IPB
Anything new?
adlai
post Feb 14 2014, 05:15
Post #1
Group: Members
So a while ago I started using Nero AAC 0.5
because it is compatible with everything that I use (Ogg vorbis unfortunately is not)
Have there been any new developments in audio encoding...within the last 2-3 years? How does apple compare nowadays? It seems like their aac encoder is still under active development, while Nero looks like they stopped like 5 years ago and said it was good enough.
Go to the top of the page
+Quote Post
LithosZA
post Feb 14 2014, 07:07
Post #2
Group: Members
QUOTE
The Opus audio codec was created, but you probably already know this smile.gif
For AAC:
I would recommend using Apple's AAC or Fraunhofer's AAC encoder. On the listening tests Apple's AAC encoder is on par or slightly ahead of Fraunhofer.
For an open source AAC encoder usable from ffmpeg then Fraunhofer's FDK-AAC is the best choice.
Nero AAC is petty much dead and doesn't really compare well.
+Quote Post
birdie
post Feb 14 2014, 09:43
Post #3
Group: Members
Fraunhofer FDK AAC codec consistently beats all other AAC codecs, so use it.
Nero loses even to Apple's QuickTime encoder which usually is a runner up.
+Quote Post
Kohlrabi
post Feb 14 2014, 09:52
Post #4
Group: Super Moderator
QUOTE (birdie @ Feb 14 2014, 09:43) *
[...] Apple's QuickTime encoder which usually is a runner up.
No, it's not. It's on par with Fraunhofer's AAC encoder, and both are at the top.
Audiophiles live in constant fear of jitter.
+Quote Post
eahm
post Feb 14 2014, 15:34
Post #5
Group: Members
QUOTE (Kohlrabi @ Feb 14 2014, 01:52) *
We've had a long discussion about this while ago, Apple is better.
This post has been edited by eahm: Feb 14 2014, 15:37
/lwAsIimz
+Quote Post
greynol
post Feb 14 2014, 15:44
Post #6
Depending on how you massage the data either Apple or Fraunhofer could be declared the winner. It is the FhG version that did so well, which is not the one found in ffmpeg, however.
What is important to note is the bitrate tested was in the 96k range, significantly lower than what you get using Nero at 0.5. At these higher bitrates you're likely going to get acceptable results with any of these encoders with most content.
This post has been edited by greynol: Feb 14 2014, 15:52
Placebophiles: put up or shut up!
+Quote Post
adlai
post Feb 14 2014, 17:37
Post #7
Group: Members
thanks.
I use foobar to encode. Yes, I'm old school. Basically just need something to bulk-encode flac files.
Can fraunhofer do this?
+Quote Post
greynol
post Feb 14 2014, 17:41
Post #8
Yes and and foobar2000 can encode using Apple's encoder with QAAC and QuickTime.
+Quote Post
markanini
post Feb 14 2014, 17:43
Post #9
Group: Members
Look for fhgaacenc
+Quote Post
adlai
post Feb 14 2014, 17:59
Post #10
Group: Members
So i just installed winamp and I'm not seeing this aac encoder anywhere.
+Quote Post
adlai
post Feb 14 2014, 18:09
Post #11
Group: Members
I've also tried to get apple's aac working with a foobar style bulk encode. Kind of confusing. ANy help here?
+Quote Post
eahm
post Feb 14 2014, 18:44
Post #12
Group: Members
QUOTE (adlai @ Feb 14 2014, 10:09) *
qaac is really easy, read here:
https://github.com/nu774/qaac/wiki/Encoder-configuration
https://github.com/nu774/qaac/wiki/Examples
You can try this "foo_converter.dll.cfg" I made as well (you will need to copy each encoder inside the folder \encoders): http://www.hydrogenaudio.org/forums/index....howtopic=104627
This post has been edited by eahm: Feb 14 2014, 18:49
/lwAsIimz
+Quote Post
Mach-X
post Feb 14 2014, 20:26
Post #13
Group: Members
Winamps is even easier, right click on "all artists" in your media library -> send to -> format converter, and set your aac settings and wait. Make sure you've selected format converter and media library as install options wink.gif
This post has been edited by Mach-X: Feb 14 2014, 20:28
+Quote Post
adlai
post Feb 15 2014, 04:21
Post #14
Group: Members
QUOTE (eahm @ Feb 14 2014, 09:44) *
I'm not that smart.
