Recommended Encoder Versions and Settings
QuantumKnot
post Sep 5 2003, 06:39
Recommended Ogg Vorbis Encoders
Please check the more frequently updated wiki for recommended Ogg Vorbis encoders.
This post has been edited by QuantumKnot: Jul 19 2007, 13:08
Zoom
post Nov 30 2004, 05:29
Group: Members (Donating)
I just built an AMD64 system and was updating my software. I tried both of the ICL compiles (P3/AMD & P4) and found that the P4 version was consistently around 2x faster. (*Not double speed)
P4 ICL Compile
Done encoding file "M:\My Music\Track03.ogg"
       File length:  2m 39.0s
       Elapsed time: 0m 08.0s
       Rate:         19.9717
       Average bitrate: 167.0 kb/s
P3/AMD
       Elapsed time: 0m 09.0s
       Rate:         17.7526
So should you use the P4 compile if you have AMD64 or should you still use the P3 version?
- QuantumKnot   Recommended Encoder Versions and Settings   Sep 5 2003, 06:39
- - dev0   You should consider adding links to Garf's sit...   Nov 9 2003, 01:00
- - mekon21   @ QuantumKnot Thanks for the effort, this has bee...   Nov 10 2003, 13:26
- - Jaleel   What are the recommended Vorbis setting for 16k Vo...   Nov 26 2003, 17:36
- - ScorLibran   It should also be noted that with the GT3b1 encode...   Nov 27 2003, 03:19
- - vinu   QuantumKnot's "Recommended Encoder Versio...   Nov 29 2003, 02:19
- - QuantumKnot   QUOTE (vinu @ Nov 29 2003, 11:19 AM)QuantumKn...   Nov 29 2003, 02:24
- - Soren   Time to update for the merged ogg encoder (GTb2 ba...   Dec 10 2003, 18:55
- - sramov   Can anyone update dll's for the CDex into GT3b...   Feb 16 2004, 14:09
- - QuantumKnot   QUOTE (sramov @ Feb 16 2004, 11:09 PM)Can any...   Feb 16 2004, 23:40
- - john33   I'll post links for these as I am still withou...   Feb 16 2004, 23:53
- - john33   OK, I've made all the GT3b2 compiles that I...   Feb 16 2004, 23:59
- - QuantumKnot   I'm assuming the CDex dll's is the one nam...   Feb 17 2004, 00:03
- - john33   QUOTE (QuantumKnot @ Feb 16 2004, 11:03 PM)I...   Feb 17 2004, 00:08
- - OggZealot   It's great to see the 3 month after I asked it...   Feb 17 2004, 03:37
- - QuantumKnot   Point taken. I'll include the official encode...   Feb 17 2004, 10:39
- - prozak   Whatever is done, I think fixing the documentation...   Apr 1 2004, 02:17
- - QuantumKnot   QUOTE (prozak @ Apr 1 2004, 11:17 AM)Whatever...   Apr 2 2004, 00:35
- - rjamorim   Update your links, dude. Everything is still poin...   Apr 2 2004, 00:57
- - QuantumKnot   Done   Apr 2 2004, 01:48
- - Tang   Hi QuantumKnot, I wanted to complain a little bit ...   May 10 2004, 01:58
- - QuantumKnot   This GT3b2 should be exactly the same as the one J...   May 10 2004, 02:13
- - Tang   QUOTE (QuantumKnot @ May 9 2004, 05:13 PM)Thi...   May 11 2004, 03:08
- - Prodoc   QUOTE (QuantumKnot)From the Vorbis listening test ...   May 24 2004, 23:54
- - eagleray   @QN From the way you did the headings it looks li...   May 25 2004, 00:09
- - QuantumKnot   QUOTE (Prodoc @ May 25 2004, 08:54 AM)QUOTE (...   May 25 2004, 00:41
- - bani   QUOTE (QuantumKnot @ Sep 4 2003, 09:39 PM)[Li...   May 30 2004, 11:49
- - QuantumKnot   QUOTE (bani @ May 30 2004, 08:49 PM)not very ...   May 30 2004, 11:56
