-V n (in 3.95.1), Presets, bitrates and lowpass of V value
Vietwoojagig
post Jan 29 2004, 11:38
Switch            equals               target  Y  b  lowpass resample
-V 0            = --preset extreme       240     128  19500
-V 0 --vbr-new  = --preset fast extreme  240     128  19500
-V 1                                     210     128  19000
-V 1 --vbr-new                           210     128  19000
-V 2            = --preset standard      190     128  19000
-V 2 --vbr-new  = --preset fast standard    190     128  19000
-V 3                                     175   1      18000
-V 3 --vbr-new                           175   1      18000
-V 4            = --preset medium        165   1      18000
-V 4 --vbr-new  = --preset fast medium   165   1      18000
-V 5                                     130   1      17000
-V 5 --vbr-new                           130   1      17000
-V 6                                     115   1      16000
-V 6 --vbr-new                           115   1      16000
-V 7                                     100   1      14900   32000
-V 7 --vbr-new                           100   1      14900   32000
-V 8                                      85   1      12500   32000
-V 8 - vbr-new                            85   1      12500   32000
-V 9                                      65   1      10000   24000
-V 9 - vbr-new                            65   1      10000   24000
Questions:
1. Is it save to use the -V switches, with no corresponding preset (especially V 1 / V3)?
2. When is it more usefull, to use abr rather than -V n (e.g. --preset 120 better than -V 5)?
3. Are the displayed target average bitrates ok (+/- 10 kbps)?
Edit: changed with Gabriel's suggestions. Added:-Y, -b, --lowpass, --resample
Edit: modified -b to fit with 3.96
Firon
post Nov 30 2006, 03:27
-k will absolutely destroy the quality of the files. Also, M/S stereo will make things sound WORSE. Leave it as joint stereo (it is NOT lossy in LAME). -h does nothing for VBR, -q0 does nothing for VBR. Setting min/max bitrate is not needed in 3.97 when using VBR.
Spectral analysis is virtually useless for measuring sound quality.
Stop screwing with the parameters and just use -V2 --vbr-new
Nothing more, nothing less. Try LAME 3.97 or 3.98a7 if you prefer going a little on the wild side. Then ABX it if you still think you hear "distortions".
This post has been edited by Firon: Nov 30 2006, 04:32
ThyBzi
post Dec 4 2006, 08:44
QUOTE (Firon @ Nov 30 2006, 08:27) *
Hmm... But when not setting minimum frame bitrate, LAME uses bitrate lower than 128 (on some songs - oftenly)... is it good?
This post has been edited by ThyBzi: Dec 4 2006, 08:45
- Vietwoojagig   -V n (in 3.95.1)   Jan 29 2004, 11:38
- - Gabriel   Nice layout. QUOTE 3. Are the displayed target av...   Jan 29 2004, 12:11
|- - moi   QUOTE (Gabriel @ Jan 29 2004, 03:11 AM)Nice l...   Feb 26 2005, 21:06
|- - Jojo   QUOTE (moi @ Feb 26 2005, 12:06 PM)To get the...   Feb 27 2005, 00:40
|- - Dologan   QUOTE (Jojo @ Feb 26 2005, 05:40 PM)use LAME ...   Mar 6 2005, 20:19
- - Dologan   Is --r3mix still remapped to -V3 --vbr-new in 3.96...   May 5 2004, 00:35
- - Gabriel   QUOTE Is --r3mix still remapped to -V3 --vbr-new i...   May 5 2004, 08:53
- - Schinkentoni   I just want to pick up the first question of Vietw...   May 5 2004, 10:05
|- - 384kbps   QUOTE (Schinkentoni @ May 5 2004, 10:05 AM)I ...   Aug 25 2004, 19:58
- - 2Bdecided   The word you're looking for is safe, not save...   May 5 2004, 11:02
