Topic: foo_infobox (Read 165486 times) previous topic - next topic
foo_infobox
Reply #225
Thanks for keeping this in development bluenet
Ed
foo_infobox
Reply #226
Introduces a new problem on w2k sp4, latest fb2k:
foo_infobox
Reply #227
How to reproduce this problem? I havn't any Wavpack file.
foo_infobox
Reply #228
Why not just encode a second or two of silence to a wavpack file with fb2k?  The support is builtin, you just need to supply the wavpack encoder.  I'm not sure if there are other ways to trigger the problem, I've not looked further into it.
foo_infobox
Reply #229
Somebody a working download link? The provided one is dead
Ciao
Thomas
foo_infobox
Reply #230
Sorry, I was absent.
It's probably not a wavpack problem, but rather a display bug when having ultra long tags. It's the "review"-tag here. I've uploaded a 0.5s (30 kByte) file with the exact tags, you'll reproduce it.
a.wv
foo_infobox
Reply #231
Slightly different here: Instead of overlaying characters, there are no characters at all. Just an empty, yet clickable line.
foobar2000 0.9.2, Windows XP Prof SP 2
Nothing is impossible if you don't need to do it yourself.
foo_infobox
Reply #232
works fine here...
foobar2000 0.9.2, Windows XP Prof SP 2, foo_infobox v2.0.3...
foo_infobox
Reply #233
System: foobar2000 0.9.2, Windows XP Prof SP 2, foo_infobox v2.0.3
Perfect here.
Ciao
Thomas
foo_infobox
Reply #234
Still comlaining  Reload info still doesnt work, will you implement this, please? Without this feature plugin is almost useless for me.
foo_infobox
Reply #236
Here is a currently working link.
Er, apparently it's not alive anymore.  Seems that gro.clinux.org is down in general.  Does anyone have a mirror of the latest version of foo_infobox?  Having a tough time finding it.
(it should be a standard component, imo -- extremely useful!)
foo_infobox
Reply #237
Looks like I posted too soon; this appears to be a connectivity issue with my provider.  My apologies.
I managed to access the download page through a proxy if anyone else is having a similar issue:
http://anonymouse.org/cgi-bin/anon-www.cgi...release_id=1095
foo_infobox
Reply #239
Found a crash bug in this!
With Foobar 0.9.3 and foo_infobox 2.0.3 and change focus checked, there is a potential for more than one "save changes?" confirmation dialog to appear, which causes foobar to then crash.
Example: Make changes, hit next, song that is currently playing ends and new snog starts. Focus of infobox changes and a new "save changes" confirmation is presented. Clicking yes, no, cancel causes crash in foobar.
foo_infobox
Reply #240
I've had this happen to me several times. Very annoying.
foo_infobox
Reply #241
yep, confirm that.
foo_infobox
Reply #242
Hi!
I'm planning to make a tagging panel.
As this will be my first c++ code, it would be great if someone could send me the sourcecode of this component. This would really make things easier for me
foo_infobox
Reply #244
Will this bug ever get fixed? Hope this component is not dead, i like it more than the default info-box. :/
Also i have a different crash-bug on this one. For me the "Save changes?" box is not even showing up when i edit the tags of a file, DONT save them and just click on the next song so it changes focus. Its crashing then right away and giving me a "Unhandled exception: Invalid nested modal call" error. This one is really annoying since it's always crashing in the wrong moments. :/
Oh and here is the requested download link for the "latest" version i could get:
foo_infobox_v203.7z
SING A SONG -No Music, No Life-
foo_infobox
Reply #246
it's strange but from the certain time instead of File Info Box on multiply files ("File Info" in context menu) appears standard properties/metadata dialog. is it a bug? or how can i edit multiply files with File Info Box?
foo_infobox
Reply #247
you can't...
foo_infobox
Reply #248
Matyas,
ok, thanks for your reply. is there any explanations of that?
foo_infobox
Reply #249
@mercury: sorry for the sparse answer.
As I see it, infobox was desiged to ease the tagging of single files, with the possibility of navigating between files easily (AutoSave, Next, Prev buttons). However, it was not designed to handle multifile-tagging at once, therefore anytime you select more than 1 file and call infobox, the standard properties dialog is displayed which handles this situation well and very effectvely using the scripts.
