WAV-->AAC with Quicktime (WIN), convert 500 files with quicktime
spirit303
post Jun 30 2003, 01:26
i need help
how do i convert my 500 WAV files into AAC (mp4) with the best quality encoder apple quick time 6.3 for !windows! ?
i don' wanna open each file and export it. it will keep me goin for years !!!
please tell me how to do it
thank u guys
FrDakota
post Jul 4 2003, 08:00
QUOTE (richard123 @ Jul 3 2003, 06:22 AM)
Perhaps we are using different versions of QT.  I'm using QT Pro 6.3.
With that version, in the main program I can just launch QT, rather than go through the empty.mov sequence
In the callQT function, the following sequence of keystrokes works for me:
%FO
Path
ENTER
ESC
%FE
ENTER
otherwise, seems to work fine on extremely limited testing (and no testing on odd characters)
I found out why it wasn't working for you...
It's not because of QuickTime, it was the OS. Mine is french.
So WshShell.SendKeys "%D" was to set the cursor in the file destination field (well it's ludicrous in fact, not needed), but corresponding to the french underlined letter when I press Alt.
WshShell.SendKeys "%E" also was used for the E of "Enregistrer" so your way to put "Enter" is the most localisation independent one.
I also modified the script to loop on failed encodings.
If the mp4 file does not exist when the mp5 one dissapears, then it exports again.
One thing that is great with QuickTime is that it can do batch transcoding this way too.
Since QuickTime can open mp3 files you only have to export to mp4 to convert. biggrin.gif
So another script where "wav" is replaced with "mp3" will do just that fine.
I'm updating the CallQuickTime function above.
- spirit303   WAV-->AAC with Quicktime (WIN)   Jun 30 2003, 01:26
- - rjamorim   You'll have to wait. At the time, there's ...   Jun 30 2003, 01:44
- - FrDakota   I have quite successfully done a VBScript that con...   Jul 3 2003, 12:19
- - richard123   It would be easier to comment on your script if yo...   Jul 3 2003, 13:17
- - FrDakota   Ok I post it. Things to know. I made a direct ref...   Jul 3 2003, 13:51
- - richard123   Perhaps we are using different versions of QT. I...   Jul 3 2003, 15:22
- - Tomb   >how do i convert my 500 WAV files into AAC (mp...   Jul 3 2003, 15:35
- - FrDakota   It strange to send an ESC to QT it should clear a ...   Jul 3 2003, 15:43
- - richard123   I send an escape because sometimes the Edit menu g...   Jul 3 2003, 16:00
- - FrDakota   My problem is that I couldn't find a reference...   Jul 3 2003, 16:33
- - richard123   You appear to be right about AppActivate. I'm...   Jul 3 2003, 18:02
- - FrDakota   I saw you cleaned the unused variables They wer...   Jul 3 2003, 18:34
- - richard123   A number of web sites recommend set fso = nothing....   Jul 3 2003, 19:23
- - FrDakota   QUOTE (richard123 @ Jul 3 2003, 06:22 AM)Perh...   Jul 4 2003, 08:00
- - SentientPC   Great work FrDakota and richard123...looking forwa...   Jul 4 2003, 08:45
- - richard123   Another point I noticed - QT won't open a file...   Jul 4 2003, 09:22
- - SentientPC   QUOTE (richard123 @ Jul 4 2003, 03:22 AM)I...   Jul 4 2003, 09:42
- - FrDakota   (w00t) I finaly found how the infamous ".wav...   Jul 4 2003, 15:57
- - richard123   I had added a delay to the loop CODEWhile fso.Fil...   Jul 4 2003, 16:38
- - c123   Hi When I tried to get this to work, I got a ...   Jul 4 2003, 21:45
- - FrDakota   Well for the script to work QuickTime Pro must be ...   Jul 5 2003, 01:01
- - spoon   I should have something to release either today or...   Jul 5 2003, 09:34
- - c123   QUOTE (FrDakota @ Jul 5 2003, 12:01 AM)Well f...   Jul 5 2003, 10:47
- - c123   Just tried to encode four wav files, and ED:...   Jul 5 2003, 11:03
- - c123   Keep on getting the "file exists already...   Jul 5 2003, 12:00
- - FrDakota   QUOTE (c123 @ Jul 5 2003, 03:00 AM)p.s. on my...   Jul 5 2003, 12:56
- - c123   I doubled the times in the vbs file, and now I can...   Jul 5 2003, 19:18
- - FrDakota   QUOTE (c123 @ Jul 5 2003, 10:18 AM)Only probl...   Jul 5 2003, 21:18
- - FrDakota   To simplify things, here his the full corrected sc...   Jul 6 2003, 07:39
- - jsnx   Thanks for sharing the script. Works good. There...   Jul 6 2003, 16:16
- - SentientPC   Error: see below.   Jul 8 2003, 03:26
- - SentientPC   QUOTE (FrDakota @ Jul 6 2003, 01:39 AM)To sim...   Jul 8 2003, 03:33
- - FrDakota   QUOTE (SentientPC @ Jul 7 2003, 06:33 PM)I ha...   Jul 8 2003, 07:34
- - perplx   Im working on my own front end that uses winapi in...   Jul 8 2003, 19:30
- - spoon   SendMessages? I found the menu handling to be quit...   Jul 8 2003, 23:20
- - perplx   I had to do that too, I wanted add bit rate ect to...   Jul 9 2003, 01:03
- - zeer   this script version works for me with EAC (if you ...   Jul 9 2003, 15:28
- - rpop   I haven't tried using this script, but I'v...   Jul 10 2003, 23:36
- - Nic   As soon as QuickTime 6 came out, I grabbed the SDK...   Jul 11 2003, 00:05
- - perplx   A question for spoon or anyone else that knows. Wh...   Jul 11 2003, 06:33
- - zeer   It seems to get Quicktime api/sdk to work the APP ...   Jul 13 2003, 11:08
- - FrDakota   QUOTE (zeer @ Jul 9 2003, 06:28 AM)CODE While...   Jul 14 2003, 09:42
- - Nic   @zeer: Ahh, I guess that maybe the case. Its a sha...   Jul 14 2003, 09:47
- - spoon   QUOTE (perplx @ Jul 11 2003, 05:33 AM)A quest...   Jul 14 2003, 11:11
- - zeer   2 FrDakota: Nobody is perfect. Actually, the prob...   Jul 14 2003, 14:07
- - zaphod   I've made a tiny Python script which "abu...   Jul 27 2003, 16:12
RSS Lo-Fi Version Time is now: 5th March 2015 - 07:31