- - Vietwoojagig   QUOTE (2Bdecided @ May 5 2004, 11:02 AM)The w...   May 5 2004, 11:42
- - Halcyon   Vietwoojagig, don't worry. It's just a si...   May 5 2004, 14:15
- - Dologan   QUOTE (Gabriel @ May 5 2004, 01:53 AM)QUOTE ...   May 5 2004, 15:22
- - Vietwoojagig   QUOTE (Dologan @ May 5 2004, 03:22 PM)Well, c...   May 5 2004, 15:41
- - Dologan   QUOTE (Vietwoojagig @ May 5 2004, 08:41 AM)On...   May 5 2004, 16:19
- - Vietwoojagig   QUOTE (Dologan @ May 5 2004, 04:19 PM) From w...   May 5 2004, 16:24
- - Tomb   QUOTE (Halcyon @ May 5 2004, 01:15 PM)PS It...   May 5 2004, 16:33
- - Dologan   QUOTE (Vietwoojagig @ May 5 2004, 09:24 AM)QU...   May 5 2004, 17:07
- - Gabriel   QUOTE Gabriel, could you please confirm this? Yes   May 5 2004, 17:38
- - Jebus   Wow, that is really interesting. So the --r3mix tu...   May 5 2004, 19:16
|- - GeSomeone   QUOTE (Jebus @ May 5 2004, 07:16 PM)So the --...   Aug 26 2004, 12:26
- - Squeller   QUOTE (Vietwoojagig @ Jan 29 2004, 02:38 AM)2...   May 24 2004, 12:02
- - shafff   -V2 (lame 3.95.1) gives me 141kbps on film track (...   Jun 24 2004, 18:56
- - westgroveg   Does LAME 3.96, -V2/--preset standard still use -b...   Jul 4 2004, 02:20
- - Vietwoojagig   QUOTE (westgroveg @ Jul 4 2004, 02:20 AM)Does...   Jul 7 2004, 10:29
- - Gabriel   Regarding "target bitrates" related to -...   Aug 4 2004, 08:43
- - Gabriel   -V1 is between -V0 and -V2. I do not know what to ...   Aug 26 2004, 08:30
- - Pio2001   ...so -V1 includes the alt-preset code level tunin...   Aug 26 2004, 11:11
|- - 384kbps   QUOTE (Pio2001 @ Aug 26 2004, 11:11 AM)...so ...   Sep 1 2004, 06:45
|- - LoFiYo   QUOTE (Pio2001 @ Aug 26 2004, 06:11 AM)...so ...   Sep 30 2004, 04:15
- - Gabriel   QUOTE (LoFiYo @ Sep 30 2004, 05:15 AM)I thoug...   Sep 30 2004, 11:22
- - detokaal   Would it be possible to add the -q switch to the t...   Oct 18 2004, 21:30
- - Gabriel   QUOTE I believe --preset standard is -q 2 whereas ...   Oct 19 2004, 09:56
- - detokaal   Rather than ask again - I just checked myself. --...   Oct 19 2004, 22:02
|- - freakngoat   QUOTE (detokaal @ Oct 19 2004, 09:02 PM)Rathe...   Oct 19 2004, 22:19
- - Gabriel   Yes, changing -V is (generally) a better idea than...   Oct 20 2004, 08:45
- - ezra2323   After reading through this thread, I'm still u...   Dec 15 2004, 03:51
|- - dev0   QUOTE (ezra2323 @ Dec 15 2004, 03:51 AM)After...   Dec 15 2004, 06:12
||- - k.eight.a   QUOTE (Vietwoojagig @ Jan 29 2004, 02:38 AM)2...   Dec 15 2004, 18:32
|- - whcanilang   QUOTE (ezra2323 @ Dec 14 2004, 10:51 PM)After...   Dec 22 2004, 21:16
||- - music_man_mpc   QUOTE (whcanilang @ Dec 22 2004, 12:16 PM)Whe...   Dec 22 2004, 21:42
|- - esa372   QUOTE (ezra2323 @ Dec 14 2004, 07:51 PM)Is 3....   Jan 19 2005, 18:23
- - Gabriel   QUOTE I just noticed that http://lame.sourceforge....   Dec 23 2004, 09:16
- - veikko   Hi. I just registered myself for the first time e...   Feb 9 2005, 23:25
|- - schonenberg   QUOTE (veikko @ Feb 9 2005, 04:25 PM)Hi. I j...   Apr 5 2005, 08:38
||- - guruboolez   QUOTE (schonenberg @ Apr 5 2005, 08:38 AM)Lam...   Apr 5 2005, 08:48
|- - Madrigal   QUOTE (veikko @ Feb 9 2005, 05:25 PM)Hi. I j...   Apr 5 2005, 13:46
- - Gabriel   A bug regarding -q0 and -q1 has been recently iden...   Feb 9 2005, 23:34
- - kwanbis   Garbiel would this fix be backported to 3.96.x?   Feb 10 2005, 00:30
- - Gabriel   Probably not as we are not working on 3.96 anymore...   Feb 10 2005, 09:51
- - JEN   my hearing is either getting really bad (i'm 2...   Mar 6 2005, 20:02
