IPB
Using garage band to eq music?
Gintoh
post Jul 8 2013, 03:53
Post #1
Group: Members
As some of you know custom EQs on iTunes don't transfer onto the iPod. Yet if I eq songs by transferring the mp3 files into garageband, eq them, then put the eq'd file back into iTunes then I can have my custom eq on my iPod.
2 questions:
Will this cause the songs to lose quality, just from apllying a little eq then putting them back?if so how many Kbps will the mp3 files lose roughly during this process?
Is there any way to to apply eqs to many tracks at ones? (since I don't want to individually eq every song in my library)
Go to the top of the page
+Quote Post
punkrockdude
post Jul 8 2013, 11:00
Post #2
Group: Members
You will have to encode them once again after you have EQ'd them in Garage Band but I do not know how many kbpsyou will lose by having to up the bitrate to preserve quality. It is better to EQ before you encode the first time to not face the problem with encoding twice but maybe that is not an option for you since you might not have them as lossless.
There was a topic here a while ago showing how much degradation several encoders suffer when encoding same file MANY times. If I remember correctly some encoders showed no audible difference even after, I am not sure, 100 times.
This post has been edited by punkrockdude: Jul 8 2013, 11:01
+Quote Post
skamp
post Jul 8 2013, 11:02
Post #3
Group: Developer
Or use a DAP that has an EQ, which is a much more sensible solution. Rockbox has one, and it works on the iPod Classic.
See my profile for measurements, tools and recommendations.
+Quote Post
Gintoh
post Jul 8 2013, 17:39
Post #4
Group: Members
No no, I only will use the 31 band eq. 10 band eqs I don't like. Apps aren't an option since none have gapless playback except for 1 with just a ten band equalizer which isn't precise enough for me. I don't like carrying around amps with my iPod. No one knows how much Kbps ill lose in the process?
This post has been edited by Gintoh: Jul 8 2013, 17:43
+Quote Post
Kohlrabi
post Jul 8 2013, 19:19
Post #5
Group: Super Moderator
QUOTE (Gintoh @ Jul 8 2013, 18:39) *
In what process? Re-encoding while trying to preserve quality will likely force you to encode at a higher bitrate, or, with quality based encoding schemes (VBR), lead to higher bitrates.
This post has been edited by Kohlrabi: Jul 8 2013, 19:30
PRaT is the new jitter.
+Quote Post
DVDdoug
post Jul 8 2013, 19:28
Post #6
Group: Members
QUOTE
Nobody can answer that... Too many variables... It depends on the format & bitrate you start with, the format & bitrate you transcode to, the program material, and your ability to hear compression artifacts... Although you always theoretically loose quality, you may not notice any quality loss. (You can calculate the average bitrate from the file size and playing time, but "kbps" isn't the issue, sound quality is the issue.)
You can try an ABX test (without the EQ) to determine if there is audible quality loss, or to help you decide if the potential quality loss is worth it. (I guess you have already decided it sounds better with EQ and re-compression.)
QUOTE
If all of the songs in your library seem to have have the same EQ problem, maybe you should try some different headphones/earbuds/IEMs???
P.S.
If you're not doing this already, it's a good idea to check your levels (and/or re-normalize) after applying EQ (and before saving) because EQ can boost your levels into clipping (distortion). This will happen if you boost the bass and it can sometimes happen even when you only cut with the EQ, due to different phase shifts at different frequencies. (I don't have Garage Band, so I can't tell you how to do that.)
This post has been edited by DVDdoug: Jul 8 2013, 19:36
+Quote Post
Robertina
post Jul 8 2013, 20:03
Post #7
Group: Members
QUOTE (Gintoh @ Jul 8 2013, 05:39) *
With reference to your thread here:
Perhaps you want to try foo_dsp_xgeq, which is a 31 band graphic equalizer.
+Quote Post
Robertina
post Jul 8 2013, 20:17
Post #8
Group: Members
QUOTE (punkrockdude @ Jul 7 2013, 23:00) *
This topic I must have completely overlooked! A search failed. Could someone please help me with a link to this thread?
+Quote Post
TomasPin
post Jul 8 2013, 23:11
Post #9
Group: Members
QUOTE (Robertina @ Jul 8 2013, 16:17) *
Here you go: http://www.hydrogenaudio.org/forums/index....howtopic=100067
A man and his music: http://tubular.net/
+Quote Post
Robertina
post Jul 8 2013, 23:55
Post #10
Group: Members
I should have been able to find it on my own.
Thank you very much, TomasPin!
+Quote Post
TomasPin
post Jul 9 2013, 00:00
Post #11
Group: Members
QUOTE (Robertina @ Jul 8 2013, 19:55) *
+Quote Post
Gintoh
post Jul 15 2013, 04:50
Post #12
Group: Members
Well, if I apply EQ to a 320 mp3 file in foobar or garagbeband and export it back into itunes, as just an estimate, how much loss of quality would it be equivalent to. Are we taking 30 kbps or 200 kbps in terms of perceived quality change?
+Quote Post
db1989
post Jul 15 2013, 15:01
Post #13
From another thread, which received one of the several duplicate copies of the above post, all of which were made only a minute apart:
QUOTE (db1989 @ Jul 8 2013, 22:56) *
You want this extensive EQ, right? Then if, as might be the case, you have no other way but to write it into the audio data itself by decoding, applying EQ to the resulting uncompressed stream, and possible re-encoding: just try it and test how it sounds to you. Applying EQ to the uncompressed stream certainly should not introduce a degradation in quality, other than the change associated with the EQ itself, as long as the DSP in question is non-broken.
If this EQ is apparently so important to you, it may well offset any degradations in quality, which can be minimised if you leave the resulting EQd files uncompressed or re-compress them at a high enough bitrate. We have lots of previous threads on the audibility of transcoding and, I suspect, quite a few on the theoretical loss of quality associated with EQs, normalisation, and other transformations. There is plenty to read there that might allay your emphatic concerns about quality.
Again, you have to decide whether you want this 31-band EQ or whether you are going to worry about theoretical losses of quality without simply testing the proposition for yourself.
The duplicates have been split away to the Recycle Bin. Stop acting as if this minor issue, which you could easily evaluate for yourself with the only pair of ears that are relevant, is worthy of deluging our forum with multiple copies of the same question. Do not make another thread about this subject, and do not assume your posts are important enough that you’re entitled to duplicate them all over the place. Head-Fi apparently got tired of it, so you should avoid risking the same conclusion here.
This post has been edited by db1989: Jul 15 2013, 15:08
+Quote Post
greynol
post Jul 15 2013, 15:07
Post #14
No one will be able to quantify the additional degradation.
It will be dependent on the sample being transcoded, the encoder used, the specific EQ applied, the listener, his transducers, and the listening environment.
This post has been edited by greynol: Jul 15 2013, 15:15
Concern trolls: not a myth.
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 21st August 2014 - 16:08
