Archiving vinyl once only 96/24?
matt_a
post Mar 26 2013, 16:11
Hi All,
I wonder if you can help.
I have recently registered with HA but have been reading the forums for months.
Very interesting and informative.
Being a recovering so called 'audiophile (fool)' I think I have at last found some sense in the real world!
But thats a whole other story for a different thread!
I have a collection of some 2000 LPs that I want to archive to digital.
Now I release that the topics of 44/16 v 96/24 has been widely discussed but just to be clear and please
correct me if Im wrong on any of these points;
- Set the phono amp output to produce a max peak volume just below ADC clipping to maximise ADC coverage?
- 16 bits is more than enough, 24 bits does not produce a more detailed rip?
- Would 24 bits needed if I want to use declicking functions and rumble filters?
- If I always set the ADC input correctly normalisation should not be necessary?
- If tracks do need normalising to say -3db what does 24 bit over 16 bit prodivde?
- The noise floor is not lower with 24 v 16 bits, I dont think I understand the concept properly yet?
- 96K rather than 44K is worth doing for capture as it pushes any anti aliasing well out of the audio band.?
- There is no point in having a final cleaned corrected file greater than 44/16 as there is no audio benefit?
(BTW Im using a great software package called Vinyl Studio!)
Thanks for any comments,
Matthew
matt_a
post Mar 26 2013, 22:01
Thanks for the answers.
Im curious though as to why digital interfaces provide 96k (or even 192) if 44/48 is good enough?
Is it a manufacturing ploy to get people to buy new stuff?
I assumed that a 24 bit v 16 bit sample of a vinyl signal peak adjusted prior to the adc at the phono
stage to give a -3db peak would actually contain more info or am i missing something.
So then consequently replayed through a 24 bit dac would have more detail?
Dont shout as im learning about this stuff!
Matthew
mjb2006
post Mar 27 2013, 04:42
QUOTE (matt_a @ Mar 26 2013, 14:01) *
I assumed that a 24 bit v 16 bit sample of a vinyl signal peak [...] would actually contain more info [...] So then consequently replayed through a 24 bit dac would have more detail
24-bit audio played through a 16-bit pipe shouldn't sound any different, unless the recording has > 100 dB of dynamic range, the difference between a jet engine and a butterfly. Your ears would be very unhappy if you had the volume cranked loud enough to that entire range, rather than just the range where the music is.
You probably noticed that when you've got the recording level set high enough for -3 dB peaks, the silent parts of the record, i.e. the whoosh of vinyl rushing past the stylus, hover around -50 or -60 dB. That's the "noise floor" and there's nothing to listen to below that; certainly all the music is way above that, even in the fade-outs. So in theory, you need maybe 11 bits, as far as dynamic range is concerned.
Increased bit depth also captures the input amplitude with greater precision, which is what you're wondering about. This precision has to be really low before the quantization noise it creates is audible and distracting (if undithered). At 8 bits, it can be rather unpleasant. At 16 bits, it's not even close to being audible.
In other words, the bit depth needs to be high enough to capture the dynamic range your input requires (about 10 or 11 bits for vinyl), and it needs to be high enough to get the quantization noise below audibility (maybe 14 bits, if undithered, I think). Beyond that, no one can tell the difference. If it makes you feel better, and you have gobs of disk space, sure, record at 24-bit. But you're not getting increased fidelity in any of the sounds that you can hear.
This post has been edited by mjb2006: Mar 27 2013, 04:44
- matt_a   Archiving vinyl once only 96/24?   Mar 26 2013, 16:11
- - DonP   QUOTE (matt_a @ Mar 26 2013, 10:11) - If ...   Mar 26 2013, 19:18
- - matt_a   Btw I didn't want to prejudice any answers but...   Mar 26 2013, 19:54
- - AndyH-ha   If you are by some means certain of what the peak ...   Mar 26 2013, 20:23
- - Dynamic   On clicking preview, I see AndyH has replied. We v...   Mar 26 2013, 20:37
- - saratoga   I would record at 48k/24 bit, then after processin...   Mar 26 2013, 20:44
- - DVDdoug   My 1st advice is always... Buy the CD, if it...   Mar 26 2013, 21:47
- - matt_a   Thanks for the answers. Im curious though as to w...   Mar 26 2013, 22:01
|- - db1989   QUOTE (matt_a @ Mar 26 2013, 21:01) Im cu...   Mar 26 2013, 22:14
|- - mjb2006   QUOTE (matt_a @ Mar 26 2013, 14:01) I ass...   Mar 27 2013, 04:42
|- - Arnold B. Krueger   QUOTE (matt_a @ Mar 26 2013, 17:01) I...   Mar 29 2013, 18:54
- - matt_a   Sorry DVDdoug your reply beat my next question whi...   Mar 26 2013, 22:12
- - matt_a   Ive just realised something fundamental! Why ...   Mar 26 2013, 22:23
|- - DonP   QUOTE (matt_a @ Mar 26 2013, 16:23) Why a...   Mar 27 2013, 01:36
- - db1989   Either placebo effect and marketers exploiting it,...   Mar 26 2013, 22:31
- - Porcus   QUOTE (matt_a @ Mar 26 2013, 16:11) - 16 ...   Mar 27 2013, 00:10
- - Apesbrain   QUOTE (matt_a @ Mar 26 2013, 17:23) Why a...   Mar 27 2013, 01:29
- - cliveb   You've had lots of good answers. I have just a...   Mar 27 2013, 10:12
|- - mjb2006   QUOTE (cliveb @ Mar 27 2013, 02:12) These...   Mar 27 2013, 12:04
- - Engelsstaub   QUOTE (matt_a @ Mar 26 2013, 09:11) ...BT...   Mar 27 2013, 10:53
- - 2Bdecided   16/44.1 is more than good enough, and has maximum ...   Mar 27 2013, 12:33
- - matt_a   Great Advice!! Ive learnt more from this ...   Mar 27 2013, 15:39
|- - pdq   QUOTE (matt_a @ Mar 27 2013, 10:39) Anoth...   Mar 27 2013, 15:55
|- - db1989   Whilst I agree that another discussion on jitter i...   Mar 27 2013, 16:14
|- - matt_a   Thats a bit rude isnt it? Especially after all the...   Mar 27 2013, 16:51
|- - db1989   QUOTE (matt_a @ Mar 27 2013, 15:51) Thats...   Mar 27 2013, 16:57
|- - 2Bdecided   QUOTE (matt_a @ Mar 27 2013, 15:51) Thats...   Mar 27 2013, 17:53
- - greynol   In the context of this discussion, any amount of j...   Mar 27 2013, 16:24
- - greynol   Please don't top-post.   Mar 27 2013, 16:53
- - Mach-X   Indeed perhaps being naive about jitter, and not r...   Mar 27 2013, 16:57
- - matt_a   Quite right, I was too hasty on the keyboard, sorr...   Mar 27 2013, 17:16
- - matt_a   I forgot to mention that its interesting listening...   Mar 27 2013, 17:40
- - matt_a   I have had a really good read through all the FAQ ...   Mar 27 2013, 19:02
- - krabapple   If you're going to sample at higher than Redbo...   Mar 29 2013, 20:42
- - greynol   Sampling and playback at higher rates is (was?) us...   Mar 29 2013, 20:48
|- - DonP   QUOTE (greynol @ Mar 29 2013, 14:48) Samp...   Mar 29 2013, 22:01
- - greynol   Oversampling; sure. I didn't mean to suggest ...   Mar 29 2013, 22:05
RSS Lo-Fi Version Time is now: 29th January 2015 - 12:22
