7 Pages V  < 1 2 3 4 5 > »
foo_dsp_xgeq, Graphic Equalizer
White_Shadow
post Sep 2 2011, 10:55
Post #51
Hey Xnor!
Thanks for this great equalizer!
One thing for your to-do-list: What I'm really missing is that there's no way to see the values I actual set for each band. Would it be possible to make them visible? (Just like the value for the master gain slider.)
xnor
post Sep 8 2011, 18:32
Post #52
Does anyone actually need the full range of +-18 dB? Cause I'd like to reduce the steps from .5 to .1 dB which would result in 360 slider positions.
This post has been edited by xnor: Sep 8 2011, 18:46
klonuo
post Sep 8 2011, 20:05
Post #53
Under wine it seems impossible to use this component: If I try to adjust any slider, it pops on top (+18dB) and can't be dragged or anything.
It looks like implemented 'draw on sliders' feature may be the cause.
xnor
post Sep 8 2011, 20:33
Post #54
Interesting. Does pressing tab to focus sliders and up/down arrow keys or page up/down work?
klonuo
post Sep 8 2011, 21:11
Post #55
White_Shadow
post Sep 9 2011, 07:55
Post #56
I'm not using the full range of +/-18dB. My Sliders are all between +/-6dB. Therefore you could cut the range to, let's see, +/-12dB, which would result in 240+1 (+/-0dB wink.gif ) slider positions.
But I'm curious to know, what you're thinking about making the values visible. (As I've requested in a previous post.) If you're changing the steps to 0.1 dB, then it would be also helpful to make it possible to set the values via Keyboard. Some kind of input box, for example, would do that.
xnor
post Sep 9 2011, 13:37
Post #57
Yeah I think an edit box with the selected band's gain should do.
Bob Brines
post Sep 17 2011, 15:06
Post #58
Are you making any progress on implementing saved presets? I really would like to used this EQ, but
1. It resets to zero on a cold start of my computer.
2. When I change speakers, I have to start from zero.
I see that you are putting a lot of effort on your crossfeed plug-in. Perhaps you could spend a little time here?
Thanks,
Bob
xnor
post Sep 17 2011, 15:20
Post #59
You're right, I spent most of the time on the crossfeed but there's definitely progress going on with the EQ. Just need to put it into a releasable state.
Regarding presets, do the DSP chain presets (DSP Manager configuration page) also get lost? That'd be strange.
This post has been edited by xnor: Sep 17 2011, 15:21
tribaljet
post Sep 17 2011, 19:40
Post #60
QUOTE (xnor @ Sep 17 2011, 14:20) *
xnor, are you doing a crossfeed plugin? Could you link it, please?
tpijag
post Sep 17 2011, 20:30
Post #61
xnor crossfeed in search box
This post has been edited by tpijag: Sep 17 2011, 20:31
Bob Brines
post Sep 18 2011, 03:45
Post #62
QUOTE (xnor @ Sep 17 2011, 09:20) *
The DSP manager configuration remains intact. xgeg reappears in the chain at system restart, but the graph is zero'd out. If I simply close and reopen f2k, the graph remains as last set.
BTW, in my installation, f2k forgets where my presets are for the default equalizer.
Bob
This post has been edited by Bob Brines: Sep 18 2011, 03:48
tribaljet
post Sep 18 2011, 04:30
Post #63
QUOTE (tpijag @ Sep 17 2011, 19:30) *
xnor
post Sep 20 2011, 16:13
Post #64
QUOTE (Bob Brines @ Sep 18 2011, 04:45) *
This is weird and should not happen.
Anyway, I've added a simple import/export feature now. Version 0.2.0 released.
chrome_waves
post Sep 20 2011, 20:28
Post #65
i am using some modded drivers for my old soundcard that improve the sound quality, but i notice that the overall volume is a bit lower than with the manufacturer's drivers- can i use this equalizer to boost the volume a bit by increasing the master gain +1 db? i don't know much about this stuff huh.gif
great plugin by the way!
xnor
post Sep 20 2011, 21:06
Post #66
chrome_waves, I don't know why the modded drivers have lower output volume so it's difficult to give advice.
Modern recordings touch 0 dBFS regularly so even a 1 dB volume boost will most likely degrade sound quality. So all I can suggest is to double check the Windows Mixer, playback device properties and soundcard control panel for anything that could attenuate the signal.
touccer
post Sep 20 2011, 22:08
Post #67
So i can use it to equalize perfectly my headphone using headroom frequency response graph like this.
xnor
post Sep 20 2011, 22:47
Post #68
touccer, I don't really see the point. The frequency response of the EQ extends beyond the first and also last band, to be precise down to 0 Hz and up to sampling rate / 2 (e.g. 22.05 kHz for 44.1 kHz audio).
This post has been edited by xnor: Sep 20 2011, 22:49
chrome_waves
post Sep 21 2011, 02:58
Post #69
QUOTE (xnor @ Sep 20 2011, 14:06) *
i'm using the pax drivers for the old soundblaster live! /audigy cards wink.gif
http://www.hardwareheaven.com/pax-drivers/
White_Shadow
post Sep 21 2011, 10:02
Post #70
Hey Xnor!
Thanks for making the band values visible. Although I had it's realization a bit different in mind. But it works and this is all I need.
touccer
post Sep 21 2011, 10:44
Post #71
QUOTE (xnor @ Sep 20 2011, 22:47) *
xnor
post Sep 21 2011, 12:40
Post #72
QUOTE (touccer @ Sep 21 2011, 11:44) *
It has the same gain as the 20 Hz band.
jgro
post Sep 21 2011, 16:28
Post #73
QUOTE (xnor @ Sep 20 2011, 17:13) *
And, in contrast to the default EQ, even gapless playback works fine with FLAC, mp3, so far tested.
Is it possible to ad graphic equalizer into the "View" menu in order to open it faster? wink.gif
cu
jgro
xnor
post Sep 21 2011, 16:48
Post #74
I think so, but the fb sdk is imo not documented properly so I'll have to bother some of the other devs about it.
This post has been edited by xnor: Sep 21 2011, 16:48
jgro
post Sep 21 2011, 18:20
Post #75
QUOTE (xnor @ Sep 21 2011, 17:48) *
Would be great for quick dis-/enabling graphic equalizer. wink.gif
cu
jgro
RSS Lo-Fi Version Time is now: 22nd October 2014 - 17:21
