4 Pages V  < 1 2 3 4 >
RareWares Debian GNU/Linux Repository, Audio + Debian Geeks = Euphoria!!
Yaztromo
post Nov 16 2005, 14:01
Post #51
Hello xmixahlx
I tried to install Lamip last night from Rarewares Debian respository but synaptic complains that it require libssl0.9.8. I can only find libssl0.9.7. Do you know a repository I can get it from?
I'm using Ubuntu Breezy Badger by the way.
xmixahlx
post Nov 17 2005, 00:11
Post #52
rarewares uses debian sid/unstable
you could see if upgrading ubuntu is possible, or using debian repo, or recompiling for ubuntu.
all the sources are in http://xmixahlx.dyndns.org/debian/
later
RareWares/Debian :: http://www.rarewares.org/debian.html
Yaztromo
post Nov 18 2005, 18:35
Post #53
QUOTE (xmixahlx @ Nov 16 2005, 11:11 PM)
later
I'd figured I need to use a repo with newer packages other than the standard ubuntu ones (universe, multiverse etc)
I have the two rarewares ones added and they work fine. I assume that packages needed to install things from them are on ftp.nerim.net, but it gives me these errors:
Get:8 ftp://ftp.nerim.net unstable/main Packages
Err ftp://ftp.nerim.net unstable/main Packages
  Unable to fetch file, server said ‘Can't open /debian-marillat/dists/unstable/main/binary-i386/Packages.gz: No such file or directory  ’ [IP: 62.4.17.14 21]
Fetched 4B in 1s (2B/s)
Failed to fetch ftp://ftp.nerim.net/debian-marillat/dists...386/Packages.gz  Unable to fetch file, server said ‘Can't open /debian-marillat/dists/unstable/main/binary-i386/Packages.gz: No such file or directory  ’ [IP: 62.4.17.14 21]
Reading package lists... Done
W: Couldn't stat source package list ftp://ftp.nerim.net unstable/main Packages (/var/lib/apt/lists/ftp.nerim.net_debian-marillat_dists_unstable_main_binary-i386_Packages) - stat (2 No such file or directory)
Do you know of any other repositories I can use or if I'm doing anything wrong with apt-get?
Your help is greatly appreciated xmix.
PS. I also tried to install packages other than lamip and got different unresolvable dependecies.
This post has been edited by Yaztromo: Nov 18 2005, 18:35
xmixahlx
post Nov 18 2005, 20:38
Post #54
refer to neomoe's post above
neomoe
post Nov 18 2005, 21:30
Post #55
Yaztromo,
add following addresses to your sources.list:
## Christian Marillat's Mult-Media Repository for Unstable aka SID
deb ftp://ftp.nerim.net/debian-marillat/ sid main
## RareWares/Debian Multi-Media Repository for Unstable - Experimental - Stable Staging
deb http://www.rarewares.org/debian/packages/experimental/ ./
deb http://www.rarewares.org/debian/packages/stable/ ./
## RareWares/Debian Multi-Media Repository for Unstable Staging (additional)
deb http://www.rarewares.org/debian/packages/unstable/ ./
##in addition to the RW-repos.
deb http://pkg-gnome.alioth.debian.org/debian/ experimental main
now procede as described on rarewares ("apt-pinning").
that should solve all your problems.
xmixahlx, the informaion on rarewares regarding apt-sources is not complete.
"deb http://www.rarewares.org/debian/packages/unstable/ ./" also needs to be added to the sources.list
This post has been edited by neomoe: Nov 18 2005, 21:33
[url="http://www.ergosum-apple.de"]www.ergosum-apple.de[/url]
xmixahlx
post Nov 19 2005, 00:54
Post #56
no, the reference to the unstable repo is on the front page
i need to edit the html to change christian marillat's repo from *unstable* to *sid*
the RW/D stable repo is mostly unusable, and is applicable to woody, not sarge. you don't need this repository unless you are running something old.
later
This post has been edited by xmixahlx: Nov 19 2005, 00:58
Yaztromo
post Nov 19 2005, 01:12
Post #57
Thank you to you both.
dpkg --force-all works a charm.
