IPB
HE_AAC_V2 encoder ignored much sound
coppla
post Apr 9 2013, 07:35
Post #1
Group: Members
Hi all,
I'm trying encoding some of my audio files into low bitrate (24kpbs) streams. I found HE_AAC_V2 as the best option.
Suprisingly, encoding one audio file (wmav2 format) containing conversation produces an silent audio file. I've tried neroaacenc, winamppro on Windows and ffmpeg with libaacplus, ffmpeg with libfdk_aac, Max and XLD on Mac.
Then I used Audacity to mix this audio file with another audio file into one audio file. This second audio file can be properly encoded by HE_AAC_V2. Next I encoded this mixed file into m4a with HE_AAC_V2 and I'm astonished to find out that sound from the first audio file does not exist in the resulting file while sound from the second file is OK.
Command line I used is as follows:
ffmpeg -i <input_file> -vn -sn -c:a libfdk_aac -profile:a aac_he_v2 -ar:a 44100 -ac:a 2 -b:a 24k -f adts <output_file>
ffmpeg -i <input_file> -vn -sn -c:a libaacplus -ar:a 44100 -ac:a 2 -b:a 24k -f adts <output_file>
What does this mean? Some sound cannot be encoded by it?
Go to the top of the page
+Quote Post
LithosZA
post Apr 9 2013, 08:25
Post #2
Group: Members
It might not be an encoder problem. The file might not be able to decoded properly.
Try:
ffmpeg -i <input_file> -c:a pcm_s16le -ar:a 44100 -ac:a 2 output_file.wav
Can you playback output_file.wav? If not then ffmpeg was unable to decode the audio correctly.
+Quote Post
coppla
post Apr 9 2013, 09:09
Post #3
Group: Members
Thanks for your quick replay but
Yes, it can
This post has been edited by db1989: Apr 9 2013, 17:16
Reason for edit: deleting pointless full quote
+Quote Post
C.R.Helmrich
post Apr 9 2013, 10:02
Post #4
Group: Developer
Coppla, can you upload a part of the wma2 file which is encoded as silence in the upload forum? HE-AACv2 might have problems with out-of-phase files.
Chris
+Quote Post
coppla
post Apr 9 2013, 10:08
Post #5
Group: Members
Hi Helmrich,
I've just registered and I cannot find the way to upload attachments.
Reason for edit: "
+Quote Post
pdq
post Apr 9 2013, 14:31
Post #6
Group: Members
Try playing output_file.wav in mono. My guess is that you will hear silence.
HE AAC V2 files contain mono data with information to direct the output toward one channel or the other. Out-of-phase audio will simply cancel.
+Quote Post
db1989
post Apr 9 2013, 17:15
Post #7
Group: Super Moderator
QUOTE (coppla @ Apr 9 2013, 10:08) *
At the bottom of the first group of forums on the list: http://www.hydrogenaudio.org/forums/index.php?showforum=35
Please do not include quotations of previous posts when they are completely unnecessary, and if you must quote in relevant circumstances, please place it above your reply, not below.
+Quote Post
coppla
post Apr 10 2013, 01:01
Post #8
Group: Members
QUOTE (C.R.Helmrich @ Apr 9 2013, 17:02) *
Chris
Hi Chris,
I've uploaded the file here: http://www.hydrogenaudio.org/forums/index....howtopic=100352
Please check it out.
Thank you!
+Quote Post
coppla
post Apr 10 2013, 01:09
Post #9
Group: Members
QUOTE (pdq @ Apr 9 2013, 21:31) *
Hi pdq,
You're right. I used Audacity to mix the two channels into one channel and the resulting waveform is a straight line...
What can I do to this audio file to correctly encode it into HE AAC V2?
+Quote Post
Brazil2
post Apr 10 2013, 07:35
Post #10
Group: Members
QUOTE (coppla @ Apr 10 2013, 02:09) *
With Audacity:
Click on the drop down menu at the top of the properties box of the sound, on the left
Split stereo track
Select right channel sound
Effect -> Invert
Drop down menu at the top of the properties box -> Make Stereo Track
Save the resulting sound
Done.
+Quote Post
coppla
post Apr 10 2013, 11:29
Post #11
Group: Members
QUOTE (Brazil2 @ Apr 10 2013, 14:35) *
With Audacity:
Split stereo track
Effect -> Invert
Done.
Thank you, it works.
BTW, I'm still wondering if i can invert channel with ffmpeg
+Quote Post
Brazil2
post Apr 10 2013, 12:21
Post #12
Group: Members
QUOTE (coppla @ Apr 10 2013, 12:29) *
I'm not sure about ffmpeg but you can do it with SoX:
CODE
sox input.wav output.wav remix -m 1 2i0
+Quote Post
coppla
post Apr 10 2013, 14:46
Post #13
Group: Members
QUOTE (Brazil2 @ Apr 10 2013, 19:21) *
CODE
Yah! sox is so powerful!
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 30th August 2014 - 10:35
