Topic: foo_youtube (Read 501680 times) previous topic - next topic
Re: foo_youtube
Reply #225
For whatever reason you presumably are unaffected, since nearly all tracks wouldn't play.
One example that failed for me in 0.0.17 and plays in 0.0.18dev1 is:
3dydfy://youtube.com/watch?v=79fzeNUqQbQ
Re: foo_youtube
Reply #226
Very strange! Before asking a link to make a trial I made a test and I did not notice any problem.
Today I cannot open any Youtube on all my foobars portable and installed!
Messages are "Insupported file", error 403, "Crash location:
Module: foo_youtube
Offset: 47DAh.
Edit
Ok with  0.0.18dev1.
Waiting for video window
Re: foo_youtube
Reply #227
In 0.0.16.1 version, all works fine...
Edit:
Ok, i didnt test enough, same is with 0.0.16.1.
I download 0.0.18dev1
Works ok.
Re: foo_youtube
Reply #228
Awesome plugin, thanks.
Can the same be done with Grooveshark? It has much better audio quality than youtube (many songs from youtube are below 128kbps) and the tags are far more accurate, that's especially important if someone is using last.fm for scrobbling.
It even has songs sorted by albums and so on, but streaming songs alone would be amazing.
Disregard the constabulary.
Re: foo_youtube
Reply #229
If you don't have API for Grooveshark, then this is not possible.
On web page source, you don't have mp3, mp4 - nothing..
So i don't think that this is possible.
Maybe Jango.com can be used?
Youtube audio quality is always 128 kbps as i see in my foobar from tracks i use.
About Tags, you can also use WSH to tag Youtube tracks.
Foobar Youtube Radio(based on last.fm) use 'track naming' from last.fm:
http://mire777.deviantart.com/art/Foobar-Y...Radio-447296512
WilB also have script based on same 'track naming': http://www.hydrogenaud.io/forums/index.php...t=0&start=0
Edit:
Ok i found API for Grooveshark > http://developers.grooveshark.com/
Someone can investigate this...
Re: foo_youtube
Reply #230
Edit:
Thanks for info, i will check that out. I rarely found some good audio quality tracks, especially when videos are few years old.
As for grooveshark, it is possible.. some other audio players already have grooveshark plugin and there are even unofficial standalone grooveshark players, but i don't know if they are using official API or some other ones like this one or this one.
I'm not dev so i don't know if links provided are any helpful so..
Re: foo_youtube
Reply #231
Edit:
This is based on python.
Did you try this:
http://www.hydrogenaud.io/forums/index.php...c=91538&hl=
http://www.hydrogenaud.io/forums/index.php...p;p=824633&
You also have this with echonest: http://www.hydrogenaud.io/forums/index.php...mp;#entry822408
Doesn't know what exactly this scripts do, maybe only create playlist from your library?
Re: foo_youtube
Reply #232
Did you try this:
My bad then.  Thought it might be useful.
As for second link, it does not work for me (crashes when i search something) but that's not foobar component, it's a standalone app.
But those are not exactly what i was looking for. Thanks anyway.
I used this component until year or so ago but it doesn't work anymore for some reason. It was streaming songs from vk.com, audio quality was ok and it had huge selection of songs, comparable to grooveshark, deezer or other streaming services.
EDIT: i thing that those scripts only generates playlist from your library, yes.. i believe i've tried some of them some time ago, not sure.
Re: foo_youtube
Reply #233
New version:
foo_youtube_0.0.18.zip
Changes:
- additional variants how to show video window. See 'Features -> Video -> Show video' combobox in preferences
- video window resizing in no-border mode
- custom video window size. Read note#1 below
- optional video window separation from main window. Read note#2 below
- optional preventing video window activation on show. Read note#3 below
- fixes for search autocomplete list. Most important - possibility to select variant from the list using mouse
- fix for supporting new ffmpeg versions. Now should work with any version greater or equal to 2.1.
Note#1.
Placed in video window context menu, 'Fix to current' item. Initial video size variants were 50%, 100% and 200%. Now added one more - current video window size (at option applying time). If selected, always will be used this size regardless of original video size.
Note#2.
See video window context menu 'Window -> Separate with main window'. If checked, video window activation does not produce main foobar window activation i.e. main window does not show if it was invisible.
Note#3.
See video window context menu 'Window -> Activate when showing'. If checked, on showing video window will not become active and thus will not deactivate current window and will not steal keyboard focus.
Re: foo_youtube
Reply #234
It seems ok with a quick trial
Note 1: ok
Note 2: ok
Note 3: I did not tried all functions.
Thanks a lot.
Re: foo_youtube
Reply #235
Works great.
I am still amazed how this video work.
Re: foo_youtube
Reply #236
Doesn't know if only i have this problem? When from menu: View>Youtube Source
In Search box i type something- click enter. Search box desapear, and nothing isn't loaded in playlist?
Re: foo_youtube
Reply #237
Ok, see it. Update will be tomorrow if no other problems will be found.
Re: foo_youtube
Reply #238
Just out of curiosity, is Youtube continually trying to prevent things like your plugin from working?
Re: foo_youtube
Reply #239
I love feature Show video automatically when Youtube clip starts to play
Re: foo_youtube
Reply #240
Well, of course it has few tricks for preventing such things from working but changes usually not relate to them. Youtube is constantly evolving even if not all the changes visible from outside. Some of those changes may break such things from working. So without continuous support they are dying more or less fast. This fact plus only VO for best quality plus few security tricks plus TOS seems enough for them.
Re: foo_youtube
Reply #241
New version:
foo_youtube_0.0.18.1.zip
Changes:
- fix for component window closing after search
Re: foo_youtube
Reply #243
Feature request: a playlist maker. I'd love to be able to paste a list of titles and/or YouTube URLs to create a playlist. For a list of titles, the first search result could be played.
Re: foo_youtube
Reply #244
List of Youtube URLs already can be added through menu File -> 'Add Youtube URL(s)...' Resize the window to enable multiline edit box and fill with URLs (one link per line).
About list of titles - noted, however I can't imagine the use case. Also first search result is not always the best one.
Re: foo_youtube
Reply #245
Awesome!!!
The list of titles would be handy so that you could copy-paste (for example) a top 10 list without having to search for every YouTube video first.
Re: foo_youtube
Reply #246
Hi, Im big fun of this component and im using it all the time. I just got one request: Can you add a tab in youtube source with saved playlists ? I use 'send by ..' playlist from youtube's channels so they are updated once a day or two so standard foobar playlist save wont work (I mean it wont add new clips to a playlist). I have to open 'Add new youtube url' dialog window and add it everytime. Ofc there are my previous links but if there are 3 or 4 channels i just dont know which is the one im looking for so I have to open browser everytime. Thanks  Also sometimes audio struggles even when im not downloading anything or do anything that could slow my pc (its not only my problem, 2 friends sometimes got same). Sry for my english, I hope you understand what I was trying to say
Re: foo_youtube
Reply #247
Can you add a tab in youtube source with saved playlists?
Ok, noted.
Ensure that you are using audio-only streams (ffmpeg required). There is nothing else that I can suggest.
Re: foo_youtube
Reply #248
New version:
foo_youtube_0.0.19.zip
Changes:
- subtitles support in video playback. See 'Show subtitles' option in Features tab
- possibility to add list of titles (first search result will be used). See 'Add Youtube URL(s)...' dialog.
- ffmpeg related, avresample can be used instead of swresample
Re: foo_youtube
Reply #249
What is this message shown together with Youtube video window,
Creating VSFilter: Classe non enregistrée
