IPB
Amp Buzzing until pushed down!, Buzzes until I push down on one of the corners
Psyphre
post Sep 17 2013, 22:28
Post #1
Group: Members
Hi all,
I've got a strange issue with my Marantz 6003 amp. It builds up a buzz shortly after turning it on and can get very loud eventually.
I used to rip my hair out thinking it was a grounding loop, or that my flat's wiring was poor.
One day I put some books on the amp and the buzz completely stopped. I narrowed it down to one of the corners on the front right, if I push down when its buzzing, the buzzing stops completely! I have no idea what's going on?????
Does anyone know what might be causing this? I really dont want to buy a new amp if I don't have to.
thanks
Go to the top of the page
+Quote Post
DVDdoug
post Sep 17 2013, 23:26
Post #2
Group: Members
Is that a mechanical buzz (from the amp) or an electrical buzz (coming out of the speakers)?
In either case, something is probably loose... Something could be loose mechanically or electrically. i.e. It could be a loose screw/washer (some vibration is normal from the AC transformer), or a loose grounding-screw, or loose connector, etc. If you have to take the cover off to wiggle things around and push on things, etc., it's worth a try. If it's an electrical issue, just unplugging and reconnecting the internal connectors might cure it. I'd leave the power on when wiggling/pushing things (so you can potentially zero-in on the problem), but turn it off before disconnecting/reconnecting connectors. (And be careful of the AC power.)
...I once had a VCR the only worked with the cover off. I never could find the problem because it just wouldn't fail with the cover off. The repair shop gave-up too. (That was back when VCRs were worth repairing.)
This post has been edited by DVDdoug: Sep 17 2013, 23:26
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 30th August 2014 - 09:55
