New opus test build
NullC
post Apr 16 2013, 23:31
I've posted up a new win32 build of libopus git master: https://people.xiph.org/~greg/opus-tools_exp_a8783a1.zip
There aren't many major changes from the prior alpha but a number of small bugs fix, some of which impact quality. I think we're particular interested in knowing about any quality regressions vs prior versions and particular cases where the speech/music detection get confused. (For the actual release we'll likely back that detector off at high rates but for now it's set more aggressively in order to find problems)
ChristianK
post Jun 17 2013, 19:10
Yes, I'm curious on how to control the stereo.
Do I need to patch something or is there a switch for it?
jmvalin
post Jun 17 2013, 19:25
Xiph.org Speex developer
QUOTE (ChristianK @ Jun 17 2013, 14:10) *
You actually need to patch the code. In src/opus_encoder.c, around line 1633, you should see:
if (st->mode != MODE_HYBRID || st->stream_channels==1)
st->silk_mode.stereoWidth_Q14 = IMIN((1<<14),IMAX(0,st->bitrate_bps-32000));
You should replace the second line simply with:
st->silk_mode.stereoWidth_Q14 = your_value;
Where your_value should be between 0 and 16384 where 0 mean "collapse to mono" and 16384 means "keep stereo without width reduction".
If you can figure out the optimal width for several bit-rates, I can change the code to reflect that.
kabal4e
post Jun 18 2013, 23:06
Hi there!
To encourage a wider audience of people with poor compilation skills, such as myself, to fine-tune the stereo width. Could you guys post a win32 build of opus-tools with that 'stereo-width' paratemtre adjustable through the comand line? So, instead of tweaking the code every time we could change this value by hand and if it's not set up by user it would use standard OPUS behaviour.
A
This post has been edited by kabal4e: Jun 18 2013, 23:13
- NullC   New opus test build   Apr 16 2013, 23:31
- - Dynamic   I was trying to test the speech/music detection, b...   Apr 17 2013, 19:32
|- - jmvalin   QUOTE (Dynamic @ Apr 17 2013, 14:32) I wa...   Apr 17 2013, 21:13
- - Gainless   Good to see the Muse Breaks fix finally bundled. B...   Apr 17 2013, 20:32
|- - jmvalin   QUOTE (Gainless @ Apr 17 2013, 15:32) Goo...   Apr 17 2013, 21:13
|- - Gainless   QUOTE (jmvalin @ Apr 17 2013, 22:13) I th...   Apr 19 2013, 14:57
- - CoRoNe   Using this test build (libopus 1.1a-67) to encode ...   Apr 18 2013, 20:27
- - Gainless   Forgot to add this one: Probably the worst of the...   Apr 20 2013, 10:52
- - IgorC   Gainless, Can You provide some ABC/HR logs compar...   Apr 20 2013, 16:14
|- - Gainless   QUOTE (IgorC @ Apr 20 2013, 17:14) Gainle...   Apr 21 2013, 10:33
- - IgorC   Here are some results for 96 kbps 1.0.2 https://f...   Apr 21 2013, 02:32
- - Kamedo2   I visualized IgorC's precious results on the p...   Apr 21 2013, 03:17
- - IgorC   Thank You, Kamedo2. I was thinking to add it but h...   Apr 21 2013, 04:00
- - Gainless   Ok, I've done ABC-HR tests with the samples at...   Apr 21 2013, 15:18
- - IgorC   There are two first samples (01 and 05) those have...   Apr 25 2013, 05:39
- - Gainless   What I don't really get, is why Opus's VBR...   Apr 25 2013, 10:41
|- - jmvalin   QUOTE (Gainless @ Apr 25 2013, 05:41) Wha...   Apr 25 2013, 13:06
|- - Gainless   QUOTE (jmvalin @ Apr 25 2013, 14:06) That...   Apr 25 2013, 14:00
|- - jmvalin   QUOTE (Gainless @ Apr 25 2013, 09:00) Can...   Apr 25 2013, 16:45
|- - Gainless   QUOTE (jmvalin @ Apr 25 2013, 17:45) Depe...   Apr 25 2013, 21:27
- - IgorC   Gainless, Some time ago You have submited one sam...   Apr 25 2013, 21:56
|- - Gainless   QUOTE (IgorC @ Apr 25 2013, 22:56) Gainle...   Apr 25 2013, 22:11
- - IgorC   Yes, it was Project 100 Sample. http://www.hydrog...   Apr 27 2013, 19:35
- - Gainless   Ok, then this is at least clear. What's probab...   Apr 27 2013, 21:11
- - IgorC   Have tried "Iron Man" sample with the ex...   May 11 2013, 19:26
- - Gainless   Igor, you may also take this sample into considera...   May 12 2013, 12:26
- - IgorC   Gainless, Yes, 1.0.2 was better than the experi...   May 12 2013, 21:42
- - Gainless   Maybe some framesize otpimation/detector can be do...   May 13 2013, 20:33
|- - jmvalin   QUOTE (Gainless @ May 13 2013, 15:33) Btw...   May 14 2013, 04:52
|- - Gainless   Sorry^1000 to Jmvalin and Igor, was my fault with ...   May 14 2013, 08:10
- - Gainless   Here's another sample that could benefit from ...   May 23 2013, 17:15
|- - jmvalin   QUOTE (Gainless @ May 23 2013, 12:15) Her...   May 24 2013, 08:43
|- - Gainless   QUOTE (jmvalin @ May 24 2013, 09:43) QUOT...   Jun 2 2013, 21:41
- - ChristianK   Hi, is this the place to also discus the latest ve...   Jun 14 2013, 19:02
- - ChristianK   Well, I'll just go ahead and post my question ...   Jun 16 2013, 22:02
|- - jmvalin   QUOTE (ChristianK @ Jun 16 2013, 17:02) I...   Jun 16 2013, 22:16
- - ChristianK   Yes, I'm curious on how to control the stereo....   Jun 17 2013, 19:10
|- - jmvalin   QUOTE (ChristianK @ Jun 17 2013, 14:10) Y...   Jun 17 2013, 19:25
|- - kabal4e   QUOTE You should replace the second line simply wi...   Jun 18 2013, 23:06
- - ChristianK   QUOTE (jmvalin @ Jun 17 2013, 20:25) Wher...   Jun 17 2013, 21:22
|- - jmvalin   QUOTE (ChristianK @ Jun 17 2013, 16:22) O...   Jun 18 2013, 00:23
|- - ChristianK   QUOTE (jmvalin @ Jun 18 2013, 01:23) You ...   Jun 30 2013, 20:50
- - Bostedclog   Could you tell me which opus encoder we should be ...   Jun 25 2013, 18:00
- - IgorC   Previously I gave a try to new temporal VBR at 48...   Jul 1 2013, 04:40
- - Gainless   A question: Does the tonality detector inside Opus...   Jul 4 2013, 15:03
RSS Lo-Fi Version Time is now: 4th August 2015 - 05:11