I have now have lamip with foobar control plugin working smile.gif It's basic, but it shows much much promise.
This post has been edited by Yaztromo: Nov 19 2005, 01:12
neomoe
post Nov 19 2005, 03:15
Post #58
QUOTE (xmixahlx @ Nov 18 2005, 03:54 PM)
ah, now I've seen it - it appears on the frontpage but not in the apt-pinning-how2. scrolling down a webpage can help a lot :-)
VCSkier
post Feb 26 2006, 08:40
Post #59
could someone point me in the direction of a slightly simpler explaination of how to enable this repo? i'm very new to linux, and am running ubuntu. apparently i dont really know what i'm doing. blush.gif i can't seem to grasp this apt pinning concept, or something; all i know is that i currently can't access the rw packages from my "synaptic package manager." i added "deb ftp://ftp.nerim.net/debian-marillat/ sid main" and "deb http://www.rarewares.org/debian/packages/experimental/ ./" to my "software sources" list in package manager, but still no luck.
the bottom line is that i'm trying to install lamip. as a former fb2k user, it seems to be the only viable alternative. this rw debian repo thing seems awesome, and appears to be the best way to get lamip, but i can't get it to work. thanks for any help or suggestions.
edit: fixed some pretty significant typos. lol, how did i do that?
This post has been edited by VCSkier: Feb 26 2006, 09:30
a windows-free, linux user since 1/31/06.
xmixahlx
post Feb 26 2006, 10:16
Post #60
i go through the apt config and explain pinning on the website, here:
http://rarewares.org/debian.html
the quick answer? add the following line to synaptic:
i've had mixed reports on ubuntu working with rarewares... it really depends how new the distro is. you may have to add debian repos, also to update some ubuntu packages.
later
VCSkier
post Mar 6 2006, 22:30
Post #61
i appear to have access to your repo's now, but i get this error message.
W: GPG error: ftp://ftp.nerim.net sid Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 07DC563D1F41B907
thanks though, so far, this has been very helpful.
rjamorim
post Mar 6 2006, 22:38
Post #62
Rarewares admin
QUOTE (VCSkier @ Mar 6 2006, 07:30 PM)
That is Marillat's repository. There have been issues with his GPG key for years. Nothing to get worried about, really.
xmixahlx
post Mar 18 2006, 20:52
Post #63
i've been playing with shine (nifty) and i also packaged it for RareWares/Debian
for my *nix brethren there are also generic linux compiles/source HERE for the moment.
later
This post has been edited by xmixahlx: Mar 18 2006, 20:58
xmixahlx
post Mar 18 2006, 21:03
Post #64
hey, so maybe i'll tell you new packages i've been playing with (i.e. added or updated)... i haven't done that in a while so here it goes:
current lamip 0.0.3 packages
ktag
dvda-author
cuetools
wav2lpcm
gstreamer0.8-monkeysaudio
k3b (~cvs)
any2dvd
kmediafactory
k3b-plugin-monkeysaudio
alac-decoder
goggles
vobstripper
vobwalker
wavpack
postfish
soundkonverter
kasound
gcdmaster/cdrdao
lame
wavgain
twolame
ssrc
abox
8hz-mp3
mpadec
later
xmixahlx
post Sep 29 2006, 09:05
Post #65
the rarewares/debian frontpage is updated with my goings-on...
here's the rundown:
2006.09.28
o UPDATED PACKAGES: cdrdao/gcdmaster, k3b (svn), monkeys-audio
o NEW PACKAGES: aqualung, libmodplug (upstream), flake
o REMOVED PACKAGES: faac, faad2, avidemux (svn) - all maintained by Marillat
2006.08.13
o UPDATED PACKAGES: k3b (svn)
o NEW PACKAGES: rubyripper, libfreedb-ruby
2006.06.13
o UPDATED PACKAGES: cuetools, flac (cvs), k3b (svn), oggenc-aotuv
later
Demetris
post Sep 29 2006, 11:10
Post #66
Thanks for Aqualung :-)
xmixahlx
post Sep 29 2006, 11:15
Post #67
you are welcome!!!
