Vorbis development, status & patent issues, PART 2 - Technical discussion
Gabriel
post Sep 25 2003, 14:37
LAME developer
Moderator comment
Currently the Vorbis patent issue covers these threads:
Vorbis development, status & patent issues PART 1 - NON-technical discussion
Vorbis development, status & patent issues PART 2 - Technical discussion (This thread)
/Moderator comment
By looking at this:
http://www.xiph.org/archives/vorbis-dev/20...2/index.html#83
it seems that Xiph (at least in 2000) was open to the idea of disclosing the patent research.
Is this position changed now, or does it still stand?
petracci
post Sep 26 2003, 09:16
I mean - in my opinion, the purpose of the Claim 1  is only to faciliate the need for the window switching from long to short blocks, in case of signal amplitude change - not to elaborate the exact switching method - because the patent itself is about MDCT switched filterbank and not about the switching methods / threshold estimations. That's why they stated "signal amplitude change" only, because this is the reason for block switching in any case - no matter how you look at the signal as I already explained in my previous post.
Next time, let me read both your posts before I try to respond B)
You argue that the actual patent is only about window switching, and that claim 1 tries to clarify why you should switch (and why this patent is of any use).
My view is that the patent comprises 3 innovations as stated in my previous post:
1 - The window switching for overlapped transforms
2 - The method of obtaining transition windows
3 - The use of (time-domain) signal amplitude changes as a steering mechanism
Elaborate methods for block switching are covered in some later patents from Johnson (M/S psychoacoustic model patent - PE based switching) and Herre/Brandenburg (patent covering time-domain block switching only, dating from 1998 IIRC).  Dolby AC3 uses other time-domain block switching method which might be patented but I am not sure.
This shows that it is/was allowed to make a patent of different steering mechanisms. Unfortunately, it does not offer us a solution for who is right.
If I am correct in saying that the actual steering mechanism is part of the patent, then different mechanisms are also patentable. If you are correct in saying that there is no claim in the patent on an actual steering mechanism, then there is still room for patenting specific steering mechanisms.
How is this all important for Vorbis? From your explanation of the way a patent works, Vorbis is either safe from the patent (my view) or not (your view).
I can obviously not say that either of us is right, only that I can understand that after reading this particular patent, one might have the idea that one could come up with a time-varying overlapped transform coder that is safe from this patent.
There are many of similar patents out there. For each of these, a detailed study/investigation has to be made to see where the loopholes are. As a programmer/researcher/developer, I would not be bothered by this, but as a company offering its customer "patent-free" solutions, I would make sure that I can provide a basis for my claims.
- Gabriel   Vorbis development, status & patent issues   Sep 25 2003, 14:37
