foo_infobox, a substitute for buildin file info box
/\/irana
post Oct 19 2003, 10:33
I have written a small plugin for enhancing the fuction of show file info box.
Here is the screenshot
Edit1: copy the post on "Third-party plugins" thread
Component name - foo_infobox
Component type (appropriate section) - General
Which foobar2000 version the component works with - 0.7.1
Short description of the component - A substitute for the build-in file info box
Compile date - October 18, 2003
Download link - http://pelit.koillismaa.fi/plugins/general.php#8
Some explanation about "Override codepage" option:
If you check that option,then you can select any codepage installed in your system.foo_infobox will convert all meta tags from ANSI to UTF-8 using selected codepage,instead of using system default codepage.
It is useful for reading some tags not stroed in Unicode correctly.
Edit:updated download link to new version
This post has been edited by /\/irana: Feb 19 2004, 18:00
sld
post Oct 19 2003, 10:51
It's nice. Quite a bit more intuitive than the current one.
What do the options 'change focus' and 'follow cursor' do? Would they actually be relevant in the file info box?
Edit:
Answer: 'Change focus' synchronises the selected song in the playlist to the file displayed in the info box and 'Follow cursor' synchronises the file info box display to the song selected in the playlist. Yes, very relevant indeed. biggrin.gif
This post has been edited by sld: Oct 19 2003, 11:00
- /\/irana   foo_infobox   Oct 19 2003, 10:33
- - neoufo51   Now this is a worthy replacement... Well done. E...   Oct 19 2003, 10:39
- - sld   It's nice. Quite a bit more intuitive than the...   Oct 19 2003, 10:51
- - kalmark   Some of my files give an error when opening the ...   Oct 19 2003, 11:02
- - kode54   Slight problem with the group boxes. (image) Stre...   Oct 19 2003, 11:38
- - /\/irana   @kode Fixed and uploaded,thanks @kalmark I don...   Oct 19 2003, 12:09
- - neoufo51   Got the new dll, but its now saying that XP doesnt...   Oct 19 2003, 12:42
- - ilikedirtthe2nd   this crash appeared (after approx a minute), when ...   Oct 19 2003, 13:15
- - /\/irana   QUOTE (neoufo51 @ Oct 19 2003, 03:42 AM)Got t...   Oct 19 2003, 13:17
- - /\/irana   It seem there are many bugs in this plugin. I have...   Oct 19 2003, 13:30
- - /\/irana   v1.2.4 uploaded Just fixed a fool bug causing the ...   Oct 19 2003, 13:45
- - guruboolez   Is there any way to sort meta fields [other] by di...   Oct 19 2003, 13:57
- - /\/irana   v1.2.5 uploaded,version num increase so fast @k...   Oct 19 2003, 14:26
- - guruboolez   Small suggestion (but don't take this one in c...   Oct 19 2003, 14:50
- - kalmark   QUOTE (/\/irana @ Oct 19 2003, 03:26 PM)...   Oct 19 2003, 15:15
- - /\/irana   V1.2.6 uploaded Now it is resizeable. @guruboolez...   Oct 19 2003, 17:21
- - guruboolez   For me, it's perfect. Thank you very much. The...   Oct 19 2003, 17:34
- - nyarlathotep   QUOTE (guruboolez @ Oct 19 2003, 06:34 PM)Som...   Oct 19 2003, 17:41
- - guruboolez   Merci very much   Oct 19 2003, 17:42
- - /\/irana   QUOTE Some explanation about "Override codepa...   Oct 19 2003, 17:42
- - /\/irana   v1.2.6.1 uploaded No more change,only fixed the fl...   Oct 20 2003, 03:04
- - Luxus   great plugin .. i love it... i hope this replace ...   Oct 20 2003, 03:24
