foo_infobox, a substitute for buildin file info box
/\/irana
post Oct 19 2003, 10:33
I have written a small plugin for enhancing the fuction of show file info box.
Here is the screenshot
Edit1: copy the post on "Third-party plugins" thread
Component name - foo_infobox
Component type (appropriate section) - General
Which foobar2000 version the component works with - 0.7.1
Short description of the component - A substitute for the build-in file info box
Compile date - October 18, 2003
Download link - http://pelit.koillismaa.fi/plugins/general.php#8
Some explanation about "Override codepage" option:
If you check that option,then you can select any codepage installed in your system.foo_infobox will convert all meta tags from ANSI to UTF-8 using selected codepage,instead of using system default codepage.
It is useful for reading some tags not stroed in Unicode correctly.
Edit:updated download link to new version
This post has been edited by /\/irana: Feb 19 2004, 18:00
/\/irana
post Dec 4 2003, 12:06
QUOTE (mazy @ Oct 28 2003, 04:42 PM)
great plugin!
i would like buttons for copying info to clipboard:
- filename
- directory
- full filename (path + filename)
i know i can do this using copy info comman, however these could still come handy
I missed this post until neoufo51 pump it.
I will add this feature in next version ASAP,perhaps in this weekend.
@herr klang
so just a few more suggestions for this plugin..
what'd be really nice in the multi-edit box is if the default fields displayed in the normal, single-item view were there too, similar to iTunes.
Hmm...I just uninstalled iTune a few days ago,and I can't understand what you mean exactly.
@treech
http://www.hydrogenaudio.org/forums/index....showtopic=15524
This thread has more discussion about multi-type tags.
- /\/irana   foo_infobox   Oct 19 2003, 10:33
- - neoufo51   Now this is a worthy replacement... Well done. E...   Oct 19 2003, 10:39
- - sld   It's nice. Quite a bit more intuitive than the...   Oct 19 2003, 10:51
- - kalmark   Some of my files give an error when opening the ...   Oct 19 2003, 11:02
- - kode54   Slight problem with the group boxes. (image) Stre...   Oct 19 2003, 11:38
- - /\/irana   @kode Fixed and uploaded,thanks @kalmark I don...   Oct 19 2003, 12:09
- - neoufo51   Got the new dll, but its now saying that XP doesnt...   Oct 19 2003, 12:42
- - ilikedirtthe2nd   this crash appeared (after approx a minute), when ...   Oct 19 2003, 13:15
- - /\/irana   QUOTE (neoufo51 @ Oct 19 2003, 03:42 AM)Got t...   Oct 19 2003, 13:17
- - /\/irana   It seem there are many bugs in this plugin. I have...   Oct 19 2003, 13:30
- - /\/irana   v1.2.4 uploaded Just fixed a fool bug causing the ...   Oct 19 2003, 13:45
- - guruboolez   Is there any way to sort meta fields [other] by di...   Oct 19 2003, 13:57
- - /\/irana   v1.2.5 uploaded,version num increase so fast @k...   Oct 19 2003, 14:26
- - guruboolez   Small suggestion (but don't take this one in c...   Oct 19 2003, 14:50
- - kalmark   QUOTE (/\/irana @ Oct 19 2003, 03:26 PM)...   Oct 19 2003, 15:15
- - /\/irana   V1.2.6 uploaded Now it is resizeable. @guruboolez...   Oct 19 2003, 17:21
- - guruboolez   For me, it's perfect. Thank you very much. The...   Oct 19 2003, 17:34
- - nyarlathotep   QUOTE (guruboolez @ Oct 19 2003, 06:34 PM)Som...   Oct 19 2003, 17:41
- - guruboolez   Merci very much   Oct 19 2003, 17:42
- - /\/irana   QUOTE Some explanation about "Override codepa...   Oct 19 2003, 17:42