- - c_haese   QUOTE (Ivan Dimkovic @ Sep 25 2003, 08:12 AM)...   Sep 25 2003, 14:43
- - Ivan Dimkovic   QUOTE Fair enough, let's start a scientific di...   Sep 25 2003, 14:53
- - Ivan Dimkovic   One more thing - the claims are not related to any...   Sep 25 2003, 14:59
- - menno   Claim 1 from patent US5214742: QUOTE 1. In a metho...   Sep 25 2003, 15:20
- - menno   1.3. High-level Decode Process It seems that the ...   Sep 25 2003, 15:41
- - Ivan Dimkovic   Ok, so we have a pretty clear basis for a serious ...   Sep 25 2003, 15:43
- - c_haese   I've already said everything I'm qualified...   Sep 25 2003, 16:03
- - Ivan Dimkovic   Well, at least there is a nice bunch of factual da...   Sep 25 2003, 16:14
- - petracci   QUOTE (Ivan Dimkovic @ Sep 25 2003, 05:36 PM)...   Sep 25 2003, 16:50
- - Ivan Dimkovic   QUOTE Claim 1 does not claim the "windowing/o...   Sep 25 2003, 16:56
- - petracci   QUOTE (Ivan Dimkovic @ Sep 25 2003, 05:56 PM)...   Sep 25 2003, 17:07
- - Ivan Dimkovic   QUOTE First of all, do you also think that claim 1...   Sep 25 2003, 17:22
- - petracci   Yes, Claim 4 is not easy to avoid. Claim 6 points ...   Sep 25 2003, 17:34
- - c_haese   QUOTE (Ivan Dimkovic @ Sep 25 2003, 11:22 AM)...   Sep 25 2003, 17:36
- - Ivan Dimkovic   QUOTE Wouldn't all claims have to apply to mak...   Sep 25 2003, 18:30
- - jmvalin   QUOTE (petracci @ Sep 25 2003, 11:34 AM)Yes, ...   Sep 25 2003, 23:31
- - JohnV   QUOTE (jmvalin @ Sep 26 2003, 01:31 AM)QUOTE ...   Sep 26 2003, 00:23
- - Ivan Dimkovic   I took a deeper look at the patent - It seems that...   Sep 26 2003, 01:05
- - Ivan Dimkovic   I mean - in my opinion, the purpose of the Claim 1...   Sep 26 2003, 01:13
- - ErikS   QUOTE (Ivan Dimkovic @ Sep 26 2003, 01:13 AM)...   Sep 26 2003, 01:48
- - petracci   QUOTE I took a deeper look at the patent - It seem...   Sep 26 2003, 08:59
- - Ivan Dimkovic   QUOTE E.g. incorporating the rate in the switching...   Sep 26 2003, 09:05
- - petracci   QUOTE I mean - in my opinion, the purpose of the C...   Sep 26 2003, 09:16
- - menno   Doesn't Parseval's Theorem say that freque...   Sep 26 2003, 09:19
- - Ivan Dimkovic   QUOTE I can obviously not say that either of us is...   Sep 26 2003, 09:21
- - petracci   QUOTE (Ivan Dimkovic @ Sep 26 2003, 10:21 AM)...   Sep 26 2003, 09:31
- - Ivan Dimkovic   I think it was: QUOTE 5853 Michael J. Smithers,Br...   Sep 26 2003, 09:48
- - petracci   QUOTE Doesn't Parseval's Theorem say that ...   Sep 26 2003, 09:49
- - petracci   QUOTE (Ivan Dimkovic @ Sep 26 2003, 10:48 AM)...   Sep 26 2003, 09:57
- - Ivan Dimkovic   I think we got into one very serous discussion rig...   Sep 26 2003, 10:04
- - petracci   QUOTE I think we got into one very serous discussi...   Sep 26 2003, 10:12
- - Ivan Dimkovic   http://cvs.sourceforge.net/viewcvs.py/ffmp...=1.18...   Sep 26 2003, 10:38
- - petracci   QUOTE I dunno about the patent - will take some ti...   Sep 26 2003, 10:49
- - Ivan Dimkovic   Actually, I never tried that FFMPEG code, so I am ...   Sep 26 2003, 10:53
- - petracci   QUOTE Actually, I never tried that FFMPEG code, so...   Sep 26 2003, 11:01
- - Ivan Dimkovic   QUOTE If they paid for licensing that patent on wi...   Sep 26 2003, 11:06
- - DSPguru   QUOTE (Ivan Dimkovic @ Sep 26 2003, 16:53 PM)...   Sep 26 2003, 11:15