- - neoufo51   Hmmmm... getting the "invalid windows XP imag...   Oct 20 2003, 04:08
- - /\/irana   QUOTE (neoufo51 @ Oct 19 2003, 07:08 PM)Hmmmm...   Oct 20 2003, 05:27
- - /\/irana   v1.2.7 uploaded download link:foo_infobox.dll Ad...   Oct 21 2003, 09:44
- - phwip   QUOTE (/\/irana @ Oct 21 2003, 09:44 AM)...   Oct 21 2003, 09:56
- - phwip   I am having trouble with this new version. When I...   Oct 21 2003, 10:06
- - nyarlathotep   Same issue here. With both v1.2.6 and v1.2.7.   Oct 21 2003, 10:08
- - Messer   1. Unzip -> you'll get foo_infobox file (wi...   Oct 21 2003, 10:19
- - Southpaw32   "Cannot Open File. Does not appear to be a va...   Oct 21 2003, 10:24
- - /\/irana   damn I check the files,it work here. I zipped th...   Oct 21 2003, 10:27
- - Southpaw32   Yup, It unzips with WinRAR just fine. but WinZip ...   Oct 21 2003, 10:29
- - Messer   QUOTE (/\/irana @ Oct 21 2003, 11:27 AM)...   Oct 21 2003, 10:30
- - Messer   Just managed to crash infobox: 1. open info box, ...   Oct 21 2003, 10:48
- - kalmark   What I got was gzipped .zip file --- foo_infobox.z...   Oct 21 2003, 10:50
- - /\/irana   QUOTE I checked it with "file" *nix util...   Oct 21 2003, 10:51
- - /\/irana   QUOTE (Messer @ Oct 21 2003, 01:48 AM)Just ma...   Oct 21 2003, 11:09
- - Messer   QUOTE (kalmark @ Oct 21 2003, 11:50 AM)What I...   Oct 21 2003, 11:18
- - x_x   hi, /\/irana: could u make it replace the ori...   Oct 21 2003, 11:36
- - phwip   You can remove the original yourself in Preference...   Oct 21 2003, 11:38
- - /\/irana   QUOTE (phwip @ Oct 21 2003, 12:56 AM)QUOTE (/...   Oct 21 2003, 11:53
- - phwip   Excellent. Thank you.   Oct 21 2003, 11:55
- - rectangle   QUOTE (/\/irana @ Oct 21 2003, 12:44 AM)...   Oct 21 2003, 11:58
- - kode54   Redownload. EDIT again: The server is gzip encod...   Oct 21 2003, 12:06
- - /\/irana   I don't have my own web server I uploaded them...   Oct 21 2003, 12:21
- - phwip   Is there any reason to zip it? The original non-z...   Oct 21 2003, 12:27
- - rectangle   QUOTE (kode54 @ Oct 21 2003, 03:06 AM)Rename ...   Oct 21 2003, 12:32
- - kode54   Register for hosting services? :B   Oct 21 2003, 12:46
- - /\/irana   QUOTE Register for hosting services? :B Temporary ...   Oct 21 2003, 14:28
- - DotNoir   The first zip link worked fine for me (having a wi...   Oct 21 2003, 15:06
- - /\/irana   QUOTE (DotNoir @ Oct 21 2003, 06:06 AM)The fi...   Oct 21 2003, 15:16
- - phwip   The link to the zip file on www.yaguo.com doesn...   Oct 21 2003, 15:16
- - /\/irana   Thanks It seem I must find other webhost.That...   Oct 21 2003, 15:36
- - TurinsRevenge   Thanks very much for such a useful plug-in First...   Oct 25 2003, 17:05
- - /\/irana   v1.3.1 download link:foo_infobox.zip mirror:foo_i...   Oct 25 2003, 18:13
- - anza   One word: Great!   Oct 25 2003, 18:16
- - nyarlathotep   Another word: Great! The first link didn...   Oct 25 2003, 18:21
- - /\/irana   QUOTE (nyarlathotep @ Oct 25 2003, 09:21 AM)A...   Oct 25 2003, 18:36
- - TurinsRevenge   Same here. First link is NG. It looks like a ref...   Oct 25 2003, 23:49
- - PoisonDan   QUOTE (/\/irana @ Oct 21 2003, 02:36 PM)...   Oct 26 2003, 14:45
- - Dora68   ... thanks a lot for the new infobox! It works...   Oct 26 2003, 20:34
- - guruboolez   Thanks, too, especially for tag sorting: I really ...   Oct 26 2003, 20:44