- - de Mon   I also think GT3b2 can be newbie confusing. Actua...   Jun 13 2004, 23:05
- - xmixahlx   well, theres nothing "stable" about it ...   Jun 14 2004, 01:17
- - Tang   QUOTE (xmixahlx @ Jun 13 2004, 04:17 PM)well,...   Jun 24 2004, 14:24
- - kidi   Hi! Could somebody help me? : I`d like to ...   Jul 17 2004, 22:49
|- - QuantumKnot   QUOTE (kidi @ Jul 18 2004, 07:49 AM)Hi! C...   Jul 18 2004, 03:34
- - NoXFeR   I think it would be nice if some information about...   Aug 3 2004, 14:52
|- - QuantumKnot   QUOTE (NoXFeR @ Aug 3 2004, 11:52 PM)I think ...   Aug 7 2004, 02:34
- - esa372   QUOTE (QuantumKnot @ Sep 4 2003, 10:39 PM)How...   Sep 10 2004, 14:27
|- - Peter Harris   QUOTE (esa372 @ Sep 10 2004, 08:27 AM)But if ...   Sep 10 2004, 17:32
|- - esa372   QUOTE (QuantumKnot @ Sep 11 2004, 05:50 PM)es...   Sep 25 2004, 19:10
- - QuantumKnot   IIRC, the old Vorbis plugin bug caused the vendor ...   Sep 12 2004, 01:50
- - DreamTactix291   Just would like to add that the compile of 1.1 wit...   Sep 25 2004, 04:29
|- - QuantumKnot   QUOTE (DreamTactix291 @ Sep 25 2004, 01:29 PM...   Sep 25 2004, 04:34
- - Garf   Prolly interesting to add: Xiphophorus libVorbis ...   Sep 25 2004, 19:16
- - Tang   Thanks for your EDIT of the 1st post QK... Very ni...   Sep 25 2004, 19:18
|- - jwu42   Nice revision there QK - much appreciated   Sep 26 2004, 17:10
- - sergelac   i'd like to use the new 1.1 but i hate these s...   Sep 27 2004, 03:33
- - esa372   Thanks for the update, QuantumKnot... excellent w...   Sep 27 2004, 05:24
|- - QuantumKnot   QUOTE (esa372 @ Sep 27 2004, 02:24 PM)Thanks ...   Sep 27 2004, 11:50
|- - esa372   QUOTE (QuantumKnot @ Sep 27 2004, 03:50 AM)Th...   Sep 27 2004, 15:39
|- - QuantumKnot   QUOTE (esa372 @ Sep 28 2004, 12:39 AM)Here...   Sep 28 2004, 00:37
- - esa372   Thanks for all your help, QK! It really help...   Sep 28 2004, 15:03
|- - QuantumKnot   QUOTE (esa372 @ Sep 29 2004, 12:03 AM)Thanks ...   Sep 29 2004, 00:37
- - music_man_mpc   I was just wondering why there is no one recommend...   Sep 28 2004, 15:38
- - dawids   I just subscribed to Jetaudio 6 plus to enter the ...   Sep 28 2004, 22:59
- - esa372   Thanks again, QK, for all the info..! It...   Sep 29 2004, 15:02
- - Prodoc   @QuantumKnot:QUOTE INT (impulse_noisetune) however...   Oct 5 2004, 21:17
|- - QuantumKnot   QUOTE (Prodoc @ Oct 6 2004, 06:17 AM)@Quantum...   Oct 6 2004, 02:57
- - LoFiYo   If this can be considered off-topic, I apologize i...   Oct 16 2004, 05:34
- - Madman2003   @QK: higher ITP are normally used with higher qual...   Oct 16 2004, 13:21
|- - QuantumKnot   QUOTE (Madman2003 @ Oct 16 2004, 10:21 PM)@QK...   Oct 19 2004, 13:28
|- - Enig123   As we know ITP uses short blocks more frequently, ...   Oct 19 2004, 14:37
- - Gray_Wolf   Hi, i am very happy with the sound quality of this...   Oct 23 2004, 20:47
|- - QuantumKnot   QUOTE (Gray_Wolf @ Oct 24 2004, 05:47 AM) Hi,...   Oct 24 2004, 02:29
|- - Gray_Wolf   QUOTE (QuantumKnot @ Oct 23 2004, 09:29 PM)Ye...   Oct 24 2004, 17:45
- - Patrick00   vorbis 1.1.0 -q7 great quality, transparent to my ...   Oct 24 2004, 23:38
