foo_utils, plugin discussion
foosion
post Feb 3 2004, 13:53
Group: FB2K Moderator (Donating)
Utilities (foo_utils)
Provides various general commands.
  • multi-level, per playlist undo and redo
  • copy and paste for playlist items
  • command search
  • extended playlist editing
  • play arbitrary track from context menu
  • send tracks to a playlist chosen from the context menu (no extra dialog involved)
The latest version for foobar2000 0.9x is available from my components page. Versions for foobar2000 0.8.3 and older are no longer available.
This post has been edited by foosion: Nov 5 2006, 20:53
foosion
post Nov 12 2006, 22:33
When using that command, foo_utils starts playback of the first transferred track in th target playlist by simulating a doubleclick on it through the proper API. Apparently there is a bug in foobar2000 itself, that is triggered when this is performed on a playlist that is not the active one. I'll point Peter to it.
q-stankovic
post Nov 29 2006, 19:36
QUOTE (foosion @ Nov 12 2006, 22:33) *
I hoped so much that this "bug" would dissappear in the new release so that i could realize my desired configuration but... crying.gif
- foosion   foo_utils   Feb 3 2004, 13:53
- - foosion   foo_utils 0.3.5fixed metadb_handle leak when no sa...   Jun 14 2004, 13:57
- - foosion   foo_utils 0.3.6fixed crash when closing fb2k after...   Jun 14 2004, 17:04
- - foosion   foo_utils 0.3.7fixed metadb_handle leak when pasti...   Jun 15 2004, 11:06
- - bluenet   Thanks foosion make this good plugins,this is usef...   Jun 21 2004, 03:32
- - foosion   QUOTE (bluenet @ Jun 21 2004, 03:32 AM)Thanks...   Jun 21 2004, 15:08
- - foosion   foo_utils 0.4.0added commands to directly send tra...   Oct 28 2004, 01:49
- - spase   it seems like if you move the context menu items a...   Nov 8 2004, 07:32
|- - foosion   QUOTE (spase @ Nov 8 2004, 08:32 AM)it seems ...   Nov 8 2004, 10:35
|- - spase   QUOTE (foosion @ Nov 8 2004, 04:35 AM)QUOTE (...   Nov 10 2004, 19:53
|- - foosion   QUOTE (spase @ Nov 10 2004, 08:53 PM)i am not...   Nov 10 2004, 20:45
- - kjoonlee   In foo_utils for foobar2000 0.9, could you add a k...   Nov 6 2005, 08:32
|- - kjoonlee   QUOTE (kjoonlee @ Nov 6 2005, 04:32 PM)In foo...   Nov 22 2005, 10:36
- - foosion   foo_utils 0.5ported to 0.9 beta foo_utils 0.5.2 S...   Nov 21 2005, 15:27
- - gfngfgf   Big thanks for the read-only option. That'll ...   Nov 22 2005, 03:13
- - jaka   Another shortcuts are nice for the playlist such C...   Dec 26 2005, 03:08
- - nirly   how exactly do i get use the multiple level undo? ...   Jan 3 2006, 18:31
- - foosion   Components cannot replace or modify existing menu ...   Jan 3 2006, 18:52
- - lupin   There is a chinese version of foo_utils which cont...   Feb 3 2006, 07:23
- - foosion   I neither made a chinese version nor did I add the...   Feb 3 2006, 10:09
- - Rapido   Firstly, many thanks for your plug-ins whitch are ...   Feb 11 2006, 19:51
|- - evo3   thanks for keeping up on these plugins, they have ...   May 9 2006, 04:13
- - Bachi-Bouzouk   I would love to see presets for the text tools par...   May 11 2006, 19:06
|- - DoXer   I want to use the lock-feature of foo_utils, but I...   May 25 2006, 15:43
