Suggest ~160kbps VBR setting.
guidryp
post Mar 30 2002, 19:27
Looking at the suggested settings/presets I am dismayed at the lack of a VBR setting that operates at a lower bit-rate.
There is APS standard, which on my music easily averages over 200Kbps. In fact my latest Rush albums are averaging over 220Kbps.
I can see noisy metal taking over 220kbps, but a song like Rush-Nobody's Hero taking 230Kbps?
For me, it calls into question the validity of the VBR model if the answer to lower than 230KBps encoding is to use the ABR/CBR settings.
ABR doesn't seem much better than CBR after watching it encode 90+ % of its samples at the target rate.
Surely a VBR setting can be cooked up that can encode the above track at ~160kbps in VBR and still sound better than 160 ABR.
PS - I want to use this setting in my compact Flash based portable, in my car etc. My max space average is 160Kbps do to the size of the portable memory. But I want the best quality in that space.
Peter
JohnV
post Mar 31 2002, 12:12
Originally posted by guidryp
I am seeking a setting that will encode the above mentioned track (nobody's hero) at 160kbps instead of 230kbps. I would think it would sound better than ABR/CBR 160kbps. If not then I question the validity of the VBR models.
Well, I don't know the song, but any such Lame vbr-mode would need to use -Y swithch. Then you would lose pretty much the over 16kHz high freq content. I'm not sure if even --r3mix -Y gives you that bitrate with that track, and if you start to tweak --r3mix for lower quality, it will probably fail pretty fast pretty ugly at least for many other tracks... That all depends on your hearing though. But if the comparison is to ABR-160kbps..
VBR setting which would give average 160kbps with metal would probably fall to low very often with different types of tracks or even with quieter sections, because the quality and bitrate is heavily dictated by the masking threshold from the psychoacoustic model (which is far from perfect).
ABR mode uses different method for determining the bits needed - ABR-160 basically first takes 160kbps for a base bitrate and then uses so called Perceptual Entropy (PE) algorithm which gives an rough estimate how difficult the frame about to be encoded is. PE then decides whether the frame is difficult or easier, but because PE is pretty rough estimate, the adjustment doesnt happen very often, only when it's pretty much needed to raise the bitrate it will, and only when it's pretty much safe to use lower bitrate, it will. Of course CBR/ABR modes also use the masking threshold of psychoacoustic but it does not dictate the bitrate like in VBR mode. Masking threshold in CBR/ABR mode will only tell the encoder where the bits should be placed, while in VBR-mode it dictates in addition the resolution (amount of bits -> bitrate) which should be used.
So if we compare abr-160 and vbr-mode which is tweaked to give 160kbps average with metal, the vbr-mode will more often use too low bitrate frames, because vbr's bitare is mostly dictated by the non-perfect psychoacoustics and you have given permission to the encoder to base the bitrate on higher masking threshold (lower resolution) in order to achieve your desired vbr average bitrate. Then again this kind of vbr-mode sometimes might quality wise correctly give higher frames when needed eg. for transients, but the problem is the bitrate falling too low from time to time. Anyway, the absolute requirement for this kind of Lame vbr setting is the use of -Y switch.
Juha Laaksonheimo
- guidryp   Suggest ~160kbps VBR setting.   Mar 30 2002, 19:27
- - SometimesWarrior   Take a look at this thread for some info on how to...   Mar 30 2002, 21:06
- - Negative Zero   You could also try the --r3mix switch, which resul...   Mar 30 2002, 21:51
- - JohnV   QUOTE Originally posted by Negative Zero You coul...   Mar 31 2002, 01:53
- - mithrandir   Why are there still so many --r3mix followers? It ...   Mar 31 2002, 02:57
- - guidryp   QUOTE Originally posted by mithrandir Although I...   Mar 31 2002, 05:59
- - mithrandir   I say alt-preset extreme -Y creates files with a r...   Mar 31 2002, 08:11
- - JohnV   QUOTE Originally posted by guidryp I am seeking a...   Mar 31 2002, 12:12
- - guidryp   QUOTE Originally posted by mithrandir If you nee...   Mar 31 2002, 18:16
- - guidryp   QUOTE Originally posted by JohnV Well, I don't kn...   Mar 31 2002, 18:55
- - mithrandir   QUOTE Originally posted by guidryp The problem I ...   Mar 31 2002, 21:02
- - JohnV   Yes, VBR would use more bits for harder sections, ...   Mar 31 2002, 21:05
- - guidryp   QUOTE Originally posted by mithrandir make two ...   Mar 31 2002, 22:03
- - guidryp   QUOTE Originally posted by JohnV Yes, VBR would u...   Mar 31 2002, 22:21
- - JohnV   QUOTE Originally posted by guidryp Rush == Metal?...   Mar 31 2002, 22:49
- - guidryp   Well after a bit of testing, I am going with: --a...   Apr 2 2002, 05:36
- - Dibrom   QUOTE Originally posted by guidryp Well after a b...   Apr 2 2002, 10:03
- - guidryp   For whatever reason, I remember --lowpass 16 using...   Apr 2 2002, 14:24
- - JohnV   QUOTE Originally posted by guidryp For whatever r...   Apr 2 2002, 14:35
- - guidryp   QUOTE Originally posted by JohnV Seems that you d...   Apr 2 2002, 15:02
- - indybrett   Thought I might try this for myself. Without goin...   Apr 2 2002, 15:34
- - JohnV   QUOTE Originally posted by guidryp I had read th...   Apr 2 2002, 16:48
- - fewtch   Just my opinion, but if you're gonna do an abrupt ...   Apr 2 2002, 17:05
- - guidryp   QUOTE Originally posted by fewtch Just my opinion...   Apr 2 2002, 17:19
- - scoper   Reading the suggestions of Dibrom and others regar...   Apr 2 2002, 17:25
- - guidryp   QUOTE Originally posted by JohnV Still I think ...   Apr 2 2002, 17:26
- - Dibrom   QUOTE Originally posted by scoper Reading the sug...   Apr 2 2002, 22:12
- - pacohaas   I ripped some complete albums and did some encodin...   Apr 3 2002, 04:25
- - guidryp   Holy Smokes! You ripped 7 albums 5 times just to ...   Apr 3 2002, 12:51
- - Amadeus93   QUOTE Originally posted by pacohaas 1. -b32 hardl...   Apr 3 2002, 13:43
- - JohnV   QUOTE Originally posted by pacohaas 2. While -Y d...   Apr 3 2002, 15:59
- - pacohaas   QUOTE Originally posted by JohnV Again... -Y is n...   Apr 5 2002, 03:08
- - pacohaas   which brings me to yet another idea that I've been...   Apr 5 2002, 03:13
RSS Lo-Fi Version Time is now: 31st July 2015 - 06:44
