Resampling - Rounding Errors and Bit Depth.
zerowalker
post May 19 2013, 22:26
Okay so i recently got knowledge about the use of Bit Depth for Resampling.
I noticed that when i resampled old SNES music (which is pretty much, midi sound) i heard noise appearing on occasions.
At first i thought it was there originally, but then i rechecked, and well it wasnīt.
I then asked around about it, and got knowledge about Rounding Errors.
When resampling is done, there will be errors, and at 16bit (which was what i was working at) the errors are noticeable as there isnīt much do work with.
But when working at 32bit Float, the errors are so small that they pretty much donīt exist i guess, at least itīs not audible from my understanding.
But now to the thing that crossed my mind.
If 32bit float is great when working with resampling and such, how is 64bit float?
Is it much better, or isn't there any improvement?
AndyH-ha
post May 20 2013, 01:53
Quantization errors are differences between the floating point calculations of the target (a different sample rate, in your case) and the discrete possible values in any format, integer or floating point. Only so many possible values can be stored because there are only so many bits.
If this isn't clear, think of doing long division on some value like Pi. No matter to how many digits you carry out the answer, there are still more because you never get an exact answer. When the audio data calculations are done, most answers are not a value which fits withing 16 bit, or 32 bit, or whatever number of bits you use. The answers must be truncated at the limit of the possible precision determined by the data format. The difference between that possible answer (determined by the number of bits available) and the "actual" calculated value which would run to more bits, is the quantization error. It is experienced as noise and distortion in the audio.
There are also errors of the same kind when converting from floating point to 16 bit (from any greater number to any lesser number of bits). There is no way to avoid quantization errors, thus more noise and distortion are added when converting down to 16 bits.
The reason for working in floating point instead of 16 bits is there will, in general, be many calculations done on each audio sample to accomplish the goal (in this case, resampling). Each of those calculations adds another error. In floating point format, the errors are too small to matter, whereas when working in 16 bit, each error is much larger.
When converting to 16 bit from 32 bit as the last step, you acquire only one of those larger errors. This is essentially impossible to hear under any normal circumstances.
The normal procedure when reducing bit depth is to dither with noise shaping. This accomplishes two things. One, the dither eliminates the quantization distortion -- not the error itself, only the distortion caused by the error. Two, the noise shaping moves most of the added noise to the highest parts of the audio spectrum. Since human hearing is much less sensitive at these high frequencies, most of the additional noise is inaudible.
In reality, although it is essentially the universal practice to dither, the noise and distortion acquired by converting from 32 bit to 16 bit probably is never audible unless you want to listen to the silence between tracks -- at a very high volume level. All this is quite different at 8 bit, as you have experienced, The noise and distortion are almost always audible at 8 bit.
zerowalker
post May 20 2013, 02:09
QUOTE (AndyH-ha @ May 20 2013, 02:53) *
What do you mean that one 1 large error remain?
Yeah read about it a little while ago, Noise Shaping seems to be something like "debanding".
But it seems like there is no real disadvantage of converting to float when resampling (some resampler seems to do this automaticly) as it getīs bigger space to work with, and generate better results (less noise, but it matters of course).
And to the 8 bit as 16 bit.
Itīs hard to explain as i donīt know myself, i have uploaded an example.
http://www.sendspace.com/file/eq568b
Try to resample it without ever changing the bit depth. It will introduce noise.
bennetng
post May 20 2013, 05:55
QUOTE (zerowalker @ May 20 2013, 09:09) *
The volume of your file is too low. Fixed-point audio will clip above 0dB and lose quality at low volume. Normalize to about -3dBFS before resampling can improve sound quality.
zerowalker
post May 20 2013, 07:52
QUOTE (bennetng @ May 20 2013, 06:55) *
It doesnīt matter. If i normalize it to that, it will sound fine, but after resampling, there will be noise.
But as said, itīs only in these cases, not any problem really, just thought it was more common than it was.
And to saratoga and AndyH.
Well thatīs good to hear, then there isnīt any reason to not work in 32bit float for resampling, other than saving resources or RAM maybe, which isnīt any problem today.
The conversion-to-16-bit error is larger than the errors while working in floating point, but there is only one such error for each audio sample. Dither the conversion and eliminate the distortion.
So if i resample in float, then convert to 16 bit, there will be a big error, but if dithered (which seems to be done by all resampler?) that big error will go away, or atleast it will be remove from being audible. Is that correct?
bennetng
post May 20 2013, 08:07
QUOTE (zerowalker @ May 20 2013, 14:52) *
Which OS, resampler and soundcard are you using?
