Topic: cue won't work (Read 4304 times) previous topic - next topic
cue won't work
the following cue file won't burn with nero. why? thx. the cue file was generated with EAC
PERFORMER "Slayer"
TITLE "Reign In Blood"
FILE "C:\Musepack\CDs\Slayer  (1986)  Reign In Blood\01 - Angel Of Death.wav" WAVE
  TRACK 01 AUDIO
    TITLE "Angel Of Death"
    PERFORMER "Slayer"
    ISRC USSM18600233
    INDEX 01 00:00:00
FILE "C:\Musepack\CDs\Slayer  (1986)  Reign In Blood\02 - Piece By Piece.wav" WAVE
  TRACK 02 AUDIO
    TITLE "Piece By Piece"
    PERFORMER "Slayer"
    ISRC USSM18600234
    INDEX 01 00:00:00
FILE "C:\Musepack\CDs\Slayer  (1986)  Reign In Blood\03 - Necrophobic.wav" WAVE
  TRACK 03 AUDIO
    TITLE "Necrophobic"
    PERFORMER "Slayer"
    ISRC USSM18600235
    INDEX 01 00:00:00
FILE "C:\Musepack\CDs\Slayer  (1986)  Reign In Blood\04 - Altar Of Sacrifice.wav" WAVE
  TRACK 04 AUDIO
    TITLE "Altar Of Sacrifice"
    PERFORMER "Slayer"
    ISRC USSM18600236
    INDEX 01 00:00:00
FILE "C:\Musepack\CDs\Slayer  (1986)  Reign In Blood\05 - Jesus Saves.wav" WAVE
  TRACK 05 AUDIO
    TITLE "Jesus Saves"
    PERFORMER "Slayer"
    ISRC USSM18600237
    INDEX 01 00:00:00
FILE "C:\Musepack\CDs\Slayer  (1986)  Reign In Blood\06 - Criminally Insane.wav" WAVE
  TRACK 06 AUDIO
    TITLE "Criminally Insane"
    PERFORMER "Slayer"
    ISRC USSM18600238
    INDEX 01 00:00:00
FILE "C:\Musepack\CDs\Slayer  (1986)  Reign In Blood\07 - Reborn.wav" WAVE
  TRACK 07 AUDIO
    TITLE "Reborn"
    PERFORMER "Slayer"
    ISRC USSM18600232
    INDEX 01 00:00:00
FILE "C:\Musepack\CDs\Slayer  (1986)  Reign In Blood\08 - Epidemic.wav" WAVE
  TRACK 08 AUDIO
    TITLE "Epidemic"
    PERFORMER "Slayer"
    ISRC USSM18600239
    INDEX 01 00:00:00
FILE "C:\Musepack\CDs\Slayer  (1986)  Reign In Blood\09 - Postmortem.wav" WAVE
  TRACK 09 AUDIO
    TITLE "Postmortem"
    PERFORMER "Slayer"
    ISRC USSM18600240
    INDEX 01 00:00:00
FILE "C:\Musepack\CDs\Slayer  (1986)  Reign In Blood\10 - Raining Blood.wav" WAVE
  TRACK 10 AUDIO
    TITLE "Raining Blood"
    PERFORMER "Slayer"
    ISRC USSM18600241
    INDEX 01 00:00:00
  TRACK 11 AUDIO
    TITLE "Aggressive Perfector"
    PERFORMER "Slayer"
    ISRC USSM18600264
    INDEX 00 04:15:40
FILE "C:\Musepack\CDs\Slayer  (1986)  Reign In Blood\11 - Aggressive Perfector.wav" WAVE
    INDEX 01 00:00:00
  TRACK 12 AUDIO
    TITLE "Criminally Insane (Remix)"
    PERFORMER "Slayer"
    ISRC USSM18600265
    INDEX 00 02:29:43
FILE "C:\Musepack\CDs\Slayer  (1986)  Reign In Blood\12 - Criminally Insane (Remix).wav" WAVE
    INDEX 01 00:00:00
cue won't work
in short. it's an irregular Cuesheet generated by EAC in order to burn the gaps properly.
You can't burn it with Nero
Try.
burnatonce
or
Burrrn
These two apps can burn these cuesheets
"You have the right to remain silent. Anything you say will be misquoted, then used against you."
cue won't work
Which option was used in EAC to generate this cue sheet?
"multiple files with gaps (noncompliant)" cannot be used with nero; only EAC.
cue won't work
What does Nero says?
What are these index-0 lines in tracks 11 and 12?
"INDEX 00 04:15:40"
"INDEX 00 02:29:43"
They make no sense, I think.
Edit: OK, non-compliant cuesheets.
how do I set up EAC to make compliant cuesheets? or better, what is the advantage of these cuesheets?
cue won't work
problem solved.. EAC can burn it... burnatonce couldn't btw...
cue won't work
yes it can, you have to add it as a playlist in the Audio Cd mastering window
cue won't work
"INDEX 00 04:15:40"
"INDEX 00 02:29:43"
nero didn't give any reason for the failure...
btw i let EAC make the cue sheet, now i have an EXACT copy of the original audio cd^^ secure rip > 8x burn. i guest the copy is 100% perfect (also correct read/write offsets).. also, cddb recognizes it..
non compliant is the most exact i think because it allows every setting of the original to be in the resulting cue sheet (i think)
>"INDEX 00 04:15:40"
>"INDEX 00 02:29:43"
doen't know, EAC made the cue sheet
cue won't work
you get to keep the pregaps in the end of the previous track and then burn them to the cd correctly.
if you use cds with pregaps (negative indexes) the pregaps must be before the track in order to burn them correctly using a standard cuesheet
cue won't work
Yep, I'm silly.
I understand that's not the case.
If you want to make a perfect copy it doesn't matter if the cue is compliant or not.
But if you're going to play those files, or make MP3s from them, or burning them without cuesheet, then you'll have the pauses at the beginning of the track if you use compliant cuesheets, which is a pain.
If I'm not mistaken, a compliant cuesheet would be:
TRACK 12 AUDIO
PERFORMER "Slayer"
INDEX 00 00:00:00
INDEX 01 00:02:00
and the 2 seconds silence would have to be at the beginning of the file.
I'd also say that if you use one WAV for all the tracks, you'll have no problem to burn the cuesheet with any program.
cue won't work
Not only EAC. Burrn & other programs accept it as well.