|- - Gray_Wolf   QUOTE (Patrick00 @ Oct 24 2004, 06:38 PM)vorb...   Oct 25 2004, 12:12
|- - Patrick00   QUOTE (Gray_Wolf @ Oct 25 2004, 03:12 AM) I m...   Oct 25 2004, 23:33
|- - Gray_Wolf   QUOTE (Patrick00 @ Oct 25 2004, 06:33 PM)i re...   Oct 26 2004, 04:21
- - Poromenos   Actually -q-1 sounds better than mp3 128 to me... ...   Oct 25 2004, 18:19
- - [solid]   erm... don't shout on me please... i seriously...   Nov 14 2004, 11:08
|- - QuantumKnot   QUOTE ([solid] @ Nov 14 2004, 08:08 ...   Nov 15 2004, 00:42
- - [solid]   no no, i've meant: gt3b2 at quality 6 - can a ...   Nov 15 2004, 20:24
|- - Dologan   QUOTE ([solid] @ Nov 15 2004, 01:24 ...   Nov 16 2004, 01:31
|- - QuantumKnot   QUOTE ([solid] @ Nov 16 2004, 05:24 ...   Nov 16 2004, 02:33
- - Zoom   I just built an AMD64 system and was updating my s...   Nov 30 2004, 05:29
- - kotrtim   ......the bitrate is similar, 167kbps, so they are...   Nov 30 2004, 05:34
- - QuantumKnot   That's interesting, when considering that AMD3...   Nov 30 2004, 05:44
- - yong   Mimicking GT3b2 with 1.1 CODEfrom QuantumKnot...   Dec 3 2004, 11:58
|- - QuantumKnot   QUOTE (yong @ Dec 3 2004, 08:58 PM)Mimicking ...   Dec 4 2004, 00:12
- - yong   @QuantumKnot: Thanks for the reply, but why try co...   Dec 4 2004, 14:36
|- - QuantumKnot   QUOTE (yong @ Dec 4 2004, 11:36 PM)@QuantumKn...   Dec 4 2004, 15:16
- - zEn   is there a special oggenc version (with P4 optimiz...   Dec 29 2004, 17:26
- - TobWen   Hi there, I've been off this site for about a...   Dec 30 2004, 03:03
|- - music_man_mpc   QUOTE (TobWen @ Dec 29 2004, 06:03 PM)Hi ther...   Dec 30 2004, 03:27
- - QuantumKnot   Vorbis 1.1 is based on aoTuV beta 2. The recent a...   Dec 30 2004, 03:28
- - TobWen   thanks for your fast and professional help! Ac...   Dec 30 2004, 03:42
|- - QuantumKnot   QUOTE (TobWen @ Dec 30 2004, 12:42 PM)thanks ...   Dec 30 2004, 03:45
- - LiTEMaTTeR   hmmm... AO; aoTuV b2 [20040420] (based on Xiph.Org...   Jan 4 2005, 08:56
|- - QuantumKnot   QUOTE (LiTEMaTTeR @ Jan 4 2005, 05:56 PM)Anyw...   Jan 6 2005, 01:09
- - mono13   i find ogg's great in a komputer stg game onl...   Feb 1 2005, 05:35
- - Buffalo Bill   Great topic! Answered almost all my questions ...   Feb 14 2005, 06:27
- - QuantumKnot   I think EAC is still the best ripper for detecting...   Feb 14 2005, 06:35
- - Buffalo Bill   Yeah, but will EAC encode my OGG Vorbis files at 5...   Feb 14 2005, 06:44
|- - dewey1973   QUOTE (Buffalo Bill @ Feb 13 2005, 09:44 PM)Y...   Feb 17 2005, 18:25
- - DreamTactix291   If you tell it to call oggenc and encode at -q 10 ...   Feb 15 2005, 06:30
- - alter4   It seems new Qk test build is recommended encoder ...   Feb 28 2005, 09:55
|- - QuantumKnot   QUOTE (alter4 @ Feb 28 2005, 06:55 PM)It seem...   Feb 28 2005, 11:16
- - Prodoc   Isn't the Oggenc2.4 serie (IMPULSE_TRIGGER_PRO...   Mar 3 2005, 12:44
|- - QuantumKnot   QUOTE (Prodoc @ Mar 3 2005, 09:44 PM)Isn...   Mar 3 2005, 12:55
- - evilchickenking   I have an amd64 processor and i was curious to fin...   Mar 14 2005, 19:59
- - QuantumKnot   QUOTE (evilchickenking @ Mar 15 2005, 04:59 A...   Mar 15 2005, 00:43
3 Pages V   1 2 3 >
RSS Lo-Fi Version Time is now: 31st March 2015 - 04:39