This post has been edited by bennetng: May 20 2013, 08:09
zerowalker
post May 20 2013, 08:17
Windows 8, donīt know the resampler itself, but itīs in Avisynth, ResampleAudio(), it works in the bit depth you give it. Sound card it, Creative ZXR Sound Blaster.
This post has been edited by db1989: May 20 2013, 12:27
Reason for edit: deleting pointless full quote
bennetng
post May 20 2013, 10:19
QUOTE (zerowalker @ May 20 2013, 15:17) *
http://www.hydrogenaudio.org/forums/index....ost&id=7530
Please download the files and play them directly, using normal volume as if you are listening to a normal song.
54321.wav: You should hear nothing. If you can hear anything then your playback environment is not optimized.
13579.wav: You should ONLY hear a single tone rising up. If you hear any other thing, such as something going up and down constantly then your playback environment is not optimized.
If you passed the tests above, use the resampler to convert the files to 44.1 and 48k and listen to them to see if they still pass the test or not. If not, then the resampler is a low quality one.
This post has been edited by bennetng: May 20 2013, 10:27
zerowalker
post May 20 2013, 19:38
I donīt know how high volume i should have on 54321. Cause "normal" volume for me changes, as many stuff i listen to have different dynamics.
But i donīt hear anything if i have low volume on the player, but if i increase it, i hear noise.
13579 sound like you are saying, a tone going upp, and i hear this "noise" like when itīs increasing, but it think itīs supposed to sound like that, cause itīs not normal noise, itīs like when someone throw a grenade in a movie, and you get that tinnitus sound.
This post has been edited by db1989: May 21 2013, 11:52
Reason for edit: deleting pointless full quote of previous post
- zerowalker   Resampling - Rounding Errors and Bit Depth.   May 19 2013, 22:26
- - AndyH-ha   Better for what? Quantization errors are obviously...   May 19 2013, 22:51
|- - zerowalker   QUOTE (AndyH-ha @ May 19 2013, 23:51...   May 19 2013, 22:55
- - jensend   Edit: I wrote the below before seeing Andy-ha...   May 19 2013, 23:24
|- - zerowalker   Probably, i have tried reading, but i guess i shou...   May 20 2013, 00:51
- - saratoga   If its 8 bit then playing it at 16 bit is no diffe...   May 20 2013, 01:49
- - AndyH-ha   Quantization errors are differences between the fl...   May 20 2013, 01:53
|- - zerowalker   QUOTE (AndyH-ha @ May 20 2013, 02:53...   May 20 2013, 02:09
|- - bennetng   QUOTE (zerowalker @ May 20 2013, 09:09) h...   May 20 2013, 05:55
|- - zerowalker   QUOTE (bennetng @ May 20 2013, 06:55) QUO...   May 20 2013, 07:52
|- - bennetng   QUOTE (zerowalker @ May 20 2013, 14:52) Q...   May 20 2013, 08:07
|- - zerowalker   Windows 8, donīt know the resampler itself, but it...   May 20 2013, 08:17
|- - bennetng   QUOTE (zerowalker @ May 20 2013, 15:17) W...   May 20 2013, 10:19
|- - zerowalker   I donīt know how high volume i should have on 5432...   May 20 2013, 19:38
|- - bennetng   QUOTE (zerowalker @ May 21 2013, 02:38) 1...   May 21 2013, 01:57
|- - zerowalker   I only hear it after, so 2. I did upload it here:...   May 21 2013, 02:01
|- - bennetng   QUOTE (zerowalker @ May 21 2013, 09:01) I...   May 21 2013, 02:15
||- - zerowalker   QUOTE (bennetng @ May 21 2013, 03:15) QUO...   May 21 2013, 02:24
||- - bennetng   Some resampler comparisons: http://src.infinitewav...   May 21 2013, 02:38
||- - zerowalker   Can i make one such graph to try the resampler i u...   May 21 2013, 02:58
||- - phofman   QUOTE (zerowalker @ May 21 2013, 03:58) C...   May 21 2013, 08:50
