IPB
Some very weird measurements H4n, Could someone explain this to me?
ktf
post Mar 20 2014, 17:47
Post #1
Group: Members
Hi all,
I was reading the SoX manual and found the spectrogram effect. I played with it, and by incident I found something which is think is really weird.
I thought, I can measure the audio output of my laptop. I hooked the line out of my laptop to the inputs of my Zoom H4n recorder, which I thought would have a better input than the combined mic/line input of my laptop. I made a linear 20Hz to 20kHz sweep in Audacity, played it through aplay, set levels, recorded it through arecord, and I got this...
H4n at lowest sensitivity, levels set to get -6dBFS
H4n at middle sensitivity, levels set to get -6dBFS
H4n at lowest sensitivity, levels set to get -12dBFS
H4n at lowest sensitivity, levels set to get -24dBFS
I was very surprised to see this, so I did the tests with my Sansa Fuse playing the files instead of my laptop, but it gave me the same results. Disconnecting the device from USB and running it standalone, recording to SD-card got me the same results as well. To me it looked like amplifier overload (instability) or something like that, so I tried a 440Hz sine combined with a sweep to check, but I got something even weirder!
Sine + sweep input
So my question to you is: what the hell is this? I know, this device is battery powered and can record for more than 10 hours on 2 AA batteries, but still, this looks like to much of a quality vs power consumption trade-off, right?
Go to the top of the page
+Quote Post
saratoga
post Mar 20 2014, 17:54
Post #2
Group: Members
FWIW I would use RMAA and not a spectrogram to do understand what is happening, as a sweep is not the best way to understand nonlinear effects.
But from those plots it looks like your recorder just has a lot of nonlinear distortion. Probably its a crappy ADC.
+Quote Post
ktf
post Mar 20 2014, 18:31
Post #3
Group: Members
QUOTE (saratoga @ Mar 20 2014, 17:54) *
I've been looking into that, but AFAIK it's Windows-only. Is there anything comparable for Linux, to be specific: Kubuntu?
+Quote Post
Arnold B. Kruege...
post Mar 20 2014, 20:10
Post #4
Group: Members
QUOTE (ktf @ Mar 20 2014, 12:47) *
Hi all,
Sine + sweep input
The H4N tests clearly show nonlinear distortion plus aliasing. That's the usual interpretation of a spurious response that goes down in frequency when the test signal is going up in frequency.
The 6 dBFS Fuze test shows groups of multiple diagonal lines that are monotonic, which appear to relate to several different orders of nonlinear distortion. The fact that the diagonal lines are in groups and are interspersed with vertical spikes is a new one on me. Seems like there is hum or noise in the test.
I agree with the comment about spectragrams not being the usual tool that is used for this sort of thing. Spectragrams are more familiar to most people as tools for analyzing real world signals like speech and music as opposed to technical problems with hardware.
+Quote Post
pdq
post Mar 20 2014, 20:27
Post #5
Group: Members
Does the H4n record as PCM, or as lossy?
+Quote Post
ktf
post Mar 20 2014, 20:30
Post #6
Group: Members
QUOTE (pdq @ Mar 20 2014, 20:27) *
All measurements displayed here were done with the H4n as an USB interface, which I presume is lossless. As a standalone recorder recording to PCM, I got the same results.
+Quote Post
Kees de Visser
post Mar 20 2014, 21:04
Post #7
Group: Members
QUOTE (ktf @ Mar 20 2014, 17:47) *
Does the H4n have line inputs ?
+Quote Post
ktf
post Mar 20 2014, 22:07
Post #8
Group: Members
QUOTE (Kees de Visser @ Mar 20 2014, 21:04) *
That depends on what you call line input. It has one 3.5mm jack input with plug-in power and two XLR/jack combo jacks that can both handle a line signal if it isn't too hot.
+Quote Post
Alexey Lukin
post Mar 21 2014, 18:10
Post #9
Group: Members
H4n has a built-in limiter and an auto-gain. Depending on your settings, they may be contributing to the nonlinear distortion.
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 29th August 2014 - 00:27
