Suggest ~160kbps VBR setting.
guidryp
post Mar 30 2002, 19:27
Looking at the suggested settings/presets I am dismayed at the lack of a VBR setting that operates at a lower bit-rate.
There is APS standard, which on my music easily averages over 200Kbps. In fact my latest Rush albums are averaging over 220Kbps.
I can see noisy metal taking over 220kbps, but a song like Rush-Nobody's Hero taking 230Kbps?
For me, it calls into question the validity of the VBR model if the answer to lower than 230KBps encoding is to use the ABR/CBR settings.
ABR doesn't seem much better than CBR after watching it encode 90+ % of its samples at the target rate.
Surely a VBR setting can be cooked up that can encode the above track at ~160kbps in VBR and still sound better than 160 ABR.
PS - I want to use this setting in my compact Flash based portable, in my car etc. My max space average is 160Kbps do to the size of the portable memory. But I want the best quality in that space.
Peter
mithrandir
post Mar 31 2002, 08:11
I say alt-preset extreme -Y creates files with a reasonable bitrate because it's comparable to --r3mix and aps, i.e. somewhere around 192kbps. Most people will agree that you need at least 192kbps on average to get near-transparent quality from MP3.
If you need 160kbps, then use --alt-preset 160. I don't know why you want to dwell on VBR. ABR uses variable framesizes, so it won't "waste" bits or underallocate on some frames like CBR. ABR makes a whole lot of sense if you have a final bitrate in mind.
From what I understand, the lower bitrate VBR modes simply use a less-sensitive ATH curve. That's probably not the best way of lowering bitrate. When you use ABR, you are telling the encoder: give me the best quality possible with this allocation of bits. When you use VBR, you are telling the encoder: here's the ATH curve I want to use, apply it to the processing of each frame.
- guidryp   Suggest ~160kbps VBR setting.   Mar 30 2002, 19:27
- - SometimesWarrior   Take a look at this thread for some info on how to...   Mar 30 2002, 21:06
- - Negative Zero   You could also try the --r3mix switch, which resul...   Mar 30 2002, 21:51
- - JohnV   QUOTE Originally posted by Negative Zero You coul...   Mar 31 2002, 01:53
- - mithrandir   Why are there still so many --r3mix followers? It ...   Mar 31 2002, 02:57
- - guidryp   QUOTE Originally posted by mithrandir Although I...   Mar 31 2002, 05:59
- - mithrandir   I say alt-preset extreme -Y creates files with a r...   Mar 31 2002, 08:11
- - JohnV   QUOTE Originally posted by guidryp I am seeking a...   Mar 31 2002, 12:12
- - guidryp   QUOTE Originally posted by mithrandir If you nee...   Mar 31 2002, 18:16
- - guidryp   QUOTE Originally posted by JohnV Well, I don't kn...   Mar 31 2002, 18:55
- - mithrandir   QUOTE Originally posted by guidryp The problem I ...   Mar 31 2002, 21:02
- - JohnV   Yes, VBR would use more bits for harder sections, ...   Mar 31 2002, 21:05
- - guidryp   QUOTE Originally posted by mithrandir make two ...   Mar 31 2002, 22:03
- - guidryp   QUOTE Originally posted by JohnV Yes, VBR would u...   Mar 31 2002, 22:21
- - JohnV   QUOTE Originally posted by guidryp Rush == Metal?...   Mar 31 2002, 22:49
- - guidryp   Well after a bit of testing, I am going with: --a...   Apr 2 2002, 05:36
- - Dibrom   QUOTE Originally posted by guidryp Well after a b...   Apr 2 2002, 10:03
- - guidryp   For whatever reason, I remember --lowpass 16 using...   Apr 2 2002, 14:24
- - JohnV   QUOTE Originally posted by guidryp For whatever r...   Apr 2 2002, 14:35
- - guidryp   QUOTE Originally posted by JohnV Seems that you d...   Apr 2 2002, 15:02
- - indybrett   Thought I might try this for myself. Without goin...   Apr 2 2002, 15:34
- - JohnV   QUOTE Originally posted by guidryp I had read th...   Apr 2 2002, 16:48
- - fewtch   Just my opinion, but if you're gonna do an abrupt ...   Apr 2 2002, 17:05
- - guidryp   QUOTE Originally posted by fewtch Just my opinion...   Apr 2 2002, 17:19
- - scoper   Reading the suggestions of Dibrom and others regar...   Apr 2 2002, 17:25
- - guidryp   QUOTE Originally posted by JohnV Still I think ...   Apr 2 2002, 17:26
- - Dibrom   QUOTE Originally posted by scoper Reading the sug...   Apr 2 2002, 22:12
- - pacohaas   I ripped some complete albums and did some encodin...   Apr 3 2002, 04:25
- - guidryp   Holy Smokes! You ripped 7 albums 5 times just to ...   Apr 3 2002, 12:51
- - Amadeus93   QUOTE Originally posted by pacohaas 1. -b32 hardl...   Apr 3 2002, 13:43
- - JohnV   QUOTE Originally posted by pacohaas 2. While -Y d...   Apr 3 2002, 15:59
- - pacohaas   QUOTE Originally posted by JohnV Again... -Y is n...   Apr 5 2002, 03:08
- - pacohaas   which brings me to yet another idea that I've been...   Apr 5 2002, 03:13
RSS Lo-Fi Version Time is now: 27th May 2015 - 05:45