|- - jensend   I don't hear any problem with your resampled a...   May 21 2013, 06:27
|- - zerowalker   Really? Donīt you hear any noise at all;S? Cause ...   May 21 2013, 07:37
|- - probedb   I'm not sure what you mean by noise in that cl...   May 21 2013, 08:10
|- - zerowalker   Increase your volume, listen at 4 sec towards the ...   May 21 2013, 08:22
|- - probedb   QUOTE (zerowalker @ May 21 2013, 08:22) I...   May 21 2013, 11:36
|- - zerowalker   QUOTE (probedb @ May 21 2013, 12:36) QUOT...   May 21 2013, 21:13
|- - lvqcl   QUOTE (zerowalker @ May 22 2013, 00:13) B...   May 21 2013, 21:25
|- - zerowalker   QUOTE (lvqcl @ May 21 2013, 22:25) QUOTE ...   May 22 2013, 01:14
|- - Brazil2   QUOTE (zerowalker @ May 22 2013, 02:14) Q...   May 22 2013, 09:14
|- - phofman   QUOTE (zerowalker @ May 22 2013, 02:14) W...   May 22 2013, 12:37
- - saratoga   I doubt you can even find a 16 bit resampler. Anyt...   May 20 2013, 03:18
- - AndyH-ha   QUOTE What do you mean that one 1 large error rema...   May 20 2013, 07:05
- - AndyH-ha   Quantization errors never "go away". The...   May 20 2013, 10:10
|- - zerowalker   QUOTE (AndyH-ha @ May 20 2013, 11:10...   May 20 2013, 19:41
|- - jensend   QUOTE (zerowalker @ May 20 2013, 12:41) I...   May 21 2013, 00:09
|- - zerowalker   By changing the noise and moving it so it doesnīt ...   May 21 2013, 01:18
- - AndyH-ha   Some companies have made a big advertising thing a...   May 20 2013, 21:23
- - bennetng   http://src.infinitewave.ca/faq.html QUOTE Absolute...   May 21 2013, 03:29
- - jensend   BTW I'm sorry if my earlier response sounded h...   May 21 2013, 07:04
- - bennetng   Source and result files in src.infinitewave.ca are...   May 21 2013, 10:23
- - lvqcl   Spectrogram for the file uploaded in post #25 (sox...   May 21 2013, 10:52
- - bennetng   http://www.hydrogenaudio.org/forums/index....howto...   May 21 2013, 15:53
|- - zerowalker   What samples should i resample at 24 bit? And shou...   May 21 2013, 21:22
|- - saratoga   QUOTE (zerowalker @ May 21 2013, 16:22) W...   May 21 2013, 21:38
|- - phofman   QUOTE (zerowalker @ May 21 2013, 22:22) W...   May 21 2013, 22:01
|- - bennetng   QUOTE (zerowalker @ May 22 2013, 04:22) A...   May 22 2013, 00:24
|- - zerowalker   Okay i compared Avisynths Resampler at both Float ...   May 22 2013, 10:11
- - Nick.C   Try this sample - if you hear anything except dial...   May 22 2013, 10:12
|- - Dynamic   QUOTE (Nick.C @ May 22 2013, 09:12) Try t...   May 22 2013, 10:35
|- - zerowalker   QUOTE (Nick.C @ May 22 2013, 11:12) Try t...   May 22 2013, 11:00
||- - bennetng   QUOTE (zerowalker @ May 22 2013, 18:00) I...   May 22 2013, 11:16
||- - zerowalker   QUOTE (bennetng @ May 22 2013, 12:16) QUO...   May 23 2013, 03:28
||- - bennetng   QUOTE (zerowalker @ May 23 2013, 10:28) W...   May 23 2013, 04:07
||- - zerowalker   QUOTE (bennetng @ May 23 2013, 05:07) QUO...   May 23 2013, 04:38
||- - probedb   QUOTE (zerowalker @ May 23 2013, 04:38) I...   May 23 2013, 08:04
||- - zerowalker   QUOTE (probedb @ May 23 2013, 09:04) QUOT...   May 23 2013, 08:12
|- - probedb   QUOTE (Nick.C @ May 22 2013, 10:12) Try t...   May 22 2013, 11:18
|- - Ferongr   QUOTE (Nick.C @ May 22 2013, 11:12) Try t...   May 22 2013, 12:49
- - bennetng   Just think that udial is more useful to detect cli...   May 22 2013, 10:44
- - bennetng   Then it seems that you can pass Ethan Winer's ...   May 23 2013, 06:00
|- - zerowalker   QUOTE (bennetng @ May 23 2013, 07:00) The...   May 23 2013, 06:16
- - bennetng   I think zerowalker's system should be fine. 13...   May 23 2013, 10:47
RSS Lo-Fi Version Time is now: 2nd March 2015 - 09:41
