IPB
Digital filters - quality value limits, min/max for Q and bw in EQ implementation
Juha
post Dec 21 2013, 15:03
Post #1
Group: Members
Are there some "standards" for max/min of Q and bw values when used in EQ.
Would 0.001-100.000 for Q and 0.010 - 20.000 for BW be reasonable ranges?
Juha
Go to the top of the page
+Quote Post
saratoga
post Dec 21 2013, 20:37
Post #2
Group: Members
I think 0.1 to 10 is pretty standard for Q.
BTW, Q is the width of the filter, with Q=1 having bandwidth equal to the center frequency (so quite broad already). A Q of .001 would be so broad it would essentially just be a really complex way of doing a volume adjustment smile.gif
+Quote Post
Juha
post Dec 21 2013, 22:12
Post #3
Group: Members
QUOTE (saratoga @ Dec 21 2013, 23:37) *
I was 'bout to select that range but, then checked the Electri-Q implementation which uses range 0.010-20.000.
As shown in the image (graph is for peak type filter), bw=20.000 corresponds Q=0.001:
In my EQ implementation, it's possible to switch the quality "type" to either Q or bw (or none (if not needed)).
In this implementation, the Notch type filter without given quality value corresponds a Notch filter with bw value set to ~0.048
(i.e. Q = 30.055) so if I select bw as min = 0.100 and max = 20.000 there's area left between those 2 type options that I can't control if needed.
I wouldn't want to set the Q/bw min/max by the filter type.
Juha
+Quote Post
saratoga
post Dec 21 2013, 22:39
Post #4
Group: Members
I'm not sure I understand what you mean?
+Quote Post
Juha
post Dec 21 2013, 22:46
Post #5
Group: Members
QUOTE (saratoga @ Dec 22 2013, 01:39) *
http://www.sengpielaudio.com/calculator-bandwidth.htm
Juha
+Quote Post
saratoga
post Dec 21 2013, 22:56
Post #6
Group: Members
I mean I don't understand what you're asking. Did you still have a question?
+Quote Post
Arnold B. Kruege...
post Dec 22 2013, 11:57
Post #7
Group: Members
QUOTE (Juha @ Dec 21 2013, 09:03) *
Look at commercial parametric equalizers implemented in the analog domain for guidance in that area. The most recent implementations of real-world equalizers are parts of digital consoles.
Some software implementations are way beyond anything that anyone would actually use or need in real world recording, etc.
QUOTE
Ne Plus Ultra, man.
This post has been edited by Arnold B. Krueger: Dec 22 2013, 11:58
+Quote Post
AstralStorm
post Feb 12 2014, 06:02
Post #8
Group: Members
In my experience, Q=0.01-40 are sufficient. There's no real reason to constrain it too badly - the main issue is numerical precision in the coefficients, especially at low frequencies.
ruxvilti'a
+Quote Post
markanini
post Feb 12 2014, 15:18
Post #9
Group: Members
Above Q10 it's more of a phase effect than an EQ.
+Quote Post
extrabigmehdi
post Feb 12 2014, 16:13
Post #10
Group: Members
Yeah, the phase shift can increase with Q (assuming minimum phase eq).
And it's preferable to use use smooth curves in your eq anyways.
Unless you use a linear phase eq, but I think you'd hear other artifacts with big Q values.
Notice that the Q value can have different impact from a digital eq, to an other (not necessarily standard values are used).
+Quote Post
AstralStorm
post Feb 13 2014, 22:53
Post #11
Group: Members
High Q filters are almost necessary at high frequencies for precision, but I didn't find any use for Q=40 to be honest. Highest I've ever needed was 24 when equalizing headphones. Blame the darn s-plane for being so skewed.
This post has been edited by AstralStorm: Feb 13 2014, 22:54
ruxvilti'a
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 28th August 2014 - 17:25