- - /\/irana   v1.2.6.1 uploaded No more change,only fixed the fl...   Oct 20 2003, 03:04
- - Luxus   great plugin .. i love it... i hope this replace ...   Oct 20 2003, 03:24
- - neoufo51   Hmmmm... getting the "invalid windows XP imag...   Oct 20 2003, 04:08
- - /\/irana   QUOTE (neoufo51 @ Oct 19 2003, 07:08 PM)Hmmmm...   Oct 20 2003, 05:27
- - /\/irana   v1.2.7 uploaded download link:foo_infobox.dll Ad...   Oct 21 2003, 09:44
- - phwip   QUOTE (/\/irana @ Oct 21 2003, 09:44 AM)...   Oct 21 2003, 09:56
- - phwip   I am having trouble with this new version. When I...   Oct 21 2003, 10:06
- - nyarlathotep   Same issue here. With both v1.2.6 and v1.2.7.   Oct 21 2003, 10:08
- - Messer   1. Unzip -> you'll get foo_infobox file (wi...   Oct 21 2003, 10:19
- - Southpaw32   "Cannot Open File. Does not appear to be a va...   Oct 21 2003, 10:24
- - /\/irana   damn I check the files,it work here. I zipped th...   Oct 21 2003, 10:27
- - Southpaw32   Yup, It unzips with WinRAR just fine. but WinZip ...   Oct 21 2003, 10:29
- - Messer   QUOTE (/\/irana @ Oct 21 2003, 11:27 AM)...   Oct 21 2003, 10:30
- - Messer   Just managed to crash infobox: 1. open info box, ...   Oct 21 2003, 10:48
- - kalmark   What I got was gzipped .zip file --- foo_infobox.z...   Oct 21 2003, 10:50
- - /\/irana   QUOTE I checked it with "file" *nix util...   Oct 21 2003, 10:51
- - /\/irana   QUOTE (Messer @ Oct 21 2003, 01:48 AM)Just ma...   Oct 21 2003, 11:09
- - Messer   QUOTE (kalmark @ Oct 21 2003, 11:50 AM)What I...   Oct 21 2003, 11:18
- - x_x   hi, /\/irana: could u make it replace the ori...   Oct 21 2003, 11:36
- - phwip   You can remove the original yourself in Preference...   Oct 21 2003, 11:38
- - /\/irana   QUOTE (phwip @ Oct 21 2003, 12:56 AM)QUOTE (/...   Oct 21 2003, 11:53
- - phwip   Excellent. Thank you.   Oct 21 2003, 11:55
- - rectangle   QUOTE (/\/irana @ Oct 21 2003, 12:44 AM)...   Oct 21 2003, 11:58
- - kode54   Redownload. EDIT again: The server is gzip encod...   Oct 21 2003, 12:06
- - /\/irana   I don't have my own web server I uploaded them...   Oct 21 2003, 12:21
- - phwip   Is there any reason to zip it? The original non-z...   Oct 21 2003, 12:27
- - rectangle   QUOTE (kode54 @ Oct 21 2003, 03:06 AM)Rename ...   Oct 21 2003, 12:32
- - kode54   Register for hosting services? :B   Oct 21 2003, 12:46
- - /\/irana   QUOTE Register for hosting services? :B Temporary ...   Oct 21 2003, 14:28
- - DotNoir   The first zip link worked fine for me (having a wi...   Oct 21 2003, 15:06
- - /\/irana   QUOTE (DotNoir @ Oct 21 2003, 06:06 AM)The fi...   Oct 21 2003, 15:16
- - phwip   The link to the zip file on www.yaguo.com doesn...   Oct 21 2003, 15:16
- - /\/irana   Thanks It seem I must find other webhost.That...   Oct 21 2003, 15:36
- - TurinsRevenge   Thanks very much for such a useful plug-in First...   Oct 25 2003, 17:05
- - /\/irana   v1.3.1 download link:foo_infobox.zip mirror:foo_i...   Oct 25 2003, 18:13
- - anza   One word: Great!   Oct 25 2003, 18:16
- - nyarlathotep   Another word: Great! The first link didn...   Oct 25 2003, 18:21
- - /\/irana   QUOTE (nyarlathotep @ Oct 25 2003, 09:21 AM)A...   Oct 25 2003, 18:36
- - TurinsRevenge   Same here. First link is NG. It looks like a ref...   Oct 25 2003, 23:49
- - PoisonDan   QUOTE (/\/irana @ Oct 21 2003, 02:36 PM)...   Oct 26 2003, 14:45
- - Dora68   ... thanks a lot for the new infobox! It works...   Oct 26 2003, 20:34
