NSPsytune's better pre-echo control - myth or reality?
JohnV
post Mar 1 2002, 14:44
Ok, I'm quite busy, but I'd like to rise this question again..
In my opinion one of the biggest problems of nspsytune is its pre-echo handling still, and especially with long-blocks.
Since the block-switching is not nearly perfect, many times long blocks are used with attacks. Also sometimes transients are just not so sharp, that short blocks would be chosen.
I compared nspsytune lines:
-b320 -h --nspsytune --lowpass 20 --noshort --athtype 2 -Z -X0
--alt-preset insane --noshort
against gpsycho line:
-b320 -h --lowpass 20 --noshort
The first nspsytune line sets the same properties as gpsycho line (same athtype, same noise shaping type, same noise quality measurement mode). Actually both nspsytune lines handled long-block pre-echo pretty much equally poorly, but first line could be considered "more fair".
some of the test clips I used to demonstrate this:
http://lame.sourceforge.net/download/samples/castanets.wav
http://sivut.koti.soon.fi/julaak/castanets_si02.flac
http://sivut.koti.soon.fi/julaak/blips.flac
http://sivut.koti.soon.fi/julaak/vangelis1.flac
Despite Dibrom's --alt-preset insane tweaks, nspsytune's long-block "problem" still is there.
--alt-preset insane does not solve nspsytune's long-block pre-echo problem...with blips.wav this long-block pre-echo problem is especially noticeable. Of course if block switching works correctly long-block pre-echo handling is not an issue. Of course normally Lame uses short blocks with sharp attacks. --alt-preset insane is still not very good with castanets_si02.wav - Gpsycho was clearly better. Same thing with castanets.wav, vangelis1.wav and quite a few other clips.
In my opinion Naoki should take a look what's going on or at least address this for nspsytune2. I've often thought, that nspsytune is not producing better pre-echo handling than gpsycho. This probably means for both long-blocks and short-blocks.
[edit]Edited out the incorrect pictures. EncSpot 1.1beta2's block-switcing view misses short-blocks. I verified this with mp3x-frame analyzer.
Juha Laaksonheimo
Dibrom
post Mar 3 2002, 07:36
Founder
Group: Admin
Originally posted by JohnV
Dibrom, I'm not talking about -alt-preset vbr modes, I'm talking pure gpsycho-nspsytune head-to-head fair preset comparison. In my opinion gpsycho wins in pre-echo handling. And we can still hear problems even with alt-presets pre-echo tweaks, direcetly related to nspsytune, which are not present with gpsycho.
I do acknowledge that gpsycho is sometimes better than nspsytune on some pre-echo, I'm just not convinced that this is always the case. If that were so, it would seem to contradict some test results from quite awhile back.
[b]Well, anyway. Naoki has acknowledged this. I believe, he said that also Robert has said the same this as I.
Hrmm.. I'd be interested in Robert's statements in this regards. When I was originally talking to him quite awhile back, he really didn't seem to have much experience listening with nspsytune or really knowing exactly how well it performed in many situations (originally, before the --dm-presets, it seemed that mostly the only one really having tested nspsytune much was Naoki, and even then he hadn't worked on it for some months). For that matter, it would appear that the --alt-presets often go against what some of the developers would "think" would work... yet somehow they do work really well. I know the --alt-presets aren't the issue here, but what I'm emphasizing is that (and no offense to the LAME team), often times it appears the LAME developers don't have the best understanding of real world performance of certain aspects of the code, due to a lack of rigorous testing.
At any rate, I have talked to both of them in the past as well (before dm-presets), and have also stated my concerns that pre-echo control is not that great in either gpsycho or nspsytune. Both agreed with me as well, but so far, aside from the tweaks I've made with the --alt-presets, nothing has really been done to remedy this.
[b]nspsytune needs better pre-echo and it's possible to implement and pre-echo handling is not clearly better than gpsyco, it's often clearly worse.
Of course I agree with the first part, I'm just not so sure that nspsytune is as bad as implied all around. Furthermore, at least from the perspective I speak from, when I say that nspsytune is "better for pre-echo", I also take into account the many tweaks and modifications I made which built upon this already. Surely you'd consider the much improved impulse handling as "better pre-echo control".
[b]Naoki is working on it for nspsytune2.
I can do some test, and show some samples to prove my point early next week.
I believe what you say, I just don't know if I feel it's to the same degree. Admittedly, I stopped comparing nspsytune and gpsycho for pre-echo handling quite awhile ago since nspsytune offers so many other improvements, so it could be possible. However, that would also seem to contradict some very early testing like I said before.
In short though, I do very much agree with you that the pre-echo handling in LAME (in both gpsycho and nspsytune) could use some serious work still.
RSS Lo-Fi Version Time is now: 31st March 2015 - 02:18