smile.gif so i'm not sleeping and packaging 'till the night turns to day, evidently
new packages:
lame (cvs), mp4tools, aften, dvd+rw-tools (upstream), lame/lame-3.97, noisechain
later
This post has been edited by xmixahlx: Sep 29 2006, 13:44
xmixahlx
post Oct 5 2006, 07:52
Post #68
more updates:
a special note! the flac packages must be downgraded to the official debian packages (1.1.2-5) due to incompatibilities in the lib/dev packages with the 1.1.3 changes.
for the time being, i've packaged flac as "flac-cvs" staticially (just binaries/manpages are included)
have fun!
# 2006.10.05
* UPDATED PACKAGES: k3b (svn), flake-enc (svn)
* NEW PACKAGES: affd
* REPACKAGED PACKAGES: flac (cvs) was moved to a static binary (flac-cvs) due to libs/devel being incompatible
* REMOVED PACKAGES: flac (cvs) - NOTE: You will want to downgrade packages from RareWares/Debian to Debian Official (1.1.2-5)
# 2006.10.02
* I'm starting to redo the old HTML - so this place might look a little weird for a few days.
* UPDATED PACKAGES: flac (cvs)
* NEW PACKAGES: aacgain, libvc1
* REPACKAGED PACKAGES: flake moved to flake-enc and split with libdevel package
later
This post has been edited by xmixahlx: Oct 5 2006, 09:10
darkbasic
post Nov 4 2006, 13:20
Post #69
Do you plan to package for amd64 too?
xmixahlx
post Nov 6 2006, 21:23
Post #70
i don't plan on it, no.
later
xmixahlx
post Nov 13 2006, 06:40
Post #71
more updates...
along with the usual cvs/svn updates come the new MDT releases, audacity beta and cdspeed
2006.11.12
* UPDATED PACKAGES: k3b (svn), flac-cvs (cvs), flake-enc (svn), musepack-encoder, xmms-musepack, libmpcdec
* NEW PACKAGES: cdspeed, audacity (beta)
later
George_007
post Nov 15 2006, 21:32
Post #72
Big big thanks for the audacity package!
xmixahlx
post Nov 15 2006, 22:20
Post #73
you're welcome!
i'm liking the feel of 1.3.2 much better than the stable branch, myself. your thoughts?
later
xmixahlx
post Dec 10 2006, 09:46
Post #74
more updates...
# 2006.12.10
* UPDATED PACKAGES: k3b (svn), flac-cvs (cvs), libmpcdec, rubyripper, wavpack (svn), lame (cvs)
* NEW PACKAGES: snd123
# 2006.11.18
* UPDATED PACKAGES: libvorbis-aotuv, alac-decoder, lame (cvs)
later
xmixahlx
post Jan 9 2008, 10:22
Post #75
yikes! i haven't updated this thread since '06?
anyways, a big update tonight:
updated packages:
* k3b (SVN)
* lame-cvs (CVS)
* musepack (SVN) - this is current SV8 r380
* xmms-musepack-sv8 (SVN) - same as ^
* wavpack (4.42.0-alpha2)
* xmms-wavpack (1.0.2, thanks david!)
* ktorrent-svn (SVN)
new packages:
* xvid (1.2.0-dev from CVS)
* linux kernel 2.6.23-kamikaze5 (k8 image, headers, manual, doc, source)
* dcadec/libdca (0.0.5, replaces libdts)
* libreplaygain (1.0, NEW LIBRARY FROM THE MDT)
older new/updated packages:
* k3b-plugin-monkeysaudio (3.1)
* mp4als
* libtagz
* ttaenc (3.3+shntool patch)
* kexis (0.2.2+shntool patch)
* bonk (0.6+shntool patch
* monkeys-audio (3.99+update4+build5+shntool patch)
* aacgain (1.7)
* xmms-musepack (1.2.1)
* shorten (3.6.1)
* shntool (3.0.3)
hope y'all had a good new years!
later
RSS Lo-Fi Version Time is now: 26th March 2015 - 23:57
