Recording line in with Soundforge, and Audiophile 24/96
evereux
post Aug 10 2003, 10:34
I'm having a problem recording the output from my CD player through the line in of my soundcard, the Midiman Audiophile (Window's XP).
The problem is distortion. I can't seem to find a way to attenuate the line level input in soundforge and this is causing clipping.
I'm beginning to wonder if this can be removed since during normal playback (through PC) I also get audible clipping, even when the line in is attenuated using Midiman's control panel. I suspect the Midiman doesn't like the output levels of my CD player?
I'm quite sure the input signal itself isn't a problem since playback direct through my amplifier reveals no clipping.
Any ideas?
daefeatures.co.uk
Brajanath
post Nov 16 2003, 17:20
QUOTE (fewtch @ Nov 15 2003, 11:39 PM)
Not really -- if the problem is a too-loud analog signal (too much voltage) overloading the card, then you need an attenuator of some sort in the analog domain.  A couple fixed-value resistors per channel would do it, or a passive variable resistor (potentiometer).
Maybe a cheap mixing board from Radio Shack?
I've heard of Soundcards with provision for adjusting the line-in signal. If this is true, do you think it is a better approach to control the signal from within the soundcard (digital) than attenuate the strong signal from the analog source. We took all the trouble of amplifying the minute signal from our record player cartridge, only to attenuate and dump some of it...
I couldn't believe that the Windows mixer can't handle volume control problems like this. Thanks for your reply...
-Dan
- evereux   Recording line in with Soundforge   Aug 10 2003, 10:34
- - Pio2001   The line in level is not in Soundforge, it must be...   Aug 10 2003, 18:01
- - evereux   QUOTE If it is reduced, but is still clipped It i...   Aug 10 2003, 19:25
- - Pio2001   I think the solution is to find the line in record...   Aug 10 2003, 21:40
- - ancl   I have an Audiophile 24/96 myself, and as far as i...   Aug 11 2003, 00:01
- - Pio2001   ¿ WTF ?! I'm not going to get rid of my...   Aug 11 2003, 11:40
- - Brajanath   Hi, I'm new here (just started yesterday), an...   Nov 16 2003, 05:38
- - fewtch   QUOTE (Brajanath @ Nov 15 2003, 09:38 PM)My w...   Nov 16 2003, 08:39
- - Pio2001   QUOTE (Brajanath @ Nov 16 2003, 05:38 AM)Befo...   Nov 16 2003, 16:22
- - Brajanath   Your message is perfectly OK. I have not had the ...   Nov 16 2003, 16:56
- - Pio2001   I don't know... The problem with the cassette ...   Nov 16 2003, 17:10
- - Brajanath   QUOTE (fewtch @ Nov 15 2003, 11:39 PM)Not rea...   Nov 16 2003, 17:20
- - fewtch   QUOTE (Brajanath @ Nov 16 2003, 09:20 AM)QUOT...   Nov 16 2003, 17:53
- - JeanLuc   Of course you can adjust input sensitivity with th...   Nov 16 2003, 18:07
- - fewtch   QUOTE (JeanLuc @ Nov 16 2003, 10:07 AM)Of cou...   Nov 16 2003, 18:16
- - JeanLuc   It is the HW mixer which is situated besides the ...   Nov 16 2003, 18:25
- - Pio2001   QUOTE (fewtch @ Nov 16 2003, 05:53 PM)I don...   Nov 16 2003, 18:50
- - ancl   QUOTE (JeanLuc @ Nov 16 2003, 07:25 PM)It is ...   Nov 16 2003, 18:52
- - JeanLuc   QUOTE (ancl @ Nov 16 2003, 05:52 PM)I guess w...   Nov 16 2003, 18:55
- - ancl   QUOTE (JeanLuc @ Nov 16 2003, 07:55 PM)QUOTE ...   Nov 16 2003, 19:01
- - JeanLuc   QUOTE (ancl @ Nov 16 2003, 06:01 PM)You can, ...   Nov 16 2003, 19:09
- - Brajanath   QUOTE (Pio2001 @ Nov 16 2003, 09:50 AM)QUOTE ...   Nov 16 2003, 22:54
- - fewtch   QUOTE (Brajanath @ Nov 16 2003, 02:54 PM)My o...   Nov 16 2003, 23:22
- - Pio2001   QUOTE (JeanLuc @ Nov 16 2003, 07:09 PM)So I j...   Nov 17 2003, 01:46
- - Kos   Thiis is probably very banale for you in here, but...   Apr 21 2006, 09:56
- - AndyH-ha   I have to admit I have not read this very closely,...   Apr 21 2006, 20:20
|- - Pio2001   QUOTE (AndyH-ha @ Apr 21 2006, 09:20...   Apr 23 2006, 03:26
- - AndyH-ha   No that is incorrect. Some of those that use the W...   Apr 23 2006, 10:53
|- - Pio2001   I don't follow you. You are making a distinct...   Apr 24 2006, 19:43
- - AndyH-ha   Most analogue volume controls are passive. Potenti...   Apr 25 2006, 05:39
RSS Lo-Fi Version Time is now: 31st August 2015 - 06:57
