37 Pages V  « < 32 33 34 35 36 > »
[Not My Release] ELPlaylist
Kwazulu
post Jan 29 2012, 04:23
Post #826
QUOTE (Perocat @ Jan 28 2012, 20:07) *
Now I would like to have a fixed column width every album, so the largest composer name should define the column width
I'm afraid it isn't possible, Perocat, because you can't base the formatting of one track on tags from another track. The only way you could do it is if every track had a field like LONGESTCOMPOSERONALBUM smile.gif
If you aren't too attached to the theme you're using with EL Playlist, you might want to consider using one of the various playlist panels that has genuine column behavior to achieve your goals.
This post has been edited by Kwazulu: Jan 29 2012, 04:26
Sixth Street
post Feb 2 2012, 00:39
Post #827
Does anyone know a reason why the popup image quality would be poor? Here's a screenshot on my ELP setup of what I'm talking about. You can clearly see the difference in the popup and my album art panel right below:
The image that is being rendered is the one here. There is no doubt as to it's quality. It's both embedded in all song files and a folder.jpg:
http://www.albumartexchange.com/covers.php...minor&sng=1
My popup script is $albumart(0,0,%POPUP.TRACK.WIDTH%,%POPUP.TRACK.HEIGHT%,0) where POPUP.TRACK.WIDTH and POPUP.TRACK.HEIGHT are both set to 400
MacStew
post Feb 18 2012, 06:39
Post #828
QUOTE (Sixth Street @ Feb 2 2012, 01:39) *
Try $drawimage()
or in "behaviour" change "resize quality"
Hi
Is there a way to show the total rating and the total size on the group header.
Thanks in advance
Sixth Street
post Feb 18 2012, 07:24
Post #829
$drawimage worked perfectly! Thank you
lettuceman44
post Feb 28 2012, 05:37
Post #830
Is it possible to rate songs using the star system with this playlist?
marc2003
post Feb 28 2012, 05:45
Post #831
short answer: no
you can configure ELPlaylist to display rating stars which will update when setting rating via context menu, buttons or keyboard shortcuts but it's not not possible to interact with the playlist itself. only simplaylist (default UI only) and EsPlaylist (works in both UIs) support that.
lettuceman44
post Feb 28 2012, 06:08
Post #832
QUOTE (marc2003 @ Feb 27 2012, 23:45) *
short answer: no
Thanks for the answer! I'll take a look at EsPlaylist then, if I don't like it I'll just configure elplaylist to display stars tongue.gif
emte
post Mar 11 2012, 12:54
Post #833
Hi. I'm trying to add a image but it isn't working. Am I doing something wrong?
//dynamic range
$imageabs(323,20,80,80,%ps_foobar2000_path%\skin\Beauty\dynamic range images\high\%ALBUM DYNAMIC RANGE%.png,,,glow:1:0-0-0:0 offset:0:0)
marc2003
post Mar 11 2012, 12:57
Post #834
you should be using %el_foobar2000_path%. ps is for panel stack splitter.
emte
post Mar 11 2012, 16:14
Post #835
QUOTE (marc2003 @ Mar 11 2012, 12:57) *
Still not working...
WilB
post Mar 11 2012, 17:01
Post #836
Did you try: %el_user_profile_path% ? See the readme that comes with the el_playlist download for more information. Also you may only need to use: skin\Beauty\dynamic range images\high\%ALBUM DYNAMIC RANGE%.png.
If none of these work then double check your image path (e.g.did you mean skin as opposed to skins in the path?) and check what el_playlist is returning for %el_user_profile_path%, %el_foobar2000_path% and %ALBUM DYNAMIC RANGE%, e.g. using a $drawtextex function in el_playlist. If all of these are correct then it should work.
This post has been edited by WilB: Mar 11 2012, 17:35
emte
post Mar 11 2012, 17:19
Post #837
None of your pieces of advice seem to work. I'm at a loss already. Don't know what wrong.
ecko
post Mar 12 2012, 22:40
Post #838
QUOTE (emte @ Mar 11 2012, 08:19) *
Add a comma before 'glow'.
