Archiving vinyl once only 96/24?
matt_a
post Mar 26 2013, 16:11
Hi All,
I wonder if you can help.
I have recently registered with HA but have been reading the forums for months.
Very interesting and informative.
Being a recovering so called 'audiophile (fool)' I think I have at last found some sense in the real world!
But thats a whole other story for a different thread!
I have a collection of some 2000 LPs that I want to archive to digital.
Now I release that the topics of 44/16 v 96/24 has been widely discussed but just to be clear and please
correct me if Im wrong on any of these points;
- Set the phono amp output to produce a max peak volume just below ADC clipping to maximise ADC coverage?
- 16 bits is more than enough, 24 bits does not produce a more detailed rip?
- Would 24 bits needed if I want to use declicking functions and rumble filters?
- If I always set the ADC input correctly normalisation should not be necessary?
- If tracks do need normalising to say -3db what does 24 bit over 16 bit prodivde?
- The noise floor is not lower with 24 v 16 bits, I dont think I understand the concept properly yet?
- 96K rather than 44K is worth doing for capture as it pushes any anti aliasing well out of the audio band.?
- There is no point in having a final cleaned corrected file greater than 44/16 as there is no audio benefit?
(BTW Im using a great software package called Vinyl Studio!)
Thanks for any comments,
Matthew
2Bdecided
post Mar 27 2013, 12:33
ReplayGain developer
16/44.1 is more than good enough, and has maximum compatibility.
On rare occasions, wear-free LPs played on great set-ups can deliver greater (all-be-it inaudible) frequency response than 44.1kHz can sample (i.e. there's real content above 22kHz). Far more commonly, information from LP playback that's above 22kHz is pure distortion, but occasionally it's something real. For those of us who might want to pull out the digital copy to check the provenance of a given recording, sampling at 96kHz might be useful to preserve this information. It's also conceivable that some future audio restoration technique might benefit from capturing at the higher sample rate. It's also just conceivable that a large proportion of audio reproduction decades into the future will use higher sample rates, and one day, probably after we're all dead, upsampling from 44.1kHz will be more of a pain than having native 24/96 or DSD or whatever.
Of all the decisions you'll have to make regarding LP transfer, sample rate is by far the least important, because 44.1kHz more than good enough (I said that already, didn't I?) and anything better can always be down-converted to 44.1kHz for use on CDs, players than only support 44.1kHz, etc. Whereas many many other factors have an audible impact on the results. e.g. condition of LP, choice of turntable, and (potentially) bad decisions regarding denoising + EQ.
Sanity hints: use FLAC for storage, add correct metadata (tags) ASAP, and ReplayGain album mode for levels.
Unless you're at home all day with nothing else to do, 2000 LPs will take you years. Start with a couple you don't really care about to test your process on, and then start again with the ones you're most likely to listen to, working downwards in preference. Then if you never finish, at least you'll have the most important ones copied.
- matt_a   Archiving vinyl once only 96/24?   Mar 26 2013, 16:11
- - DonP   QUOTE (matt_a @ Mar 26 2013, 10:11) - If ...   Mar 26 2013, 19:18
- - matt_a   Btw I didn't want to prejudice any answers but...   Mar 26 2013, 19:54
- - AndyH-ha   If you are by some means certain of what the peak ...   Mar 26 2013, 20:23
- - Dynamic   On clicking preview, I see AndyH has replied. We v...   Mar 26 2013, 20:37
- - saratoga   I would record at 48k/24 bit, then after processin...   Mar 26 2013, 20:44
- - DVDdoug   My 1st advice is always... Buy the CD, if it...   Mar 26 2013, 21:47
- - matt_a   Thanks for the answers. Im curious though as to w...   Mar 26 2013, 22:01
|- - db1989   QUOTE (matt_a @ Mar 26 2013, 21:01) Im cu...   Mar 26 2013, 22:14
|- - mjb2006   QUOTE (matt_a @ Mar 26 2013, 14:01) I ass...   Mar 27 2013, 04:42
|- - Arnold B. Krueger   QUOTE (matt_a @ Mar 26 2013, 17:01) I...   Mar 29 2013, 18:54
- - matt_a   Sorry DVDdoug your reply beat my next question whi...   Mar 26 2013, 22:12
- - matt_a   Ive just realised something fundamental! Why ...   Mar 26 2013, 22:23
|- - DonP   QUOTE (matt_a @ Mar 26 2013, 16:23) Why a...   Mar 27 2013, 01:36
- - db1989   Either placebo effect and marketers exploiting it,...   Mar 26 2013, 22:31
- - Porcus   QUOTE (matt_a @ Mar 26 2013, 16:11) - 16 ...   Mar 27 2013, 00:10
- - Apesbrain   QUOTE (matt_a @ Mar 26 2013, 17:23) Why a...   Mar 27 2013, 01:29
- - cliveb   You've had lots of good answers. I have just a...   Mar 27 2013, 10:12
|- - mjb2006   QUOTE (cliveb @ Mar 27 2013, 02:12) These...   Mar 27 2013, 12:04
- - Engelsstaub   QUOTE (matt_a @ Mar 26 2013, 09:11) ...BT...   Mar 27 2013, 10:53
- - 2Bdecided   16/44.1 is more than good enough, and has maximum ...   Mar 27 2013, 12:33
- - matt_a   Great Advice!! Ive learnt more from this ...   Mar 27 2013, 15:39
|- - pdq   QUOTE (matt_a @ Mar 27 2013, 10:39) Anoth...   Mar 27 2013, 15:55
|- - db1989   Whilst I agree that another discussion on jitter i...   Mar 27 2013, 16:14
|- - matt_a   Thats a bit rude isnt it? Especially after all the...   Mar 27 2013, 16:51
|- - db1989   QUOTE (matt_a @ Mar 27 2013, 15:51) Thats...   Mar 27 2013, 16:57
|- - 2Bdecided   QUOTE (matt_a @ Mar 27 2013, 15:51) Thats...   Mar 27 2013, 17:53
- - greynol   In the context of this discussion, any amount of j...   Mar 27 2013, 16:24
- - greynol   Please don't top-post.   Mar 27 2013, 16:53
- - Mach-X   Indeed perhaps being naive about jitter, and not r...   Mar 27 2013, 16:57
- - matt_a   Quite right, I was too hasty on the keyboard, sorr...   Mar 27 2013, 17:16
- - matt_a   I forgot to mention that its interesting listening...   Mar 27 2013, 17:40
- - matt_a   I have had a really good read through all the FAQ ...   Mar 27 2013, 19:02
- - krabapple   If you're going to sample at higher than Redbo...   Mar 29 2013, 20:42
- - greynol   Sampling and playback at higher rates is (was?) us...   Mar 29 2013, 20:48
|- - DonP   QUOTE (greynol @ Mar 29 2013, 14:48) Samp...   Mar 29 2013, 22:01
- - greynol   Oversampling; sure. I didn't mean to suggest ...   Mar 29 2013, 22:05
RSS Lo-Fi Version Time is now: 3rd July 2015 - 23:27