- - TheStonepedo   I fail to understand the b value of 128 on -V 0. ...   May 20 2005, 04:42
|- - Jojo   QUOTE (TheStonepedo @ May 19 2005, 07:42 PM)I...   May 20 2005, 17:20
|- - =trott=   QUOTE (TheStonepedo @ May 19 2005, 07:42 PM)I...   Jun 23 2005, 12:02
|- - guruboolez   QUOTE (=trott= @ Jun 23 2005, 12:02 PM)you ha...   Jun 23 2005, 12:22
- - tycho   I believe the -b 32 will override the default (128...   May 20 2005, 07:36
- - latuman   Hi! I'm new to this forum. I registered b...   Nov 16 2005, 12:20
|- - Alex B   QUOTE (latuman @ Nov 16 2005, 01:20 PM)-V6 --...   Nov 16 2005, 13:05
- - latuman   I might be a bit thick, but whats the point using ...   Nov 16 2005, 17:27
|- - Gambit   QUOTE (latuman @ Nov 16 2005, 06:27 PM)I migh...   Nov 17 2005, 00:22
|- - Alex B   QUOTE (latuman @ Nov 16 2005, 06:27 PM)I migh...   Nov 17 2005, 01:16
- - latuman   So I shall leave that setting alone for portable u...   Nov 17 2005, 10:54
- - DickxLaurent   Is there an updated copy of the chart in the first...   Jun 19 2006, 03:44
|- - pika2000   QUOTE (DickxLaurent @ Jun 18 2006, 19:44)...   Jun 19 2006, 06:59
- - Alex B   I have posted an updated table here: http://www.hy...   Jun 19 2006, 04:42
|- - DickxLaurent   QUOTE (Alex B @ Jun 18 2006, 22:42) I hav...   Jun 19 2006, 05:19
- - Jojo   the minimum bitrate should be removed from the cha...   Jun 20 2006, 20:21
- - ThyBzi   Sorry for possible offtopic. I just found this top...   Nov 29 2006, 20:36
- - jmartis   Spertrograms are no judge of sound quality. Use an...   Nov 29 2006, 21:25
- - Firon   -k will absolutely destroy the quality of the file...   Nov 30 2006, 03:27
|- - ThyBzi   QUOTE (Firon @ Nov 30 2006, 08:27) Settin...   Dec 4 2006, 08:44
|- - greynol   QUOTE (ThyBzi @ Dec 3 2006, 23:44) Hmm......   Dec 4 2006, 08:49
- - greynol   -m s isn't such a bright idea either. Never...   Nov 30 2006, 03:29
- - ThyBzi   Thanx for your support, people But, as far as I ...   Nov 30 2006, 19:22
|- - greynol   QUOTE (ThyBzi @ Nov 30 2006, 10:22) Are t...   Nov 30 2006, 19:49
|- - pepoluan   QUOTE (ThyBzi @ Dec 1 2006, 01:22) Thanx ...   Nov 30 2006, 20:28
- - halb27   To me the main problem is that you seem to think i...   Nov 30 2006, 19:45
- - ThyBzi   "(The mere fact that Joint Stereo is used in ...   Nov 30 2006, 20:31
|- - pepoluan   QUOTE (ThyBzi @ Dec 1 2006, 02:31) ...   Nov 30 2006, 20:40
|- - greynol   QUOTE (ThyBzi @ Nov 30 2006, 11:31) Or di...   Nov 30 2006, 20:58
- - ThyBzi   QUOTE Do you have foobar2000 installed on your sys...   Dec 1 2006, 18:49
|- - greynol   QUOTE (ThyBzi @ Dec 1 2006, 09:49) I down...   Dec 1 2006, 20:03
- - ThyBzi   Thanx a lot, you all just broke down my hasty and ...   Dec 2 2006, 12:09
- - dv1989   2) The new VBR method, faster and reputed several ...   Dec 2 2006, 12:23
- - robert   1 - because it makes no difference for VBR NEW, no...   Dec 2 2006, 12:33
|- - ThyBzi   Thanks Dv1989 and thanks Robert (an answer from LA...   Dec 2 2006, 13:04
|- - dv1989   QUOTE (ThyBzi @ Dec 2 2006, 12:04) But wh...   Dec 2 2006, 14:38
- - dv1989   Wow, LAME 3.98 should be interesting! Thanks ...   Dec 2 2006, 12:36
- - halb27   Before 3.97 development started --vbr-new wasn...   Dec 2 2006, 13:49
- - ThyBzi   Thanx for all! I'll try using -V2 --vbr-ne...   Dec 2 2006, 17:42
- - Firon   QUOTE You are partially wrong. In low-bitrate, Jo...   Dec 4 2006, 09:49
- - ThyBzi   Thanks again Now I see, LAME is even more clever ...   Dec 4 2006, 17:12
RSS Lo-Fi Version Time is now: 4th August 2015 - 13:28
