IPB
Extracting audio from a CD doesn't include all index marks
Amrad
post Sep 17 2013, 06:05
Post #1
Group: Members
In AA 3 (and 1.5), when extracting audio from a CD, it always used to include all index marks on the CD, which were shown in Edit View. Recently, though, it has only been extracting (or at least, only displaying) track index marks but not 'negative countdown time' index marks for the tracks.
Here is an example Cue Sheet:
REM Created by CueListTool
PERFORMER "Various"
TITLE "CD Title"
FILE "CD File name.wav" WAVE
TRACK 01 AUDIO
TITLE "Track 1 title"
PERFORMER "Performer"
INDEX 01 00:00:00
TRACK 02 AUDIO
TITLE "Track 2 title"
INDEX 00 00:15:03
INDEX 01 00:18:03
TRACK 03 AUDIO
TITLE "Track 3 title"
INDEX 00 01:24:33
INDEX 01 01:27:33
TRACK 04 AUDIO
TITLE "Track 4 title"
INDEX 00 04:53:70
INDEX 01 04:56:71
The track's 'Index 01' mark indicates the start of the track, the 'Index 00' mark indicates the start of negative countdown time for the track, in the example cue sheet, this time is 3 seconds. It is the 'Index 00' marks that are missing. Until recently, all index marks used to be extracted, and are still not extracted even after having to re-install the Win XP Pro SP2 operating system.
Using Exact Audio Copy, with the same disc in the same drive, EAC extracts the audio and a separate cue list, opening that cue list in Cue List Tool shows all the index marks; index 00 and index 01. Cue List Tool can extract the cue list from a wave file, reading the cue list from the wave file extracted by Audition shows only the index 01 marks.
I think that completely rules out the drive as the problem, which suggests that Audition isn't extracting the index 00. Audition was installed from the same disk that I always use, so quite why that is, I don't know. I tried various wave in device properties settings, which made no difference.
Does anyone know why this is so? Thanks.
Regards,
Dave.
Go to the top of the page
+Quote Post
greynol
post Sep 17 2013, 06:55
Post #2
Group: Super Moderator
It sounds like the algorithm you're using in EAC works with your drive while the one in Audition doesn't.
This post has been edited by greynol: Sep 17 2013, 06:56
Placebophiles: put up or shut up!
+Quote Post
Amrad
post Sep 17 2013, 08:01
Post #3
Group: Members
QUOTE (greynol @ Sep 17 2013, 06:55) *
I wouldn't think so, because it has always worked with Audition until recently, and there have been no changes to Audition since then.
Regards,
Dave.
+Quote Post
greynol
post Sep 17 2013, 14:44
Post #4
With that particular drive?
+Quote Post
Amrad
post Sep 17 2013, 17:05
Post #5
Group: Members
QUOTE (greynol @ Sep 17 2013, 14:44) *
Yes.
Regards,
Dave.
+Quote Post
greynol
post Sep 17 2013, 18:39
Post #6
Other than to make sure you've installed the ASPI patch (which may not be relevant with your versions) and make sure you don't have anything installed (or not installed) hindering access to the drive, I'm at a loss.
+Quote Post
Amrad
post Sep 17 2013, 20:37
Post #7
Group: Members
QUOTE (greynol @ Sep 17 2013, 18:39) *
That makes two of us! I'll check the ASPI patch but if it's not that then I'm stuck.
Regards,
Dave.
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 26th July 2014 - 12:32
