6 Pages V   1 2 3 > »
foo_convolve - Impulse response convolver, 'Mother of all effects' plugin
Garf
post Jun 20 2003, 20:50
Server Admin
Group: Admin
Download for foobar2000 0.8.x (250K)
Please see the official additional components page for the foobar2000 0.9.x compatible version.
This DSP component takes impulse response and does a
fast convolution of the sound data with that impulse
response.
Basically, it allows quick computation of any combination of
linear effects, such as equalization, echo, flange, reverb,
phase shift and so on. It can transform the sound to exactly
the image you would get as where the impulse response was
recorded, allowing you to get an accurate reproduction of
a big theather or stadium.
This effect is available as 'Acoustic Mirror' in Sound Forge.
A restricted version is available as 'Digital Convolution'
in Cool Edit.
A small manual is included in the readme.
Some discussion about convolutions:
http://www.hydrogenaudio.org/show.php/act/...t/ST/f/1/t/9116
Edit: Added download instructions for foobar2000 0.9.x compatible version.
This post has been edited by foosion: Sep 13 2007, 10:56
xbenchman
post Jun 20 2003, 21:08
Thanks Garf,
Looks like a new toy to play with.
Melomane
post Jun 20 2003, 21:32
ERROR (CORE) : Failed to load DLL: foo_convolve.dll, reason: Unable to load dll.
win98 se foobar 0.667
Music is my first love.
Garf
post Jun 20 2003, 21:48
Server Admin
Group: Admin
Get libmmd.dll from rarewares. Does it solve things?
http://rarewares.hydrogenaudio.org/files/libmmd7.zip
DigitalMan
post Jun 20 2003, 21:58
Garf,
Thanks for creating this - it could be extremely powerful. libmmd.dll fixed this same error for me.
Question - what tools would you recommend for creating custom impulse responses, say for a room correction amplitude equalizer? Could this be done with Sound Forge?
Was that a 1 or a 0?
Garf
post Jun 20 2003, 21:59
Server Admin
Group: Admin
I reuploaded it, the new version does not need libmmd.dll.
Garf
post Jun 20 2003, 22:06
Server Admin
Group: Admin
QUOTE (DigitalMan @ Jun 20 2003 - 10:58 PM)
I have no experience with 'room correction amplitude equalization', but basically, if you find a single tool that can do it, and allows you to feed the impulse through it, you're set.
You can even use analogue equipment.
DigitalMan
post Jun 20 2003, 22:22
QUOTE (Garf @ Jun 20 2003 - 01:06 PM)
Thanks, I think I can make this work for equalization. By the way, any chance this plugin could be made to have the option for separate impulse responses for each channel? I'm interested in equalization and that would help a lot.
Also, is it correct to assume that the impulse response must be created with the same sampling rate as the file to be convolved? If not I would expect the time/frequency values would shift.
Garf
post Jun 20 2003, 22:30
Server Admin
Group: Admin
Way ahead of you smile.gif Just make stereo impulse responses.
Correct.
Garf
post Jun 20 2003, 22:37
Server Admin
Group: Admin
Thanks to Case the example impulses are now in WavPack format (which foobar can read by default, you needed a plugin for the FLAC ones I had before).
Canar
post Jun 21 2003, 00:36
QUOTE (Readme.txt)
It can do an 2 048 tap equalization at 42 times realtime.
The default 18 tap foobar2k equalizer runs at 30 times
realtime. In effect, it can equalize faster than the
equalizer can.
How difficult is it to generate the tap data from the equalization parameters?
2. Assume good faith.
Garf
post Jun 21 2003, 00:45
Server Admin
Group: Admin
QUOTE (Canar @ Jun 21 2003 - 01:36 AM)
QUOTE (Readme.txt)
equalizer can.
As explained in the readme, just feed an impulse through your effect of choice. In this case, diskwrite 'Unitimpulse2k.wav' with EQ settings of choice enabled.
If you want to, you can speed it up further by editing the resulting WAV with a sound editor and cutting the near silence before and after the impulse.
Canar
post Jun 21 2003, 05:38
QUOTE (Garf @ Jun 20 2003 - 03:45 PM)
Ah, so it can't be done algorithmically?