- - Ivan Dimkovic   QUOTE recently, the official ffmpeg homepage had b...   Sep 26 2003, 11:21
- - Ivan Dimkovic   QUOTE e.g. if the complete technological details w...   Sep 26 2003, 12:01
- - petracci   QUOTE Ivan Dimkovic That is also interesting,...   Sep 26 2003, 12:18
- - Ivan Dimkovic   QUOTE If a respected developer/researcher like Iva...   Sep 26 2003, 12:34
- - petracci   QUOTE You are right - I am not sure,  of cour...   Sep 26 2003, 14:18
- - danchr   QUOTE (DSPguru @ Sep 26 2003, 12:15 PM)QUOTE ...   Sep 27 2003, 11:09
- - c_haese   Okay, let's get back to the scientific problem...   Sep 29 2003, 22:17
- - menno   QUOTE (c_haese @ Sep 29 2003, 10:17 PM)After ...   Sep 30 2003, 14:03
- - Ivan Dimkovic   Ok, for those with lmiited ability to read: Inste...   Sep 30 2003, 23:09
- - JohnV   Thread re-arranged. This thread is now only for te...   Oct 1 2003, 09:00
- - jmvalin   QUOTE (Ivan Dimkovic @ Sep 30 2003, 05:09 PM)...   Oct 1 2003, 23:26
- - Ivan Dimkovic   QUOTE (jmvalin @ Oct 1 2003, 10:26 PM)QUOTE (...   Oct 2 2003, 09:21
- - JohnV   Ok, I asked Xiph's opinion about this specific...   Oct 5 2003, 23:38
- - Ivan Dimkovic   All in all, this is how I perceive the picture... ...   Oct 6 2003, 08:30
- - jmvalin   QUOTE (JohnV @ Oct 5 2003, 05:38 PM)Ok, I ask...   Oct 6 2003, 20:11
- - JohnV   QUOTE (jmvalin @ Oct 6 2003, 10:11 PM)QUOTE (...   Oct 6 2003, 21:25
- - jmvalin   QUOTE (JohnV @ Oct 6 2003, 03:25 PM)Discussio...   Oct 7 2003, 03:17
- - JohnV   QUOTE (jmvalin @ Oct 7 2003, 05:17 AM)I said ...   Oct 7 2003, 04:54
- - jmvalin   QUOTE I was the only one who was talking about tha...   Oct 7 2003, 06:40
- - JohnV   QUOTE (jmvalin @ Oct 7 2003, 08:40 AM)OK, fir...   Oct 7 2003, 07:09
- - Ivan Dimkovic   Like I said - if somebody is so sure he avoided pa...   Oct 7 2003, 08:06
- - PatchWorKs   I don't want to be boring, but i have to say i...   Oct 7 2003, 08:34
- - Dibrom   QUOTE (PatchWorKs @ Oct 7 2003, 12:34 AM)I do...   Oct 7 2003, 08:43
- - sthayashi   JohnV, It seems to me that Monty's unofficial...   Oct 7 2003, 14:22
- - Ivan Dimkovic   QUOTE (PatchWorKs @ Oct 7 2003, 07:34 AM)I do...   Oct 7 2003, 14:36
- - Ivan Dimkovic   QUOTE (sthayashi @ Oct 7 2003, 01:22 PM)JohnV...   Oct 7 2003, 15:02
- - rsilva   Let me try to "preach to the deaf" once ...   Oct 7 2003, 19:17
- - sthayashi   QUOTE (Ivan Dimkovic @ Oct 7 2003, 06:02 AM)W...   Oct 7 2003, 20:41
- - ScorLibran   QUOTE (sthayashi @ Oct 7 2003, 03:41 PM)QUOTE...   Oct 7 2003, 21:20
- - Ivan Dimkovic   QUOTE "Vorbis is a hybrid transform domain ge...   Oct 7 2003, 23:00
- - Ivan Dimkovic   QUOTE (sthayashi @ Oct 7 2003, 07:41 PM) QUOT...   Oct 7 2003, 23:04
- - PatchWorKs   From XviD.org website: QUOTE European parliament ...   Oct 8 2003, 09:39
- - Ivan Dimkovic   I don't know what XVid claims (and for what pa...   Oct 8 2003, 10:07
- - Ivan Dimkovic   QUOTE Sorry to be so boring...  Sorry if I s...   Oct 8 2003, 11:27
- - Garf   QUOTE (ScorLibran @ Oct 7 2003, 10:20 PM)(Not...   Oct 8 2003, 17:07
- - Diocletian   QUOTE (Ivan Dimkovic @ Sep 26 2003, 12:01 PM)...   Oct 9 2003, 18:27
- - ScorLibran   QUOTE (Diocletian @ Oct 9 2003, 01:27 PM)Do y...   Oct 9 2003, 19:09
RSS Lo-Fi Version Time is now: 3rd May 2015 - 15:29
