Improving ReplayGain, some ideas for Devs etc
2Bdecided
post Nov 18 2003, 17:04
ReplayGain developer
Every now and again I wish I had the time to update the ReplayGain website and add some new ideas, and maybe even clarify some old ones. I don't, so this thread will have to do.
Firstly, the format used to store ReplayGain info in files is not documented correctly on the ReplayGain website, and it would be good to "publish" what has emerged as the standard for each format.
Secondly, what is stored is not documented correctly on the ReplayGain website, and I'd like to re-examine what is stored...
One change has already happened, and I think it's a good change:
Forget Radio and Audiophile - Track and Album are much better names.
(that's an open admission of me being wrong, for anyone who discussed this with me previously!)
So, we store:
ReplayGain Track adjustment
ReplayGain Album adjustment
(ReplayGain) Track peak
(ReplayGain) Album peak
(this last one wasn't in the original proposal, but it has been widely used - I've put it in bold to remind me to include it in the update)
That makes sense, and most software supports this. I'd like to formalise some extensions, some of which were there from the start, and others that have cropped up more recently:
1. (ReplayGain) undo adjustment
- this is written when the gain of the file is changed (e.g. by mp3gain, or by decoding with ReplayGain enabled), and is the gain change required to put the file back to where it started.
e.g. If I apply -8dB gain change using mp3gain, then
(ReplayGain) undo adjustment = +8dB
e.g. If I use --scale 0.5 when encoding (for whatever reason?!), then
(ReplayGain) undo adjustment = +6dB
If the gain of an already ReplayGained file is changed, the original four values (Track and Album adjustment and peak) should be updated so that they are correct for the new audio data. (see an example in this thread: http://www.hydrogenaudio.org/forums/index....topic=15412&hl= )
I can't see any argument against defining this field. It would be zero (or absent) if the audio file hasn't been altered. It's useful in all formats because you can always apply wavgain before encoding, and it would be nice to know that this has been done.
2. ReplayGain calculation method
OK - I've had this argument before, but this really is important. ReplayGain can be improved, but you'll never know whether files are tagged using the old or new ReplayGain calculation unless the calculation method (actually a number which corresponds to the method) is stored. This doesn't increase the complexity of players, as they won't care - it just makes it very easy to pick out files that were tagged with the old version, and update them.
3. ReplayGain lossy approximation
This is just a single bit: 0 or 1.
0= this ReplayGain info has been calculated from the data in this file
1=this file has been lossily encoded/transcoded since this ReplayGain info was calculated.
What's the point of this? If you have a file with ReplayGain info, you can transcode it and copy the RG info across. It'll be close enough to give you excellent loudness equalisation, and you won't have to re-calculate it. Yet they'll be a label there to tell all you anal retentives that it's not quite right, and should be recalculated if you want to be 100% sure (especially important for peak amplitude).
You could (should?) have one “ReplayGain lossy approximation” bit for each of the four values, which gives you the chance (for example) of re-calculating the peak values (quick, and important - so let's do it), but leaving the ReplayGain values (slow, and unimportant - so let's not do it).
4. ReplayGain user adjustment
Instead of suggesting that users should change the calculated values if they wish, give them a field to enter their own value if they really have to. Players should give the option to read the user value in preference to any others (i.e. let it act as an over-ride), and taggers should give the option of removing the user values from all (downloaded) files.
5. ReplayGain RealLife adjustment
The gain required to give the actual SPL of the original event (in a calibrated system), or a human judged sensible replay level (see the explanation behind the original "Audiophile" level and the work of Bob Katz if you think this is an impossible idea). I've found a few DVD-A discs that have this information (it's in the MLP stream), so it would be nice to have somewhere to store it. It's unlikely to get used much, but it would be a useful thing to have. It would be the last link in some of the best recordings out there.
I'd like to come to a consensus of which ones of these (if any/all) should be included, and then get some specs as to how they are/should be stored in each file format (especially APE2.0 tags) finalised and published on-line.
Comments? Suggestions? Offers of help?
btw I've received a couple of suggestions for improving the ReplayGain calculation. One is trivial, and seems like a great idea. I'll post it for testing when the problem of version numbering is solved. If anyone else has slightly or totally re-worked the ReplayGain algorithm/concept, now would be a good time to step forward! We could do listening tests to find the best candidate for "calculation version 2".
Newbie warning: this thread is not for asking questions about ReplayGain that are already answered on www.replaygain.org or in previous threads on HA. (I'm always happy to answer "silly" questions via email – half of them aren't silly at all.)
However, if you do already have some understanding of ReplayGain then this thread is the perfect place for clarifying anything to do with the above proposals which is not clear.