- - Bachi-Bouzouk   personally, I go to EDIT-> Read only but from t...   May 25 2006, 16:00
- - DoXer   Thx, found and works....   May 25 2006, 16:07
- - esa372   Thank you for the utils package, foosion... I use...   May 25 2006, 16:07
- - foosion   That is on purpose, it hints at what this search m...   May 25 2006, 16:42
|- - esa372   QUOTE (foosion @ May 25 2006, 08:42) That...   May 25 2006, 17:40
|- - q-stankovic   As a new member on this forum let me first thank y...   May 28 2006, 14:22
- - foosion   q-stankovic: I'll consider it.   May 28 2006, 18:12
- - ladiko   hello! i have a question to the "text too...   Jun 3 2006, 12:20
- - Bachi-Bouzouk   http://wiki.hydrogenaudio.org/index.php?ti...#.25f...   Jun 3 2006, 12:25
- - ladiko   and total lenght / size ? how do autoplaylist and ...   Jun 3 2006, 14:03
- - SoulMan   Hello, This foobar new version is verry verry nic...   Jun 8 2006, 10:18
|- - foosion   QUOTE (SoulMan @ Jun 8 2006, 11:18) I was...   Jun 8 2006, 13:06
- - SoulMan   Yes, I think you are right, the get function is ou...   Jun 8 2006, 13:21
- - foosion   foosic does not use HTTP POST. The submission prot...   Jun 8 2006, 13:28
- - SoulMan   Yes, I know that, but, what I was trying to explai...   Jun 8 2006, 13:50
- - Bachi-Bouzouk   Another request about text tools: add something by...   Jun 13 2006, 19:15
- - SoulMan   Hmmm, yon can do this script yourself, and propose...   Jun 15 2006, 10:13
|- - ladiko   QUOTE (SoulMan @ Jun 15 2006, 11:13) Hmmm...   Jul 11 2006, 08:44
- - ephemeros   Great component, foosion. Thx I was able to as...   Jun 26 2006, 00:50
- - Hakubo   First of all, thanks for this component, foosion. ...   Aug 13 2006, 00:08
- - Hakubo   It seems I don't really need persisting values...   Sep 3 2006, 10:20
- - Rambaldi   link ist down. Can someone give a working link? O...   Nov 5 2006, 20:34
- - foosion   I corrected the link in the first post. The versio...   Nov 5 2006, 20:54
|- - hal9001   QUOTE (foosion @ Nov 5 2006, 22:54) I cor...   Nov 6 2006, 04:10
- - Supernaut   Could you provide an option of not filtering dupli...   Nov 6 2006, 16:19
|- - foosion   QUOTE (Supernaut @ Nov 6 2006, 16:19) Cou...   Nov 7 2006, 23:49
- - q-stankovic   Using foo_utils very often in different scenarios ...   Nov 10 2006, 17:15
- - q-stankovic   I thought that it was a bug in ColumnsUi and so i ...   Nov 12 2006, 21:53
- - foosion   When using that command, foo_utils starts playback...   Nov 12 2006, 22:33
|- - q-stankovic   QUOTE (foosion @ Nov 12 2006, 22:33) When...   Nov 29 2006, 19:36
- - ladiko   are there a function like %playlist_total_time% an...   Jan 19 2007, 13:50
|- - foosion   QUOTE (ladiko @ Jan 19 2007, 13:50) are t...   Jan 19 2007, 15:00
||- - ladiko   and the development is stopped? "mature...   Jan 19 2007, 15:15
|- - norz   QUOTE (ladiko @ Jan 19 2007, 13:50) are t...   Mar 4 2007, 15:22
- - foosion   I give a component the label "mature" if...   Jan 19 2007, 15:49
- - ladiko   i would like to have %total_playlist_time% and %to...   Jan 19 2007, 20:09
- - Problemkerze   This will sound strange but setting a keyboard sho...   Jul 19 2007, 20:30
|- - foosion   QUOTE (Problemkerze @ Jul 19 2007, 21:30)...   Jul 19 2007, 20:59
- - Problemkerze   thanks foosion - works now with context / now play...   Jul 21 2007, 07:47
