Topic: Play fail on very very short audio (WMA) (Read 4670 times) previous topic - next topic
Winamp and wma2wav also cannot decode it. The output is 44-byte file i.e. header-only. What program is able to decode this file?
I tested FFmpeg decoder and it too fails to produce any output. Wmal2pcm.exe can decode it to four samples long wav file. I suspect this is the same gapless issue that WMA Lossless has suffered for years now. The bug is that some files fail to decode to original length with third party WMA decoders and only wmal2pcm decodes them correctly. If someone finds a solution for this I suspect Peter would be more than happy to implement it.
The bug is that some files fail to decode to original length with third party WMA decoders...
I guess you're saying that bug "fail to decode to original length" is the cause of the FB2K playback error? Perhaps because FB2K does not tolerate the change in length?
GoldWave (the creator), Windows Media Player.
If you mean this GoldWave, I tried both release v5.70 and beta v6.05 and they both failed to open the file. Granted, they did not show any error messages but the file they claimed to have opened was empty. Zero samples long.
Windows Media Player in both Windows 7 and Windows 8.1 also failed. They allowed adding the file to the library but if you add the file to a playlist you will see it is missing length. And playback stops when it reaches the track. So WMP encounters an error but doesn't bother reporting about it.
I'm suspecting the same length bug is the cause but not because foobar2000 is intolerant about length mismatches. For longer files it breaks the promise of being lossless and can cause audible issues if track was supposed to be gapless. But foobar2000 has no trouble playing the non-missing parts of such files. You only have problems with invalid audio files that contain no audio at all.
Yup.
What indicates that's a failure?
What indicates this file is invalid?
The file should be four samples long.
This file isn't invalid but decoders that people can use in their programs can't decode it correctly. Only wmal2pcm tool decodes it right.
The file should be four samples long. This file isn't invalid
You've lost me there. If it is valid, then it does have the correct number of samples, surely.
Well, one of the reasons for me reporting it here is the hope people will improve their code
AFAIK foobar2000 uses system decoder written by Microsoft. So it seems that you should ask MS developers to improve their code.
I should have been more careful with my wording in the earlier post. Like I corrected in a later post the file isn't invalid but the decoder bug makes it look invalid for foobar2000.
The file is a valid lossless WMA file and contains four audio samples. It can be decoded to a four samples long WAV file with wmal2pcm tool and the decoded audio file works fine in foobar2000. But the decoder built into Windows fails to decode it correctly and truncates the file to nothingness. This is where the problem comes from. It should contain data and foobar2000 correctly reports the error decoder gives with the file.
That is correct. The only other available decoder implementation that I know of is FFmpeg and it too fails here.
I'm sure MS has it's reasons for using faulty code. I can't imagine what FB2K's is
IMHO foobar2000 uses the best available solution.
"Wmal2pcm.exe can decode it"
wmal2pcm is a closed source program: MS didn't open its source code. So I cannot understand how fb2k can use it.
If wmal2pcm can do it, fb2k can do it.
Why not? Reverse engineer wmal2pcm.exe and publish the code under a non-restrictive license. I'm sure foobar2000 developers will be happy to use it.
Or use the command-line decoder wrapper plugin.
This solution has its own problems: no tags, slow seeking, pauses between tracks (when wmal2pcm decodes .wma to .wav)...
Well, sure, the real problem is the broken file, not the choice of decoder. I just wanted to mention another solution.
How many samples in length did you actually save?
I didn't specify a specific number of samples (just a short duration) and the program GoldWave didn't tell me.
What was the duration you specified?
Just a short duration. With a mouse drag. I didn't read the measure.
Unrelated to foobar2000's support of this track, it seems that FFMPEG both registers that the duration and pre-roll fields of this file are identical (as with any file which is less than 1ms) and thus zero length, but the bitstream parser is unable to decode any sample data from the 13KB of bitstream provided, so there's something wrong with their decoder as well, or so it seems.