This post has been edited by 2Bdecided: Nov 18 2003, 17:42
2Bdecided
post Jan 8 2004, 12:29
QUOTE (SamK @ Jan 7 2004, 02:57 PM)
QUOTE (2Bdecided @ Jan 7 2004, 02:07 PM)
ReplayGain is referenced to SMPTE RP 200, a calibration by which a -20dB FS RMS pink noise signal will give a real world SPL of 83dB. All RG figures come from this concept, and all ReplayGain values are the gain adjustments needed to make that track (or album) match the perceived loudness of that test signal. (+6dB in most implementations)
The values are not based on bit depth. The notion of "how loud" a full scale sine wave is flows from SMPTE RP 200, and it is not 90dB, 96dB or 144dB. It's frequency dependent, but will be 103dB SPL for 2kHz (IIRC in the calculations I originally proposed).
ah ok, the replaygain is already bitdepth independant. I had read most of replaygian documents, but this wasnt clearly stated anywhere.
If I had known matlab's wavread function returns an array of numbers in [-1, 1], I would have gotten the clue from the matlab demonstration code..
Maybe you should add a first step in the 4-step "General Concept" at http://replaygain.hydrogenaudio.org/rms_energy.html, like :
0. the signal is converted to floating point numbers, and divided by the full scale of the original format. (which is 2^15 for 16 bit integer encoding)
or something, to insure everyone gets this point.
I think, if you follow it through, it doesn't matter whether wavread returns [1,-1] or [-32768,32767] (you're right saying that it returns the former). As long as the value "ref_Vrms" has been calculated by the same method (which is essential anyway), then calibrating to it (i.e. subtracting it at the end) will cancel out whatever scaling or units or whatever are used at the input. That's because both the file in question, and the ref_pink.wav file will be scaled the same on the way in (to [1,-1] or [-32768,32767] or whatever). Subtracting in the logarithmic domain (which dB is) is the same as dividing in the linear domain. So any scaling is cancelled in this last step.
To sum up what I understood,
replaygain computations are bitdepth independant from the start,
and the proposal is to store
Vrms = 83+ (replaygain(filename) - ref_Vrms);
(with ref_Vms being the gain of the standard digital signal corresponding to 83db SPL
ref_Vrms = replaygain("pink_ref.wav");  )
instead of previous :
Vrms = - (replaygain(filename) - ref_Vrms);
Then players would now use the stored value like that :
average_song_Vrms = 89; // user setting
rel_gain = average_song_Vrms - Vrms;
ratio = 10^(rel_gain/20);
// multiplies decoded samples by ratio.
Yes exactly - though I'm not strongly suggesting we change it. I was saying it's a pity it isn't like this already, but should it be changed now?
I'll answer your other post, and them expand on that point...
EDIT: 1000th post! Should have made it better! laugh.gif
This post has been edited by 2Bdecided: Jan 8 2004, 13:19
- 2Bdecided   Improving ReplayGain   Nov 18 2003, 17:04
- - Gabriel   I think that a point that should be clarified/upda...   Nov 18 2003, 17:11
- - 2Bdecided   Frank heavily criticised my proposal for storing R...   Nov 18 2003, 17:22
- - Gabriel   You might be interested by: http://sourceforge.net...   Nov 18 2003, 17:32
- - 2Bdecided   Moderators: On this page: http://replaygain.hydro...   Nov 18 2003, 17:35
|- - danbee   QUOTE (2Bdecided @ Nov 18 2003, 04:35 PM)Almo...   Oct 27 2004, 17:54
