12 Pages V   1 2 3 > »
Peakmeter for Columns UI
foo_pm
post Jun 5 2007, 20:47
I created a new component: foo_uie_peakmeter. The component displays the level for each channel in dB.
Version 0.0.4.1 alpha
If you find it usefull you can download it here: foo_uie_peakmeter
This component is replaced by a new plugin: foo_uie_vis_peakmeter_spectrum.
This post has been edited by foo_pm: Feb 10 2008, 12:49
Yotsuya
post Jun 5 2007, 21:34
Very nice! New toys are always fun. It even works well under wine.
My only suggestion is that since this is primarily a visualization component you may want to consider renaming it foo_uie_vis_peakmeter
http://www.ubuntu.com
roentgen
post Jun 5 2007, 21:36
Thank you for this. I've been waiting so much for it.
Paws
post Jun 5 2007, 21:43
yeah this is pretty cool. any way it could work for Panels Ui?
Yotsuya
post Jun 5 2007, 21:47
Paws
$panel(name,Peakmeter,x,y,w,h,)
PedroElGringo
post Jun 6 2007, 00:43
Very nice, but could it have an option to make it vertical ?
This post has been edited by PedroElGringo: Jun 6 2007, 00:43
miscellanea
post Jun 6 2007, 00:53
Non-profit Netlabel : Bump Foot
http://www.bumpfoot.net/
A_Man_Eating_Duc...
post Jun 6 2007, 03:46
QUOTE (PedroElGringo @ Jun 6 2007, 11:43) *
I second this.
also could it be possible for the range of the meter to be customised from -60dB to +10dB to say -30dB to +3dB or what ever the person wants. So the meter will be a smaller dB range but the physical onscreen length is still the same (basically makes the meter move more).
Keikonium
post Jun 6 2007, 04:15
This is awesome!
I second the request to make this vertical, and the request for customizable dB levels. Inputting our own (like an "Add New" button to add entries, and a "Remove" to remove entries) would be nice smile.gif.
EDIT: Also, if we could export our settings (like all the colors and settings) to a file and then import them into a second or whatever peakmeter that would be great too. I want to put the left channel on the left side of my playlist, and the right on the right side, but thats a lot of manual color typing and I am lazy lol.
I can see potential for this component. Keep up the good work!
This post has been edited by Keikonium: Jun 6 2007, 05:12
odyssey
post Jun 6 2007, 07:47
...and transparancy for PanelsUI?
Strictly4me
post Jun 6 2007, 07:49
((((( Strictly4me )))))
stampgevaar
post Jun 6 2007, 08:15
mil3s
post Jun 6 2007, 08:26
A few suggestions though.
* Center everything in available space (vertically I mean).
* Ability to remove the L, R in the beginning of a meter.
* Padding, left and right.
* Peak falloff feature, with time setting.
* Currently there doesn't seem to be an option available to flip the meters to go from bottom up instead of left right.
Keep up the good work.
Maranatha
post Jun 6 2007, 10:23
Very nice, indeed! And if you can find a way to implement all the suggestions you've gotten so far, this will really be at the top of the list!
odyssey
post Jun 6 2007, 10:46
Post #15
Also it would be nice to change the color of the small channelboxes (or am I blind?), and the possebility of removing them. I didn't see the possebility of changing the falloff indicator color. huh.gif
It would be nice if you could add some channel configuration condition, so only the channels in use would be displayed.
Bug(/Annoyance): It seems that the falloff indicator are based on the current track, since I've never seen it actually fall off. Could you add a (configurable) timeout to it, as they would normally act?
But this is a really cool plugin!
This post has been edited by odyssey: Jun 6 2007, 11:27
Lesmo16
post Jun 6 2007, 10:59
Post #16
Thank you so much for this component!
zmur
post Jun 6 2007, 11:18
Post #17
Maranatha
post Jun 6 2007, 11:53
Post #18
Hummm... I cannot seem to get it to work with Panels UI.
I have all the latest components installed, and have libmmd.dll , libpng13.dll , and zlib1.dll in the install directory.
I used this code to make a panel appear:
/////////////Equalizer Panel///////////////
$panel(Equalizer,Peakmeter,24,470,200,70,)
The box showed up, and then I right-clicked and got into preferences, and set them exactly as shown in the example photo that was posted, just to get me going.
The background changed from black to grey after I applied the preferences, but when I play a song, nothing happens. I only see a grey rectangle.
Would someone suggest to me what I'm not doing correctly here? Thanks!
PedroElGringo
post Jun 6 2007, 12:18
Post #19
The same occured to me, just click on "reset all" button on the plugin preferences page, and it will work fine...
odyssey
post Jun 6 2007, 12:29
Post #20
QUOTE (PedroElGringo @ Jun 6 2007, 13:18) *
Don't you loose all settings for every plugin then?
PedroElGringo
post Jun 6 2007, 12:33
Post #21
QUOTE (odyssey @ Jun 6 2007, 13:29) *
No, the plugin has its own preference page, once you right-click preferences on the panel.
And its own "reset all" button, that only resets the VIS setting.
I couldn't get it to work until I accidentally hit this button...
This post has been edited by PedroElGringo: Jun 6 2007, 12:33
Maranatha
post Jun 6 2007, 12:41
Post #22
QUOTE (PedroElGringo @ Jun 6 2007, 06:18) *
Ahh... Yes, that was the issue. Works like a charm now. Thank you very much!!
odyssey
post Jun 6 2007, 12:57
Post #23
QUOTE (PedroElGringo @ Jun 6 2007, 13:33) *
Except for you PanelsUI users, yes you DO lose settings for other components, like Columns UI and foobar2000 settings. But I guess you don't care for settings as long as you have your nice gfxs ;-)
Maranatha
post Jun 6 2007, 16:03
Post #24
QUOTE (odyssey @ Jun 6 2007, 06:57) *
Seriously? I also have a couple of configs that use Columns UI, and I really wouldn't want that to happen there!! Of course, I have backups, but still, I believe that this is something we should all be aware of, yes??
Thanks for the heads-up!
This post has been edited by Maranatha: Jun 6 2007, 16:04
foo_pm
post Jun 6 2007, 17:18
Post #25
QUOTE (Yotsuya @ Jun 5 2007, 22:34) *
Thanks! I guess you are right. I will think about it.
RSS Lo-Fi Version Time is now: 19th September 2014 - 14:02