Garf
post Jun 21 2003, 09:18
Server Admin
Group: Admin
QUOTE (Canar @ Jun 21 2003 - 06:38 AM)
How is this not 'algorithmically'???
You need to transform the frequency response of the EQ into an impulse response. Guess what diskwriting the impulse with EQ enabled does...
Edit: I guess that you're asking whether it's possible to make an EQ component that uses the foo_convolve engine as a backend for the equalizer. Yes. In fact I checked and there are similarities between the current backends, but my code is faster, and you can finetune the filter length. Not to mention it also works in stereo.
Canar
post Jun 21 2003, 18:33
Post #15
QUOTE (Garf @ Jun 21 2003 - 12:18 AM)
I mean directly calculating the tap data, rather than running a Dirac pulse through a system and finding its impulse response.
Ack. I think I need to start being more specific when I'm posting about technical stuff... wink.gif
Garf
post Jun 21 2003, 18:38
Post #16
Server Admin
Group: Admin
It's possible. I don't think it has much of a point though. The advantage of the convolver is that it's infinitely flexible and that you can combine the equalization with any other effect.
lucpes
post Jun 21 2003, 22:42
Post #17
I may have found a bug:
[speakers off!] download one of the files that are here: http://www.geocities.com/beamsonic/studio.htm,
Garf Edit: We killed the site. I uploaded files to http://sjeng.org/ftp/fb2k/analogue.zip
(I took the DBX 160 file) open in wave editor, keep only first 16384 samples, duplicate channel to get stereo, then save & set as impulse file in FB2k. Play something, then close FB2k. Open it and play the thing again, but now go into DSP properties to the convolver settings. You'll be granted with either a crash or a very loud distorted sound (kinda like microphone feedback).
edit: added speakers off warning...
This post has been edited by Garf: Jun 21 2003, 23:46
lucpes
post Jun 21 2003, 23:01
Post #18
Problem "solved" by keeping the impulse sample as short as possible (trimming the impulse to get most of the 0's around it out).
Garf
post Jun 21 2003, 23:09
Post #19
Server Admin
Group: Admin
It's a bug - the impulse doesn't get loaded when the config panel isn't opened. Will fix.
Edit: You don't need to convert to stereo - the component will convert automatically.
Garf
post Jun 21 2003, 23:21
Post #20
Server Admin
Group: Admin
Uploaded new version with bugfixes and speed improvements.
Messer
post Jun 22 2003, 02:16
Post #21
Thanks for this truly essential tool, Garf.
Tiny req: I think that "dry/wet" slider would be nice for your tool.
_Shorty
post Jun 22 2003, 02:50
Post #22
Group: Banned
you don't think this type of thing would/should be an all or nothing affair? Seems to me that your impulse response would be giving you exactly what you wanted and there wouldn't be any need for mixing it with the original.
Messer
post Jun 22 2003, 03:53
Post #23
QUOTE (_Shorty @ Jun 22 2003 - 03:50 AM)
Well, yes, you're probably right.
I'm just used to wet/dry sliders in DSP effects wink.gif Especially in reverb, hrtf-related effects and similiar stuff. It's just an easy and fast way to adjust "amount" of effect you'd like at the moment. It's not "a must" for convolver, but that was first thing that I've been kinda "missing" while I was playing with IRs converted from SF Acoustic Mirror wink.gif
Guess it could also be general request for DSP manager, but there are some plugins (like gap killers, crosfaders...) that couldn't utilize this functionality for any reasonable purpose... So, no.
_Shorty
post Jun 22 2003, 09:48
Post #24
Group: Banned
I'm not strictly confident that a mix control would be useless in this case, it was just a thought, given how it operates.
lucpes
post Jun 22 2003, 10:28
Post #25
QUOTE (Garf @ Jun 21 2003 - 10:21 PM)
Thanks!!! Now if I can borrow a tube preamp... it would be great... muhahaha B)
edit: @Garf: can you include these in the analogue 'pack' (the pipeline preamps)?
http://www.noisevault.com/index.php?page=3....
BUG! [speakers off...] what happens if I load a 32bit float (IEEE) file as the impulse file? -> answer: blown tweeter fuses tongue.gif dammit... I need to get new fuses smile.gif
This post has been edited by lucpes: Jun 22 2003, 13:32
6 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 25th May 2015 - 21:43
