WAV-->AAC with Quicktime (WIN), convert 500 files with quicktime
spirit303
post Jun 30 2003, 01:26
i need help
how do i convert my 500 WAV files into AAC (mp4) with the best quality encoder apple quick time 6.3 for !windows! ?
i don' wanna open each file and export it. it will keep me goin for years !!!
please tell me how to do it
thank u guys
c123
post Jul 5 2003, 10:47
QUOTE (FrDakota @ Jul 5 2003, 12:01 AM)
Well for the script to work QuickTime Pro must be installed.
- Yep it's installed.
And you'll have to verify that the path given in the script corresponds to the path where you installed QuickTime.
- Yep that's OK.
My QuickTime is in "C:\Program Files\QuickTime\QuickTimePlayer.exe" yours ?
- "D:\Program Files\QuickTime\QuickTimePlayer.exe"
I'm using FAT 32 so that's why the Progra~1 works, I don't know if it does under NTFS.
- also using FAT32.  Tried truncating to "Progra~1", no change.
You could try this "C:\\Program Files\\QuickTime\\QuickTimePlayer.exe" as a replacement.
Another thing, the destination path of the mp4 is the same as the source wav.
changing that is possible but needs a string handling I've not written.
- OK thanks, wasn't doing that before...  However, no change when I do that.
I don't advise you to change that since EAC must find the mp4 where the wav are since it needs to rename both after encoding.
- OK, source file is now d:\test.wav and target file is d:\
And I only specified the two temp (mp4 and mp5) files to be at root to have a short path.
- now my test source file is also at the root (and the vbs script is in D:\Save)
The wav files are placed where you selected in EAC and so that's where the final mp4 will be.
Good luck.
- cheers, unfortunately still get the same error...
***update*** just got to work.  will test with more than one file and post back shortly.
thanks for the help FrDakota!
This post has been edited by c123: Jul 5 2003, 11:11
- spirit303   WAV-->AAC with Quicktime (WIN)   Jun 30 2003, 01:26
- - rjamorim   You'll have to wait. At the time, there's ...   Jun 30 2003, 01:44
- - FrDakota   I have quite successfully done a VBScript that con...   Jul 3 2003, 12:19
- - richard123   It would be easier to comment on your script if yo...   Jul 3 2003, 13:17
- - FrDakota   Ok I post it. Things to know. I made a direct ref...   Jul 3 2003, 13:51
- - richard123   Perhaps we are using different versions of QT. I...   Jul 3 2003, 15:22
- - Tomb   >how do i convert my 500 WAV files into AAC (mp...   Jul 3 2003, 15:35
- - FrDakota   It strange to send an ESC to QT it should clear a ...   Jul 3 2003, 15:43
- - richard123   I send an escape because sometimes the Edit menu g...   Jul 3 2003, 16:00
- - FrDakota   My problem is that I couldn't find a reference...   Jul 3 2003, 16:33
- - richard123   You appear to be right about AppActivate. I'm...   Jul 3 2003, 18:02
- - FrDakota   I saw you cleaned the unused variables They wer...   Jul 3 2003, 18:34
- - richard123   A number of web sites recommend set fso = nothing....   Jul 3 2003, 19:23
- - FrDakota   QUOTE (richard123 @ Jul 3 2003, 06:22 AM)Perh...   Jul 4 2003, 08:00
- - SentientPC   Great work FrDakota and richard123...looking forwa...   Jul 4 2003, 08:45
- - richard123   Another point I noticed - QT won't open a file...   Jul 4 2003, 09:22
- - SentientPC   QUOTE (richard123 @ Jul 4 2003, 03:22 AM)I...   Jul 4 2003, 09:42
- - FrDakota   (w00t) I finaly found how the infamous ".wav...   Jul 4 2003, 15:57
- - richard123   I had added a delay to the loop CODEWhile fso.Fil...   Jul 4 2003, 16:38
- - c123   Hi When I tried to get this to work, I got a ...   Jul 4 2003, 21:45
- - FrDakota   Well for the script to work QuickTime Pro must be ...   Jul 5 2003, 01:01
- - spoon   I should have something to release either today or...   Jul 5 2003, 09:34
- - c123   QUOTE (FrDakota @ Jul 5 2003, 12:01 AM)Well f...   Jul 5 2003, 10:47
- - c123   Just tried to encode four wav files, and ED:...   Jul 5 2003, 11:03
- - c123   Keep on getting the "file exists already...   Jul 5 2003, 12:00
- - FrDakota   QUOTE (c123 @ Jul 5 2003, 03:00 AM)p.s. on my...   Jul 5 2003, 12:56
- - c123   I doubled the times in the vbs file, and now I can...   Jul 5 2003, 19:18
- - FrDakota   QUOTE (c123 @ Jul 5 2003, 10:18 AM)Only probl...   Jul 5 2003, 21:18
- - FrDakota   To simplify things, here his the full corrected sc...   Jul 6 2003, 07:39
- - jsnx   Thanks for sharing the script. Works good. There...   Jul 6 2003, 16:16
- - SentientPC   Error: see below.   Jul 8 2003, 03:26
- - SentientPC   QUOTE (FrDakota @ Jul 6 2003, 01:39 AM)To sim...   Jul 8 2003, 03:33
- - FrDakota   QUOTE (SentientPC @ Jul 7 2003, 06:33 PM)I ha...   Jul 8 2003, 07:34
- - perplx   Im working on my own front end that uses winapi in...   Jul 8 2003, 19:30
- - spoon   SendMessages? I found the menu handling to be quit...   Jul 8 2003, 23:20
- - perplx   I had to do that too, I wanted add bit rate ect to...   Jul 9 2003, 01:03
- - zeer   this script version works for me with EAC (if you ...   Jul 9 2003, 15:28
- - rpop   I haven't tried using this script, but I'v...   Jul 10 2003, 23:36
- - Nic   As soon as QuickTime 6 came out, I grabbed the SDK...   Jul 11 2003, 00:05
- - perplx   A question for spoon or anyone else that knows. Wh...   Jul 11 2003, 06:33
- - zeer   It seems to get Quicktime api/sdk to work the APP ...   Jul 13 2003, 11:08
- - FrDakota   QUOTE (zeer @ Jul 9 2003, 06:28 AM)CODE While...   Jul 14 2003, 09:42
- - Nic   @zeer: Ahh, I guess that maybe the case. Its a sha...   Jul 14 2003, 09:47
- - spoon   QUOTE (perplx @ Jul 11 2003, 05:33 AM)A quest...   Jul 14 2003, 11:11
- - zeer   2 FrDakota: Nobody is perfect. Actually, the prob...   Jul 14 2003, 14:07
- - zaphod   I've made a tiny Python script which "abu...   Jul 27 2003, 16:12
RSS Lo-Fi Version Time is now: 25th April 2015 - 21:07