- - guruboolez   Thanks, too, especially for tag sorting: I really ...   Oct 26 2003, 20:44
- - Silverbolt   whoa, great plugin; foobar's default infobox b...   Oct 27 2003, 00:24
- - zegilles   QUOTE (guruboolez @ Oct 26 2003, 09:44 PM)Tha...   Oct 27 2003, 09:20
- - Sniffer   Very Good Plugin. Thanks for your work.   Oct 28 2003, 12:13
- - foosion   <ot> QUOTE (Silverbolt @ Oct 27 2003, 0...   Oct 28 2003, 12:55
- - /\/irana   v1.3.2 changes -most of Silverbolt's suggesti...   Oct 28 2003, 17:58
- - mazy   great plugin! i would like buttons for copyin...   Oct 29 2003, 01:42
- - neoufo51   Is the project dead?   Dec 3 2003, 21:18
- - atici   This plugin seems great. Is it possible to include...   Dec 3 2003, 21:28
- - herr klang   so just a few more suggestions for this plugin.. ...   Dec 4 2003, 05:48
- - treech   What would be really useful (at least for me) is t...   Dec 4 2003, 10:38
- - /\/irana   QUOTE (mazy @ Oct 28 2003, 04:42 PM)great plu...   Dec 4 2003, 12:06
- - atici   Is it possible that I could now erase the original...   Dec 4 2003, 16:40
- - RedawgTS   Great plugin. Very useful. Now if it could automat...   Dec 5 2003, 00:41
- - bluenet   QUOTE (atici @ Dec 4 2003, 07:40 AM)Is it pos...   Dec 5 2003, 02:09
- - /\/irana   v1.3.3 Added copy command button.It is independen...   Dec 8 2003, 17:36
- - DustMagnet   I love this plug-in! BTW, the dll from the ma...   Dec 10 2003, 04:29
- - neoufo51   Ah, thank you. This really should be considered ...   Dec 10 2003, 04:39
- - phwip   QUOTE (DustMagnet @ Dec 10 2003, 04:29 AM)BTW...   Dec 10 2003, 10:24
- - DustMagnet   QUOTE (phwip @ Dec 10 2003, 01:24 AM)QUOTE (D...   Dec 11 2003, 03:38
- - phwip   I did understand what you meant first time, just d...   Dec 11 2003, 09:34
- - /\/irana   QUOTE (DustMagnet @ Dec 10 2003, 06:38 PM)QUO...   Dec 11 2003, 11:42
- - Silverbolt   There seems to be a bug in 1.3.3. You can no longe...   Dec 11 2003, 18:19
- - /\/irana   QUOTE (Silverbolt @ Dec 11 2003, 09:19 AM)The...   Dec 12 2003, 11:13
- - /\/irana   updated dll download link to v1.3.3c Now you can ...   Dec 12 2003, 13:49
- - atici   Sorry. Latest link seems to be dead.   Dec 12 2003, 16:36
- - kalmark   QUOTE (atici @ Dec 12 2003, 05:36 PM)Sorry. L...   Dec 12 2003, 16:41
- - Silverbolt   Found a very small bug (nitpicking really). Standa...   Dec 18 2003, 01:25
- - mixmixmix   awesome plugin. thanks! haven't found any...   Dec 18 2003, 02:10
- - /\/irana   QUOTE (Silverbolt @ Dec 17 2003, 04:25 PM)Fou...   Dec 18 2003, 18:09
- - aron   /\/irana: are there any plans to make infobox...   Dec 20 2003, 00:35
- - Silverbolt   aron: it already does :] select the multiple items...   Dec 20 2003, 01:01
- - RedawgTS   I think aron means that he want's it to automa...   Dec 20 2003, 04:09
- - /\/irana   QUOTE (RedawgTS @ Dec 19 2003, 07:09 PM)I thi...   Dec 20 2003, 08:29
- - aron   QUOTE (RedawgTS @ Dec 19 2003, 07:09 PM)I thi...   Dec 20 2003, 11:04
- - zegilles   I love the way it works now. That is to say you ca...   Dec 20 2003, 11:52
- - aron   QUOTE (zegilles @ Dec 20 2003, 02:52 AM)I lov...   Dec 20 2003, 12:20
- - zegilles   QUOTE (aron @ Dec 20 2003, 12:20 PM)QUOTE (ze...   Dec 20 2003, 12:37
- - aron   QUOTE (zegilles @ Dec 20 2003, 03:37 AM)QUOTE...   Dec 20 2003, 12:40
3 Pages V   1 2 3 >
Closed TopicStart new topic
RSS Lo-Fi Version Time is now: 28th July 2015 - 16:39