I can't get it to work.
+Quote Post
LedHed8
post Feb 15 2014, 04:45
Post #15
Group: Members
Here's a command-line example from Foobar:
CODE
-V 73 --no-optimize - -o %d
This will give you Apple/Quicktime VBR files @ approximately 145kbps on average. Change the 73 to 82 to jump up the quality to the next step. Change to 91/100/109/118/127 for subsequent jump ups in quality.
Change the encoder preset to custom, point the encoder to where the qaac.exe is stored, and type in m4a for the file extension, and add your command-line as desired. Hope this helps. smile.gif
P.S.
CODE
-V 63 --no-optimize - -o %d
This might be a good place to start. The VBR encodes will average around 128kbps.
This post has been edited by LedHed8: Feb 15 2014, 04:52
+Quote Post
detmek
post Feb 15 2014, 10:44
Post #16
Group: Members
@adlai QAAC also requires at least Apple Application Support installed if one does not use extracted files or QuickTime or iTunes installed. Also, you did not speciffy what is wrong, what is error message.
+Quote Post
C.R.Helmrich
post Feb 15 2014, 14:04
Post #17
Group: Developer
QUOTE (eahm @ Feb 14 2014, 16:34) *
At 96 kbps this might be true. But for other bit-rates there have been no tests on HA which incl. Fraunhofer AAC encoders.
In fact, IgorC did a 64-kbps test in 2012 with Fraunhofer's Winamp encoder at 64 kbps, apparently twice. His latest results:
http://www.hydrogenaudio.org/forums/index....st&p=796836
Chris
+Quote Post
adlai
post Feb 15 2014, 16:08
Post #18
Group: Members
QUOTE (LedHed8 @ Feb 14 2014, 19:45) *
CODE
P.S.
CODE
thx for this. still, get this error
CODE
Source: "C:\Users\v\Desktop\Our Brother The Native - Terra Traipse-1\Our Brother The Native - Terra Traipse - 04 Unquieted.flac"
  An error occurred while writing to file (The encoder has terminated prematurely with code 1 (0x00000001); please re-check parameters) : "C:\Users\v\Music\iTunes\new music drop\Our Brother The Native - Terra Traipse\04. Unquieted.m4a"
  Additional information:
  Encoder stream format: 44100Hz / 2ch / 16bps
  Command line: "C:\qaac\x64\refalac64.exe" -V 73 --no-optimize - -o "04. Unquieted.m4a"
  Working folder: C:\Users\v\Music\iTunes\new music drop\Our Brother The Native - Terra Traipse\
  Conversion failed: The encoder has terminated prematurely with code 1 (0x00000001); please re-check parameters
This post has been edited by adlai: Feb 15 2014, 16:08
+Quote Post
lvqcl
post Feb 15 2014, 16:12
Post #19
Group: Developer
refalac encodes to ALAC, not to AAC. You need qaac.exe
+Quote Post
adlai
post Feb 15 2014, 17:48
Post #20
Group: Members
QUOTE (lvqcl @ Feb 15 2014, 07:12) *
ah, thanks for that.
got it working. Seems...good.
+Quote Post
adlai
post Feb 15 2014, 17:55
Post #21
Group: Members
QUOTE (LedHed8 @ Feb 14 2014, 20:45) *
CODE
So, what settings and quality levels for qaac do the people in this thread use, personally?
This post has been edited by adlai: Feb 15 2014, 17:56
+Quote Post
eahm
post Feb 15 2014, 19:09
Post #22
Group: Members
QUOTE (adlai @ Feb 15 2014, 09:55) *
You don't need --no-optimize.
I use -A for archiving, -V63 for iPhone and even -V36 +ReplayGain for the Sansa Clip Zip.
This post has been edited by eahm: Feb 15 2014, 19:09
/lwAsIimz
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 31st July 2014 - 23:22
