever,
I Just Want To Live While I'm Alive.
rt87
post Mar 28 2004, 04:41
Post #37
QUOTE (Hyperion @ Mar 27 2004, 07:17 PM)
you should try VC++ 7.1 version
http://www3.cypress.ne.jp/otachan/in_mpg123_118ot66vc71.zip
Sorry for my English.
Hyperion
post Mar 29 2004, 03:46
Post #38
That's GREAT.
It's My Life,
It's Now Or Never,
jormartr
post Mar 29 2004, 15:13
Post #39
It seems doesn't work under win98 with winamp 5.02.
I made a fresh installation with EVERY plugin and option that come in winamp installer off, then deleted in_mp3.dll and replaced by in_mpg123.dll.
Worked perfect under winxp.
After that just copied the winamp directory to a win98 machine. It didn't recognize the plugin.
Made some test, I installed some plugins, all of them worked perfect under XP and 98, but under Win98 im_mpg123 was not recognized at all.
kjoonlee
post Mar 29 2004, 15:22
Post #40
Could you try with this version instead?
http://www3.cypress.ne.jp/otachan/in_mpg123_118ot66a.zip
smz
post Mar 29 2004, 15:23
Post #41
@jormartr:
Are you aware that in_mpg123 is available in different "flavours", compiled to support different instructions sets (bare X86, SSE, SSE2)?
Couldn't be the case that on the Win98 machine you have a processor that doesn't support SSE and/or SSE2 and you're using the worong version of in_mpg123?
Sergio
Sergio
Revox B150 + (JBL 4301B | Sennheiser HD430)
jormartr
post Mar 29 2004, 17:34
Post #42
ohmy.gif Obviously that was the reason...
laugh.gif Thanks.
Mr_Rabid_Teddybe...
post Mar 29 2004, 17:44
Post #43
You can use something like WCPUID or CPU-Z to check which instructions sets your processor supports.
"ONLY THOSE WHO ATTEMPT THE IMPOSSIBLE WILL ACHIEVE THE ABSURD"
- Oceania Association of Autonomous Astronauts
cyde
post Mar 30 2004, 22:27
Post #44
Whats the difference between "INT" And "Float" Bitrate options?
For example.. Should I be using 32bit int or 32bit float on my audigy?
rt87
post Apr 10 2004, 02:30
Post #45
in_mpg123 ot67 released
*Plugin doesn't work in win95 issue fixed
*Otachan changed compiler to VC++ 7.1
*Marged three downloads into one
http://www3.cypress.ne.jp/otachan/in_mpg123_118ot67.zip
rt87
post Apr 10 2004, 02:33
Post #46
QUOTE (cyde @ Mar 30 2004, 01:27 PM)
32bit float = 24bit int
if you use KX Project or something similar, you can use both of them.
rt87
post Apr 11 2004, 03:05
Post #47
Oops....ot67a is out....
http://www3.cypress.ne.jp/otachan/in_mpg123_118ot67a.zip
amano
post Apr 12 2004, 01:50
Post #48
...and now updated to ot67b.
http://www3.cypress.ne.jp/otachan/in_mpg123_118ot67b.zip
This post has been edited by amano: Apr 12 2004, 01:51
cyde
post Apr 12 2004, 02:57
Post #49
What is KX Project?
amano
post Apr 12 2004, 03:04
Post #50
http://kxproject.lugosoft.com/index.php?skip=1
A third party driver for some creative soundcards.
This post has been edited by amano: Apr 12 2004, 03:04
RSS Lo-Fi Version Time is now: 22nd May 2015 - 12:10