- - Silverbolt   whoa, great plugin; foobar's default infobox b...   Oct 27 2003, 00:24
- - zegilles   QUOTE (guruboolez @ Oct 26 2003, 09:44 PM)Tha...   Oct 27 2003, 09:20
- - Sniffer   Very Good Plugin. Thanks for your work.   Oct 28 2003, 12:13
- - foosion   <ot> QUOTE (Silverbolt @ Oct 27 2003, 0...   Oct 28 2003, 12:55
- - /\/irana   v1.3.2 changes -most of Silverbolt's suggesti...   Oct 28 2003, 17:58
- - mazy   great plugin! i would like buttons for copyin...   Oct 29 2003, 01:42
- - neoufo51   Is the project dead?   Dec 3 2003, 21:18
- - atici   This plugin seems great. Is it possible to include...   Dec 3 2003, 21:28
- - herr klang   so just a few more suggestions for this plugin.. ...   Dec 4 2003, 05:48
- - treech   What would be really useful (at least for me) is t...   Dec 4 2003, 10:38
- - /\/irana   QUOTE (mazy @ Oct 28 2003, 04:42 PM)great plu...   Dec 4 2003, 12:06
- - atici   Is it possible that I could now erase the original...   Dec 4 2003, 16:40
- - RedawgTS   Great plugin. Very useful. Now if it could automat...   Dec 5 2003, 00:41
- - bluenet   QUOTE (atici @ Dec 4 2003, 07:40 AM)Is it pos...   Dec 5 2003, 02:09
- - /\/irana   v1.3.3 Added copy command button.It is independen...   Dec 8 2003, 17:36
- - DustMagnet   I love this plug-in! BTW, the dll from the ma...   Dec 10 2003, 04:29
- - neoufo51   Ah, thank you. This really should be considered ...   Dec 10 2003, 04:39
- - phwip   QUOTE (DustMagnet @ Dec 10 2003, 04:29 AM)BTW...   Dec 10 2003, 10:24
- - DustMagnet   QUOTE (phwip @ Dec 10 2003, 01:24 AM)QUOTE (D...   Dec 11 2003, 03:38
- - phwip   I did understand what you meant first time, just d...   Dec 11 2003, 09:34
- - /\/irana   QUOTE (DustMagnet @ Dec 10 2003, 06:38 PM)QUO...   Dec 11 2003, 11:42
- - Silverbolt   There seems to be a bug in 1.3.3. You can no longe...   Dec 11 2003, 18:19
- - /\/irana   QUOTE (Silverbolt @ Dec 11 2003, 09:19 AM)The...   Dec 12 2003, 11:13
- - /\/irana   updated dll download link to v1.3.3c Now you can ...   Dec 12 2003, 13:49
- - atici   Sorry. Latest link seems to be dead.   Dec 12 2003, 16:36
- - kalmark   QUOTE (atici @ Dec 12 2003, 05:36 PM)Sorry. L...   Dec 12 2003, 16:41
- - Silverbolt   Found a very small bug (nitpicking really). Standa...   Dec 18 2003, 01:25
- - mixmixmix   awesome plugin. thanks! haven't found any...   Dec 18 2003, 02:10
- - /\/irana   QUOTE (Silverbolt @ Dec 17 2003, 04:25 PM)Fou...   Dec 18 2003, 18:09
- - aron   /\/irana: are there any plans to make infobox...   Dec 20 2003, 00:35
- - Silverbolt   aron: it already does :] select the multiple items...   Dec 20 2003, 01:01
- - RedawgTS   I think aron means that he want's it to automa...   Dec 20 2003, 04:09
- - /\/irana   QUOTE (RedawgTS @ Dec 19 2003, 07:09 PM)I thi...   Dec 20 2003, 08:29
- - aron   QUOTE (RedawgTS @ Dec 19 2003, 07:09 PM)I thi...   Dec 20 2003, 11:04
- - zegilles   I love the way it works now. That is to say you ca...   Dec 20 2003, 11:52
- - aron   QUOTE (zegilles @ Dec 20 2003, 02:52 AM)I lov...   Dec 20 2003, 12:20
- - zegilles   QUOTE (aron @ Dec 20 2003, 12:20 PM)QUOTE (ze...   Dec 20 2003, 12:37
- - aron   QUOTE (zegilles @ Dec 20 2003, 03:37 AM)QUOTE...   Dec 20 2003, 12:40
3 Pages V   1 2 3 >
Closed TopicStart new topic
RSS Lo-Fi Version Time is now: 4th September 2015 - 03:12