Corey
post Apr 13 2012, 09:38
Post #839
Embrace for n00b question, how do I change this ugly colors? Can't seem to find it in Settings.
marc2003
post Apr 13 2012, 16:04
Post #840
you want to be looking at the script>group header tab and then the first $drawstring function.
Corey
post Apr 14 2012, 09:22
Post #841
Tried, only can change glow effect, and still can't turn it off, nor change color or font, at least I don't know how.
Falstaff
post Apr 14 2012, 09:26
Post #842
QUOTE (Corey @ Apr 14 2012, 09:22) *
a .txt file is included in the ELPlaylist component package (available here http://foo2k.chottu.net/), it explains the synthax of each commands, translate it from japanese to english then read it if you want to learn how to do something.
This post has been edited by Falstaff: Apr 14 2012, 09:26
http://br3tt.online.fr/
PatFromGermany
post May 10 2012, 14:35
Post #843
I'm from germany - btw: I'm sorry if someone can't understand my, because my english skills aren't professional. dry.gif
Now I like to describe my problem.
I have tested a lot of different audio players. There are J.River MC, iTunes (more translucent than it is), MediaMonkey, fb2k ...
After the installation of fb2k, I installed the WASAPI Plugin from Peter (thank you man, I love you for that!^^).. but now, I wanted to change the skin.
For my, the best Skin is FooPlacebo. After changing some values in the settings for cover width, text size and so on I found out that the size-changed-covers aren't showed as well...
If a album have just a few songs (today it's normal - unfortunately. -.-), the album cover will be cut-off..
Here you can see it (Album: Zombie EP from The Devil wears Prada): http://imageshack.us/photo/my-images/502/i...d100520121.jpg/
What could I change to end this problem?
Best regards
PatFromGermany
-Thank you for move this into the correct section!-
This post has been edited by PatFromGermany: May 10 2012, 14:39
marc2003
post May 10 2012, 16:57
Post #844
grouping>minimum row number of group
$max(8,%el_item_count%)
PatFromGermany
post May 10 2012, 18:11
Post #845
Thank you bro!
Another Question.. how can I change the font-color of a song which is played?
I want to have it black if it's played now.
This post has been edited by db1989: May 12 2012, 21:48
Reason for edit: removing unnecessary full quote, merging double-post
whoknowsit
post May 22 2012, 06:31
Post #846
Hey everybody,
I am an absolutely newbie in coding, so I hope maybe you can help me out?!?
I have written this in the "Script" and there in the "Track list" in the ELPlaylistSettings:
$drawtextex(%play_count% |, $sub(%el_width%,100),0,60,%el_height%,$get(text_color_alt),right vcenter)
Now I want to change it in that way, that it only shows the Playcount, if there is another number then the "0". If there is an "0" it should write " |". Is it possible and can you help me with it?
And my other question is, if I can code to perform a Short-Key if I klick on a button? I have a button with an heart and if I will klick on it, it should perform the Short-Key "STRG+F" and that will favorite the track on last.fm. If I Klick on it again it should unlove the track on last.fm with "STRG+U".
Only using the Short-Keys works, but I want it on the button too. Is it possible?
Thank you for helping me!
n3x0n
post Jun 6 2012, 14:30
Post #847
I configured to have all groups collapsed by default. However, I want the group to automatically expand when a song is being played from it.
I was thinking of something along the lines of:
$if(%el_is_collapsed%%,
// expand group when playing song from the group
expandCurrentGroup;
How can I do this? Thanks!
MacStew
post Jun 6 2012, 20:31
Post #848
QUOTE (n3x0n @ Jun 6 2012, 15:30) *
expandCurrentGroup;
I think it's not possible
n3x0n
post Jun 8 2012, 16:09
Post #849
Shit, really? Is there any playlist component that does this?
ExtremeHunter
post Jun 11 2012, 19:15
Post #850
Add this code to WSH panel script
if (fb.Titleformat("%album%").Eval() == album) return;
album = fb.Titleformat("%album%").Eval();
fb.RunMainMenuCommand("View/Columns playlist/Activate now playing");
fb.RunMainMenuCommand("View/ELPlaylist/Redraw");
RSS Lo-Fi Version Time is now: 28th November 2014 - 11:04