- - 2Bdecided   QUOTE (Gabriel @ Nov 18 2003, 04:32 PM)You mi...   Nov 18 2003, 17:38
- - Digga   QUOTE (2Bdecided @ Nov 18 2003, 05:35 PM)(It...   Nov 18 2003, 23:26
- - Mike Giacomelli   I would just like a way to write replaygain info i...   Nov 18 2003, 23:49
- - Gabriel   QUOTE Almost everyone is using a reference level o...   Nov 19 2003, 15:28
- - 2Bdecided   That would be fine. Or... Would the following ...   Nov 20 2003, 12:43
- - Gabriel   Seems interesting. It would be nice to hear other ...   Nov 20 2003, 13:04
- - 2Bdecided   Do none of the developers have any comments? Two...   Nov 21 2003, 12:24
- - phwip   QUOTE (2Bdecided @ Nov 21 2003, 12:24 PM)1. I...   Nov 21 2003, 12:31
- - 2Bdecided   QUOTE (phwip @ Nov 21 2003, 11:31 AM)QUOTE (2...   Nov 21 2003, 14:04
- - n68   QUOTE (2Bdecided @ Nov 21 2003, 02:04 PM)QUOT...   Nov 21 2003, 14:43
- - robUx4   Just a question from a user point of view. iTunes ...   Nov 23 2003, 17:03
- - robUx4   QUOTE (2Bdecided @ Nov 18 2003, 05:35 PM)Almo...   Nov 23 2003, 17:05
- - guruboolez   QUOTE (robUx4 @ Nov 23 2003, 05:03 PM)Just a ...   Nov 23 2003, 17:23
- - 2Bdecided   QUOTE (robUx4 @ Nov 23 2003, 04:05 PM)QUOTE (...   Nov 23 2003, 17:30
- - Case   QUOTE (robUx4 @ Nov 23 2003, 06:05 PM)QUOTE (...   Nov 23 2003, 17:55
- - dev0   3. ReplayGain lossy approximation Storing this se...   Nov 23 2003, 18:36
- - /\/ephaestous   QUOTE (2Bdecided @ Nov 21 2003, 06:24 AM)1. I...   Nov 24 2003, 06:02
- - /\/ephaestous   QUOTE (dev0 @ Nov 23 2003, 12:36 PM)3. Replay...   Nov 24 2003, 07:01
- - guruboolez   Try lame abr for exemple (there's a --scale 0....   Nov 24 2003, 11:18
- - 2Bdecided   QUOTE (Case @ Nov 23 2003, 04:55 PM)QUOTE (ro...   Nov 24 2003, 11:50
- - 2Bdecided   QUOTE (dev0 @ Nov 23 2003, 05:36 PM)3. Replay...   Nov 24 2003, 11:51
- - 2Bdecided   QUOTE (guruboolez @ Nov 24 2003, 10:18 AM)Try...   Nov 24 2003, 11:58
- - guruboolez   And what about the idea of a personnal track/album...   Nov 24 2003, 12:26
- - 2Bdecided   See my reply in your other thread, and my suggesti...   Nov 24 2003, 12:54
- - Case   QUOTE (2Bdecided @ Nov 24 2003, 12:50 PM)Sorr...   Nov 24 2003, 18:06
- - 2Bdecided   Another suggestion (this isn't fundamental)......   Nov 26 2003, 11:02
- - andyh   I'm confused as to how the RealLife level is d...   Jan 2 2004, 17:44
- - Lear   QUOTE (2Bdecided @ Nov 18 2003, 05:35 PM)(It...   Jan 2 2004, 19:10
- - Lear   QUOTE (2Bdecided @ Nov 20 2003, 12:43 PM)Fiel...   Jan 2 2004, 22:46
- - SamK   I think it's the right time to switch to absol...   Jan 4 2004, 15:48
- - knik   QUOTE (2Bdecided @ Nov 18 2003, 07:35 PM)Almo...   Jan 5 2004, 12:16
- - Mike Giacomelli   Stupid question: Is 0dB relative also 96 dB in 16...   Jan 6 2004, 06:28
- - SamK   QUOTE (knik @ Jan 5 2004, 12:16 PM)After clos...   Jan 6 2004, 14:52
- - 2Bdecided   QUOTE (Lear @ Jan 2 2004, 06:10 PM)QUOTE (2Bd...   Jan 6 2004, 15:12
- - knik   QUOTE (2Bdecided @ Jan 6 2004, 05:12 PM)I do,...   Jan 6 2004, 18:45
- - knik   QUOTE (SamK @ Jan 6 2004, 04:52 PM)So you...   Jan 6 2004, 20:56
- - 2Bdecided   QUOTE (knik @ Jan 6 2004, 07:56 PM)QUOTE (Sam...   Jan 7 2004, 14:07
- - 2Bdecided   QUOTE (Lear @ Jan 2 2004, 09:46 PM)QUOTE (2Bd...   Jan 7 2004, 14:16
- - Gabriel   Lame is using the fixed point representation from ...   Jan 7 2004, 14:23
- - SamK   QUOTE (2Bdecided @ Jan 7 2004, 02:07 PM)Repla...   Jan 7 2004, 15:57
- - SamK   reading http://home.earthlink.net/~bobkatz24bit/in...   Jan 7 2004, 20:34