- - q-stankovic   Not a feature request but more a suggestion for ne...   Sep 19 2007, 13:17
- - foosion   foo_utils 0.6.2 beta 1 Requires foobar2000 0.9.5 a...   Oct 20 2007, 17:53
- - radio_cascara   cool, hope to see some stuff like read-only incorp...   Oct 23 2007, 19:45
- - Borisz   Is it normal that, using the latest beta (0.6.2 b3...   Oct 30 2007, 23:13
- - foosion   That is perfectly normal, see my last post before ...   Oct 30 2007, 23:31
- - tberman333   It seems that the "Highlight in Playlist...   Nov 13 2007, 16:55
- - foosion   "Edit/Highlight in Playlist" is definite...   Nov 13 2007, 18:10
- - q-stankovic   QUOTE (foosion @ Nov 13 2007, 18:10) Howe...   Nov 14 2007, 14:50
- - Vomitus   So, we have a "readonly playlist" featur...   Dec 20 2007, 17:09
|- - foosion   It is technically not possible to add such a title...   Dec 20 2007, 17:34
|- - Kiteroa   Thanks for the update with the sorting functionali...   Dec 20 2007, 21:42
|- - tb2496   hi, looks like when using "edit\insert i...   Jan 27 2008, 15:03
- - loft   foosion, could I ask for a new feature? I'm us...   Feb 23 2008, 17:54
- - foosion   Missing updates and information on changes below. ...   Mar 10 2008, 21:40
|- - wolfsong   The link for this is broken.   Mar 10 2008, 23:07
|- - foosion   QUOTE (wolfsong @ Mar 10 2008, 23:07) The...   Mar 10 2008, 23:32
- - q-stankovic   The "Highlight in Playlist" (applied on ...   Apr 4 2008, 14:37
- - Lucky Luciano   What about a "delete parent folder" opti...   Apr 4 2008, 16:21
- - foosion   QUOTE (q-stankovic @ Apr 4 2008, 14...   Apr 4 2008, 16:44
- - q-stankovic   QUOTE (foosion @ Apr 4 2008, 16:44) [*]Ad...   Apr 4 2008, 16:54
- - foosion   No problem. It's nice to know I could help.   Apr 4 2008, 17:10
- - Lucky Luciano   My bad, what I meant was What ABOUT a "delete...   Apr 4 2008, 21:11
- - foosion   No, that would not fit into foo_utils. A better pl...   Apr 4 2008, 21:52
- - jbk_atl   Great plugin. Could a request be made for a ...   Apr 19 2008, 16:05
- - fireslug   Possible bug report: Selecting "Insert into ...   Jan 5 2009, 16:06
- - rubber soul   when i try to create a keyboard shortcut: Add to p...   Mar 24 2009, 01:47
- - foo_peter   Hello Foosion, a very careful inquiry I would like...   Apr 14 2009, 15:53
- - Forfit   I listen smoothjazz.com. It shows the titles of th...   Apr 30 2009, 14:13
- - marc2003   thanks for this great plugin. i can now create .m3...   Jun 30 2009, 11:13
- - Sapta   The first post of this thread says the plug-in all...   Oct 13 2009, 16:22
- - tpijag   For me, it does just what you want. What behavio...   Oct 13 2009, 16:38
- - foosion   Please note that the first post refers to an earli...   Oct 13 2009, 19:23
- - twe4k   Hey there ! Thanks a lot foosion for your awes...   Oct 15 2009, 04:59
- - Yirkha   Blame ELPlaylist. It won't let you use dynamic...   Oct 15 2009, 09:30
- - Johnnz   Just wondering if the feature that makes a playlis...   Oct 17 2009, 21:52
- - tpijag   Pretty particular use case to wait on someone else...   Oct 17 2009, 22:02
- - Johnnz   QUOTE (tpijag @ Oct 18 2009, 10:02) Prett...   Oct 17 2009, 22:12
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 26th January 2015 - 10:44
