WAV-->AAC with Quicktime (WIN), convert 500 files with quicktime
spirit303
post Jun 30 2003, 01:26
i need help
how do i convert my 500 WAV files into AAC (mp4) with the best quality encoder apple quick time 6.3 for !windows! ?
i don' wanna open each file and export it. it will keep me goin for years !!!
please tell me how to do it
thank u guys
zaphod
post Jul 27 2003, 16:12
I've made a tiny Python script which "abuses" FrDakota's script for batch encoding outside of EAC. I'm a very inexperienced coder and the script could doubtlessly be much more elegant. Also, it doesn't provide any safety at all, it'll just fail without a useful error message if something is not right.
It expects eac.vbs in C:\, but that can easily be changed, as all the other absolute references. Thanks to FrDakota's script, encoding to AAC with QuickTime has become a real possibility and I hope my addition is of use for some...
# This should serve to use the eac.vbs script to batch encode files in a
# given directory (and its subdirectories) using QuickTime AAC.
# Many thanks to FrDakota for making this possible!
# Usage: python qtmp4.py c:\*.wav
# -> This will encode all wave files on drive C:
# -> The encoded files will be in the same directory as the source files,
#    and with the same name.
import sys
import os
print "Compiling list of wave files..."
os.system("dir " + sys.argv[1] + " /s /b > c:\\wavs.txt")
f=open("c:\\wavs.txt", "r")
name=f.readline()
while name!="" :
    wav=name[:-5] + ".wav"
    mp4=name[:-5] + ".mp4"
    print "Encoding " + wav + "..."
    os.system("cscript //Nologo //H:CScript c:\\eac.vbs " + "\"" + wav + "\" " + "\"" + mp4 + "\"")
#    os.remove(wav)             # un-comment if you want to have the wave file deleted after encoding
    name=f.readline()
print "Done!"
sys.exit()
Cheers, Zaphod
- spirit303   WAV-->AAC with Quicktime (WIN)   Jun 30 2003, 01:26
- - rjamorim   You'll have to wait. At the time, there's ...   Jun 30 2003, 01:44
- - FrDakota   I have quite successfully done a VBScript that con...   Jul 3 2003, 12:19
- - richard123   It would be easier to comment on your script if yo...   Jul 3 2003, 13:17
- - FrDakota   Ok I post it. Things to know. I made a direct ref...   Jul 3 2003, 13:51
- - richard123   Perhaps we are using different versions of QT. I...   Jul 3 2003, 15:22
- - Tomb   >how do i convert my 500 WAV files into AAC (mp...   Jul 3 2003, 15:35
- - FrDakota   It strange to send an ESC to QT it should clear a ...   Jul 3 2003, 15:43
- - richard123   I send an escape because sometimes the Edit menu g...   Jul 3 2003, 16:00
- - FrDakota   My problem is that I couldn't find a reference...   Jul 3 2003, 16:33
- - richard123   You appear to be right about AppActivate. I'm...   Jul 3 2003, 18:02
- - FrDakota   I saw you cleaned the unused variables They wer...   Jul 3 2003, 18:34
- - richard123   A number of web sites recommend set fso = nothing....   Jul 3 2003, 19:23
- - FrDakota   QUOTE (richard123 @ Jul 3 2003, 06:22 AM)Perh...   Jul 4 2003, 08:00
- - SentientPC   Great work FrDakota and richard123...looking forwa...   Jul 4 2003, 08:45
- - richard123   Another point I noticed - QT won't open a file...   Jul 4 2003, 09:22
- - SentientPC   QUOTE (richard123 @ Jul 4 2003, 03:22 AM)I...   Jul 4 2003, 09:42
- - FrDakota   (w00t) I finaly found how the infamous ".wav...   Jul 4 2003, 15:57
- - richard123   I had added a delay to the loop CODEWhile fso.Fil...   Jul 4 2003, 16:38
- - c123   Hi When I tried to get this to work, I got a ...   Jul 4 2003, 21:45
- - FrDakota   Well for the script to work QuickTime Pro must be ...   Jul 5 2003, 01:01
- - spoon   I should have something to release either today or...   Jul 5 2003, 09:34
- - c123   QUOTE (FrDakota @ Jul 5 2003, 12:01 AM)Well f...   Jul 5 2003, 10:47
- - c123   Just tried to encode four wav files, and ED:...   Jul 5 2003, 11:03
- - c123   Keep on getting the "file exists already...   Jul 5 2003, 12:00
- - FrDakota   QUOTE (c123 @ Jul 5 2003, 03:00 AM)p.s. on my...   Jul 5 2003, 12:56
- - c123   I doubled the times in the vbs file, and now I can...   Jul 5 2003, 19:18
- - FrDakota   QUOTE (c123 @ Jul 5 2003, 10:18 AM)Only probl...   Jul 5 2003, 21:18
- - FrDakota   To simplify things, here his the full corrected sc...   Jul 6 2003, 07:39
- - jsnx   Thanks for sharing the script. Works good. There...   Jul 6 2003, 16:16
- - SentientPC   Error: see below.   Jul 8 2003, 03:26
- - SentientPC   QUOTE (FrDakota @ Jul 6 2003, 01:39 AM)To sim...   Jul 8 2003, 03:33
- - FrDakota   QUOTE (SentientPC @ Jul 7 2003, 06:33 PM)I ha...   Jul 8 2003, 07:34
- - perplx   Im working on my own front end that uses winapi in...   Jul 8 2003, 19:30
- - spoon   SendMessages? I found the menu handling to be quit...   Jul 8 2003, 23:20
- - perplx   I had to do that too, I wanted add bit rate ect to...   Jul 9 2003, 01:03
- - zeer   this script version works for me with EAC (if you ...   Jul 9 2003, 15:28
- - rpop   I haven't tried using this script, but I'v...   Jul 10 2003, 23:36
- - Nic   As soon as QuickTime 6 came out, I grabbed the SDK...   Jul 11 2003, 00:05
- - perplx   A question for spoon or anyone else that knows. Wh...   Jul 11 2003, 06:33
- - zeer   It seems to get Quicktime api/sdk to work the APP ...   Jul 13 2003, 11:08
- - FrDakota   QUOTE (zeer @ Jul 9 2003, 06:28 AM)CODE While...   Jul 14 2003, 09:42
- - Nic   @zeer: Ahh, I guess that maybe the case. Its a sha...   Jul 14 2003, 09:47
- - spoon   QUOTE (perplx @ Jul 11 2003, 05:33 AM)A quest...   Jul 14 2003, 11:11
- - zeer   2 FrDakota: Nobody is perfect. Actually, the prob...   Jul 14 2003, 14:07
- - zaphod   I've made a tiny Python script which "abu...   Jul 27 2003, 16:12
RSS Lo-Fi Version Time is now: 25th May 2015 - 04:30