- - Lear   QUOTE (2Bdecided @ Jan 7 2004, 02:16 PM)QUOTE...   Jan 7 2004, 20:47
- - knik   Thanks for explanation, 2Bdecided. It really helpe...   Jan 7 2004, 21:32
- - 2Bdecided   QUOTE (SamK @ Jan 7 2004, 02:57 PM)QUOTE (2Bd...   Jan 8 2004, 12:29
- - 2Bdecided   QUOTE (SamK @ Jan 7 2004, 07:34 PM)reading ht...   Jan 8 2004, 13:11
- - 2Bdecided   I remembered something last night. When it stored...   Jan 8 2004, 13:18
- - SamK   QUOTE (2Bdecided @ Jan 8 2004, 01:11 PM)No, b...   Jan 8 2004, 14:15
- - SamK   QUOTE (2Bdecided @ Jan 8 2004, 01:18 PM)I...   Jan 8 2004, 14:27
- - SamK   QUOTE so the relative gain itself will still be br...   Jan 8 2004, 16:29
- - SamK   To sum up my opinion, I am for storing 3 values i...   Jan 8 2004, 17:07
- - 2Bdecided   I think you've got more time to write that I h...   Jan 8 2004, 18:03
- - SamK   QUOTE (2Bdecided @ Jan 8 2004, 06:03 PM)I thi...   Jan 8 2004, 20:31
|- - David Nordin   QUOTE (SamK @ Jan 8 2004, 08:31 PM)QUOTE (2Bd...   Jul 18 2004, 09:10
|- - 2Bdecided   QUOTE (David Nordin @ Jul 18 2004, 08:10 AM)I...   Jul 19 2004, 12:02
- - Iconoclast_a   Well, I think the genre dependent adjustment could...   Jul 13 2004, 10:03
|- - Kuuenbu   There should be an option to turn the equal loudne...   Jul 18 2004, 00:54
|- - 2Bdecided   QUOTE (Kuuenbu @ Jul 17 2004, 11:54 PM)There ...   Jul 19 2004, 12:06
|- - Kuuenbu   QUOTE The peak sample value tells you _exactly_ ho...   Jul 26 2004, 02:18
- - Pio2001   I'd still like to see a plugin that would read...   Jul 18 2004, 08:07
|- - 2Bdecided   QUOTE (Pio2001 @ Jul 18 2004, 07:07 AM)I...   Jul 19 2004, 12:01
|- - Peter   QUOTE (2Bdecided @ Jul 19 2004, 02:01 PM)QUOT...   Jul 19 2004, 21:08
- - Ariakis   For CDs from lossy files in fb2k, you can clean yo...   Jul 18 2004, 08:43
|- - Pio2001   QUOTE (Ariakis @ Jul 18 2004, 08:43 AM)For CD...   Jul 18 2004, 17:32
- - indybrett   If it hasn't been brought up yet, I would like...   Jul 18 2004, 18:09
- - snek_one   only thing i have to get off my chest about replay...   Jul 18 2004, 18:52
|- - Cyaneyes   QUOTE (snek_one @ Jul 18 2004, 01:52 PM)only ...   Jul 18 2004, 19:30
|- - Pio2001   QUOTE (snek_one @ Jul 18 2004, 06:52 PM)only ...   Jul 19 2004, 20:50
- - indybrett   I don't think that is the same as what he is a...   Jul 19 2004, 21:51
- - dev0   This can be done by raising the Pre-Amp.   Jul 19 2004, 22:01
|- - indybrett   QUOTE (dev0 @ Jul 19 2004, 04:01 PM)This can ...   Jul 19 2004, 22:29
|- - Pio2001   QUOTE (indybrett @ Jul 19 2004, 09:51 PM)QUOT...   Jul 19 2004, 22:50
- - Xenno   2B > The peak sample value tells you _exactly_ ...   Jul 19 2004, 23:01
|- - SamK   QUOTE (Xenno @ Jul 19 2004, 11:01 PM)2B > ...   Jul 20 2004, 00:52
|- - SamK   QUOTE (SamK @ Jul 20 2004, 12:52 AM)my opinio...   Jul 20 2004, 00:55
- - 2Bdecided   The RG peak value is the largest absolute value wi...   Jul 20 2004, 13:07
|- - SamK   QUOTE (2Bdecided @ Jul 20 2004, 01:07 PM)The ...   Jul 20 2004, 14:08
||- - 2Bdecided   QUOTE (SamK @ Jul 20 2004, 01:08 PM)Wow, 1.5x...   Jul 20 2004, 14:50
|- - SamK   QUOTE (2Bdecided @ Jul 20 2004, 01:07 PM)isn...   Jul 20 2004, 14:19
- - dev0   CODEreplaygain_track_gain = -10.99 dB replaygain_t...   Jul 20 2004, 14:59
- - 2Bdecided   That's different to the latest issue discussed...   Jul 20 2004, 15:13
- - jcoalson   not a bad idea, e.g. replaygain_reference_level=9...   Oct 27 2004, 18:23
RSS Lo-Fi Version Time is now: 21st April 2015 - 06:46
